Need some log moving advice.
Started by JAG, September 09, 2016, 08:33:51 PM
JAG
Hey everyone, I need some advice on moving logs. The new job I'm at has much steeper slopes then what i had for the last 6 years at the other job, and very rocky. This is in Northern CA so the ground is still relatively soft. I run a Lucas 6-18 and 8-30 and cannot mill where the logs are felled. Other than just milling where i drop trees i normally either use chains (for short distances), or a LogRite tractor arch. The terrain is way to steep for any of that and these logs are a bit big to try ether of those options. Range is about 26"-28" up to 36"-42" DBH. Is there anything that is the middle ground from a tractor arch and a Tiberjack cable skidder? Any help would be great. Thanks
Lucas 6-18, MS046, MS660, MS390,
711ac
3 point tractor winch?
Some have 12k or more of (single line) pull with around 180' of winch line.
JAG
Thanks 711ac, we have a tractor with a three point hook up. I'll start looking them up.
David-L
Try to pull straight on with tractor winches, they can tip a tractor with a big log being pulled quickly. Skidders can tip to but are more stable. Bucket on the ground for tractor logging pulling big ones in. Good Luck.
Ed_K
 If you buck the logs where the tree fell, you can get away with a 3pt hitch 6k winch unless you wanting 40' lumber. I skidded a lot of 33' logs with a Fransguard winch and a 2 wheel drive 55hp tractor. If they got to be to much I made 2 logs.
Ed K
Puffergas
Some kind of cat might be worth thinking of.
I like the idea of a swing saw. The 6" is somewhat affordable but i would like to be able to make 8" boards but but the 8" swing is rather pricey.. How do you like your swing mills?
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, Trojan 114, Timberjack 225D, D&L SB1020 mill, Steiger Bearcat II
47sawdust
If you do use a tractor and winch on steep ground make sure your tractor is well secured before winching.Too large a log or hitting a stump or rock and the tractor will be going downhill.Stand clear of the tractor before engaging the winch.Common sense and good forethought will keep you safe.
Mick
Ed_K
 Yes on the well secured. Most new 3pt winches you can put the base of the winch into the ground. Also lock the brakes, I curl my bucket to max dump and push that in also.
Ed K
711ac
Quote from: JAG on September 10, 2016, 01:10:48 AM
While your shopping, a few snatch blocks are indespensable, and a self releasing one will speed things up.
JAG
thanks guys, 711ac ya i snath blocks are a must, puffer gas i like them a lot they are very portable and simple, a lot more simple then moving heavy logs up steep hills.
dgdrls
Lewis winch with some snatch blocks, you can par-buckle them up most any slope
or straight line pull them,  anchor required ;)
D
DDW_OR
schmalts
On the popular auction sight there are a bunch of W-874 PTO drive winches. They are made for military trucks and are surplus. Anyone have any ideas if they could be adapted to a tractors PTO??  I cannot find specs of what the shaft input speed and power needs to be but it is a pretty small shaft so I would guess a tractors 540RPM PTO would power it well.  I am not sure what they mean by "worm break" on some of the descriptions. If it is an off on clutch that would be needed as I do not know how else you could turn the thing on or off besides the tractors control.  Any ideas?
Puffergas
On my doodlebug I had a standard pto winch. Worm drive with a brake on the end of the gear. Round cover had arrows to show the direction to tighten, if I remember correctly. Yes, use tractor clutch to engage winch.
ppine
There are practical limits on slope for using conventional yarding equipment.  Typically it gets a lot more difficult with slopes much greater than 30 percent.  You do not mention the steepness of the slopes you are working with.
The normal response to steeper country, is a cable show.  Commercial scale yarding would include some portable spars with a an overhead mainline and a moving carriage like you can see on "Axe Men."
For smaller scale operations, it is possible to use winches and snatch blocks and maybe a cable yarder.
There is a lot steep country in the West, and cable shows are the norm in a lot of places.
Forester
Rural
On my small (30 acre) property just about every log is going to be at the bottom of a steep slope and inaccessible directly and must be winched. I have a home built hydraulic winch on a midsize 35hp tractor which will pull the tractor back with bucket dug in, I generally cut logs to length where fell  depending upon size and weight (and slope) but the biggest problem I have is the log digging in, a companion with a big bar (or peavy) giving the log a roll usually helps ..... we are not a commercial logger and not in a  big hurry. For a really tough one we will chain the tractor to the nearest tree and double line it, as others have said in tough places a snatch block to get a straight pull and to direct the log around objects is essential. Have tried a skid plate under the front of the log but it rarely stays put so more work than help!
Can hardly ever remember backing up to a log to haul it out in this rugged property, just finding a trail to get close can be a challenge.... LOL
47sawdust
About logs digging in....I have had success hanging my snatch block from a tree,a small aluminum ladder helps to gain more height.Others have used skidding cones with good results.
Mick
John Mc
Quote from: 47sawdust on September 13, 2016, 05:47:16 PM
Or made a skidding plate (or used the hood from an old VW beetle).
JAG
PufferGas did you build that doodlebug? That looks like a warpig if i have ever seen one.
PPine, yes the yarder is a go-to around here but with this very small amount of trees needed to be taken it seems to much to get into, i dont have one nor know where to get my hands on one. sounds like a strong tractor winch or a winch buggie might be worth trying.
ppine
Puffergas is showing one of the good old style gypo rigs that works everywhere.
Forester
schmalts
Quote from: Puffergas on September 12, 2016, 08:45:52 PM
Looks like it came off the mad max set
Puffergas
It was an easy build. Removed the old bed. A fella down the road had the wrecker bed. I just had to rig it on and pto shaft stuff. Worked darn good. She would level out the skid roads as ya skidded. In mud singles would work better. In the woods a skidder is best then a homemade doodle bug of sorts.
Puffergas
ppine
If you are in PA call Puffergas and get some work done.
Forester
That looks good. Before I started to live here,I use to drive my truck in the woods and throw the wood right into the body. My land is hard to get around on. The truck was hard to get turned around in the woods. Really no way to drive in and than drive out. Have to turn around somewhere.
