General Forestry => Timber Framing/Log construction => Topic started by: fishfighter on April 08, 2015, 12:11:58 PM
Title: Started the build.
Post by: fishfighter on April 08, 2015, 12:11:58 PM
This small house is going to be a guess/camp house. 2br/1 bath. It's going to be a little over 800sf living. I am building it in three phases. Half of it will be timber/stick built and the other half will be stick built.
At this point, I do have most of the posts  and top plate beams done. I do have to mill a new top plate beam. One went wild. I hope t get to milling a new one soon, but everything is very wet with a lot more rain coming next weekend.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0139~0.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0140~0.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0141~0.JPG)
So, at this point, I'm on phase one. This side will be the timber/stick built side. It will be 13.6'x24.6'. It is the living room/kitchen area. My plans are to get the timbers up ASAP and get it closed in ASAP. That way it will keep drying out. The roofing system will be all trusses that I bought.
The foundation. I still have to come back and add more pillars on the centers of all the sills. That will get done tomorrow.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0165.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0167.JPG)
The sills are 8"x6"'s in pine and floor joist are true 2x8's of Red Oak. I was going to use 4/4 red oak for the sub flooring, but I think I will save that for the real floor and use 21/32 OBS sub flooring.
That building in the back will be one of the bedrooms. It's built out of cypress and redwood and it is already finished inside.
Title: Re: Started the build.
Post by: fishfighter on April 10, 2015, 07:06:03 AM
Got the decking down yesterday. If I get a break in the rain weather, I will mill some more sills and pour more footings for the rest of the build this weekend.
Post by: Magicman on April 10, 2015, 08:33:10 AM
Yaaaaeeeee !!!  This build will be fun/interesting to watch.   8)
Post by: fishfighter on April 12, 2015, 06:58:12 AM
Thanks MM.
With the forecast today and thru all next week of 80-100% chances of rain, would it be a bad idea to start putting up post and beams? All of them were milled about two months ago, so they are still green.
Post by: PC-Urban-Sawyer on April 12, 2015, 08:49:49 AM
Quote from: fishfighter on April 12, 2015, 06:58:12 AM
Thanks MM.
Depends on how wet you want to get while raising the frame. The rain probably won't hurt the timbers much but it sure makes your feet squish in your boots...  :D :D :D :D :D
Good luck and be careful!
Herb
Post by: fishfighter on April 13, 2015, 09:32:23 AM
Thanks. I'm putting it off due to way to much rain and mud. My backhoe or tractor would rip everything up and make even more of a mess. ;D
Post by: fishfighter on May 05, 2015, 08:14:15 AM
Got a little work done yesterday. Didn't get any pictures, but once I get back later today, I will get some.
I got a problem. :'( The pine sills have some green mold that started growing on it. I had everything covered with a tarp due to all the wet weather, but now uncovered. What should I use to spray to kill that mold?
Post by: beenthere on May 05, 2015, 09:54:10 AM
Some chlorine bleach solution will kill it. Say a 10% mix with water, spray or brush it on, rinse off before it dries but after the mold is gone. That would be what I'd try.
Post by: Jim_Rogers on May 06, 2015, 07:44:20 AM
Quote from: beenthere on May 05, 2015, 09:54:10 AM
x2
Post by: fishfighter on May 07, 2015, 04:07:36 PM
Going to do the bleach tomorrow.
Got a little more work done today. Like I said, this is going to be a timber/stick build.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0197.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0198.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0199.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0200.JPG)
Got a bit hot today hitting 88F. Had to shut it down due to heat kicks my butt big time. It's now raining. Oh well.
Post by: fishfighter on May 10, 2015, 11:15:08 AM
Got some more done yesterday.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0213.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0214~0.JPG)
Bad thing is, as I was setting the center cross beam, I was on a ladder and I was under the beam lifting it into place. Ladder gave way and I crushed/cut my left hand. Had to shut things down after that. Sucker is hurting bad this morning.
Post by: Herb Brooks on May 13, 2015, 01:13:02 PM
Hope you heal quick.
Post by: red on May 13, 2015, 01:40:54 PM
Pictures ???   blood guts etc
Post by: fishfighter on May 13, 2015, 06:26:42 PM
Quote from: red on May 13, 2015, 01:40:54 PM
Still swelling three times normal. I go into the hospital every Wednesday for a infusion. I'm a very hard stick for a IV and my nurses thru a fit this morning. :D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0215.JPG)
Lesson learned that I forgot. Ladders do have weight limits. I only weight 170 lbs. Add a wet red oak beam propped on your shoulder. Oh well. :'(
Post by: AlaskaLes on May 14, 2015, 05:34:46 PM
Sorry to see that.
Reminds me of my own hand many years ago when a 4" grinder disc at work exploded due to a cracked disc.  I had to shift my motorcycle clutch on the way home and it was truly brutal pain!!  Couldn't see the knuckles through the swelling.
Hope you heal soon.  You should perhaps take a bit of time and planning and start using some sort of lifting frame.  It's a heck of a lot safer and keeps you out of the crush zone.
Building is looking good....hand, not so much.
Post by: fishfighter on May 14, 2015, 09:18:58 PM
I had got the beam in place with my backhoe, but still needed to shift things and lift things to get that cross beam in place. It sits about 1 1/2" on the post under it, but stabs into the top plate beams.
Got some work done today on my braces. Going to be fun fun tomorrow when I have to jack up the top plate beams to place the braces in place. Shouldn't have much of a problem doing that, I hope. ;D
Post by: fishfighter on May 15, 2015, 09:34:28 PM
Got a few of the corner braces in today till the rain ran me off.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0227.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0228.JPG)
Got a few more in, but I was just to wiped to take any pictures.
Post by: AlaskaLes on May 18, 2015, 03:28:58 PM
Looking good Fish!  Those braces add a nice profile to the box-like structure of the main timbers.
I can't wait to start working on some of that stuff myself.
Timber framing class is coming up in a few weeks and then we'll start planning the first BBQ-Party Gazebo.
Leaning towards a Hexagon or an Octagon shape.
Mom's property up the road has a beautiful creek running through it and it's just aching for a nice timber framed structure right next to the creek.
I want to start collecting good tools for this, but I'm forcing myself to wait till I have a clue of which ones will really be useful.
Post by: fishfighter on May 18, 2015, 04:48:18 PM
Tool wise, I'm making due with what I have. The only thing I had to go out and buy was a bandsaw to cut the corner braces. Those are made out of 3" thick boards. I didn't have anything that could cut that thick other then a chainsaw. Oh, paid $75 for the bandsaw off craigslist. ;D
The hand is getting better. All swelling is gone, but still missing some meat on the cut area.
Post by: AlaskaLes on May 19, 2015, 01:59:00 PM
We've got a Jet 18" bandsaw with a new kreg resaw fence, a circle/bowl blank jig and upgraded Carter guides.
We set that up last year for the woodturning side of things.  It's nice when you can cover several bases with one tool.
I'm still wondering what we'll need in the way of chisels; slicks; corner chisels, etc.
I'm not against using power tools where they can speed up the process without sacrificing the quality.
Sometimes you just need to bleed a little for the job...seems to appease the Gods.
Post by: fishfighter on May 22, 2015, 08:21:01 PM
Had been just milling sills and a couple beams along with some 2 by boards. I will be doing some more concrete work next week. Hope to get phase 1 roofed in too! Rain been hitting just about every day. We are having one of the wettest springs in a long time.
Post by: fishfighter on May 28, 2015, 08:51:25 PM
Got the last post sawed along with the last top plate beam today. Got a little work that needs to be done. Hoping I have it all up by the weekend.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0246.JPG)
Post by: fishfighter on June 02, 2015, 06:26:20 PM
 Got all the post and top plate beams up on phase 1. I still have to saw up some more stock for braces. To set those in, I have to jack up the top plates. Got a break in the rain for a few days, I hope.
Tomorrow, hospital infusion day that takes all day and Thursday, doctor's appointment. Just never enough time to do everything. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0249.JPG)
I am still floating all the braces. I will be pegging them in place in the future.
Post by: fishfighter on June 07, 2015, 04:47:49 PM
Got a little more done today. Had to call it quits by 7:30. Sick as a dog. :'( SIL up there. Just knew I would of passed out. Those trusses are 7/12.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0256.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0257.JPG)
Side view.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0255.JPG)
Had used my backhoe to lift all trusses.
Post by: fishfighter on June 16, 2015, 06:43:17 AM
Got a little more done. Been moving along real slow due to rain, heat and me not doing all that good.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0260.JPG)
Post by: Dad2FourWI on June 16, 2015, 09:58:46 AM
Your project is looking very nice!!!
... but your health is priority #1 ... Take care of yourself!
Love the pics, thanks for sharing!  ;D ;D ;D
-Dad2FourWI
Post by: fishfighter on June 16, 2015, 02:39:01 PM
Quote from: Dad2FourWI on June 16, 2015, 09:58:46 AM
-Dad2FourWI
Sound like my wife of 35+ years. :D
I start at day light and have to shut it down by 10:30.  Got a good start this morning hanging stringers on the backside of the building on the trusses. I have a couple more runs to do. Even got a few sheets on OBS hung on the side. I should be getting some help to hang the medal roofing Friday. The sheets are 18'. I don't think I can handle that by myself.
Post by: fishfighter on June 23, 2015, 01:22:11 PM
Got a few runs of the roofing on. My son and SIL got up there to start it off for me. Then of course, what I did was rip a muscle in my lower back pouring more pads. Those green pine sills are slopping down on me about 3/8" and I need to get some support in the center of them ASAP. Pain unbearable in my back. Two days in the doctor's offices. One for my heart which was bad news and one for my back. I'm at bed rest and that is killing me.
When it rains, it pours. Something screwed up in my backhoe. It will not shift into reverse. :'( Please make it stop.
Was hopping to get it closed in ASAP. Going to have to wait till my son and SIL can help me get it done.
Post by: thecfarm on June 24, 2015, 07:09:56 AM
The Lucky God's are not really helping you out much.  :(
But it's looking good.
Post by: fishfighter on June 25, 2015, 05:25:42 AM
Was in the hospital yesterday for my weekly infusion and my sister showed up. Her husband was at the ER with a heart attack. They do have him stable now, but it's going to be a long road for recover for him.
My heart is doing a bit better, but the back is not letting off. More blood work today. Fluid build up is the big killer when one is in heart failure. Being 6' tall and weight in at 170 lbs, it is hard not to see the fluid build up on me, but it looks like I have most of it gone and under control again.
Post by: dablack on June 26, 2015, 11:26:14 AM
First time I'm seeing this thread!  I love the build but please take care of yourself.
Sorry about your BIL!
Post by: fishfighter on June 26, 2015, 01:10:08 PM
Things have slow down to a stand still due to me with my back. Hoping my son and sil make it over to finish out the roof this weekend. I did try to do a little this morning. Got some more OSB hung. Got a couple pillows up under a sill. Then rain came and ran me off. Maybe later I will be able to pour two more footing that I need to get in place. I do have them framed out and wire and ground strap in place.
Yesterday, I dropped the trannie out of my backhoe and took it apart. Sure enough, I busted the clutch spring. Another name for that part is a Belleville. Parts on order and will not get them till mid next week.
Post by: fishfighter on July 06, 2015, 05:26:19 AM
After a few days in the hospital with a pinched nerve and pain out of control, they did a epidural steroid  shot in L4 in my lower back. What a relief. Kind of still dragging the left leg, but doing 100% better.
Yesterday, my son and SIL came and finished putting the tin on the front side and installed the pillars for the flooring. Then the rain came down in buckets. That shut down everything. >:(
Parts are in for my backhoe, so I will make the trip to go pick them up and finish rebuilding the backhoe shuttle drive. Problem there, I can't install it. At over 120lbs, they is no way I could pick it up right now. So, another job for the kids. That is something I hate to have to wait done.
Anyway, this is were things stand now.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0283.JPG)
Post by: fishfighter on July 14, 2015, 05:48:26 PM
Been taking it very easy doing very little each day on the camp. Got the rear roof line finished. Hope to get the roofing on this weekend. My son and SIL will be doing that.
Got just about all the OSB siding up. Just have the peak to do. Maybe Friday I can get some of that done.
It's been so hot that I been shutting things down around 9am. Way to hard after that for me to catch my breath.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0292.JPG)
Post by: fishfighter on July 20, 2015, 05:44:01 PM
Within the limits of what I been able to do, I been getting very little done. This heat wave has got to let off soon. Heat index has ben hitting 110F here this past week.
Just about got phase one closed in. Two sheets of tin left on the back side to put in place and some tarp at the eves on the other side. My son and SIL have been working 7 days a week. So, I been doing what I can with the help of my wife and backhoe.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0304.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0305.JPG)
I need to start sawing more lumber for phase two. I do have the sills done, but completely out of 2x4's. Got the dirt work done and started laying out things. I have a few pine logs that are easy 450 BF in each one. Big suckers. ;D
Post by: fishfighter on July 20, 2015, 05:46:51 PM
Oh, The peak of the roof from the ground is 23' up. I don't care for heights anymore. ;D
Post by: rasman57 on July 21, 2015, 12:25:21 AM
Wow.  Most of us do not know you but let me say you are one tough son of a gun!   Those health issues, accidents, heat and breakdowns would stop a lot of folks.  You keep on  keeping on!   Best of luck moving forward.   You deserve a few good breaks after all you have gone through.  Interesting project.  Take care of yourself too.
Post by: fishfighter on July 21, 2015, 06:28:04 AM
Thanks. I had always been a hard worker, DIY'er kind of person. The house I live in, I built it about 16 years ago. It's 2800 slf with a total of 3650 under roof. Working at the time which was 12 hour shift work, I built it in 6 months by myself from start to finish. And people say it couldn't be done. ;D If there is a will, there is a way. I live by that.
WE are under Heat advisories again today. 5:30 am and it's 80F. >:(
Post by: sawmilllawyer on July 21, 2015, 11:11:42 PM
My hat is off to you, Sir. Keep on plugging away you'll get her done. Enjoyed reading about your progress and refusal to quit.
Post by: Chilterns on July 22, 2015, 02:32:00 AM
Hi Fishfighter,
I was interested to see that you have decided to perch your building on staddle stones and wonder why you have chosen this method since this will potentially result in a cold floor.
Standing buildings on staddles was traditionally employed on granaries, apple stores, etc. i.e. where the contents need a degree of protection from rats and mice.
All that said - I like it !!
Chilterns
Post by: fishfighter on July 22, 2015, 07:22:03 AM
Here in the south, you build on concrete or off the ground. Being that I am sawing all my lumber, it is a lot cheaper for me going this route. I will be insulating under the floor once all the plumbing and wiring is done. Our winters are very mild here. Building off the ground also helps keep the house cool in the summer. Problems building on concrete here is that one has to put the concrete in tension with cables to help the slab from cracking due to big temperature swings and ground drying out fast. We don't have to build for snow load or have to deal with a frost line.
Post by: fishfighter on July 25, 2015, 07:33:00 PM
Phase one is closed in now. Got the rest of the roof on and everything closed up tight. Unreal on the heat.102F and HOT today. I need to cut more lumber, but just can't do it. :'(
Post by: fishfighter on July 28, 2015, 03:40:20 PM
Really not much going on with the camp other then getting the last of the tarp up on the open side. Been cleaning, clearing, pushing dirt and burning. After a very wet March, April and June, things are drying up.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0313.JPG)
Post by: fishfighter on August 11, 2015, 06:41:03 PM
Been a couple weeks from my last update. Been sawing up lumber for phase two. A lot of oak and pine studs. Just so hot this summer that has taken a lot out of me. With almost two more months of hot weather still to go.
Tomorrow, I will start more foundation pads. Nothing like handling 80lb bags of readymix, lifting them up high to put them in the mixer. ;D
Post by: fishfighter on August 12, 2015, 12:36:37 PM
Got a couple of the pads poured this morning. After all the rain we got yesterday, there is nothing like working in mud.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0352.JPG)
After two pads, I had to call it quits. Got hot fast this morning and my back had enough. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0351.JPG)
  Floor joist and wall studs stacked in the back ground. Got other stacks too!
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0350.JPG)
Post by: fishfighter on August 21, 2015, 12:58:18 PM
Got half the floor framing done today. Still waiting for the ground to dry some. I still have 3 more pads to pour, but the rains have been coming down every day. If it doesn't stop for just two days, then I will just have to pour things wet.
Post by: Magicman on August 22, 2015, 08:57:07 PM
You are just like a Timex.  Take a linkin' and keep on tickin'.  I love your progress.
Post by: fishfighter on August 22, 2015, 09:11:35 PM
That is what the wife says. ;D I'm trying to get this phase framed in before winter. Got three more pads done today before I had to quit. That wiped me out to were I had to take a 4 hour nap after. :'( Just two more to go on phase two. I had enough of the mud and yes, another 1"+ of rain this afternoon. I did cover the pads with plastic. Rain chances suppose to drop next week somewhat. ;D
Post by: fishfighter on August 25, 2015, 01:10:21 PM
Got out and did a little work on the camp this morning. Was kind of nice. Was 73F for a change. ;D Still having trouble with the back. :'( So, this is were I'm at.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0368.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0369.JPG)
No rain in the farcast the next few days. Things are still wet and muddy.
Post by: fishfighter on August 27, 2015, 06:35:28 PM
This is were I'm at as of today.
I had added at each sill joint some 3" angle at each corner with some leg bolts. Really didn't need it, but I had everything.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0370.JPG)
From there, I had finished getting all the floor joist in place.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0371.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0372.JPG)
Being green lumber, I took some 1" boards and tie the new floor joist to the old phase one flooring. I hope to deck it out this weekend.
The building in the back ground is a back bedroom. Bad news for that. I have to move it out the way to add more dirt under it. >:( My dumb out. Oh well. ;D
Post by: fishfighter on September 01, 2015, 05:20:41 PM
Got the back room moved. Very heavy SOB.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0374.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0377.JPG)
Added dirt and used my backhoe to pack it in. It weight over 13K lbs and did a fine job. This morning I poured three of the five pads.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0378.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0379.JPG)
Tomorrow, I hope to get the last two. Then move the building back in place and tie it into phase two sills.
Post by: fishfighter on September 06, 2015, 06:25:08 AM
Back room moved back in place. To get it next to phase two and set, I applied a bunch of grease to some blocks that blocked the building up and just pushed it in place with my backhoe. ;D Worked like a charm. This picture doesn't show it all the way in place, but it is.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0380.JPG)
I still need to lower it on it's own concrete blocks, but before I do that, the front wall were the door way is will be removed. I will start on that tomorrow.
I did get the decking down on phase two and locked in with phase one.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0384.JPG)
That shows the back building in place, lined up, but still high.
Post by: fishfighter on September 08, 2015, 04:22:48 PM
Got a little work done this weekend and today. I had to remove the front wall to the back building once it was set on it's concrete blocks.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0386.JPG)
Once that was done, I started framing a couple walls. The heat ran me off.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0388.JPG)
I still have to tie in the top plates, but wanting to get everything just right. ;D Big gap is for a matching window to phase one.
Post by: fishfighter on September 15, 2015, 03:22:43 PM
Been picking at it little by little. All framed up and started hanging some OSB siding. Got to hot to finish that today. :'( Hope to complete that tomorrow and then put some trusses/roof on after I tie in the back bedroom roof line.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0403.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0404.JPG)
Post by: beenthere on September 15, 2015, 05:22:11 PM
You are moving right along. Especially with the heat.
Post by: fishfighter on September 16, 2015, 03:31:03 PM
The mornings have been kind of nice, but by 9am, it's just hot. Got all the OBS up this morning and I should be placing the trusses up on top. I have to go look at a bunch of pine logs in the morning to see if they are good. I need some bad. Out of 2x's all together.
Post by: beenthere on September 16, 2015, 04:20:58 PM
OBS the same stuff as OSB for Oriented Strand Board ?
Post by: fishfighter on September 16, 2015, 04:39:43 PM
Yes, guess my typing sucks. ;D
Couple pictures.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0408.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0410.JPG)
Post by: fishfighter on September 21, 2015, 07:30:27 AM
Got the trusses sitting up on top. Used the backhoe to lift them up. Nice to have a extendahoe. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0420.JPG)
The end truss, I had finish it on the ground, covering it with OSB and then tar paper. It too is now resting up on top. By doing this, it made it safer and faster being everything is just so high. I have a reach of 24' with the extendahoe and that was a job to get the trusses up.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0421.JPG)
I hope to start standing them up in place today.
Post by: fishfighter on September 21, 2015, 08:02:21 PM
Started stacking and setting the trusses. If I didn't go up a ladder two thousand times today, maybe 1999. Very hard to set these trusses all by myself and had to take extra steps to get were I'm at with everybody working. :(
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0428.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0429.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0430.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0431.JPG)
I'm dragging like a fat cat, but hope to get them all set tomorrow.
Post by: beenthere on September 21, 2015, 10:15:54 PM
Did you spray paint those trusses black for some reason?
Post by: fishfighter on September 22, 2015, 05:44:35 AM
I bought them like that. They were treated to keep wood bees from drilling in them.
Post by: fishfighter on September 23, 2015, 06:51:39 PM
This morning I double check the trusses and locked them in. After that, I blocked in between rafters and wherever I needed to screw sheetrock to the ceilings. Once that was done, I started stripping the trusses for the metal roof. Call it a day at 12 and when and picked up a couple fresh cut pine logs. And yes, I woke up before 2am and I'm beat. :'(
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0432.JPG)
Post by: fishfighter on September 28, 2015, 06:48:24 AM
At this point I have the front all stripped out for the metal roofing. Got one side on the back tying in the back bedroom roofing done. Was very tricky due to the difference in the heights of the walls. Had to use a chainsaw and a planner to cut and finish a couple of the angles. My sawsall died. :'( Didn't get anything done this weekend and now my body is locking up. ;D
Post by: fishfighter on September 28, 2015, 05:46:37 PM
Got the other side of the back bedroom roof line done today and called it quits at noon time. Way to hot for me to be up on a roof. Tomorrow, I will start stripping the back roof if it doesn't rain.
