L10 cummins
Started by coxy, June 02, 2015, 10:10:40 PM
coxy
does the L10 have  1,2 or 3 heads  there is no tag just says 404 on the head the guy says its an L10  but he also said the truck was a IH but has freightliner all over it  ;D it looks to be older not any electric things hanging all over it  he also says it smokes really bad but it don't seem to use oil as bad as it smokes his words  any ideas what the smoke maybe  from    thanks
LeeB
White smoke? blue smoke? black smoke?
4x4American
are you talking about valve covers?
Boy, back in my day..
treeslayer2003
an L 10 cummins will have one head as opposed to three like an N 14 or 855. L10 is a pretty good little engine.
perhaps a bad turbo......hard to say.
coxy
Quote from: LeeB on June 02, 2015, 10:15:10 PM
not shur I haven't heard it run just going by what he said and yes there could be a few thoughts on the smoke not knowing the color
Quote from: 4x4American on June 02, 2015, 10:19:49 PM
no heads all the cummins the bigger ones that I have seen has a head for every 2 pistons  this one has one long head for all 6
UN Hooker
L-10 has one long heavy head. A couple weeks ago, I repaired a broken cross arm guide pin and did a valve job on one.
         UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
snowstorm
i have had one for 10 yrs. in a ih plow truck. single head pt pump starts real well in the cold. never holds a lot of oil pressure enought but nothing extra. the only thing i have done to mine is replace the water pump and oil pan....it rusted
4x4American
10-4.  Yea the Cummins L-10 I think has the infamous P-T fuel system on it..might be another way to help identify it.
snowstorm
if you a looking at an l10 to run a loader you will need a variable speed governor on it
coxy
thanks for all the info the truck has a loader on it  never new anything about the governor thing thanks snowstorm
BW_Williams
DonT know anything about them newer Cummins, but my 69 really smokes!  On the airport job it was always the first rig running.  Mine uses air foot throttle to both sides and i really like them.  Now if i could get the 8 track working.........
Support your local Volunteer Fire Dept.  (not by accident)
Support your local Ski Patrol (by snowboarding:)
Mayor of Millerdale, Washington, USA (by God)!
coxy
Quote from: BW_Williams on June 04, 2015, 10:01:39 AM
I have one that works you want it  lots of tapes to  :D :D :D