Had to take a few hours nap, but I'm recharged again for tomorrow. ;D
Oh, had a ground crew of one. The wife, but doesn't know much. ;D She sure can start the genset instead of me climbing down every time. ;D
Post by: fishfighter on September 30, 2015, 04:59:20 PM
Been stripping the trusses with 2x4's along with tying everything together. Getting up on a 8 on 12 pitch roof line is hard and took a lot out of me. I'm at the point to start putting the metal roofing on phase two. I had order new metal roofing for the back bedroom. Hope that comes soon.
This is were I'm at as of this afternoon.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0444.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0445.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0446.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0447.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0448.JPG)
I still have to pour concrete pads for the back porch and for the front porch. I think once I get all the roofing done, I will take a break. I have a bunch of logs I need to saw up. For some reason, the mill keeps yelling my name every morning. ;D
Post by: fishfighter on October 07, 2015, 04:26:32 PM
I have a roof over my head now. Was kind of hard working on that 8/12 pitch for this old man. ;D Ran into a couple problems joining in some valleys. All on the back side. Main building has 10' ceilings, back bedroom has 8'. Got that with no problem. The big problem was joining in the back porch valley, coming off the valley of the main build and back bedroom. I'm still not real happy on what I have, but I'm sure I will work it out.
Next up is to pour pads for the front and back porch. I need to cut some timbers for them. That will be timber framed.
Post by: fishfighter on October 28, 2015, 08:02:09 AM
Been some time on a update. Really haven't been doing much on the camp. Kind of been under the weather.
Anyway, we got a bunch of rain here last weekend. Over 6". ;D Checked the inside of the camp for any roof leaks and everything high and dry 8). If it dries up a little more today, I plan on start installing some sub flooring. 1 by's, pine boards. I will be passing the edges on my tablesaw and cutting it on a 45 degree angle, both edges of the boards to over lap when installed. I will be nailing them down with ring shank nails to the floor joist. Also will be laying down some roof felt paper in between.
On a side note. Why I'm using felt paper inside and out as a vapor barrier. It was all free. :D No other reason. :D
Post by: DeerMeadowFarm on October 28, 2015, 11:55:44 AM
Looking good!
Post by: fishfighter on October 29, 2015, 06:04:20 PM
This was done yesterday in the bathroom area. I finished it today. The bathroom area is 8'x9'. There is a closet and another one for a washer/dyer stack set. I do have a bath tub that I will be putting in there maybe tomorrow.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0486.JPG)
Took a lot of time resawing the edge of the boards. Had the tablesaw inside the cabin. Clean up 3, 5gallon buckets of saw dust. Way to wet outside and walking in mud to your ankles. ;D I will be installing some 3/16" luan on top. The real flooring is some 100+ year old pine t&g 3" flooring that I got for free. 8)
More rain coming this weekend. I will stage some pine logs at the mill. In need of some more 1bys.
Must of had a lot of dust on my phone camera lens. :D
Post by: fishfighter on November 01, 2015, 02:47:52 PM
Got the tub set in. Small steps now.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0487.JPG)
Post by: Magicman on November 01, 2015, 03:14:40 PM
Quote from: fishfighter on November 01, 2015, 02:47:52 PM
But every step is one step closer.   ;D
Post by: fishfighter on November 02, 2015, 05:06:20 PM
Yep. ;D Really I'm not in a big hurry. Taking this on is to help my more health wise and give me something to do when I feel up to it.
Post by: fishfighter on November 05, 2015, 06:11:19 PM
After a week of laying real low, I felt a bit better today. First time outside from last Sunday.
Anyway, stacked some logs at the mill, did a brake job on the truck, and did a little plumbing in the camp.
Did I say I was beat? The dear wife all over me now. ;D
Post by: fishfighter on November 17, 2015, 03:59:31 PM
Been doing easy things inside the camp. A little rough in plumbing, a little electrical work.
Got this wood burner stove to install in the camp. Fired it up and it checked out great. Got some double wall piping ordered for it. Got a bunch of free fire bricks to build the base for under it. Just waiting to put down some sub flooring in the area were I will install the stove.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0512.JPG)
And of course I been cutting a lot of 1 bys for sub flooring.
Post by: fishfighter on November 18, 2015, 06:50:38 PM
Started installing this in the camp today. I need a heat source to help dry things out ASAP.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0520.JPG)
Post by: fishfighter on December 08, 2015, 07:00:52 PM
Been some time from my last up date.
Got just about all the plumbing done. Nail down more sub flooring. Added the back porch base. Hoping to get a roof over it before it rains again.
Had a bunch of 1 by's that had some waves in it. Started to pass them thru my planner to knock off high spots. Extra work because I was to lazy to change blades on the mill. >:(
Sorry, no pictures. My phone is over loaded. :o Have to dump everything on the puter.
Post by: fishfighter on December 28, 2015, 10:41:31 PM
Really haven't been doing much in the camp other then some more sub floor work and cutting some beams and post for the front and rear porch. The frame work will be timber framing for everything above the decking. My plans are to use 6"x6" on post and beams and the front porch, the rafters will be 3"x6". That roof line will be a 8/12 as the same as the main building. Back porch is just a lean too type roof that comes off the main roof line and is only a 3/12 pitch.
Post by: richhiway on January 17, 2016, 07:06:27 PM
Nice camp. Take care of yourself and Have a good 2016.
Post by: fishfighter on January 18, 2016, 07:41:10 AM
Thanks. It's been slow going the last couple months. Just a little work here and there.
Anyway, a couple post and beams that I started for the back porch. Still have to mortise cuts.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0577.JPG)
These are the post foot braces that will be lag bolted to the decking that I had weld up. I will have about a 1/4"+ gap from the bottom plate to the bottom of the post. That way I will have air flow to let the bottom of the post dry after any rain.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0578.JPG)
Post by: fishfighter on January 19, 2016, 07:09:03 PM
CD
Did a little work on the camp today. Was a cold start for me at 31F. Used to love cold weather, but now, I just can't take it anymore. :(
Anyway, I had to take out a window on the back bedroom and frame to help support a post that will be attach to the building. Then I had to mount the post base to the decking. After that, I installed the post. You can see were the window was in this picture.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0586.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0585.JPG)
The post base holders are lag bolted down, leaving a 1/4"+ gap to let air flow.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0587.JPG)
I will try to get the beam set on top maybe Friday. Infusion day tomorrow and rain for Thursday. I need to get this roof on ASAP or when ever. ;D
Post by: fishfighter on January 20, 2016, 07:46:09 PM
Got home from my weekly infusion and had the weather on my mine. More rain in the forecast, then cold. >:( So, I jump at the chance of installing the back porch beam. Sunny and 74F. ;D Fun trick doing this by one's self.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0589.JPG)
Backhoe did the trick. ;D When I laid out the beam, I saw about a 1/4" arch to one side which can be a good thing in this case. Just stress in the beam. That side is facing down. I will be drilling and driving 10" nails thru the beam, down into the post. I will use the weight of the backhoe bucket to push down the center of the beam were the arch is. Just hope it doesn't pop back up.
I was going to put some 45 degree corner braces at the post, but being the post are only about 7' on center and the roof rafters will be 2x6's, 16" OC, I don't think I will need them. Really no weight and for sure no snow load. ;D
Post by: fishfighter on January 24, 2016, 05:15:37 PM
Wasn't happy with some of the windows that I had install. Came across a real nice power buy on some new windows. Spent the day ripping out the old, re framing for the new and got two of them installed. Much nicer windows. Heck I wish they had them in other sizes. I would buy them for my house. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0602.JPG)
Post by: jimdad07 on January 25, 2016, 06:15:18 PM
Looks like you're making progress!
Post by: fishfighter on January 25, 2016, 07:48:47 PM
Slow at that. Framed up two more windows, but only installed one. Started raining again. Going to be raining the next two days. Just then things started drying up. >:(
Post by: fishfighter on January 29, 2016, 07:11:49 AM
Got all the new windows installed. Started back on the back porch. Having a real rough time with a valley joining all the roof lines in. >:(
As you can see, my problem is coming off the main building, joining the back bed room all to the back porch roof. I will get a better picture today.
The main building is a 8/12. The back bedroom is a 5/12. The porch is a 3/12.
Post by: fishfighter on January 30, 2016, 07:07:13 AM
Well, I figured a way I will be joining the roof lines. Not the best, but it should work out.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0604.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0603.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0607.JPG)
The 2x6 that is right next to the building, once I put the metal roof on, I will install a flashing. The building itself, I will be replacing the roofing with new metal roofing. When I do that, I will extend rafters over the porch roof, add another flashing and tie it all together.
Had to go buy another augur bit yesterday. $25 for it. To drill a hole to install some 3/8" x 12" lag bolts thru the top beam and post.
Oh, the porch roofing will extend under the main building roofing about 10". The channels will match up. I had to do a special cutting on the first metal roofing to match up everything.
Post by: Andries on January 30, 2016, 01:26:10 PM
Way to go fishfighter!
That project is looking good, step-by-step.
Funny how these FF posts are like an episode from 'This Old House'.
We see just the tip of the iceberg. The other parts in the background/underwater are the 95% work related stuff like sourcing flooring, sharpening blades for the mill, sweet talking your ever-loving' into being that extra set of hands.
I'm guessing that most of us pause to take a picture when we get that feeling of "aahhhh, got THAT part done!"
Hang in there, you'll be planning your next project before too long!
Post by: fishfighter on January 30, 2016, 06:16:09 PM
Thanks for the kind words. This project s a rehab project. I'm in heart failure for the last 5 years and beating it all.
Today was nice, but very windy and hit 72F. I have roof on the back porch. ;D As one can see the difference in the roof lines I'm dealing with.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0609.JPG)
Anyway. I think my plans will work.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0611.JPG)
Oh, that is my son giving me a hand today. Really need it due to the wind whipping. Sheets were like a kite.
Now this little camp/guess house is about 1,000 feet behind my house. The more I'm building it, the more I'm thinking of moving into it. :D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0612.JPG)
On e can barely see the building in the back ground in that last picture.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0613.JPG)
Post by: Bruno of NH on January 30, 2016, 08:56:09 PM
Fish
Buy some timber lock or GRK lags .
You don't need to predrill for them
Have used them for years with great results
Bruno
Post by: fishfighter on January 31, 2016, 10:17:23 AM
The lag bolts I'm using are 12" long. Getting for free. ;D Installing them in green oak is something else. :o Now that I bought a good auger bit, that made things easy.
Post by: fishfighter on February 01, 2016, 06:08:53 PM
We have blasphemy in the house. :o Really! Came across a deal, real good deal on enough Hardie board siding to do the compete building for $800. I did the math and the time to get enough pine logs, buy saw blades, gas and diesel, I will come out ahead using the Hardie siding. ;D Was wanting to do shiplap sides out of pine, but it's going to be shiplap in Hardie siding. ;D
Now moving over 9000 lbs of that stuff did take it's toll on me, but it is here. Rain tomorrow and fusion day Wednesday. I need the rest bad. ;D
Post by: venice on February 01, 2016, 06:48:36 PM
Sacrilege! You will burn in hell. For sure.  :D
Post by: fishfighter on February 01, 2016, 07:16:39 PM
Quote from: venice on February 01, 2016, 06:48:36 PM
I hope my daily prays to the Good Lord keeps me for there. But yes, it is. :D Now to get the sawer's hopping. :D
Post by: sandsawmill14 on February 01, 2016, 07:23:21 PM
fishfighter you already used metal roofing why not hardie board :-\    :D :D :D :D
Post by: sandsawmill14 on February 01, 2016, 07:23:59 PM
nice job on the camp btw :)
Post by: fishfighter on February 01, 2016, 07:55:23 PM
At my age, I need every break I can get. :D
Post by: sawmilllawyer on February 01, 2016, 09:45:35 PM
Been reading this thread for a while. Like you when the dollar signs point the way, along with a fifty year life expectancy, then Hardie board siding it is. Great build by the way.
Post by: Dakota on February 02, 2016, 10:09:25 AM
After years of helping my Dad apply linseed oil to his cabin, when I finally built my own cabin, I went with fiber cement siding.  I love it.  If your siding is in 12' lengths, be sure to carry it vertically, it breaks easier than you think.
 (https://forestryforum.com/gallery/albums/userpics/11185/094.JPG)
Post by: fishfighter on February 02, 2016, 06:32:04 PM
Got that right off loading it in the back of my truck by hand yesterday. Over 9000lbs by hand loading and unloading. :o It's nice to have a 3/4 ton, 8' bed truck with air bags. Install the air bags for my truck camper. ;D
Post by: fishfighter on February 03, 2016, 03:19:48 PM
Got a chance to see how that back porch roofing did with the 3+" of rain we had yesterday. Did great. No leaks in between the roof and the back bedroom. 8)
Now if it would only dry up some. :(
Post by: fishfighter on February 05, 2016, 06:52:39 PM
Quote from: Bruno of NH on January 30, 2016, 08:56:09 PM
Fish
Bruno
This is one of the lag bolts I been using.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0617.JPG)
Was kind of dragging, but it was sunny, cool and little wind today. So I started hanging some Hardie plank on the south side. Hoping to get most of that side done by the weekend.
Post by: fishfighter on February 06, 2016, 05:22:03 PM
Well, this is were I stop today. Just one of those days I just couldn't go on.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0620.JPG)
Post by: sawmilllawyer on February 06, 2016, 10:27:30 PM
Looks great!!! Rest a little bit & Live to fight with it another day. You'll get r done.One step at a time.
Post by: thecfarm on February 07, 2016, 08:50:32 AM
It is not going no ways. And the worst part is,no more will be done either.  ;D
Post by: fishfighter on February 07, 2016, 05:54:10 PM
Well, such a nice day, got back on it. ;D Not much done, but got some sun.
Post by: fishfighter on February 08, 2016, 02:59:34 PM
I shouldn't have, but I did. Attacked the back wall on the back porch this morning. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0622.JPG)
Wind blowing at 30mph and gusting above 45 mph. Ladders were flying. Had to call it a day.
I have three sets of scaffold coming this evening. I will not get back on the build for a few days. :(
Post by: beenthere on February 08, 2016, 04:08:18 PM
Looks a bit treacherous to just try to walk and work around there. ?? Don't break a leg or sprain an ankle.
Post by: fishfighter on February 08, 2016, 05:30:12 PM
Tomorrow mornings job is to do a clean sweep all around the camp. Way to much trash and lumber just thrown around. >:( Most of that lumber was used to hold down the porch roofing. Was real windy that day.
Post by: fishfighter on February 09, 2016, 05:44:14 PM
Quote from: beenthere on February 08, 2016, 04:08:18 PM
Done and takin care of. ;D 4 buckets on the backhoe full of trash. >:( Can't burn anything due to the high winds, but by the end of the week, I'm going to have one heck of a fire. ;D
Didn't do any work, but things are better walking/moving around the job site. Things got way out of hand due to rain or me just not having the energy to pick up at the end of my days. Some days, I can put a 10 hour day and some days I start, but have to quit an hour later. The old saying is, " excuses are like butt holes, everybody has one." But, I'm not like that and if I post a picture again with things out of order, please let me know. ;D
Had to pick up some 2x4's. >:( Haven't been sawing anything even though I have a couple logs ready to go. Just maybe I need to step back and take care of what I really need to do.
A full days rest tomorrow then just maybe fire the mill off.
Post by: fishfighter on February 11, 2016, 06:14:05 PM
Got a little work done today. Nice that it warm up to 75F and blue skies, But the wind blew some.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0631.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0632.JPG)
It's hard on me climbing up and down on latters. So it is slow going at this point till I can get some help. No way the wife would even try climbing up. :D Will have another good day tomorrow then cool down thru the weekend just in time to go rabbit hunting.
Post by: beenthere on February 11, 2016, 06:20:12 PM
Keeps on looking better and better all the time. smiley_thumbsup
Post by: fishfighter on February 12, 2016, 04:11:39 AM
Thanks. Could hardly sleep tonight. Waking up at 2am is not good. My legs are killing me. :( Doing this siding job is for young people, not someone that is 59. ;D Guess I will climb aboard the pain train some more today. :o
Post by: samandothers on February 13, 2016, 10:32:52 AM
You may work out the soreness!  As Beenthere stated it is looking better and better!
Post by: fishfighter on February 20, 2016, 07:56:58 AM
Why thanks. Got some more siding up. I have to finish framing in the eaves and install the soffit hardie board before finishing the trim out on the side of the building. Looking to get that done today.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0635.JPG)
I started the front, but have to stop after one more rung of siding till I add the front porch. I'm still up on the wind as to which way I'm going to do the roof line or if I'm going to do a full length front porch. By going with the later, it's a Cajun thing. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0636.JPG)
Post by: Darrel on February 20, 2016, 05:47:49 PM
I just sat here and read the whole thread and looked at all the pictures. I'm inspired!  No only by the quality of the work, but also by the stamina of the man. He is fighting more than fish. Thanks so much for the inspiration!
Post by: plowboyswr on February 20, 2016, 06:39:52 PM
Quote from: fishfighter on February 20, 2016, 07:56:58 AM
Don't know 'bout it being a "cajun" thing, but this ozark hillbilly redneck thinks a full porch on it would look sweet!  8) looks great.
Post by: fishfighter on February 21, 2016, 02:02:39 PM
Thanks guys. Got very little work done yesterday. First thing in the morning, I nailed my left index finger. Wasn't good being up high. I hit that sucker just above the finger nail and I really think I broke it. A 22oz framing hammer can do some damage. :D
I did finish framing in that eaves. Started some siding on the other side and had to call it a day. DanG finger was pounding and still is today.
Got rain in the forecast the next two days and Wednesday is infusion day. So that gives me three more days rest. Besides, I got to start doing my taxes. >:(
Post by: fishfighter on February 27, 2016, 05:43:25 AM
Been a very slow week due to me under the weather, but was able to get a little siding done. I need to move some scaffold over to this side now.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0637.JPG)
Don't mine the hand, the sun was beaming in that direction. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0639.JPG)
Oh, the casings around the windows are 2x4 hardie boards. Heavy suckers. To hang them, I had to predrill them and use a 20d 4" long nails. Working out real good. Besides, when I got the hardie siding, the guy threw them in for free. ;D
Post by: SkyDoc on February 27, 2016, 10:26:51 AM
Good morning Fish,
Just read the whole thread. I love that you are putting up pictures as you go. I have to bookmarked to keep up on your progress. I am looking forward to taking a look at what you have accomplished when I make it back to land.
I cant wait to get home and show the Mrs. what you have done. She's the one that thinks I am crazy to think that I can buy a mill, get logs, mill them, and build things. She might be from the south, but she's a city girl through and through LOL. This forum is chock full of people that are doing exactly what she says "cant" be done and I love it. From learning how you have done things, to lessons learned, to actual proof that these projects are able to be done. Thanks for the inspiration!
Doc
Post by: fishfighter on February 28, 2016, 02:26:26 PM
Stop in with the wife any time.
Post by: fishfighter on March 01, 2016, 09:43:02 PM
Nothing done the last three days. The wife flat out told me to park my butt in the lounge chair for a weeks rest. I'm starting to climb the walls now. ;D Due in Thursday with my heart transplant team and hoping they tell me to keep up the work. ;D
Post by: sandsawmill14 on March 02, 2016, 12:13:54 AM
maybe everything will go well and you can get back at it smiley_thumbsup
Post by: fishfighter on March 07, 2016, 07:54:13 AM
Still under the weather. My trip wasn't to good. They wanted to put me in the hospital, but I turn them down. I am feeling a bit better and nice weather thru the weekend. So, I did get out yesterday and did a little dirt work around the camp. Needed to move more dirt in with the backhoe. Forecast starting tomorrow thru next Saturday is rain, rain and more rain each day. :(
Post by: fishfighter on March 14, 2016, 08:44:50 PM
Was a good day for me, so I wanted to get outside and do a little work. With all the flooding rains we had, it was way to wet to work on the camp. So, I started building the bathroom vanity.
This is some water oak I sawed about a year ago.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0646.JPG)
Top boards that were air dried. Of course my tin had a few holes as you can see from the water spots. ;D Also, the top boards had a little cup in them. :( No problem, I ripped them up to 2 1/4" and 6" on the table saw.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0645.JPG)
Once done, I passed the thru my planner.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0649.JPG)
After that, I started cutting them up as needed. Hope to get this put together by tomorrow.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0647.JPG)
Post by: Darrel on March 14, 2016, 08:58:50 PM
Looks like  the water oak turned out pretty nice in spite of the fact that it got water on it. Looking forward to seeing this build.
Post by: fishfighter on March 14, 2016, 09:28:54 PM
Sure did. It was sawed at 4/4 and I plane it down to 1" thick. That water oak had very little shrinkage.
I have a bunch of red and post oak I will be using inside the camp. Looking forward to see how that makes out.
Post by: dablack on March 15, 2016, 08:52:00 AM
It has been a while since I was on the forum.  Your build is coming along great!
Austin
Post by: fishfighter on March 15, 2016, 11:02:07 AM
Why thanks. It is moving kind of slow lately, but when I'm up to it, I try to put time in it.
Started gluing that vanity front together this morning. Should have it just about put together today.
Had put my truck in the shop for tires. Buddy call and told me that the complete front end needs replacing. >:( Hair under 3K for everything. Trade in time. ;D
Post by: fishfighter on March 16, 2016, 08:53:46 PM
Well, after looking at new trucks, I be DanG if I was going to pay those prices. :o
Truck is fixed and good to go for another 100K. ;D
Got the vanity base put together today.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0657.JPG)
Heck, it is even level. :D
If the rain holds out tomorrow, I will get back on it.
Post by: fishfighter on March 19, 2016, 12:40:07 PM
Got the draws and the vanity base done. Just have to work on the draw fronts and doors. Kind of under the weather and of course the weather kind of sucks here today. :D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0666.JPG)
Back side. Oh, this vanity will be slipping in between two walls.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0665.JPG)
Post by: fishfighter on March 20, 2016, 04:12:38 PM
Got the vanity top done. I will be installing a vessel sink on top.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0671.JPG)
Post by: scouter Joe on March 20, 2016, 07:42:09 PM
Thanks for keeping us up to date with your progress . I'm really enjoying this . scouter Joe
Post by: fishfighter on March 22, 2016, 08:04:29 AM
Got a little more done on the vanity yesterday. Was going to white wash it. Well, the more I thought about it, I got to thinking I would have way to much white in the room. So, I went a 180 degrees the other way. :D Happy I did.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0674.JPG)
What surprised me when staining is that the live edge took on a darker color. I like it. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0676.JPG)
After a few beers, I came up with an idea for the drawer fronts and doors. Way outside the box that will make this a one of a kind. ;D
Post by: Darrel on March 22, 2016, 09:59:19 AM
I like it!
Post by: fishfighter on March 22, 2016, 09:00:43 PM
Thanks. Got the doors just about done. Wasn't really up to it. Been under the weather, but with more rain coming, I would really like to get this done so I will have time to varnish it when the rain comes. ;D
I had to stain in the grove I had cut for the metal panel. The metal  panel is stucco wire, spray painted flat black. :D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0677.JPG)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0678.JPG)
Came up with this idea after a few cold beers yesterday. :D The wife loves it along with me. 8)
Post by: sandsawmill14 on March 23, 2016, 12:11:46 AM
looks good fish smiley_thumbsup
Post by: fishfighter on March 23, 2016, 08:46:08 PM
Got the doors hung and the drawer fronts on. Just need to stain them. Then pull everything apart to varnish it. Rain for tomorrow. :(
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0679.JPG)
Bad picture, but the drawers have the same wire mesh in them.
Post by: sawmilllawyer on March 24, 2016, 12:10:33 AM
Great workmanship! Very unique doors and drawer fronts. Keep at it you will get there.
Post by: Magicman on March 24, 2016, 01:43:32 PM
I see that you have been busy at home while I have been busy not at home.  Lookin' good.   smiley_thumbsup
Post by: fishfighter on March 24, 2016, 03:53:15 PM
Thanks. MM, I see you been on the road. Heck, I need a road trip to now where. :D
Got the drawer fronts stain before the rain this morning. Clear sky's now, but the wind is blowing 20+mph. Maybe early tomorrow I can get a first coat of varnish on.
Post by: fishfighter on April 05, 2016, 06:11:25 AM
I did finish the vanity last week.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0704.JPG)
What I been working on is the woodstove base. Had to take it out to install the fire bricks that go under the stove. Heavy sucker to move by one's self. ;D I should finish that up today.
Still doing little things around the camp due to being under the weather. :(
Post by: fishfighter on April 05, 2016, 05:59:18 PM
Got the woodstove base down. Going to acid wash them in a day or two. Those are fire bricks that came from a old house that was well over 100 years old.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0710.JPG)
Also I changed the back door. The one I had was one I had just laying around. Now I have the right swing door that I wanted. Didn't have any shims on hand to finish. >:( Will cut some tomorrow and finish that up.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0711.JPG)
Post by: sawmilllawyer on April 05, 2016, 11:16:01 PM
As always, IMPRESSIVE WORK!!! You are the little engine that says "I think I can, I think I can"! The wood top on the vanity looks great in the picture.
Post by: jimdad07 on April 05, 2016, 11:28:05 PM
Looking great, hope you listen to your body though.
Post by: fishfighter on April 06, 2016, 08:09:34 AM
Quote from: jimdad07 on April 05, 2016, 11:28:05 PM
Yep, I do and it is telling me to lay low this morning. Even the wife is not happy. So, I will just finish that door and shut it down for the day. :(
Post by: sawmilllawyer on April 06, 2016, 09:12:53 PM
Probably wise to do just that.
Post by: fishfighter on April 11, 2016, 10:03:41 AM
Had one heck of a set back this weekend. >:( Was under the camp with my son doing a little plumbing work and before I knew it, I passed out. :o Not once, but twice. Scared my son big time along with me. He help me out and before getting to the house, I passed out again. The wife rush me to the ER.
Come to find out that I came down with a bad case of vertigo. Still kicking my butt this morning. >:( Never had this before and taking meds for it, but still having my house spinning out of control. >:(
Anybody ever deal with this?
On a side note. Thank God it didn't hit me a 1/2 hour before when I was up on the roof. ;D
Post by: MikeZ on April 11, 2016, 10:54:20 PM
ff- sorry to say I have had vertigo after having fusion of neck vertibra about 7 yrs ago. Not much fun! Dr. said it was because there was lack of head movement while recovering from surgery and the brain then doesn't like movement. Took awhile and eventually got better. Now I have small sessions of it mostly from medications. Don't know about you though because sounds like your always after it. Good luck, that sounds like a lot for one day.
Post by: fishfighter on April 12, 2016, 07:06:20 AM
My world is still spinning out of control this morning. >:(
Mike, I to had a fusion done in my neck. 5 and 6, but that was about 15 years ago and never had a problem after that.
As to why I came down with this, heck if I know. All I know is that this is just unreal. Used to offshore fish all the time. After stepping off my boat after a rough day at sea, one would rock for a few hours after. This is even worse then that. :o Going to call my GP today to see if there is anything else that can be done.
Post by: Magicman on April 12, 2016, 08:56:13 AM
I had been wondering where you were??  I understand the "burning candles at both end" thing, but take care of yourself.
Post by: fishfighter on April 13, 2016, 05:35:03 AM
Day 4 with this vertigo and I'm still falling all over the place. >:( It's driving me mad. I'm going nuts sitting/laying around the house. God, I hope this passes soon.
Post by: Magicman on April 13, 2016, 08:20:17 AM
With this rain you could not get out anyway so rest my friend.   :)
Post by: fishfighter on April 13, 2016, 08:40:27 AM
You right about that. It's coming down in buckets. If I was up to it, I could get some electrical work done, but there is no way I would climb a latter. ;D
I have 6 nice syp logs I need to go pick up before the people trash them. Only good thing about the rain is keeping them from doing that. ;D
Post by: Magicman on April 13, 2016, 08:55:13 AM
This rain shut my sawing down for the entire week.  Some areas have gotten 4"-5" per day.   :o
Post by: fishfighter on April 13, 2016, 09:09:43 AM
I just check. A hair over 3" so far this morning. More to come. :(
Post by: MikeZ on April 13, 2016, 10:14:06 PM
ff-nothing from the GP about your problem? They always want to dump you off to several specialists for tests and all you get done is spend money and time. I had a bladder infect. couple years ago, been telling my GP about it for six months. Well it finally went septic on me and I wound up in ER and hospital for a week. Then they thought i should have artery biopsy of my r temple because of severe headaches. More money and time. All they would have to have done is treated the initial infect. Quality of life suffers when you're trying to function being a half a bubble off.  :( Best of luck to ya.
Post by: fishfighter on April 14, 2016, 04:03:02 AM
I have faith in my GP. Been using him over 35 years and he is a good friend. Problem is that I'm in heart failure and I can't take steroids. He told me that that would race my heart all over the place and my CRT-D would go crazy. :D I'm paced 100% of the time. :( So, he really wants to let is run it's course a little longer before I try them. Even the ER doctor said the same thing when I first came down with this.
It's going to be a very interesting day. Going to pick up a water heater. No way for me to drive, so my son is off and he is going to drive me. Heck, the walls are closing in on me. I haven't been out of my Pj's since Sunday other then to take a bath. :D I will have a puke bag with me. :o
Post by: edkemper on April 18, 2016, 05:00:13 PM
Quote from: fishfighter on April 12, 2016, 07:06:20 AM
The question is if it is still fused. You might be surprised. (PS: 30 years a licensed Dr)
Post by: fishfighter on April 18, 2016, 07:23:49 PM
No trouble with the neck. They put some dead man bone and a acebandage  thing with 4 screws.
Anyway, I did start feeling a bit better yesterday that I got out and started building a trailer for my mill. Just real tired and tired my ears are ringing off the hook. :D
More rain in the near forecast this week and I am in need of some sills and 2x6's.
Title: Re: Started the build.
Post by: fishfighter on May 11, 2016, 05:06:20 PM
It's been a bit over a month from the last time I did any work on the camp. :( Anyway, I did put in a half day hanging siding. Was tricky getting on a ladder. DanG thing kept swinging in the wind. DanG vertigo. >:( Anyway, had to shut it down do to the heat. Going to try to jump back on it in the early morning.
Post by: dablack on May 12, 2016, 02:36:04 PM
I know you know what you can handle but with ladders, take it easy.  I hate those things!
Austin
Post by: fishfighter on May 13, 2016, 06:19:12 AM
I'm not a fan of ladders too! Getting to old, I guess, The wife gets out there with me and watches me like a red tail hawk. ;D
Got a little bit more siding up yesterday. Had to shut things down. Got hot way to quick. Hit 91F yesterday and going to do it again today. :(
Post by: Hackermatack on May 13, 2016, 06:42:59 AM
Nice build I just found this thread. As for hanging siding I like my old pump jack scaffolding with attached work table. I load the table up with siding, take my cordless trim saw, square, jug of water and a radio.
Post by: fishfighter on May 13, 2016, 06:58:16 AM
Would love to have a set of those. I did have a few sets of scaffold that I got from my SIL, but he needed them for a job. Suppose to bring them back to me soon. Till then, I'm not going any higher then what I can get with 12' ladders.
Post by: Hackermatack on May 13, 2016, 09:04:21 AM
The old style like mine that run on wood don't bring much at auctions, I don't even think OSHA approves them but they are plenty safe if you use good lumber for legs and brace them when it starts getting high and shaky. When I was a little younger we used to splice out 2 x 4 's and go up 25-30 feet on them. Nice part is after you get going just keep moving up with the job and always have your work at a comfortable height.
Post by: fishfighter on May 15, 2016, 06:24:26 PM
Got some siding up the last few days.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0811.JPG?easyrotate_cache=1463350392)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0812.JPG?easyrotate_cache=1463350471)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0813.JPG?easyrotate_cache=1463350518)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0814.JPG?easyrotate_cache=1463350573)
Reason I didn't go higher, no scaffold. :( Still waiting on SIL to bring some. He still working high up. Also, I will be starting to box up the lower eves so I can get higher and finish areas.
A lot of rain coming next week. :( Will be doing inside work at that time.
Oh, the bad thing is that when I hung the back porch siding, I screwed up. Didn't take into account to level things to where the siding would match corner to corner. So. I will have to remove that area and reinstall. >:( I am about 2" difference. :( Just not happy, so I will redo it.
Post by: Darrel on May 16, 2016, 05:09:30 PM
It does look good!  Also glad to hear that you ar staying safe.
Post by: fishfighter on May 16, 2016, 05:36:04 PM
Quote from: Darrel on May 16, 2016, 05:09:30 PM
Well, that didn't go so good today. Busted my butt getting off a ladder. DanG vertigo took over and before I knew it, I was on the ground. :'( DanG doctor that I went to said there is no way of passing out. Like to put foot to where no sun shines on his backside. >:( Anyway, just a couple small cuts and my pride busted. :D
Not much progress today. Just boxing in eves. After the spill, I called it a day. Wife wasn't to happy with all the blood. :D
Oh, I am keeping the work area clear. Thank God that I did. ;D
Started raining and that is in the forecast thru the week. So, down time that I need.
Post by: Hackermatack on May 17, 2016, 06:43:05 AM
 :( Be safe man. We tend not to heal as fast as we grow older.
Post by: fishfighter on May 17, 2016, 07:26:56 AM
Quote from: Hackermatack on May 17, 2016, 06:43:05 AM
For sure. Got places hurting were I didn't think it was possible this morning. :D
SIL brought two sets of scaffold yesterday evening. Bad thing, the bottom fell out with rain. Rain all night. There is no way to even think about setting the scaffold up with the soft mud I have around the building. :( A lot more rain in the forecast for the rest of the week. :(
If any work is going to be done, it will be inside.
Post by: Hackermatack on May 17, 2016, 02:01:10 PM
Seven years ago I was the lead carpenter for my sons shop, it is 16' to the eaves. Myself and a guy 2 years younger than me did most of the roof work because the young guys were scared of heights. This summer we are doing another large building and I told him that I am ground control only and he better find guys that can climb or it ain't getting built. I made it this far without being completely crippled and I am not pushing my luck.
Post by: fishfighter on May 18, 2016, 04:55:30 PM
Was able to get some work done today. Some more eves work and got that back wall fixed like it should of been in the first place. Then went inside due to rain and set the platform in the attic for the water heater, then triple up wall studs under it. That is how I did it in my house with no problem. ;D
Post by: grouch on May 23, 2016, 01:05:32 PM
fishfighter: Ever considered building a medieval assault tower? Build a set of stairs and an elevated platform on wheels. Make the stairs with wide tread and low risers and then if you pass out, you don't tumble far.
Post by: fishfighter on May 23, 2016, 04:02:30 PM
With the mud I have around here, it would sink. :D Scaffold on wheels sink and I use my backhoe to just push them over as needed. ;D
Got a little work done on the inside Saturday. Found a rafter that is in the kitchen area that went south. Sucker dropped about 2" in the center. Thank God that is the only one. ;D Also, started running wires. Had a heck of a time drilling thru some of the beams. Guess my drill bit needs to be sharpen.
Wild rafter. Look close to see the blue line.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0838.JPG?easyrotate_cache=1464035839)
That sucker did drop. :D
Post by: fishfighter on May 26, 2016, 01:25:39 PM
Got the scaffold up and some more siding. Vertigo took over after a few hours when I was climbing down. Wasn't good. >:( Was going to shut that down anyway. HOT! Was 75F at 5:30am. Dew point was 73. Sticky is all I can say.
After that, I had a few oak logs that I needed to move to my log rack before any rain. Then I had some clean up to do around the camp. Going to chill for the rest of the day or service my mill. ;D
Post by: fishfighter on May 28, 2016, 12:22:31 PM
Got about 90% of the siding up as of yesterday. To finish the rest, I still need to box in the eves. Taking it easy today. Pushed myself way to much yesterday, but wanted to finish the north wall.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0839.JPG?easyrotate_cache=1464451906)
Once I finish those eves, I have to start on the front porch add on. Been sawing posts and beams and I still don't have enough. Fell a few trees and have them stacked to saw. That should finish my saw list as for as beams.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0840.JPG?easyrotate_cache=1464451930)
Post by: fishfighter on May 30, 2016, 07:17:25 PM
With the dry weather I been having, I thought it was time to start cleaning the camp yard. The north side, I had about 1 ac of woods that I dug up all roots and trees last fall. Had one heck of a wet winter and I couldn't do anything till now. A few hours on the backhoe and digging myself out a few time, I got things stacked and fired it off.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0841.JPG?easyrotate_cache=1464649630)
After working it the better part of the day, I was down to this.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0842.JPG?easyrotate_cache=1464649653)
More pushing and I got it down more. Then what? Rain! Still burning though. ;D
Post by: fishfighter on May 31, 2016, 05:31:19 PM
Still burning and still pushing.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0843.JPG?easyrotate_cache=1464729652)
In the woods to the right, I started clearing an area for a settlement pond. Had to dig up one big oak, roots and all. Took about three hours and I like to not get the stump out the hole. Did come out with two nice logs off that sucker. ;D Anyway, the settlement pond has to be 25'x25'x5' deep. I will be installing a treatment plant that will feed a run off barrel that will have a pump to pump it to the pond which is about 300' away.
Post by: grouch on May 31, 2016, 06:06:11 PM
You gonna put some goldfish or koi or similar in that pond to eat mosquitoes?
I remember talking to a guy from Louisiana ten or so years ago, complaining about the big European hornets that moved in around here. He said, "The hornets here are not too bad; you can *usually* take them out with a single shot from a .45. It's the dang mosquitoes with the inch-and-a-half drill bits that'll get you!"
Post by: fishfighter on May 31, 2016, 06:22:25 PM
DanG skeeters will carry off a youngin. :D
Post by: fishfighter on June 02, 2016, 03:24:00 PM
Got the settlement pond dug. Was going to do the treatment plant, but rain. :( Forecast for the next 5 days has rain in it with chances of 70% or more. :(
My son standing in the pond. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0845.JPG?easyrotate_cache=1464895117)
Post by: fishfighter on June 08, 2016, 05:01:46 PM
Finally got dry enough to install the treatment plant. Digging down 6', I had water. Once I put the tank in that was floating some, I filled one of those totes that are 300 gallons. Pumped the water from my pond. After 4 trips, it was full and resting on the bottom. ;D Took the better part of the day to get it in.
DanG heat took it toll on me today. :(
Post by: fishfighter on June 23, 2016, 04:35:31 PM
Been some time from my last update. Really not much done. Replaced a couple ceiling rafters that went wild. Of course they were set around the woodstove area. >:(
Today, I started laying out the front porch. It will be the full length of the front of the cabin. To keep it Cajun, the front porches are only 5' to 6' wide. So, I'm going 5'6" wide. :D
Didn't get any pictures. :( Tomorrow, I will with I hope some progress. ;D
Post by: Magicman on June 24, 2016, 09:01:53 AM
Just don't get too hot my friend.   smiley_sweat_drop
Post by: fishfighter on June 24, 2016, 06:46:37 PM
Thanks MM. My dearest wife watches me like a hawk. She shut me down this morning around 9:30. Super hot. :(
Got the sills all set up. I still need to cut my joist to size. Before I put it all together, I will treat everything with tar and diesel mix. I will have to let it dry some for installing everything. ;D
This is a picture of the sills. Just dry fitting things, so don't mine the piers. They are not set yet.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0879.JPG?easyrotate_cache=1466842796)
Hope Monday I will get the piers set in place.
Post by: fishfighter on June 27, 2016, 09:24:06 AM
Pull everything apart and painted all fitting areas with a tar/diesel mix. I will give it a few days to dry. I did a test piece Friday and I had cut it open to see how far the mixture got sucked in. It went in a little more then a 1/4". It was fully dried this morning. I did have a little rub off which Dawn soap washed right off my hands. ;D
Was 79F at 6am this morning. :( I'm soaking wet.
Once I set the sills and floor joist, I will come back and finish treating everything. I will be using 5/4 treated decking on top. Also, the outside edge will be finish out with the same siding as the rest of the building. One will not see the blacking.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0883.JPG?easyrotate_cache=1467033105)
Post by: fishfighter on June 29, 2016, 05:45:24 PM
Got some more work done on the inside of the camp. Nothing news worthy other then I have my first tenant that moved in. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0885.JPG?easyrotate_cache=1467236381)
I also have one that built a nest on the back porch.  Don't know what it is, but the nest is wider then 6" beam. Haven't seen them yet.
Post by: fishfighter on July 01, 2016, 12:08:02 PM
Got the front porch sills in place and all treated. Going to let them dry till next week then add the floor joist.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0890.JPG?easyrotate_cache=1467388829)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0892.JPG?easyrotate_cache=1467388868)
The decking will sit level with the front door. Well, a little slope downward on the outer edge. Just enough for rain to run off ;D
Post by: fishfighter on July 05, 2016, 04:48:16 AM
Got out early Saturday morning and installed the porch joist. Only problem is that all of them have some growth on them. :(  I will spray them today with bleach. Then I will treat them. I still have to install some cross members in between them too! I did use treated 2x6's on the outsides.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0893.JPG?easyrotate_cache=1467708106)
Post by: Magicman on July 10, 2016, 10:00:41 PM
I am following along, well almost anyway.  Don't get too hot!   smiley_sweat_drop
Post by: plowboyswr on July 12, 2016, 12:44:13 PM
Quote from: Magicman on July 10, 2016, 10:00:41 PM
X2
Post by: fishfighter on July 12, 2016, 12:57:45 PM
Thanks guys. Got way over heated last Saturday morning. Knocked me for a flip for a few days. :o
I did get out and sawed a couple post for the front porch this morning. ;D
Post by: fishfighter on July 14, 2016, 01:10:12 PM
Been sawing up more lumber for the front porch. Just about have everything I need. So, today, I built the post brackets. Got them welded up, but still have to clean them up and prime them with some red lead paint. Was going to get that done, but T storms came early today.
The post are 6x6. These brackets are 3" wide and the plates are 4" high by 5" wide. I will be putting the post back on the saw mill and cut slots to were the brackets will slip inside the bottom of the post. Once I mount the bracket, then the post will slide down. A couple bolts will run thru the post and bracket. The lag bolts that bolt down the bracket will keep the bottom of the post from touching the bracket. There is a 3/8" lip on the bottom of the brackets that will let air flow there.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0923.JPG?easyrotate_cache=1468515326)
Post by: BigZ La on July 14, 2016, 01:20:27 PM
I'm gonna have to make my way to your area one day to see your build. I've been reading along though.
Post by: fishfighter on July 14, 2016, 01:54:20 PM
Quote from: BigZ La on July 14, 2016, 01:20:27 PM
Were you live at? Come by any time.
Post by: BigZ La on July 15, 2016, 10:43:59 PM
I live on the river between White Castle and Donaldsonville. I'm up your way a few times a year.
Post by: fishfighter on July 17, 2016, 10:16:45 AM
Got a few of the post up yesterday. Had to shut it down due to the heat. :(
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0925.JPG?easyrotate_cache=1468764470)
This is how the bracket is set. Below them, I had installed a 4x6 treated timber in between the joist. The bracket is lag bolted down with two 3/8 lag bolts. I will be bolting thru the sides, then install some 1x6's over that once I get the decking down.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0926.JPG?easyrotate_cache=1468764529)
Post by: Magicman on July 17, 2016, 04:03:31 PM
That is quite innovative.   smiley_idea
Post by: fishfighter on July 19, 2016, 04:27:38 PM
Got the other post up. Then I had to resaw some beams this morning.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0927.JPG?easyrotate_cache=1468959142)
Once I got that done, I lay them out and went to town. Once that was done, I threw some paint to help checking.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0931.JPG?easyrotate_cache=1468959207)
The heat took it's toll. :( Hand to shut things down, but hope to get them in place early tomorrow.
Post by: fishfighter on July 21, 2016, 11:14:36 AM
Got the cross beams up and in place. I cheated. :o Used some 12" lag bolts to bolt the post/beam together.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0934.JPG?easyrotate_cache=1469113515)
Predrilled and installed two per post. It's not going anywhere. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0933.JPG?easyrotate_cache=1469113444)
Well, everything is level and straight. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0932.JPG?easyrotate_cache=1469113418)
Maybe tomorrow I will get the rafters up. The heat is unbearable now. :(
Post by: Magicman on July 21, 2016, 02:09:10 PM
Each step puts you closer to rocking on that porch with a glass of iced tea.   ;D
Post by: fishfighter on July 21, 2016, 04:28:11 PM
Quote from: Magicman on July 21, 2016, 02:09:10 PM
Each step puts you closer to rocking on that porch with a glass of JB and coke.   ;D
Fixed. :D
Post by: Magicman on July 21, 2016, 08:33:40 PM
 :D :D
Post by: fishfighter on July 25, 2016, 02:59:53 PM
Been so hot, it took three days just to hang 21 rafters. :( I had to take yesterday to rest. Anyway, I going to try to get the area stripped out tomorrow.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0935.JPG?easyrotate_cache=1469472699)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0936.JPG?easyrotate_cache=1469472670)
Just small steps, but getting there. ;D
Post by: rasman57 on July 25, 2016, 05:36:46 PM
Looks good. ...guess you don't have to worry about a big snow load sitting on your porch down that way. smiley_sun
Post by: samandothers on July 25, 2016, 06:28:10 PM
Looking great!  Steady gets the job done.  Don't over do it in all this heat.
Post by: fishfighter on July 26, 2016, 06:10:59 AM
Quote from: rasman57 on July 25, 2016, 05:36:46 PM
Last snow we had was about 6 years ago. About 6" and was gone within 6 hours. Our winters down here are like if one sits, one will see all four seasons in a week.
Having a bit trouble this morning with DanG vertigo. :o This is not good. Walking around like I'm drunk. Hope it ease up some.
Post by: red on July 26, 2016, 07:21:28 AM
Vertigo . . do we have to show you Magicmans Bloody Photos ? . . take a break
Post by: fishfighter on July 26, 2016, 12:51:56 PM
I managed to work thru it somewhat. Extra careful climbing a ladder. The wife watched my butt too! Anyway, got the strips down and just maybe the roof tomorrow.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0942.JPG?easyrotate_cache=1469551638)
Post by: fishfighter on July 31, 2016, 03:29:35 PM
I have roof over the front porch. ;D Got that done yesterday. Today was clean up around the area and get some of the grass/weeds cut. That was all getting out of control. :o
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0975.JPG?easyrotate_cache=1469993073)
Even the wife is happy. :D
Post by: Czech_Made on August 01, 2016, 03:20:15 PM
Looking good!  :)
Quote from: fishfighter on July 31, 2016, 03:29:35 PM
Post by: fishfighter on August 02, 2016, 06:32:57 AM
Thanks, it's just slow going due to the heat. Been doing a bit of dirt work around the building. Been dry for a change. ;D I'm sure waiting on my pond to drop lower so I can finish digging it. Looking at about 10,000 yards of dirt I will have to move. I have two roads that I need to build/crown up with the dirt.
Post by: Magicman on August 07, 2016, 07:19:35 PM
Quote from: fishfighter on July 31, 2016, 03:29:35 PMEven the wife is happy.
I'm happy for you both.   8)
Post by: fishfighter on August 12, 2016, 07:04:08 AM
Short update. I kind of been under the weather. Haven't done much. :(
Anyway, I had the power company come in to see what it's going to take to run the power lines. I have no choice but to fell 6 trees that I wanted to keep. :(
We getting pounded by rain now, so those tress will have to wait.
Post by: fishfighter on August 19, 2016, 05:02:56 PM
Fell only just one today. Was the biggest one out the bunch. Heck of a job cleaning up after.
Also played with a few boards for wainscoting. My plans are to do a nickel gap. I really like what I see and think it will come out outstanding. ;D The bugs had got in this batch of boards before I had a chance to treat them, but I like what I see. I will retreat them before installing. This was one of the oaks that had died for no reason. Now, just a ton of planeing.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0984.JPG?easyrotate_cache=1471640073)
Post by: fishfighter on September 07, 2016, 06:58:13 AM
Been taking it very easy the last few weeks. Was in and out the hospital a couple times. Guess the heat took it's toll on me. Then, last week, one of my brothers passed away. He has been fighting cancer the last 7 years. :'(
Anyway, yesterday was a big step day. I now have power lines ran to the camp. ;D Today, they will come back and drop a line to the temp pole. I will be able to install a window ac unit to cool things down so I can get some work done on the inside till cooler weather comes which will be a couple more months down here.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_0986.JPG?easyrotate_cache=1473245250)
Post by: Magicman on September 07, 2016, 08:00:07 AM
Sorry to hear about your Brother.  It seems that even the expected is always unexpected.
It's good to see you still chugging along.   :)
Post by: venice on September 07, 2016, 03:46:55 PM
Same here. What to say. Sorry to hear about your loss.
venice
Post by: fishfighter on September 07, 2016, 04:40:34 PM
Thanks guys. Was really hard for me to be praying that the Good Lord would take him ASAP. He suffered more then a person should. he told me two days before he passed that God would take him.
He was 63, married, three kids and 7 grandkids.
This was my second brother that had died from cancer. First one passed at 40 due to agent orange, after serving two tours in Vietnam. >:(
Post by: Magicman on September 07, 2016, 05:27:20 PM
I never had but one Brother whom I lost at age 44 in 1984.  I so often wonder about what we would be doing together now.
Post by: thecfarm on September 07, 2016, 06:43:47 PM
Porch looks good.
Sorry to hear about your brother.
Post by: fishfighter on September 08, 2016, 06:45:49 AM
Had a set back yesterday getting power. They came, but then asked if I had a Temp power pole permit. I asked WHAT? Never hear on that. >:( Had to get the permit office guy out to look at the pole. He had came, looked at it for a minute and said I was good to go. Yep, I was mad as hell and I had a few choice words that I don't care to repeat. :D
The power company will be here first thing this morning. ;D
Post by: fishfighter on September 09, 2016, 02:10:16 PM
Got power yesterday, but was a bit under the weather.
This morning, I started hanging insulation. Was nice to work a little with a big box fan blowing and no genset running. ;D
Oh, I been kicking up an idea of using oak boards with a nickel gap for the ceiling in the living room and kitchen. Don't have a clue how that would look along with oak wasinecoating  and pine flooring.
Post by: Jim_Rogers on September 09, 2016, 07:39:26 PM
Sorry for your loss
Jim Rogers
Post by: fishfighter on September 10, 2016, 07:06:08 AM
Thanks Jim.
Post by: sandsawmill14 on September 10, 2016, 07:20:43 AM
sorry about your brother  fish :(
Post by: fishfighter on September 10, 2016, 07:48:30 AM
Thanks.
Was planning on going Teal hunting this morning. Opening day. Went to load my pirogue and saw that it had a big hole in the bottom. DanG powerline crew that trimmed some branches must of dropped one on it. >:(
Post by: fishfighter on September 20, 2016, 01:33:02 PM
Small update. Been planning boards for the wainscoting. A lot of work, but I think it is going to come out real nice. After planning, I had set up one of my tablesaws with a dado blade. Had that set at 1/2" wide. Made a pass on the backside edge and then flipped the board over and made a second pass. This kind of set me up for a nickel gap or ship lap. I started hanging some of it today. Using liquid nail to glue all joints and a small nail gun, I don't think I will have any problems with it.
Oh, the boards were all planed down to 3/4".
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1005.JPG?easyrotate_cache=1474391869)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1004.JPG?easyrotate_cache=1474391848)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1002.JPG?easyrotate_cache=1474391800)
I will be testing different wood stains to see what really will pop out the wood. Then I will varnish it all.
Post by: Czech_Made on September 20, 2016, 02:18:24 PM
Looks good.
Post by: Magicman on September 20, 2016, 03:33:37 PM
Very nice.  Now aren't you sorry that you complained about those Ambrosia Beetle holes?    ;D
Post by: fishfighter on September 25, 2016, 09:00:00 AM
MM, they sure do bring out the grain of the wood. ;D  Just about finish hanging the wainscoting. Came up about 7 boards short. :( So, yesterday I made them up. Went to hang them and my air compressor died. >:( Guess after 7-8 years in use and being a cheap harbor freight, I got my money out of it. :D So, I went and bought a new one just like it. :D
Will finish hanging today.
Post by: Magicman on September 25, 2016, 09:13:17 AM
Thankfully the weather is cooling off so we can all get more done.   :)
Post by: ChugiakTinkerer on September 25, 2016, 12:14:16 PM
Quote from: fishfighter on September 25, 2016, 09:00:00 AM
Just got to put in a plug for my Rolair JC10 quiet compressor.  It's small, only 1 HP, but it is whisper quiet.  And it can handle my framing gun.  Awesome for interior work.
Post by: fishfighter on September 25, 2016, 06:38:59 PM
I use the compressor to spray paint too!
MM, yep, cooler weather coming. Got 12-15 oak logs that has been stacked a month or two that I need to saw up bad. The heat been taking it's toll on me. :( Heck, only made two teal hunts this season due to little to no birds down and way to hot to hunt.
Post by: Magicman on September 25, 2016, 10:17:02 PM
When someone in your country misses duck hunting, something is very bad.   :-\
Post by: fishfighter on September 26, 2016, 09:13:23 AM
There were just no teal down this year. My daughter and SIL hunted White Lake WMA yesterday. The best place to duck hunt in all of Louisiana. It is only hunted by Lotto hunt or pay $30K for a weekend for 10 hunters. :o Then didn't even fire a shot. :o
Going to stage some of those oak logs this morning to saw them up maybe at the end of the week.
Post by: fishfighter on October 03, 2016, 07:24:33 AM
Really not much progress. Did a little corking outside and started painting the roof with some elastomeric paint. If only I could find a spray gun to apply this stuff. :(
Post by: Magicman on October 03, 2016, 07:38:08 AM
Even a little progress is good.  Are you rolling it on?
Post by: fishfighter on October 03, 2016, 07:16:27 PM
Yes, got about half the back done. Can't take the heat.
Really started outa BAD day. >:( My break light on my truck started coming on for a few seconds, the drop out. Check all breaks. Not a easy thing jacking up a 6300 lb truck and didn't find any problems. :o
If only things can go down hill from there. Yep, they do. >:( Been having a good size oak stump kind of in the road way to my camp. So, I took that on to dig it up. Broke it free after about an hour.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1041.JPG?easyrotate_cache=1475535476)
Went to move the hoe and for some reason, it was in gear. Before I knew it, I was somewhat in the pond. :o
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1042.JPG?easyrotate_cache=1475535530)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1040.JPG?easyrotate_cache=1475535567)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1039.JPG?easyrotate_cache=1475535606)
I just want to bang my head to a tree. No water in the engine, but for some reason when I try to start it, it is acting like the hydro is locked up. At this point I had to have a few beers. :o
There is always tomorrow and a fresh start. ;D Just hope today doesn't repeat. ;D
Post by: barasingha on October 03, 2016, 10:24:51 PM
Try to shake the sticks while cranking.  My backhoe has the hydraulic pump in front of the engine--the part of yours that's underwater.  On my pump is an electric destroke solenoid that removes the pumping load from the starter.  Mine is a deere, but if yours is similar it is probably not destroking, making it hard to crank.
Shake the sticks to remove hydraulic pressure, crank it up, and crawl out of there!
Post by: fishfighter on October 04, 2016, 07:31:05 AM
I did try that. After sleeping on it, I think somehow the hydraulic system sucked up a bunch of water. Thinking that is what has it locked up. Waiting on day light to check that.
Post by: fishfighter on October 05, 2016, 08:37:54 AM
Got it out yesterday. Took a 16 wheeler tow truck and $300. :o
Still don't know as to why the hydraulics locked up. But once on flat ground after about an hour, she fired right up and everything is good.
Post by: barasingha on October 05, 2016, 10:01:48 AM
Ouch!  Glad you got it out and don't have water in the oil.  $300 is cheap compared to complete hydraulic rebuild.  Mine has wet packs in the transmission and wet brakes in the diff.  I have heard that water in the oils causes all clutch packs and brake materials to melt away.   Big money.
Post by: fishfighter on October 19, 2016, 01:16:24 PM
With the heat we been having and dealing with my ear, not much has been done. :(
Anyway, yesterday I was up to just messing around. So, I started building a door out of oak and if it comes out like I want, I will build two more.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1066.JPG?easyrotate_cache=1476896716)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1067.JPG?easyrotate_cache=1476896741)
The inside filling I will be doing nickel gap/ ship lap like I did on the wainscoting. Was going to do that today, but had something I had to go get.
Got a airless spray rig to paint the roof. Rolling was way to much work on me. Cool clear weather coming this weekend and hope to get that done.
Post by: AlaskaLes on October 19, 2016, 02:58:44 PM
Sounds like Murphy has been a guest at your place lately... ;D
Glad you got the Backhoe out without a rebuild.  That could have really hurt the budget.
We burned up 43 hours on a rented a 30K excavator a few weeks back.  I was
working on expanding a packed clay bridge that crosses an old dry slough in the middle of our 80 acres.
When I got to the last push to connect to the far bank, the back of the ex got stuck.  Muck and gravel up to about 1 ft up the back of the body; tracks almost completely buried; all I could still do was spin 360 and dig.  Too much suction to pull/drive fwd, even with my bucket on the solid far bank.
I panicked for about 10 seconds, thinking I was screwed...then I remembered that I was driving a huge shovel and started digging under me and around me.  Still pretty amazed at what those dang things can dig their way out of.  I was so relieved when it crawled out onto the far bank.
I really like the wood ideas on the inside of your cabin.  That is going to be very sweet!!
We are actively planning our TF house build for next year.  We've got a file full of great ideas, just have to start picking the ones we're going to use.
Post by: fishfighter on October 19, 2016, 04:59:50 PM
I have some more ideas that I going to see if it will work out. Like the base boards will be live edge oak and also door and window trim. 8)
Post by: AlaskaLes on October 20, 2016, 02:44:18 AM
Baseboards might be a challenge if you care to make one flow into the next.
Window and door trim would be much easier to match the widths at the miters.
I like this idea.
Post by: fishfighter on October 20, 2016, 06:36:43 AM
My runs for the base boards are all under 13' due to the post framing. I have sawed some that has been stack in stickered that are 14' x avg 6" wide and 1" thick. I will be passing them thru my planner. Also for the chair rail, I will have to do a off set to the back side due to the wainscoting is 3/4" thick, but the sheet rock is 1/2" thick. Those will be around 2 1/2" wide.
Got some chances of rain today. We need it bad. Been over a month from last rain and I have cracks in the ground one could fall in. ;D Going to try and finish that door.
Post by: Magicman on October 20, 2016, 02:36:44 PM
Keep plugging along.  I like your plans for the doors.   smiley_thumbsup
Post by: ChugiakTinkerer on October 20, 2016, 03:28:08 PM
Quote from: fishfighter on October 19, 2016, 04:59:50 PM
Live edge sounds way cool.  And it sounds like a good opportunity to do a couple mock-ups, both with live edge and a straight edge trim board to see how they compare.  And a really nice opportunity to take pictures and post them on FF!
Post by: fishfighter on October 20, 2016, 07:03:33 PM
Well, it's a guest/camp house. So no telling what. ;D
Got the door all framed out and I like it. ;D It's going to match out great and I will be carrying this over to the kitchen cabinets. This door is made out of some of the first boards I sawed up. 8)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1068.JPG?easyrotate_cache=1477004127)
Post by: sandsawmill14 on October 20, 2016, 07:43:38 PM
looks good smiley_thumbsup
Post by: Magicman on October 20, 2016, 10:04:57 PM
Very Nice my Friend.   smiley_thumbsup
Post by: AlaskaLes on October 21, 2016, 03:12:22 AM
Yup, sexy doors indeed!
Hanging out with you guys, I'll be turning my own cabinet knobs before it's over...
Post by: fishfighter on October 21, 2016, 06:19:17 AM
One thing is, that door will have to be hung with 4 hinges. Heavy SOB. :D
Post by: Bruno of NH on October 21, 2016, 07:05:34 PM
Nice looking door Mr Fish :)
Post by: fishfighter on October 22, 2016, 09:40:33 AM
Heck, the door came out square. :D
Got up on the roof and sprayed the back side yesterday. 100x's better then rolling on the coating. Fixing to do the front side today.
Post by: fishfighter on October 22, 2016, 02:45:01 PM
Got the front roof coated. Hell on my back doing a 8/12 pitch, hanging by a rope.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1070.JPG?easyrotate_cache=1477161572)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1071.JPG?easyrotate_cache=1477161634)
Post by: AlaskaLes on October 25, 2016, 02:58:12 AM
Go Man Go!
Looking good.
Post by: fishfighter on October 26, 2016, 07:11:38 AM
Been trying to finish boxing in the eves. Slow going there due to climbing up and down a ladder.  :( Trying to get that done before I have ear surgery on the 3rd of next month. Was told that will shut me down for about two weeks. Going to have a big chunk cut out. Dam skin cancer. >:(
Also, my transplant team is throwing a fit. My CRT-D has a problem with the battery and the home monitor that reads the pacemaker quit working. Waited on the phone for an hour yesterday trying to get in touch with the pacemaker people. >:( Never got thru. >:(
Post by: Justin Bailey on October 26, 2016, 11:39:20 PM
I made a 3" thick oak door that was a slim 27 or so inch wide, but used ball bearing hinges, and also a hard maple 1-3/4 thick one 30x80 where I used them as well.  Just three.  They were easy enough to find and then you could use just three hinges if you wanted to.  They work smoothly, but the knuckles are larger than with normal hinges, causing trim clearance interference concerns.
I just routed away a close fitting dado in the trim for them to clear or one can just set the leaves back away from the edge inside the door and the jamb, but that may make the swing and strike a problem, in order to have a nice close gap there.  Another consideration is removability-some of them do not have removable pins.
You may already found the solution w/ 4, Sorry I had not thought of it sooner and commented.
Just an idea.
Post by: fishfighter on October 27, 2016, 02:14:50 PM
Hey, thanks, I'm always looking for a better way. ;D
Did a bunch of blocking in eves yesterday. I paid the piper last night for climbing up and down the ladders the better part of the day. ;D Ran out of 1 x 4's. Guess I will fire up the mill tomorrow. ;D
Found out that I might have to have the battery changed out in my CRT-D. >:( If so, that will shut me down 4 weeks. Just about when duck hunting season starts. >:(
Post by: tareece on October 27, 2016, 08:38:53 PM
Quote from: fishfighter on October 22, 2016, 02:45:01 PM
I am plumb jealous
Very inspiring fish!
Post by: Magicman on October 27, 2016, 10:07:50 PM
We would rather have you down for 4 weeks than down.  Keep the spirit alive my friend.   8)
Post by: fishfighter on October 28, 2016, 06:22:46 AM
Thanks MM. Yesterday was a down day. Got to listen to what my body says. Slept on and off all day. I'm doing a little bit better this morning. Myself and the transplant center has been trying to get thru to St Jude medical. Still no luck. >:( What I found out is that the CRT-D (pacemaker) has a battery life of about 5 years due to being paced 100% of the time. Bad thing is, I been having this dam spark pack in for 5 1/2 years. Last reading of it was May, 2015 which has been way to long. So, nobody knows how much juice the battery has left. If we don't get thru today, I guess a trip to New Orleans will be in order Monday. :(
On another note, I'm going to try in saw up some 1x4's today if the wife lets me. :D She will be my tail person. ;D
Oh, in that picture with the door. Under it, those are the last two benches I needed to get built. Still have one more I need to build custom made to order for someone. A easy $200. Costing me around $4 to build along with about three hours work. 8)
Post by: SkyDoc on November 01, 2016, 07:05:46 AM
I scored you some yellow fin tuna to grill up or cook as you see fit. I'll be back on land on 11-10. If you get down my way let me know where you can meet me and I will get it to you.
Pulled the trigger on my big trailer mill last week. I should pick it up after the 1st of the year. It's going to be a monster!! I am excited to get it.
Doc
Post by: fishfighter on November 01, 2016, 07:28:47 AM
Hey, thanks. I will make it out your way, I hope.
Still waiting on doctors for a plan. Got ear surgery Thursday to remove the last of some skin cancer. From there, maybe a battery replacement. :(
I did get a little work don't on the camp. Finished treating the front porch. Just hate painting. :D Going to try and do the back porch today.
Oh, picture of the front porch.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1076.JPG?easyrotate_cache=1478027774)
Post by: btulloh on November 02, 2016, 08:30:18 AM
Looking good.  What did you use to treat the porch?
Post by: fishfighter on November 02, 2016, 09:05:30 AM
One gallon of tar mixed with about 1/2 gallon of diesel. Once it dries, I will paint it before I put the flooring down.
Post by: fishfighter on November 02, 2016, 03:01:07 PM
Got out this morning for a couple hours before the heat came and applied some hardie plank to the front porch decking.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1078.JPG?easyrotate_cache=1478112804)
Maybe this weekend I will get the hardie plank above if I can get a little help.
Fondly got thru the pacemaker people. DanG week and a half. >:( Anyway, sparkie is good for another two years. 8) Tomorrow, DanG ear surgery to remove that DanG spot that just don't want to heal. That sucker hurts just to the touch. :(
Got to take the dear wife out to dinner tonight. 37 years married today. Got a good one. :D
Post by: sandsawmill14 on November 02, 2016, 07:17:20 PM
congratultions smiley_love smiley_love
porch looks good too smiley_thumbsup
Post by: Magicman on November 03, 2016, 09:29:08 AM
smiley_love  You have your priorities in order my friend.   food3
I wish you the best with your ear surgery, and good news about 'sparkie".
Post by: fishfighter on November 03, 2016, 06:01:51 PM
Thanks guys. Had that surgery. Man oh man, what a can of worms they open. :o Start to be about the size of 3/8" and ended out to the size of a quarter. :o Even had to remove some cartilage. :o After that, they did a skin graft. This SOB is now really hurting like 40 kinds of hell. :(
I will be down and out for the first week. They told me to take it easy up to 8 weeks. SUUUUURRRRRE. :D Good side, they got all the cancer cut out. 8) Took 4 hours to do the job. Would do better paying him by the foot. :D
Post by: sandsawmill14 on November 03, 2016, 06:51:08 PM
my grandad lost the top of his ear from where it attached to his head up  :o to cancer they just cut it off straight across :o
and i had an uncle had it on the end of his nose and they went back 7 times  :o shaving one layer at a time till they got it all  we got to memphis at 6:30 am and they finished the surgery at 2: pm ;D a long day but worth it the funniest thing about that day was they had his nose bandaged up as big as your fist ;D no kidding :D  thaen of course you cant eat before surgery so he was staring to death and we stopped at the first place we seen a wendy's and he ordered 2 #1 combos and an extra burger and turned around to me and said "what do you want"  :D :D :D :D he ate it all  :o and took about 1/2 of the 2nd drink with him for the ride home :D he was not a small fellow about 6'6" and weighed about 275 he was around 60 when this happened and was still working everyday as a plumber/electrician  ;) he lived about 15 more years and has since passed and i miss more than anyone from the family that has left us so far but alot of fond memories :)
sorry for rambling on so  but the point of this ( before i forgot to make it :-[ ) was that both live 15 or more years after the surgeries and the cancer never came back so if the said they got it all its gone and you are good smiley_thumbsup  just lay around till you feel better and let it heal up good :)
Post by: sandsawmill14 on November 03, 2016, 06:52:23 PM
i should say that both died from strokes not any kind of cancer :)
Post by: fishfighter on November 03, 2016, 07:38:32 PM
Yep, slice by slice till they hit paydirt. :D
Post by: sandsawmill14 on November 03, 2016, 07:50:28 PM
sorry i got to rambling fish but i am very glad it all went good for you and i will be praying for a speedy recovery :)
Post by: thecfarm on November 03, 2016, 07:56:08 PM
You can ramble any time. I like the story.  ;D
That sounds good on the heart and ear!!!
Post by: sandsawmill14 on November 03, 2016, 08:46:56 PM
Quote from: thecfarm on November 03, 2016, 07:56:08 PM
thanks cfarm ;)
it is funny how stories of people you held dear get so long after they are gone :)
Post by: fishfighter on November 04, 2016, 02:18:47 AM
That is for sure sandman. It's after 1am and I hurting way to bad to even put my head down. >:(
Post by: fishfighter on November 10, 2016, 03:24:57 PM
Went to the doctor this morning for my ear. :( Yep, one heck of a chunk was cut out. For the skin graft, they sliced a chunk right behind the same ear. Anyway, pain is just about gone, but tinder to the touch. Was told to still take it easy for another week. :(
Let me know if y'all want me to take out this picture.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1083.JPG?easyrotate_cache=1478809148)
Post by: sandsawmill14 on November 10, 2016, 06:38:10 PM
glad you are feeling better smiley_thumbsup  dont worry about the pic it dont look to bad  :)  just be glad its still there to hold up your hat ;)
Post by: thecfarm on November 10, 2016, 06:48:30 PM
Kinda like another members pictures,just scrool right by them,quickly.
Post by: fishfighter on November 11, 2016, 09:49:44 AM
Quote from: sandsawmill14 on November 10, 2016, 06:38:10 PM
:D Yep, though of that too! :D
Passed a bad night, last night. :( DanG thing was hurting. :( A bit better this morning. ;D
Oh, on the back side of that ear, they took a big chunk of skin/meat for the skin graft. Got around 8 stiches there still.
Post by: fishfighter on November 16, 2016, 07:47:02 AM
Got out yesterday and did some service work on my equipment. $400 in oil and filters. Ouch :o
Anyway, I was given a 28' camper. It is in very bad shape. My plans are to take my backhoe and just rip everything off the trailer. ;D That is going to be fun. ;D I took the camper just for the trailer to make a log trailer out of it. 8)
Post by: sandsawmill14 on November 16, 2016, 11:59:11 AM
if its like the one we have you will have to do some bridgework to stiffen it up and some bracing on the goose neck but they are a good start ;) i think ours was only 20' but we got it ready to start reworking and something broke and had to pull it out of the shop to put the hay roller in to do some welding and havent got back to it  ::) that was only 7-8 yrs ago ::) its still sitting beside the shop and we will get to it some day :D :D :D
glad your feeling good enough to be back at it smiley_thumbsup
Post by: fishfighter on November 16, 2016, 02:35:27 PM
I had to chill for two weeks per the doctor for that DanG ear. :( It is still taken it's time to heal. :(
Pull the windows out the camper and then moved it close to my burn pile.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1089.JPG?easyrotate_cache=1479323919)
Then had fun with my backhoe. 10 minutes and it was clear. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1092.JPG?easyrotate_cache=1479324102)
Yep, I will beef it up along with cutting it down to around 18', 22' with the hitch. It's 32' long now.
Post by: sandsawmill14 on November 16, 2016, 03:38:59 PM
i was guessing it was a 5th wheel by the length but i see it is not now ;) with it being the tag along it long enough to make 2 out of  :D :D :D
Post by: fishfighter on November 16, 2016, 06:19:03 PM
The camper tag had it's weight at 8700 lbs. The axles I think are 5K each. So, that should do as far as a couple logs at a time.
Post by: sandsawmill14 on November 16, 2016, 06:32:00 PM
i wouldnt be afraid of 6-800 bdft doyle on it myself if your truck can handle it  :) but i have hauled 55 7x9 hardwood ties with my c 30 chevy pulls it fine stopping it requires some practice ;D :o :D :D :D
Post by: Ljohnsaw on November 16, 2016, 07:22:58 PM
Quote from: fishfighter on November 16, 2016, 06:19:03 PM
Knowing how they build trailers and like to cut corners, I doubt they are 5k axles.  At 8,700 pounds, the tongue weight is supposed to be 15%, or 1,305.  That leaves a net weight for the axles of 7,395.  They might have skimped and only did 3.5k but probably had custom 3.7k axles made up, maybe used 4k.  Is there a sticker on the axles (manufacturer with a model number)?  Would be worth checking.
Post by: fishfighter on November 17, 2016, 03:14:07 AM
Didn't see anything on the axles. Good thing, the electric brakes still work. Load wise, I have a Dodge 2500 diesel. ;D
Post by: ChugiakTinkerer on November 17, 2016, 12:46:44 PM
I got this off a page at etrailer.com:
Typical Axle Diameters Based on Axle Capacity
- 1,000-lb - 2,000-lb Axles: 1-1/2 inch - 1-3/4 inch diameter
- 3,500-lb Axles: 2-3/8 inch diameter
- 6,000-lb - 7,200-lb Axles: 3 inch diameter
- 8,000-lb Axles: 3-1/2 inch diameter
- 9,000-lb Axles: 4 inch diameter
- 10,000-lb Or more axles: 5 inch diameter
Post by: fishfighter on November 18, 2016, 05:20:28 AM
By going by that, the axle pipes are 3". 6K each? I hope. :D Thanks. Got a bunch of work done on it yesterday. Will get some more done today. I had cut the trailer bed down to 18' besides the hitch. I'm still beefing it up.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1100.JPG?easyrotate_cache=1479464236)
Post by: Ljohnsaw on November 18, 2016, 10:05:27 AM
Quote from: fishfighter on November 18, 2016, 05:20:28 AM
Well that's good news!  Are you going to be using a WDH (weight distribution hitch)?  The reason I ask is the axles look pretty far back.
Post by: fishfighter on November 18, 2016, 01:05:04 PM
My truck has air bags installed. I put a 2300lb truck camper in the bed. Oh, it has a 8'bed too. ;D Truck weights in a little over 6500lbs.
Post by: fishfighter on December 13, 2016, 01:50:16 PM
been some time from my last up date on the build. Really haven't did much, but just small little things. Last Saturday morning, it was 30F with a lot of wind. Told myself it was a very good day to fire up the woodstove. I had lit small fires in it, but of course it was hot outside.
Well, I put a real fire in it and I was very happy with the out come. ;D Didn't take long to warm things up in the camp. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1143.JPG?easyrotate_cache=1481654546)
Now, it is 77F and raining. :(
Post by: fishfighter on January 27, 2017, 05:21:14 PM
Kind of shut down building on the camp the last few months. :( Health wise, I had to. Anyway, I got out for a little to work on it. Did I say I like free things? ;D Couple weeks ago, I copped some free metal roofing that is new. Sheets from 8' to 14'. Only problem there, they are different colors, but still the same as what I have up on the main building. Really no problem due to I will coat them like the rest of the building.
Anyway, I finished boxing the north side of the back bedroom and installed the first new sheet of roofing. Got tired and sealed everything back up. :( Going to try and do the complete roof section the next few days.
Didn't get any pictures. :( But, if the rains hold out like they are saying, there will be a good chance to get my load of sheetrock in by next week. ;D Just waiting for it to dry some.
Post by: sandsawmill14 on January 27, 2017, 05:48:53 PM
its been real wet here too    glad you are feeling good enough to work a little now :)
Post by: fishfighter on January 28, 2017, 12:19:56 PM
Quote from: sandsawmill14 on January 27, 2017, 05:48:53 PM
Well thanks, but as of this morning, I'm coming down with the third cold this winter. >:( My immune system is very low due to heart failure. :( Got a doctors appointment Monday with my heart transplant team. I'm sure they are not going to be happy again. ;D I been fighting this over 6 years and I live with the can do attitude. That has been kind of going down hill the last few months.
Post by: sandsawmill14 on January 28, 2017, 12:59:48 PM
hang in there fish :)
Post by: fishfighter on February 01, 2017, 06:01:57 AM
Well, I was right about the doctors not being happy. ;D Have  to go back once I get over this DanG cold. Finely the fever broke. ;D Got out yesterday and did a little more on the roofing that I started. Weather was a nice 75F and sunny with little to no wind. ;D Going to try and finish out that side today. Only have about two hours work left. I will get some pictures today.
Post by: Magicman on February 01, 2017, 08:44:24 AM
Sorry about the Doctors, but it is good to see you stirring about.   8)
Post by: fishfighter on February 02, 2017, 08:17:34 AM
Thanks MM. Got out yesterday and finished the one side and had to call it quits. DanG cold is now in my chest. This is not good at all.
Anyway, different color roof. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1202.JPG?easyrotate_cache=1486040679)
But, as I did to the main roof, I will be spraying it with elastomeric coats in white. Suppose to save up to 15% energy.
Post by: fishfighter on February 17, 2017, 08:02:39 AM
Just a update. Got sheetrock in, but still have to hang it. Was going to buy a machine to do that, but a cheap one cost over $200 and once finished, I hope I would not need it again. :D
So, I will just build one. ;D
I also copped some granite counter tops. More then enough for the camp. Paid $125 for it. ;D More and more, the wife wants us to move to the camp. :D
Post by: flyingparks on February 17, 2017, 09:23:57 AM
Whats Sheetrock? :D
Post by: fishfighter on February 17, 2017, 05:38:17 PM
Quote from: flyingparks on February 17, 2017, 09:23:57 AM
Whats Sheetrock? :D
Guess you are a Yankee. :D Gypsum board I guess, if you are a Yankee. :D
Started building the lift today. With a saw mill, why not make it out of wood? ;D Oak box tube and a double 2x4 pine for the lift section and legs. Got $6.14 so far into it. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1221.JPG?easyrotate_cache=1487370414)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1222.JPG?easyrotate_cache=1487370456)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1224.JPG?easyrotate_cache=1487370487)
It will reach 10'. I will be adding some caster wheels to the base which I have on hand. Then make the spread bars to handle the SHEETROCK. :D
Post by: Ljohnsaw on February 17, 2017, 06:29:44 PM
Quote from: fishfighter on February 17, 2017, 05:38:17 PM
Whats Sheetrock? :D
Pretty cool!  But, what I think he was saying is, Your not doing pine, cedar or walnut planking?
Post by: fishfighter on February 17, 2017, 06:40:12 PM
Using a lot of oak and pine for the flooring. ;D
Going to have expose oak beams too! Walnut, what is that? There might be maybe one tree within 100 miles. :D
Post by: fishfighter on February 18, 2017, 06:19:05 PM
Finish the sheetrock lift. Got wheels and hope to put it to use next week. ;D
I can pin it in this direction for ceilings.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1225.JPG?easyrotate_cache=1487459362)
Or drop it down for the walls.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1226.JPG?easyrotate_cache=1487459393)
The frame is 45"x8'. When using it for the walls or loading it, I had cut a slot on the bottom of the frame to help loading.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1227.JPG?easyrotate_cache=1487459429)
All rooms other then the bathroom, I will be installing 1/2x4'x12' sheetrock.
Post by: Magicman on February 19, 2017, 10:20:08 PM
Oh my, I have done my share of sheetrock.  The best part of each job was when the job was completed.  Nice lift.
Post by: fishfighter on February 20, 2017, 06:18:38 AM
Yep, did my share too! Did my house that is 2750 living with 9',12,14 and 17' ceilings. Was not fun at all. ;D
Make a short rabbit hunt yesterday which took a lot out of me. Took a nap at 2pm and woke up at 4:30 this morning. :o Feel like a new man. :D
Post by: Magicman on February 20, 2017, 02:35:02 PM
Rip Van Winkle did that too.   :)
Post by: Darrel on February 20, 2017, 02:55:22 PM
Yes he did. I didn't saw nothin or hang any Sheetrock  Passed a kidney stone instead. Now I think I'll take my turn playing Rip Van Winkle.  Z z z z zz
Post by: alabama on March 01, 2017, 06:00:06 PM
Looking real good! That is a lot of blood sweat and tears...
Post by: flyingparks on March 01, 2017, 10:31:49 PM
Whats Sheetrock? :D
Awesome lift. Meant no disrespect. I just try to avoid sheetrock as much as I can. I've done too much. Inside joke I guess. I'm just a westerner who prefers wainscoting. I've been really enjoying this thread. Keep up the good work fish.
Post by: fishfighter on March 02, 2017, 05:59:52 AM
Quote from: alabama on March 01, 2017, 06:00:06 PM
Sure has been. Has been good at times for my health. 10X better then just sitting around and watching TV. DanG shame I'm not finished, but when you are retired, one never has enough time to do all the things that need to be done. :D
Been wanting to get the sheetrock up, but my son and SIL has been tied up with their work. So I been working on my saw mill shed.
Post by: fishfighter on March 15, 2017, 07:41:49 AM
Well yesterday, I got out and did a little work on my new saw mill shed. Added a window and trimmed the lap siding. I will get back on this project in time.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1252.JPG?easyrotate_cache=1489576966)
After getting that done, I got the wife to help me hang a couple sheets of sheetrock in the camp. My home made lift worked great. ;D Going to try and hang a couple more today. Cold here, so yesterday I had the wood stove fired up and will do that again today. ;D
This is the kitchen area.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1253.JPG?easyrotate_cache=1489576923)
Post by: Magicman on March 15, 2017, 09:19:56 AM
It's good to see you making progress Paul.  Every step that you make is a step closer.
Post by: fishfighter on March 15, 2017, 06:24:46 PM
Thanks Lynn. Had the wife help me today or should I say watch me. She is like a hawk. She doesn't want me to fall off a ladder. :o :D  She did what she could do. Heck, she even clean up a bunch. :D The new med they put me on is doing some good. 8) As of from this past Saturday to this morning, I dumped 5 lbs of fluid which makes me feel like a million. Even though I take a lot of Lasix, this new med has stepped up a bunch. I think I had somewhat adjusted to it, but there is a little dry cough. That is not good. :( Other meds like this did the same and I had to stop using them. :(
Anyway, we hung some more sheetrock. Not breaking any speed records, but it's getting done. Both of my kids,(son and SIL) are working their butts off. I have one more wall in the living room area to do. Then the ceilings and other rooms. Going to try tomorrow to get some more done. ;D
Post by: Darrel on March 15, 2017, 07:03:45 PM
Fishfighter, your determination inspires me.  I know it can't be easy, but you just keep plugging away. I've had patients roll over and die when faced with much less. Glad you have someone to "watch over" you.
Post by: fishfighter on March 16, 2017, 06:51:02 AM
Thanks Darrel. I took on this project to help keep me going. I have always been very active before I came down with heart failure. DanG virus bug had attached my heart. My EF is below 20% were the left side just ain't doing anything. :( I still give it hell when I feel good. ;D I do have my "good" days. But, those "bad" days, I can't even get out the lounge chair. >:(
But anyway, I thank the Good Lord for every day he has gave me, good or bad.
Post by: sandsawmill14 on March 16, 2017, 07:27:30 AM
glad the new med is helping and your feeling better :) maybe the cough will go way :)
Post by: fishfighter on March 17, 2017, 07:05:07 AM
The wife and I finished hanging rock in the living room and kitchen yesterday. ;D
Going to have to rest today. Got to service the lawn mower so the wife can cut the yard today. :D Bought her a new Bad Boy ZT 60" mower last fall. Time for the first oil change. :D
Post by: fishfighter on March 17, 2017, 04:30:48 PM
So much for resting. There has been something driving nuts and I just had to tackle it now that things are drying up. DanG mill shed that I been working on had a big problem. One side had a drop about 3/4" center. The people I got this "free" building didn't know what they were doing. Spanning 14', using 2"x6" just wasn't going to cut it. No matter how high I jacked up that side center, it wouldn't let the ends drop down. >:( So, the more I checked things, I found out that they also used some 2x8's, but cut the ends to 2x6. >:(
So, to fix things, I had cut out the end floor joist and replaced it with two new 2x6. The plan worked ;D I do have a 6x6 running under the ends and center. All things are good now and I will start back doing the siding. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1257.JPG?easyrotate_cache=1489781786)
The siding I doing.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1246.JPG?easyrotate_cache=1488837420)
And a picture of my sheetrock lift in action. :D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1255.JPG?easyrotate_cache=1489781762)
Post by: Darrel on March 17, 2017, 11:09:52 PM
Yup, some days it's more work to stay in bed and rest then it is to just get up and go to work. Lookin good!
Title: Re: Started the build.
Post by: Magicman on March 18, 2017, 09:36:18 PM
Looking good Sir.
We have a couple of medical hiccups going on here but when we get them behind us we are planning a visit.   :)
Post by: fishfighter on March 19, 2017, 07:05:53 AM
I'm sending prays for y'all. God speed to a fast recover.
I did get a little work done on the shed yesterday, but had to stop. :( Maybe a little more today. Moving at a snails pace. :(
Post by: Bruno of NH on March 19, 2017, 04:31:41 PM
Good work Mr Fish
You are doing good :)
Post by: fishfighter on March 19, 2017, 05:37:13 PM
Why thanks Sir.
Got a little more done on the shed, but the heat ran me off. :( First day of Spring is what, tomorrow? Already to hot. :(
Post by: fishfighter on April 03, 2017, 04:38:42 AM
Saturday, I had My son, daughter and SIL over for a day of sheetrock floating. They did a great job. Now if only I can get them back for a sanding party. :D Small steps, but getting there. 8)
Post by: fishfighter on April 08, 2017, 05:08:52 AM
The last two days I been working on the back bedroom roof along with some wiring. I had done one side in the pass, but due to weather I been putting it off. With the good weather we been having, it was time for me to finish that roofing. It's in place, but I still need to trim it out. I will finish that today.
For some reason being kind of old and doing roofing just don't mix. ;D DanG knees and lower back is hurting. ;D
Tomorrow, I will be spraying the second coat of roofing kool seal paint. My knees are not up to it to do it today. :(
Post by: sandsawmill14 on April 08, 2017, 08:15:54 AM
fish sounds like your making good progress you will be finished in no time ;) smiley_thumbsup
Post by: fishfighter on April 08, 2017, 08:44:06 AM
I don't know about finishing this any time soon. Only been working on this for 2 years. :o When I built my house which is 4 br/2baths, from ground breaking to finished, I did it in 6 months. And yes, I did more then 90% of all the work and worked a full time 12 hour shift job at the same time. :o But back then, that was 17 years ago. :D
Post by: BigZ La on April 08, 2017, 10:52:30 PM
Back then you were young fish, now not so. Us old guys have to pace ourselves.  :D
Post by: fishfighter on April 09, 2017, 06:44:17 AM
For sure, but I still think that I can do what needs to be done. Well, things just didn't work out yesterday. Made one climb up on a ladder and had to call it a day. Must of got some bad food Friday night. Spent the day in the bathroom or bed. >:( A bit better this morning, but still kind of weak. :(
Post by: Magicman on April 09, 2017, 09:51:16 PM
It's good to see you plugging along ff, but take care of yourself.  Remember, we do not mix well with ladders.   :-\
Post by: fishfighter on April 10, 2017, 07:38:02 AM
Quote from: Magicman on April 09, 2017, 09:51:16 PM
For sure. :o How's that arm and shoulder?
Still didn't do any work on the camp yesterday. Was still dragging, but helped the wife with a little yard work.
Today, I got to hang around my heart monitor for a remote reading. Once that is done, I have to finish up that roof. Rain in the forecast , and tomorrow I have to go to New Orleans. Doctor appointments. :(
If I have a little extra time, I will go fell a few oak trees and drag the logs out. I'm in need of some heavy timbers for my saw shed.
Post by: fishfighter on April 12, 2017, 06:09:07 AM
I did finish up the roofing and did some rock sanding and applying a second coat of mud to the sheetrock Monday.
Yesterday's trip to New Orleans was somewhat ok. Doctor doubled up the new med and read my heart monitor report. Wasn't to happy on that. Showed I had 3 bad episodes in the last 3 months. He asked why I didn't go to the ER to be checked. :o Oh well.
Going to try and get out today and do some sawing. In need of some lumber for the mill shed. ;D Besides, the wife will be going into work today and she flat out told me NO ladders today. :D
Post by: Magicman on April 12, 2017, 01:53:51 PM
Smart Lady.   ;)
Post by: fishfighter on April 12, 2017, 02:48:19 PM
After being married 37 years to me, smart might not be the right statement. :D
Guess the old saying, "love is blind" is true. :D
Got out and sawed up some 4x4's and 6x6's. DanG, it got HOT quick this morning. The sun is telling me I need to get hopping on my mill shed quick. :o
Post by: fishfighter on May 11, 2017, 07:09:06 PM
Been a few weeks, but today I got back on the project hanging more sheetrock and sanding. Step by step, I hope to finish up this project by the end of the summer.
Post by: Magicman on May 11, 2017, 10:14:28 PM
It's good to see you making progress again.
Nothing happening here tomorrow....rain.
Post by: fishfighter on May 12, 2017, 06:04:52 AM
Rain coming here too. Going to do some more work on the camp inside today. Still waiting on replacement parts for my mill which should be here Monday.
Now the bad news. I have to head to New Orleans Monday. My heart monitor has been going off. They called yesterday evening and wanted me to go to the local ER. Told them I was ok, so they changed my appointment a couple days early. Learn one thing from the past. Never, ever do I want to go down there on a Thursday or Friday. If they put me in the hospital on those days, no matter what, they always keep me thru the weekend. Anyway, it might be that my battery is dying. Last check said less then a year. I'm paced 100% of the time and if the battery gets to low, it might not have the power to fire off the defibulator  if I need it. Since last Saturday, I been dragging somewhat. So, that is why I think the battery is getting low. :(
Post by: Magicman on May 12, 2017, 02:16:19 PM
Please keep us updated and my prayer is for a successful outcome.
Post by: grouch on May 12, 2017, 09:16:49 PM
fishfighter:
You know even a cordless weed whacker needs a recharge now and then. Don't want that little dog having to wake you up in the yard again.
Post by: fishfighter on May 13, 2017, 06:15:03 AM
Thanks guys, I'm still ticking. DanG battery suppose to last 10 years. Been having this thing in me just over 7 years. In all that time, it only fired off three times. Something I hope it never does again. :o Not a good feeling getting kicked in the chest by a mule. But, it could be worse. ;D
Going to go pick up a load of SYP logs today. Been putting that log trailer to work. Cost wise,  been burning about $10 in fuel per load of logs. So that is around $3 per log which avg size has been 16' long and the small ends around 20". 8)
Post by: sandsawmill14 on May 13, 2017, 06:44:43 AM
i knew pine was cheap but that is about the best/worst price i have heard of ( depending on which side your on ;D ) :D
hope everything goes well for you at the doc and will be praying for you :)
Post by: fishfighter on May 13, 2017, 06:49:46 AM
The logs are for free. Just helping a guy out getting them off his place. He had them felled a couple weeks ago. He didn't want to burn them.
Post by: grouch on May 13, 2017, 08:35:49 AM
Quote from: fishfighter on May 13, 2017, 06:15:03 AM
Maybe that's 10 years for folks who sit and click the tv remote or ride around in walmart carts. 7 years for somebody rearranging a swamp, sawing logs and building a cabin through mud, storms and muggy heat might just be a testament to good batteries.  ;)
Post by: fishfighter on May 13, 2017, 12:07:18 PM
Add in a new saw mill building. ;D
Back home with three nice SYP logs. Feller had a tractor there to pull them up to the road. Made it easy today. ;D Problem now, I'm unable to off load them. Don't want to cut up the road, that is soaking wet. :(
Post by: fishfighter on May 17, 2017, 03:49:36 PM
Just a update. Had to stay down in New Orleans for a couple days. >:( They adjusted meds, reset my CRT-D, well adjusted it and sure as heck, they replaced my heart monitor. Come to find out my blood pressure was dropping way to low. :o Guess it was just a oil change. This is Louisiana and we love good Cajun food, Something about hospital food just don't do it. >:(
I'm feeling a bit better and looking to get back at it. 8) Wanted to do something this afternoon, but the wife flat out said NO. :D Maybe tomorrow. 8) Got to wrap some beams in plastic for painting around them.
Post by: grouch on May 17, 2017, 04:16:15 PM
Good to hear you're rearin' to go again. Don't let those Cajun spices push you beyond good sense. :)
Post by: fishfighter on May 18, 2017, 04:28:20 PM
Us southern folks love good food. ;D
Got out and hung some more sheetrock with the dear wife helping me today. Even with a big shop fan, I was soaking wet before 9am. :o That took a lot out of me and had to shut it down at noon. :( Going to get at it tomorrow again.
Post by: fishfighter on May 20, 2017, 06:21:42 PM
Got very little done yesterday, but did a bunch done today. More rock hung and rapped all beams and post in plastic. Even have the windows covered. I'm looking to start spraying some wall/ceiling texture maybe tomorrow. Now that everything is covered in the living room and kitchen, the texture will go very fast. Then after that dries, I going to spray the first coat of primer. 8)
On a side note. this morning, I installed a 110V ac in the front bedroom. That is were I'm hanging and floating sheetrock. I could kick myself in the backside for not doing this three weeks ago. :D
Post by: fishfighter on May 22, 2017, 04:45:13 PM
Rain, rain and more rain. The only good thing about that, it has helped cool things down. So, I spent the morning installing insulation in the attic.
A few months back, I had came across a real good power buy on some R30. Problem, the batts are only 18"x48". My trusses are on 24" center. So I had to wait till I installed the ceiling before installing the insulation.
Started cutting the batts to fit using just a knife. That was a PITA. >:( So my back up plan.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1297.JPG?easyrotate_cache=1495484965)
After making that cut, I came back with the knife which made things a lot easy. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1299.JPG?easyrotate_cache=1495484993)
Good thing the roof pitch is 8/12 and was easy to install the insulation out to the eves. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1301.JPG?easyrotate_cache=1495485005)
I will be coming back to add more insulation in the future. I will be blowing in some.
Post by: Ljohnsaw on May 22, 2017, 04:59:02 PM
Quote from: fishfighter on May 22, 2017, 04:45:13 PM
There is a super easy and fast way to cut the batts - you need two 2x4s or 2x6s.  Lay one on the ground and place the center line of the cut you want to make over it.  This 2x4 (or 1x4) is to protect your knife tip (and possibly the floor).  Now lay another 2x4 (or a 2x6 if you have a wide foot) on top to use as a straight edge.  Step on it to compress the batt.  With a sharp utility knife, you should be able to make one pass and cut all the way through.  Note that you will NOT be able to run the blade next to the 2x4 (and you really don't want to).  Space it so the side of the knife handle runs along the wood.  It will slide easy and you can keep the blade perpendicular to the batt making a nice clean cut.  The boards should be long enough to stick out at both ends of the batt so you can line things up.
Post by: grouch on May 22, 2017, 05:34:57 PM
ljohnsaw's method is the way I've always done it. A piece of scrap OSB or plywood also works -- it or a 1x4 will let you put the blade right against the straight edge where you have the insulation compressed the most.
Dust mask? Eye protection?
Post by: fishfighter on May 22, 2017, 05:54:05 PM
That is how I started doing it. This insulation is 6+" thick and I couldn't compress it enough to make a clean cut. That is why I changed. ;D
Post by: jimdad07 on May 22, 2017, 05:58:29 PM
You're doing a good job, just watch your body, do what it tells you to do.
Post by: Ljohnsaw on May 22, 2017, 07:02:20 PM
Quote from: fishfighter on May 22, 2017, 05:54:05 PM
Either you need to eat more or drink more beer (or both!)  :D
Post by: grouch on May 22, 2017, 08:17:52 PM
That's when you use a 2x10 underneath and a couple of 2x6s on top. Kneel on the 2x6s but don't get carried away with that utility knife -- you wanna stop cutting before you get to the crotch.  ;D
Post by: loganworks2 on May 22, 2017, 09:14:10 PM
Instead if a utility knife I use a insulation knife made by Milwaukee. The blade is about 8" long and works better than a utility knife ever did. To keep it sharp give it a light touch with a file. Cuts like a hot knife through butter.
Post by: grouch on May 22, 2017, 09:31:01 PM
Quote from: loganworks2 on May 22, 2017, 09:14:10 PM
I didn't know such a thing existed. Thanks!
Post by: ChugiakTinkerer on May 23, 2017, 12:23:49 PM
Me either.  Looks like a useful tool that will want awful hard to jump into the tackle box.
Is it down to personal preference for smooth (https://www.milwaukeetool.com/hand-tools/utility-knives/48-22-1921) or serrated (https://www.milwaukeetool.com/hand-tools/utility-knives/48-22-1922)?
Post by: fishfighter on May 23, 2017, 07:54:32 PM
Nice tip, but I hope I don't have to deal with anymore insulation. :D Still have the itch. :(
Today was a rest day. Just one of those nap all day days. >:( DanG more rain coming in tonight. Was hopping to get to do some sawing, but things are way to wet. Rain gauge so far thru the weekend has it at 5.2". :o
Post by: grouch on May 23, 2017, 09:28:20 PM
Quote from: fishfighter on May 23, 2017, 07:54:32 PM
After more years of that itch than I'm willing to admit to, I finally figured out that those full body disposable painter's suits (paper? tyvek?) were worth the sweat. The ones with the little booties and the hood do the job.
Post by: fishfighter on May 24, 2017, 03:31:48 AM
When I go to blow in more insulation, I will be wearing one.
Way back in the day I used to build some boats. Grinded way to many times on fiberglass which is 10x worse then insulation. :o Applying baby powder on exposed body parts filling your pours does help some.
Post by: fishfighter on May 27, 2017, 07:11:50 AM
Been hanging sheetrock and floating. Hoping the kids will show up this weekend for a sanding party. ;D DanG humidity has been so high, it has been taking two days for the mud to set. :o Been running fans to help dry things.
On a side note, I have to go back in doing some of the plumbing. DanG PEX tubing is a PITA. >:( Going to get that done the first thing this morning so I can finish hanging sheetrock. Installing headers to feed all water lines, I was going to install them in the attic, but I changed my mine. Oh, talking about headers, I had to build them. Just couldn't find what I needed. I will get a picture of them later today.
Also, I am installing the water heater in the attic. It is already up there, but not in it's final resting place due to it is very close to were all the wiring goes into the breaker panel. It will be moved into place today.
Post by: Magicman on May 27, 2017, 07:11:53 PM
All of the water lines in our home are in the attic and there is no worry or concern about freezing.  Freezing, what is that?   :D
Post by: fishfighter on May 27, 2017, 09:33:13 PM
Lynn, you are right. :D Well, after fighting that DANG PEX tubing, I had enough. >:( If I ever do another house, I will use copper. One can never find what one needs at any one place to deal with PEX tubing around these parts. >:( The only good thing about it, if by chance I get a heavy freeze, water expands 9 times the size and PEX tubing suppose to be able to expand 15 times it's size. Being this house is off the ground and water lines ran under and up in the attic, that is why I went with the PEX. Yep, could put my foot to were the sun don't shine on my backside. ;D
Anyway, I had put a good days work in today, I'm beat. Got the plumbing straight and hung a bit more sheetrock. The kids are suppose to come tomorrow for floating /sanding party. :D Yes, the wife will feed them. :D
On a side note. I picked up a very old 6" jointer late this afternoon. Paid $65 for it. It will need to be clean and oiled up, but I been wanting one real bad. Going to need it, that is what I told my dear wife for future projects. ;D
Post by: Magicman on May 27, 2017, 10:06:31 PM
I had good luck with PEX at the Cabin.  The bad thing with copper is that the second time it freezes = wet.
I have PVC/CPVC in the attic here at home.  Bats between the joist, pipes, and then ~12" of blown fiberglass on top.  It has never frozen.
Post by: Briankinley2004 on May 27, 2017, 11:40:37 PM
Pex is worth the savings on a large new construction project where there is a lot of pipe and fittings are few. Also saves the plumber on the rough in for a slab. Otherwise it is a PITA. I used it on my house addition and I could have sweated the copper faster than crimping all those fiftings. I did a shower with body spray which means a loop. Having to add blocking for that flimsy mess is time consuming too. Guess I'm old school but most of these new cats can't solder or pack lead and jute rope in a cast iron hub. I went ahead and insulated all the pex in my attic even though the water heater up there will probably rot and bust before something freezes. Pex is easier to fish with though and harder to crimp   No bending springs needed for the most part
Post by: fishfighter on May 29, 2017, 03:56:52 PM
Yesterday my son and SIL showed up at 7am. Floating and a bit of sanding was the plan of the day. Front bedroom is all taped up.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1326.JPG?easyrotate_cache=1496086980)
Then floating an are just outside the bedrooms.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1328.JPG?easyrotate_cache=1496086522)
Due to the bad weather, we called it a day at noon time.
Saturday afternoon, I bought an old 6" jointer. Paid $65. Looked in rough shape, but just new a little TC, it would be a power buy.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1304.JPG?easyrotate_cache=1496086586)
So, today I pulled it completely apart. Clean, sand and some new paint.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1323.JPG?easyrotate_cache=1496086616)
And all back together.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1330.JPG?easyrotate_cache=1496086644)
Bearing are tight and spend freely. Going to pull the motor tomorrow and service it, then some fresh paint. Motor did run fine before hand. I'm going to order new blades tomorrow. I like power tools and power buys. ;D
Post by: fishfighter on May 31, 2017, 12:16:47 PM
Got a second coat of mud done in the front bedroom yesterday. Ran a fan all night and was hoping the mud would set overnight. Still was wet in spots this morning. :( DanG rain. >:(  I was able to sand some, but I will have to wait till tomorrow to float a third coat. I will be shooting a orange peel coating in the living/kitchen dinning area tomorrow. All that area is ready, have all the beams, doors and windows all taped/covered. I just hope my air compressor is strong enough. :o
Post by: fishfighter on June 03, 2017, 08:52:25 PM
After 3 days of laying low due to my back, I got out today. Was going stair crazy. :o Had a change order. Something I over looked in the front bedroom. :embarassed:
The closet opening was 5'. Wrong there. :embarassed: I will be building barn doors for the closets that will slide on tracks. Problem was, the 5' opening would not give me enough room to slide a door over. So, I enclosed the opening to 36". That closet is only 8' wide and by doing that, it didn't create a problem. ;D Good thing I am only on the second mud coat for a change out. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1331.JPG?easyrotate_cache=1496535823)
First mud coat.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1332.JPG?easyrotate_cache=1496535857)
When you forget things, you just want to kick yourself. Even more so when it comes to plumbing and walls are closed up. >:( I been holding out closing up some walls due to not pressuring up the water system. My confidence is not that high using PEX. I never used it before. Well, another change order. ::) I forgot to run a cold water line for a frig ice maker. :embarassed: Well, that is an outside wall. Good thing about that, I also forgot to place in a outside line on that side of the building. I will have to cut into the wall in two places, drill and repair. Just hope I have enough room for the drilling that I don't have to drill thru a beam. :(
Anyway, I can't sand drywall( back problems), but I sure as hell can make some holes in it. Picked up what I needed to cut everything in this afternoon and just hope the rain will give me enough time to cut everything in tomorrow.
On a side note*
This side of the build has 8'8" ceilings. Yep, kind of screwed up there when I did the other side of the building somewhat. That is why you see two tape lines on the walls. Hey, really not that big of a problem due to I sawed up the lumber and the cost for the drywall was very little. Besides that, extra high ceiling are very good down here in the south.
My house has 9',12',15' and 17' ceilings. Helps so much when it comes to cooling. We run AC as people up north run heat more months out the year. Heck, been running the ac since Feb on and off, but more on. :(
Post by: Magicman on June 03, 2017, 10:32:15 PM
If it keeps on raining you are gonna have to call Noah, and have him help you build a houseboat!!!   ;D
Post by: fishfighter on June 04, 2017, 08:53:28 AM
It already started this morning. :( Hope you not getting all this rain.
Post by: fishfighter on June 04, 2017, 06:50:46 PM
Got some plumbing done. Fixing a couple problems I forgot. :o Even with all kinds of rain, I had to crawl under and yes a wet behind. >:( First was to get that DanG ice maker line in. Kind of went easy. ;D Had to cut a hole to fit the box and one at the floor to drill thru the wall base plate.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1333.JPG?easyrotate_cache=1496615089)
Sorry about the picture. :( Once I drilled thru, things fell into place easy.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1334.JPG?easyrotate_cache=1496615120)
Of course the bottom of the valve stuck out way below the box, so I did have to cut for that. I will leave that open till I pressure up the system. That will give me a chance to check if there is a leak there.
From there, I moved into the bathroom were the washer/dryer will be installed and set the box for that. Now I can finish the closet inside to the front bedroom.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1335.JPG?easyrotate_cache=1496615151)
Then set the feed for the John. Didn't need a picture there. ;D
I have to get under the building and tie a few lines in. :( Not looking to do that, but it has to be done. Just maybe by next Friday if things dry up, I will do the crawl.
Once I did that, I did some sanding in the front bedroom. Got about half way, got over heated and had to stop. :( Tomorrow is another day. ;D
Post by: Magicman on June 04, 2017, 09:03:59 PM
Did you put your icemaker drain in?  I couldn't tell by the picture.
Post by: fishfighter on June 04, 2017, 09:28:26 PM
Don't have one. Heck, I don't have one in my house. Never needed one or just lucky. :D
Post by: Magicman on June 04, 2017, 09:35:27 PM
OK, ours goes through a cleaning/flushing cycle and has a drain.  Also ice is constantly melting in the bin which also drains.
Yours must make the half moon shaped ice and drops into a freezer bin?
Post by: fishfighter on June 05, 2017, 07:58:27 AM
Sure does. Got to hate those half moon cubes trying to get that last sip of Jim Beam. :D
Post by: Magicman on June 05, 2017, 08:37:37 AM
Those dreaded half moons are why we went with one that makes squares, but it was much more expensive.  :o   :-\   :-X
Post by: jimdad07 on June 05, 2017, 10:34:37 AM
Quote from: Magicman on May 27, 2017, 07:11:53 PM
You southern guys are just plain spoiled.
Post by: fishfighter on June 05, 2017, 10:50:48 AM
Heck, in the summer months we get instant hot water running water lines in the attic. :o
Laying low today. Kind of pushed myself the last couple days. DanG back acting up again. >:( Besides, DanG raining here.
Post by: BigZ La on June 05, 2017, 11:43:06 PM
Fish, the wife and I made a trip around the river yesterday. I've got to get your number as I never know in advance when we go.  :D
Post by: fishfighter on June 06, 2017, 03:48:23 AM
Quote from: BigZ La on June 05, 2017, 11:43:06 PM
You have PM. Stop in next time you are in my area. With all this rain, bring your rubber boots. :D
Post by: fishfighter on June 07, 2017, 04:59:54 PM
After two days rest and just watching the rain, got a break today with sun shine. ;D Threw on my rubber boots and headed to the camp. Thank God I kept a pair of old shoes back there. :D
Got to work sanding. :(  That has to be worse then painting. >:( Anyway, I have all the walls done in the front bedroom. Still have to sand out the ceiling, but my arms just couldn't do anymore. :( Floating, sanding sheetrock is for sure for young people to do. ;D So, got a call in to my son and SIL to see if one or both can do that for me. If not, that will take me a couple days. :(
After finishing out the walls, I took a leave blower and blew off the walls. Had my big 36" box fan blowing out a window. Dust for days. :D
Once the dust settled down, it was time to shoot some texture in the living/kitchen area. ;D Took a new clean 5 gallon bucket, added a box of mud and added around 1 1/4 gallons of water. With a mixer blade on the drill, I mixed it. Added water as needed to get a pancake mix.
I bought a cheap HF hopper texture gun a week or so ago. Paid $22 out the door with a 25% discount. I was hopping my cheap HF air compressor(5 gal) could do the job. Well, today I was going to find out.
Have covered all beams with plastic along with windows and had to cover doors. Loaded up the gun and come to find out, my air hose had a couple leaks. :( A 5 min fix and I started shooting. After about an hour, I was finished. ;D Just enough mud mixture. ;D I have to say, the texture gun and my air compressor did the job. 8)
On a side note. When shooting mud on walls and ceiling, DON:T forget to wear a hat. :D I was covered.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1337.JPG?easyrotate_cache=1496867291)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1338.JPG?easyrotate_cache=1496867306)
A hot shower and now a few beers. ;D
Post by: grouch on June 07, 2017, 07:41:09 PM
I don't want to hurt your feelings, but them ain't sexy knees.
Post by: Darrel on June 07, 2017, 07:48:13 PM
 :D :D :D
Post by: fishfighter on June 07, 2017, 08:28:01 PM
Hey now, for 60 years old, I think they look fine. :D
Post by: Darrel on June 07, 2017, 09:17:03 PM
Quote from: fishfighter on June 07, 2017, 08:28:01 PM
That very well may be, but fine is not the same thing as sexy! ;D
Post by: Darrel on June 07, 2017, 09:18:52 PM
:D
Post by: fishfighter on June 08, 2017, 06:13:09 PM
Spent the day under the building finishing up all plumbing. Not to easy, but everything is done. ;D I have all the lines ran up in the attic. Changed my mine of installing the headers in the walls. Just wasn't enough room. :(
Main line coming in feeding the head and going up in the attic.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1343.JPG?easyrotate_cache=1496959344)
Vanity water and drain/vent lines. Had to off set the vent line.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1341.JPG?easyrotate_cache=1496959278)
Washer water and drain/vent lines. Also water lines that feed the tub and kitchen, ice maker and a outside water line all the way on the other side of the house. Was one heck of a job running 50' of PEX tubing for each kitchen line and 30' from the tub lines. I tried to not put anymore connections then I needed. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1339.JPG?easyrotate_cache=1496959211)
Got hot quick today. I will install all lines on the headers tomorrow, then start throwing some primer paint in the living/kitchen area tomorrow.
Post by: Magicman on June 08, 2017, 09:43:08 PM
You need a second opinion 'cause they is ugly!    ;D
Post by: fishfighter on June 10, 2017, 01:17:47 PM
Got some more work done yesterday on the plumbing. Got the headers all hooked up.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1346.JPG?easyrotate_cache=1497113812)
After that, it was time to pressure up the system.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1347.JPG?easyrotate_cache=1497113872)
Just knew I hate this DANG PEX. >:( After about two hours, I lost a couple pounds of air. >:( I went back over each connection with soapy water three times and sure as hell, I can't find the leak. :( I am thinking that the leak is coming from the tub faucet. Kind of moving slow today, but I will get back on that leak tomorrow. My game plan is to charge up the system with water. Problem, I don't have the main water line ran yet. So, with a 30 gallon tank, a 12V water pump that will get up to 40 psi, I will charge it. Then with such a small leak, I will go back to each connection with butt wipe paper. :D
Post by: Ljohnsaw on June 10, 2017, 04:03:01 PM
Bummer.  Looking at your manifolds, I thought the idea with PEX was to put a valve on each line at the manifold rather than at the the delivery point.  Then you can isolate the runs which would help in locating leaks.
Post by: fishfighter on June 10, 2017, 06:03:34 PM
Yes, you are right about using a valve that way, but being such a small building and being that the headers are in the attic, I decided to install valves at each location. There is nothing like going up in a attic in the summer months around here. That space can hit a easy 120F. :o
Post by: Ljohnsaw on June 10, 2017, 07:00:55 PM
Quote from: fishfighter on June 10, 2017, 06:03:34 PM
I get that!  My attic used to get real hot on just a normal sunny day.  I installed that silver Mylar "fabric" on the bottom of my rafters (insulation is between and on the ceiling joists).  It blocks a TON of heat.  I have a tile roof so no issue with the heat build up.  Might be an issue with comp roof, however.  One day when I was installing it, it was HOT.  As I held up the Mylar, it felt like I turned on the A/C it was such a dramatic change.
Post by: fishfighter on June 12, 2017, 07:06:59 AM
After hooking up a water pump and having the system with 40 PSI all day, still can't find the DanG leak. >:( So I left it all hooked up over night. Maybe I will find it today.
Post by: Magicman on June 12, 2017, 01:39:52 PM
You may not have a "wet" leak or at least one that you will ever fine.
Post by: Ljohnsaw on June 12, 2017, 02:16:47 PM
I'm thinking the leak is high up - all the air has not escaped yet.  Do you have a valve between the pump and the plumbing that you can close?  Maybe the water pressure is leaking back through the pump?
Post by: fishfighter on June 12, 2017, 04:05:29 PM
I do have a valve and gauge. It's been holding 38psi all day. So maybe it fixed itself. :-\ Going to leave the pressure overnight and see what is what. The hot water side is fine. Got that charged up to 30 psi and been holding steady.
DanG rain has been coming down two days in the row. There is just no place for it to go. Another week long run for rain. :( At least the wife got a chance to mow the yard Saturday. ;D
Post by: fishfighter on June 13, 2017, 01:20:01 PM
Well, I guess the leak did fix itself. Still sitting with 38psi. Just maybe I hit the center with the tub faucet. >:( DanG faucet is one that center is off and one turns the knob to a temp one wants left or right.
Got some painting done this morning. Primed up the living/kitchen area. Took a bit over 3 gallons and about 4 hours. Should of just sprayed that sucker which would of took about 30 mins. :D Oh well, it's got a good coat.
Oh boy, more rain now. >:(
Post by: Briankinley2004 on June 13, 2017, 08:14:32 PM
Pump it up to 100 psi or so and they will show up
Post by: fishfighter on June 14, 2017, 08:22:45 AM
Here, the water meters regulate the pressure down to 40psi. Reason I am testing at 38 psi. I am going to raise the pressure up to 50 today. Problem there, I'm going to try and adjust the water pump pressure up to that and I don't know if it can be done. As of yesterday afternoon, I still haven't lost any pressure or water. So I think I was just chasing my tail to start with due to the tub facet. :(
Going to start hanging sheetrock in the bathroom today. ;D
Post by: Briankinley2004 on June 14, 2017, 10:15:14 PM
Use air for the 100 test. 40 is ok wet but make sure you bleed all the air off. I pump my copper up to 150 psi using air for water and nitrogen on HVAC work. My grandad was a plumber and I helped him growing up. I remember using a bicycle pump to add pressure to the lines in the days before air compressors.
Post by: fishfighter on June 15, 2017, 06:24:53 AM
I was able to adjust the pump up to 55 psi. Have let it sit like that all day and no leaks. ;D So I am calling it good. Like I said, it had to be the tub facet that was leaking.
Didn't hang any rock, but I did cut a hole in the floor and set up a dryer vent line. Almost forgot to do that. :o
Going to try and do a little work today, but the heat is getting to the point of unreal by 9am. :(
Post by: fishfighter on June 17, 2017, 05:52:28 PM
Got some sheetrock hung in the bathroom and installed a second AC window unit in the house. Just been way to hot to go pass 9am doing anything. :( The second ac is a 240V, so I had to wire in on the temp power supply a 30amp feed disconnect and made up a extension cord for it. Hey, the ac was free and I had the #6 wire and disconnect already along with everything I needed to do it. Why not? ;D
Pending weather next week, I am hoping to get back sawing up some lumber that I need and get back building my sawmill shack. Sometimes one just needs a break and do something else. ;D
Post by: fishfighter on June 20, 2017, 01:41:02 PM
With bad weather coming, I took some time today to plane out some oak boards for window casings. I put my $65 jointer to work. ;D Did a great job. Once I got one side to were I wanted, I then pasted the boards thru my planner. Then back on the jointer for edging.
Before cleaning up.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1351.JPG?easyrotate_cache=1497979844)
After
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1350.JPG?easyrotate_cache=1497979894)
Those boards are 78" long. Did 12 of them and 6 that were 40".
On a side note. Some of my boards before cleaning them up had some stains like this one.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1352.JPG?easyrotate_cache=1497980628)
These boards were stacked and stickered to air dry about 8 months ago. Good thing, after they were clean, no stains. ;D
Post by: fishfighter on June 26, 2017, 02:35:23 PM
Put my joiner and planner back to work today. These boards will be used to build a barn door for the bathroom that will run on tracks.
Some 2x6 water oak and 1x6 water oak.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1353.JPG?easyrotate_cache=1498501189)
Cut things to size and did the job. Of course ambrosia beetles got into this wood too. But hey, I like it. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1355.JPG?easyrotate_cache=1498501238)
All precut and planned out. Got to hot and had to call it a day. Hope to have this door done tomorrow.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1357.JPG?easyrotate_cache=1498501274)
Post by: Darrel on June 26, 2017, 05:45:40 PM
That's some purdy wood, going to make a very purdy door.
Post by: fishfighter on June 26, 2017, 05:56:40 PM
Got three more to do. A lot of work and heavy. This door, I planned down the 2x6's to a true 1 3/8 thick. The center boards were planned down to 1/2". Those will be nickel gapped like I built one for the front bedroom door.
Post by: fishfighter on June 27, 2017, 07:46:12 PM
That door is 98% finished. Just need to trim it out. I got to invest in a couple more pipe clamps. :( Just taken way to much time waiting for glue to set. >:(
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1362.JPG?easyrotate_cache=1498606849)
Post by: Darrel on June 28, 2017, 12:23:19 AM
I like it and showed it to my wife. She says Nice!
Post by: fishfighter on June 28, 2017, 07:02:44 AM
Hey, thanks. It's a lot of work, but I love the way it came out. One thing, these doors are very heavy. Easy 125 lbs. :o Being that this one will be running on a track system, I will be hand forging the hardware and tracking for it. Got a bunch of left over firewood that I need to burn off. That will knock out two birds with one stone. ;D
Post by: grouch on June 28, 2017, 07:43:28 PM
So you have the panel boards floating in a 1/2 inch plus a "nickel gap" groove?
Post by: fishfighter on June 28, 2017, 08:43:06 PM
Yes, but I did set them with a nickel, glued and then nailed them in place with 18ga air gun nails. You can't see nails.
To get the grove, I used a dado blade on a tablesaw set at 1/2" with a depth of half. Also the framing boards, I used the dado blade to cut the slot that the center boards set into.
Another thing or two. When I did the finishing on the center boards, I had cut the lengths from the same board of one at 26", then a 40". After that, on the end cut, I numbered them in pairs. That way I kept the boards with the same wood grain to match top and bottom.
Also what I did was set the wood grain "cup" swapped to were one is on one side, the next board was on the other side. This helps keeping the boards locked in and straight.
Today, the wife and I hung the last of the sheetrock in the bathroom. Wasn't easy doing the ceiling. The wife is 5' nothing. :D Tomorrow I will try to start floating it out.
Post by: Bruno of NH on June 29, 2017, 07:55:47 AM
door looks great
Post by: GRANITEstateMP on June 29, 2017, 08:56:39 AM
Really like the door fishfighter!  Heck, I like the whole project (not the heat, don't like that at ALL!)
Post by: fishfighter on June 29, 2017, 09:05:08 AM
Thanks guys. Was planning on some work today, but it turn out to one of those days I have to just chill and rest. Past a bad night. :( Besides that, it's raining cats and dogs. Just when things were drying out. >:(
Post by: fishfighter on July 07, 2017, 01:43:04 PM
Kind of been under the weather the pass week+, but started feeling a bit better yesterday. So, I took it easy and started building wheel sets for the bathroom door. I priced a complete set with tracks. No way this old boy would pay $149 + taxes. :o
Well, this is how I made a wheel set using 1/4"x2 1/2" steel plate.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1379.JPG?easyrotate_cache=1499447922)
The wheels came from casters that is rated to 200lbs.That cost was $3 each. Bought some nylon bushing for spacers. That was $1.00. Bought a 1/4"x36" steel rod. Cost $3.00. The steel cost me $2.00.
Total cost, about $10 for a pair. ;D
Today, I built the track. Made out of 3/16"x 2" angle and a piece of 1/16"x1" flat bar. Total cost for the steel was $15.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1376.JPG?easyrotate_cache=1499447996)
Track is 72" long.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1375.JPG?easyrotate_cache=1499447964)
Wheels on the track.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1378.JPG?easyrotate_cache=1499447885)
Done sanded everything and threw on the first coat of paint.
Now, as to why I used the 2"x2" angle. That will off set the door away from the wall and give enough space for my trim.
Best part about this, built the complete tracking system for $25. A lot stronger then what is sold for $150. ;D
Post by: Darrel on July 07, 2017, 04:14:55 PM
Saved $125 and had some fun too!  Couldn't beat that with a stick!
Post by: grouch on July 07, 2017, 11:38:10 PM
But, but, but... Think of the children! Your contraption won't wear out and create jobs for robots to make more self-destructing tracks! You're ruining the industry.
Post by: fishfighter on July 08, 2017, 07:13:20 AM
Well, with all the taxes I pay, I really don't feel to bad. ;D
Post by: fishfighter on July 10, 2017, 02:30:35 PM
Well, the track system and door are hung along with the door jam trim. Rolls real nice, smooth and easy. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1385.JPG?easyrotate_cache=1499711082)
Good look how it matches out. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1386.JPG?easyrotate_cache=1499711127)
Post by: Magicman on July 11, 2017, 06:33:22 AM
That looks very nice Paul.  Is it a pocket door or exposed on the other side?
Post by: fishfighter on July 11, 2017, 07:17:32 AM
Exposed on the other side. It slides into a area were there will be a stackable washer/dryer in a cove. I will get a picture of the other side. I do have to take everything back down. Still haven't threw mud up in the bathroom. Also, I need to cut the length of the track. I knew I was going to have to do that, just wanted to make sure I had enough. ;D
Was super HOT yesterday. Planed out a lot of oak boards for trimming for windows. I am still wanting to use live edge base boards and trimming around everything. I sawed a bunch about 7 months ago that has been stacked and stickered. I am going to pull some today and resaw, plane and past the edges on the joiner. I will then see what is what.
On a side note. Weather wise. That DanG invest TD4 that is hanging way out east. They are calling it for it to come in the gulf and hit Louisiana. No real winds, but a big rain maker. :( Heads up Lynn.
Also, I feel in love with my joiner. Working with rough sawed lumber, I just don't see how one can do without one. ;D Makes things so much easy. ;D
Post by: grouch on July 11, 2017, 07:46:50 AM
I *like* that door.
It's just in the wrong location. You could greatly improve its artistic dash, structural integrity, and architectural trendinosity by moving it a wee bit nor'eastward. Say about 800 miles?
Post by: fishfighter on July 11, 2017, 07:54:48 AM
 :D  Now you are sounding like my wife. The more she sees how things are going, the more she is hinting of remodeling our house. Just ain't happening. ;D
Post by: ChugiakTinkerer on July 11, 2017, 12:48:40 PM
I'm feeling some powerful door envy myself.  I really enjoy reading and seeing the progress you've made.  Quite the testament to fortitude and ingenuity.
I still owe you the Kasco blade I promised.  I haven't forgotten.  Well, in truth I forget every day, but then remember when I'm reading your posts.   :P
Post by: grouch on July 11, 2017, 04:09:46 PM
Quote from: ChugiakTinkerer on July 11, 2017, 12:48:40 PM
[snip]
Forget the blade; send a truckload of igloos! Make sure they pass by me on the way to Loozhyanna. For inspection, only, of course.
Post by: fishfighter on July 11, 2017, 05:14:32 PM
When you get a chance. Really haven't been sawing anything lately. :( DanG shame I been walking right by it 3-4 times a day and I hear it calling my name. :D
This is pictures from inside the bathroom.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1388.JPG?easyrotate_cache=1499805586)
Door open into the washer/dryer cove.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1387.JPG?easyrotate_cache=1499805553)
Today I trimmed out the other window jam in the livingroom. After that, raided my stock pile of live edge oak boards and haul them up to the house. Sawed one board that was live edge just on one side. All of my live edge stock is 4/4. After checking the moisture level which was 15%, I felt good to use it. Debarking in a couple spots was a bit tricky. :( Then I got a call to go do blood work. I'm still not up to par. :(
Anyway, after sawed more then what size I needed, I went to plane it out. DanG planner didn't want to run. :o Dangit. After checking switches, a rock hit me in the head. Check the brushes. Pulled and clean and back together. Bad boy fired up. ;D
Planned that one board out down to 7/8" which I really want 3/4", but rain was coming. Could hear the thunder. :(
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1390.JPG?easyrotate_cache=1499805623)
Same board as door trim.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1391.JPG?easyrotate_cache=1499805654)
If I go that way, I would saw the board down to 3 1/2" wide.
Now using live edge as a topping on wainscoting with a piece of 3/4"x 2" oak.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1392.JPG?easyrotate_cache=1499805670)
Another.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1393.JPG?easyrotate_cache=1499805694)
Over all, I really didn't like it around the door, but I loved it on the wainscoting. Still going to plane out a few more and tack them up just to see and then go from there.
Post by: Darrel on July 11, 2017, 10:57:53 PM
I like it but not my wife. She likes the bathroom door but not the live edge.
"No live edge in my house!" Says she.  I'll be building it for her so the live edge will be relegated to the outside of the house. Even that sounds risky. :D
Post by: fishfighter on July 12, 2017, 06:20:24 AM
Quote from: Darrel on July 11, 2017, 10:57:53 PM
Heck, at our age, you should know to always keep the boss happy. ;D If you need help as to how I built the door, let me know. I can take pictures step by step.
Post by: fishfighter on July 12, 2017, 04:02:20 PM
Got out this morning and plane my butt off till after 1pm. Just way to HOT even with a fan on. Planed out a easy couple hundred BF. Just a start for cabinets. I will need a lot more. Didn't take any pictures, but haul off around 4 55gal drums of shavings. That stuff burns off very fast. ;D
Post by: fishfighter on July 17, 2017, 10:22:58 AM
Got a good start on the kitchen island. It's size is 33 1/2" x 72". Well the slab top is that size. The island is 24"x68" with arms to reach out the over hang of the slab for support. Got this done Saturday.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1401.JPG?easyrotate_cache=1500300394)
Yesterday, I started the front. First was to grab some rough lumber. These boards are from my pile of first cut lumber when I first got my sawmill. ;D
Had to rip some boards and saw up my cut list.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1396.JPG?easyrotate_cache=1500299885)
Once all sawed up, I past them all thru my planner.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1398.JPG?easyrotate_cache=1500299957)
From there, broke out my hand joiner. Sawed everything to size and glued it all together.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1400.JPG?easyrotate_cache=1500299994)
I hope to get it finish some time this week.
Post by: fishfighter on July 21, 2017, 06:30:23 AM
Update on the island. Just about have it finish. It has been so hot that it has took it's toll on me. :o But overall, I am very happy with this project. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1402.JPG?easyrotate_cache=1500596606)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1404.JPG?easyrotate_cache=1500596622)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1406.JPG?easyrotate_cache=1500596645)
Got to order some hinges for it and enough for the rest of the cabinets. Also I have to pick up some caster wheels for the island so I can move the island back away from the wood stove in the winter months.
All the rest of the cabinets thru out the house will be built just like this too!
On a side note. I will forgo the live edge on all the trim and just trim it out with finish boards.
Post by: grouch on July 21, 2017, 03:26:30 PM
That's looking really good!
Did you say those air dried for 2 years?
Don't know what kind of top you're going to put on it, but please knock the sharp edges off. My wife slipped one morning and hit her head on the corner of a (bought) bedpost. Scared the crap out of me. I took a spokeshave to that idiotic thing.
(https://forestryforum.com/gallery/albums/userpics/38564/cut-4897.jpg?easyrotate_cache=1500664944)
(That was my attempt to close it up until we could get to the doc).
Post by: fishfighter on July 21, 2017, 08:18:14 PM
Ouch.
Yes, air dried over two years. Moisture meter has it at 10%. The top will be granite. The slab is 3cm thick and is 38"x 72". Bought enough for the complete kitchen counter tops for $125 last fall. A lot of people were remodeling their homes after a big flood.  ;D
Post by: fishfighter on July 25, 2017, 07:15:38 AM
I did finish up that island cabinet. Took my wife, daughter, son and I to load it in my truck and to install it in the camp. One heavy sucker. :o
I did forgo the caster wheels. I just couldn't find any that would fit under and be able to carry the weight. A light went off when I was shopping for the wheels. Saw some of those Teflon pads that one can put under anything to slide things on a floor. Bingo. ;D Added some blocking at the corners and just nailed a pad to each corner. 8) One can not see them and only lifts the island up about 1/8" off the floor.
Kind of been under the weather again. DanG heat is very bad. Got to the point of having very bad legs cramps every night. Them things HURT.
Post by: Darrel on July 25, 2017, 10:42:36 AM
Quote from: fishfighter on July 25, 2017, 07:15:38 AM
When you get leg cramps, try eating a dill pickle.  If you're like most people, you'll be amazed at how well and how fast it works.
Post by: fishfighter on July 25, 2017, 02:17:05 PM
Did that along with drinking the juice, even drinking vinegar. Little to no help. Blood work all shows good too. No lack of potassium.
Got out a little this morning doing a inventory on oak lumber. Getting a bit low. :o Now did my saw list for the rest of the kitchen cabinets. Just maybe I can start on that tomorrow. That is a lot of wood planning I am looking at. :o
Post by: Magicman on July 26, 2017, 09:12:34 AM
Looks like you have been sorta busy while I have not.  Nice kitchen island.   ;D
Post by: fishfighter on July 26, 2017, 03:17:33 PM
Thanks Lynn. I'm backing off this so I can get a roof over my sawmill shack. This DanG heat is just unreal. With the rain( which now helps the heat) I need a roof. ;D
sawed up my first log in over three months today. That was real work. :o
Post by: fishfighter on January 14, 2018, 07:30:54 AM
After 5+ months, I had not did anything on this build due to life changing events. It is still very hard for me to even go to this house. But. I started back working on it and hope to try to finish it.
So I been building the kitchen cabinets.
Built the upper first.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1645.JPG?easyrotate_cache=1515238535)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1643.JPG?easyrotate_cache=1515238508)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1636.JPG?easyrotate_cache=1513974628)
And I have the bottom cabinets just about done. Only have the sink base cabinet picture, but there are two more That I had built.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1659.JPG?easyrotate_cache=1515931664)
One bad thing, well two bad things I had to fix was moving some plug outs. They were off about 8". :( No real biggie, but just a little extra work. One of them was for the stove which will be electric and the wire is 10/4 ga. That was a bit tricky. ;D
Forgot I had these.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1663.JPG?easyrotate_cache=1515932435)
Of course it has been extra cold here as everybody else this winter. I do have a ac/heating window unit in the front bedroom, but not big enough for everything. I do have to run it just for my air compressor. That sucker was freezing up. :o
But working in the kitchen/living room, I been feeding this sucker. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1662.JPG?easyrotate_cache=1515932871)
Post by: Magicman on January 14, 2018, 10:31:05 PM
It's good to see you back on this project Paul.   :)
Post by: Darrel on January 14, 2018, 11:10:17 PM
Fishfighter, the guy that keeps on keepin on.  That's a quality to be admired!
Post by: fishfighter on January 15, 2018, 08:21:51 AM
Thanks guys. It is real hard doing this. My wife has a lot to do with me going back to finish.
I have a doctors appointment this morning in New Orleans today. My blood work from last Friday wasn't all that good. :(  Besides that, It's been very hard for me to just to catch my breath after a short walk.
Anyway, I did finish that last base cabinet yesterday. Got a little lite sanding on everything and then varnishing it all. Problem there, this DanG cold weather. I wanted to spray but doing that, I couldn't have any open flames. :o
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1666.JPG?easyrotate_cache=1516022437)
Post by: richhiway on January 15, 2018, 05:29:42 PM
those cabinets are very nice.
Post by: fishfighter on January 16, 2018, 03:52:23 AM
Price is even better. Got about $75 in them for a couple sheets of 3/4" plywood for the shelves. Other plywood, my son had got it off a job for free. Have way more then what I need to build all the draws. ;D
Going to be a backwards weather day with a very good chance of snow here today. A inch of that shuts everything down here in the south. :D We are not set up for ice or snow. :o
Doctors appointment went so so. Back on another med that should help, I hope.
Got a question. Anybody ever recut granite counter tops? I been checking on how to do it videos. Yesterday afternoon I did make my templates. The granite I have is 3 cm thick. I do have a stone blade for my saw and a small 4" blade for my grinder. Used these blades for the Hardiplank I installed. I will make up a GFCI extension cord to feed it. Besides that, the power feed is already GFCI protected. I will fix up a 5 gallon bucket with a small tube and valve to feed water real slow as I cut. That should be just enough to help keep the blade clean and cool. Also, I will use a wet vac to help suck up extra water to help keep things on the dry side. Don't want to get shocked. :o  Of course I will have to wait till next weekend for the weather to warm back up. Suppose to get back up in the low 70's. ;D
For the sink, I am really kicking the idea of using a very very old time wash board kitchen double cast iron sink I have. I would have to refinish it with epoxy which I had done before. ;D I will get a picture of it today.
Post by: Dakota on January 16, 2018, 08:55:07 AM
When you get done, I'd like to hear what worked best for you as I will be doing the same in the spring.
Post by: ChugiakTinkerer on January 17, 2018, 10:45:55 AM
I've only cut granite tiles, less than a cm thick.  But slow and wet worked just fine.
Post by: fishfighter on January 17, 2018, 10:52:42 AM
Yep, slow thin cuts at a time till thru all the way is the plan.
Post by: Briankinley2004 on January 18, 2018, 11:07:35 PM
I cut some old granite toilet partitions about 1" thick to use for fireplace hearths at camps. Used a diamond blade in a skil saw. Two or three cuts.
Post by: fishfighter on January 19, 2018, 08:26:43 AM
That is my plan. ;D Now if it would just warm up. I did install the draw runs yesterday and if it warms up like it suppose to, I will get all the sanding done today.
Post by: fishfighter on January 19, 2018, 01:30:48 PM
Had a chance of plans. Success  ;D Did cut up the granite tops. Very happy on the out come. 8)
Before I started I had made templates of the counter top with 1/8" luan  plywood.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1692.JPG?easyrotate_cache=1516384883)
As you can see, when the people that had removed the top, they crack it. Well that really doesn't matter due to this piece and the joining piece was way to long.
First cut, I had set the blade less then a 1/4". I life saver is that guide that I bought from HF. Paid $15 and well worth it. ;D Using a pump sprayer with water helped a lot. Two people cutting this would go a lot faster, but it only took me about two hours having to take the time to wet out the cuts. Made 7 cuts.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1690.JPG?easyrotate_cache=1516384999)
It took 5 passes to cut thru. Big NOTE here# MAKE SURE THE SLABE IS FULLY SUPPORTED UNDER IT. I used some pieces of OSB. That way on the final cut the blade didn't have any problems cutting that. Another NOTE# Keep a lot of pressure down on the saw. If not, it will try to jump up a little. This helps for a very clean cut. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1691.JPG?easyrotate_cache=1516385018)
Stand a loan cabinet with it's top.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1696.JPG?easyrotate_cache=1516385066)
I still haven't cut for the sink. Undecided  if I will used an old school or just buy a new SS one. One way or the other, it will be mounted on the top. I don't want to have to drill this stuff. DanG drill bits cost a arm and a leg. Way more then what I paid for the granite in the first place. :D
Post by: ChugiakTinkerer on January 19, 2018, 10:59:40 PM
That looks fantastic.  When will you and the Mrs be moving into this building?  :D
Post by: fishfighter on January 20, 2018, 05:14:15 AM
Baby steps my man, just baby steps. :D I did go out and bought a new sink yesterday. So today, I will finish cutting the granite. I have to order the right stuff that grinds the edges. Really only have one edge that I have to refinish out that is exposed on a outer edge. Youtube has some very good videos on how to do stuff. 8)
Post by: fishfighter on January 22, 2018, 07:49:39 AM
Yesterday I had finished cutting out the sink area. Saturday it rained all day. And sure enough, 100% chance of rain today. >:( I did have my SIL over to help me move them in place. Just need to fine tune them and set them. ;D
The two halfs
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1697.JPG?easyrotate_cache=1516624956)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1698.JPG?easyrotate_cache=1516624973)
Post by: fishfighter on January 22, 2018, 04:46:52 PM
Got the kitchen sink cabinets installed all the way along with the counter top. Just have to put everything together on the sink and install it all the way. Maybe tomorrow.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1702.JPG?easyrotate_cache=1516657275)
I still have that little piece to install too!
Post by: Darrel on January 22, 2018, 09:56:02 PM
Progress! 8)
Post by: fishfighter on January 25, 2018, 11:58:51 AM
Got a couple of the top cabinets hung this morning. Going to have to wait till I get some help to hang the last one. Way to big and heavy for one person to handle. :(
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1706.JPG?easyrotate_cache=1516899185)
Post by: Darrel on January 25, 2018, 12:11:01 PM
Starting with that wench on the left side of your pictures rig up a cabinet lift. 8)
The ones you've got up already look great!
Post by: fishfighter on January 26, 2018, 06:48:19 AM
Now you did it. :D Got me thinking. :D That is my home made sheetrock lift that I made. Finished with it and been using it to hold up lights. :D Now you done it, wheels are turning. :D
Post by: fishfighter on January 26, 2018, 12:23:16 PM
Darrel, I owe you. You had put me back to work. :D
After a little modifying my sheetrock lift, success. 8) Had to move the island out the way. Was not easy sliding it due to the weight of it. Then I had to drag the cabinet out the front bedroom and put it close to in place. Everything just fell in place. 8)
The lift with forks. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1709.JPG?easyrotate_cache=1516986666)
Got cabinets installed. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1710.JPG?easyrotate_cache=1516986612)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1713.JPG?easyrotate_cache=1516986595)
With rain for today and all tomorrow, I will tackle sanding and cleaning up everything. Then next week I will start varnishing them. 8) Doors and draws are in the near future. ;D
Title: Re: Started the build.
Post by: Darrel on January 26, 2018, 07:05:52 PM
Paul, just put the check in the mail!
:D :D :D :D :D
Post by: fishfighter on January 29, 2018, 02:23:53 PM
Today was a play around day with stains. I had fixed up this stain about 7 months ago. Been brewing that long. Steelwool and vinegar mixture. The beams have aged nice and on the dark side. I want to keep it that way. So, were the sheetrock butts up to the beams, there is a small gap. I left it that way so the beams would dry and would not pull away from the sheetrock. My plans are to install a 1" square strip. Had them sawed and planed out a long time. The problem there is that the strips are light color. That is why I made the stain in the first place. ;D
My sample next to a beam
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1720.JPG?easyrotate_cache=1517253029)
Just tacked them up. Happy with the match. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1719.JPG?easyrotate_cache=1517252441)
Now I been thinking real hard on this. Been kicking the idea to stain all the wood work to a darker color.
Some samples with the same stain. It is kind of hard to see, but one end has two coats, them a bit of one coat and then clear. Same thing for the plywood that I used for the cabinet shelving.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1717.JPG?easyrotate_cache=1517252360)
Two coats just about match the oak without any stain. I'm going to try a third coat and see what happens there.
So, what y'all think about staining all the wood work to a bit of gray?
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1718.JPG?easyrotate_cache=1517252394)
Another color I am thinking would be a mixture of Cherry and dark cherry. I like the rich of that color. Just need to go pick up some and give it a try.
Post by: Crusarius on January 29, 2018, 02:48:31 PM
What mix did you use on the beam I like that color.
Post by: fishfighter on January 29, 2018, 06:02:14 PM
The beams are their natural color. I like them too! ;D To get a match on the 1"x1"'s, I took 2 steelwool pads in a quart container and filled with white vinegar. That sat for 7 months, but I'm sure it could be ready in a month. I did strain with a coffee filter before using.
I went and picked up some different cherry stains. DanG wood is not going the way I really would like it. :( I even mixed with no help. This water oak just don't like to be stained. Still going to try other things. If not, just varnish. ;D
I'm going to post on the wood working section of ideas. ;D
Post by: fishfighter on January 30, 2018, 01:36:48 PM
Still debating to stain or not to stain. :D
Did a little for the backsplash. Took a true 2"x6" water oak board. Planed it down and edged. From there, on the back side, top, I added two strips of 3/8" plywood 1" wide and screwed them in place. From there, I passed them thru my planner and got what I was looking for.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1724.JPG?easyrotate_cache=1517336596)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1726.JPG?easyrotate_cache=1517336641)
Put in place.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1728.JPG?easyrotate_cache=1517336656)
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1730.JPG?easyrotate_cache=1517336674)
I will be trying something for the full backsplash. ;D
Post by: fishfighter on January 31, 2018, 06:33:20 PM
Today, I came up with a idea some what. For the backsplash, I was planning on using some old rusty tin roofing. Came up with even more of a crazy idea. Kind of need some help here if I'm going down the right path. :D
So, I put this together. Which door would you choose?
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1733.JPG?easyrotate_cache=1517440453)
Now that is a top cabinet door with the metal rust roofing. My plans are to use that same roofing for the backsplash. I will spray paint them with clear varnish to lock in the rust and help keep things clean.
On a side note, I was thinking to do just the bottom doors and wood or glass for the top doors.
I'm at the point that today I had resawed some 4/4, 8" and 10" wide boards. I needed  about 150' LF of true 1"x2" just for the framing of the doors. Planed, edged and planed all that today.  8)
Post by: Darrel on January 31, 2018, 07:58:09 PM
As far as the rust goes, if you only have it on the back splash and cabinet doors, I don't think it will look good.  If you stand in the middle of the kitchen and turn your back on the cabinets and sink area you still need to see some rust. Maybe not as much, but there will need to be some in key places that will catch your eye. Maybe even have it here and there throughout your house. If you have rusty light fixtures or lamps for example. Then if you want the highest concentration of it in the kitchen, that's great. Doing this will prevent getting poked in the eye by rust when you walk into the kitchen.
My 2¢  8)
Post by: fishfighter on January 31, 2018, 08:44:22 PM
I was planning on building some light fixtures in a rough form that will be a bit rusty or part of copper. Got a trick up my sleeve there that I have plans for. ;D Those will be in the kitchen area. In the living room, I will carry out that theme somewhat. Hardware for the doors, kind of thinking copper in a rough form. ;D
Post by: Dakota on February 01, 2018, 09:26:24 AM
I would go with the wood doors.
Post by: fishfighter on February 01, 2018, 05:46:56 PM
There is a lot of wood in this area. ;D
So, today, out with the new sink. Just wasn't going to make it. Will be ordering a new one. Looking at copper.
Now I did some testing on stains and different varnishes. Glad I did. Was planning using a gloss. Big wrong there. Satin looked so much better.
Back to cabinet doors. After varnishing some scrap pieces with different stains, I found that doing the lite gray would look best. Even the wife loved it the best. Know what that means? :D
So, I did glue up that door and clamped it in place. The piece of wood is coated with 2 coats of satin. Half is stained.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1736.JPG?easyrotate_cache=1517523642)
This is a swap with using a gloss varnish.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1737.JPG?easyrotate_cache=1517523679)
Then I had coated a piece of the rusted roofing. Half and half. There was no different. :(
Placed up at the door.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1738.JPG?easyrotate_cache=1517523724)
It turned out darker. A bit more then what I was looking for. :( So, for sure using it as a backsplash, it is not going to work. I might still use a little around the stove area and trim it out in oak.
This is what the door looks like about 12' away.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1739.JPG?easyrotate_cache=1517523761)
Don't know if the cabinets will clash with the beams above. Still out on that one.
Post by: Magicman on February 01, 2018, 10:28:02 PM
I don't even try.  "She" has the first and last say-so.  Most times when I don't pay attention it get's re-done.   ;)
Post by: fishfighter on February 02, 2018, 04:39:14 AM
Well, another change from the boss. :o Our daughter took a walk back there with the wife. The ruling came out. :o No stain at all. :o Still they want the metal in the upper cabinet doors and wood in the bottom doors. :D Whatever. :D Only thing that hasn't changed is using a satin varnish. :D They want me to build two new doors for the top with the metal and clamp them in place so they can really see if that is what they want. :-X Yep, had to just bite the bullet. ;D At lease those doors only take about 30 minutes to build. ;D Oh well. :D
Post by: Magicman on February 02, 2018, 08:48:26 AM
The Ladies are Wonderful Creatures.  If they say it, believe it, and when two agree, the Supreme Court could not overturn the decision.   :P
Post by: fishfighter on February 03, 2018, 08:41:14 AM
So, yesterday I tried to make two doors for the top using glass. Went and bought the glass. Had to resaw the gap were the glass slips in. No biggie. Looked real nice till both glasses popped. :o The glue I used expands. I didn't think about that and sure as heck, both glass panels popped. >:( The glass had way more them enough room to move, but not with that glue. >:(
Live and learn, I guess. But there is a silver lining to this. My daughter came to pick up her son yesterday evening. Told her what had happen. Well, one of her hobbies is making stain glass  panels. ;D She took what I had and started making a new stain glass panel. ;D 8)
So, another change. :D
And yesterday the wife and I went looking at different tiles for the backsplash. Everything that we liked was way to much that I didn't want to spend. :o Here comes another change. :D Drinking my coffee this morning and thinking about that, had something that popped in my mind. I have a bunch of 4"x6" and 6"x6" oak beams that are cut offs. Why not cross saw them across the end grain to make subway tiles. Glue them up, then grout them and then varnish them for the finish? Leave them in the rough and make them not the same thickness. ;D I see that I will have to make a jig to hold the beams up right to saw them on my sawmill. 8) Would do that today, but rain is on the way. :(
Post by: Magicman on February 03, 2018, 02:14:45 PM
The tile idea should be a good one.  You just might make points with the wife yet.   :D
Post by: Darrel on February 03, 2018, 06:23:29 PM
I've seen tiles done that way for flooring and it looked great. I see no reason why it wouldn't look good as a backsplash.
Post by: fishfighter on February 04, 2018, 08:01:44 AM
Did the mistake of showing the wife a picture of a backsplash made out of pallet wood. So, she wants me to get some for enough to see what it would look like. :o Really no problem getting them for free around here.
I'm getting to the point that I will just do whatever. :D
Post by: Magicman on February 04, 2018, 08:35:24 AM
Yeah, whatever she says.   :D
Post by: fishfighter on February 04, 2018, 09:26:48 AM
This is a picture she like with the pallet wood.
 (https://forestryforum.com/gallery/albums/userpics/38788/pallet_wood.jpg?easyrotate_cache=1517754081)
Stain glass panel my daughter did last night.
 (https://forestryforum.com/gallery/albums/userpics/38788/53939124645__F75B7933-3F1F-4083-B33D-0CA7BDA3BE7D.JPG?easyrotate_cache=1517754179)
Post by: fishfighter on February 06, 2018, 07:26:19 PM
Been putting door frames together. DanG shame I only have two clamps that extend over 30". :( Should go out and buy a couple more, but there will be a good chance I will never use them again.
Anyway, My daughter wanted me to install a stain glass to make sure it is strong enough. All is good. ;D Don't mind the blue tape. I put that there so I can varnish it. ;D My daughter wanted to add more color to the glass, but I said all is good. I wife loves it. Guess that is what counts. :D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1740.JPG?easyrotate_cache=1517962548)
Should finish the top doors tomorrow and varnish them first before installing the glass.
Post by: Ljohnsaw on February 06, 2018, 07:38:46 PM
I thought the blue tape looked good!  Thought it was a different glass she was trying out.
How are you attaching the glass in the back?  Glazing points or turney things like for screens.  Picture please!
Post by: fishfighter on February 06, 2018, 08:48:44 PM
I used my router and cut a grove about 1/2" wide and 1/2" deep. From there, I put a bead of  clear silicone, then put the glass in. From there I had some oak strips that are 1/2" wide that filled the gap and thickness of the frame. More silicone, then the strips. Used a staple gun and stapled them in place. Once the silicone is dry, Remove the staples.
Back side. You can see a little of gap. I will fill that. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1741.JPG?easyrotate_cache=1517967654)
Post by: Darrel on February 06, 2018, 09:16:13 PM
I kinda liked the rust but the glass really looks nice.
Post by: PC-Urban-Sawyer on February 06, 2018, 09:40:38 PM
Looks really good...
Question: Is the door opening laid out so the long side of the door is vertical (in the basic orientation shown in the photos...) or does the long side go horizontal?
The reason I ask is if it is to be installed with the long side vertical it looks a little odd because the stiles are not the full length of the door...
Nothing wrong with that, just most people make the stiles the full length of the door height, rather than making the rails the full width...
Still looks good.
Herb
Post by: fishfighter on February 07, 2018, 05:15:38 AM
I see what you are saying. ;D But yes, the long side will be vertical.
Darrel, the rust tin was just to dark and the wife didn't care for it. So, whatever the boss says, goes. :D
Post by: fishfighter on February 10, 2018, 05:17:56 PM
Finished getting all the upper door frames together. Just need to varnish them. Daughter has a bunch of the glass done.
Got all the drawer boxes built. With the rain we having, it's stopping me from varnishing and resawing rough boards to plane out for the lower cabinet doors and drawer fronts. :( Didn't take any pictures.
Post by: fishfighter on February 16, 2018, 05:55:53 PM
Really haven't been doing to much. :( Kind of been under the weather. Over 13 years ago, I had neck surgery to fuse together C5 and C6. Well the last couple months, this came back with problems. >:( The pain got to the point, I couldn't sleep. So, off to the doctor that did the work. Not good. :( Things above and below are in very bad shape. Looks like more surgery down the line. >:(
Anyway, got all the upper doors and a piece of backsplash varnish.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1751.JPG?easyrotate_cache=1518821561)
I did put together the matching door to the first today. Got a pair now. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1752.JPG?easyrotate_cache=1518821545)
My daughter has a couple more of the glasses done, just need to go pick them up.
Post by: Darrel on February 16, 2018, 06:10:49 PM
I like that!
Post by: fishfighter on February 18, 2018, 07:49:36 AM
Yesterday, I sprayed out one of the cabinets. Sprayed a clear satin finish. Really made the wood grain pop. ;D
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1755.JPG?easyrotate_cache=1518957974)
Used a cheap HF spray gun that cost $10 that did a great job. ;D After spraying, any runs, I came back with a foam brush. That took care of it. ;D
Post by: Magicman on February 18, 2018, 04:31:03 PM
I am just now catching up with what you did while I was on the road sawing Paul.  I see that your Wife and Daughter are making good decisions and you are doing well by following them.  Looking Good.   :)
Post by: fishfighter on February 20, 2018, 06:57:08 AM
Thanks Lynn. Spent the day on a tractor moving dirt. Paying the price for that this morning. Got to do a CT this morning on my neck to see if there is anything they can do to fix it. I hope so or my sawing days could be over.
Post by: Magicman on February 20, 2018, 08:54:46 AM
Here is wishing you the best my Friend.  :)
Post by: Darrel on February 20, 2018, 09:15:47 AM
Thoughts and prayers that they will find it fixable.
Post by: fishfighter on February 20, 2018, 09:29:58 AM
Thanks guys. I did hang a set of the doors.
Having trouble posting a picture.
Post by: fishfighter on February 22, 2018, 11:07:32 PM
Did get the rest of the top cabinets sprayed.
Still fighting to post pictures. One can't add any text once one copies and paste. Have to mod a post to do so.
Icon's will not post too!
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1760.JPG?easyrotate_cache=1519358447)
Post by: Magicman on February 23, 2018, 09:44:14 AM
Those cabinets are looking good Paul.
Also the picture thing will be easier after you watch the videos.  It's the same, except different, but better.  ;D
Post by: fishfighter on February 25, 2018, 09:26:55 AM
Still fighting it. My puter is not happy. Did a clean up and reboot. No help there.
Anyway, got all the draws finished and sprayed. Was going to start spraying the bottom cabinets today, but way to much rain.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1766.JPG?easyrotate_cache=1519568554)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1767.JPG?easyrotate_cache=1519568573)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1768.JPG?easyrotate_cache=1519568591)
Post by: Darrel on February 25, 2018, 10:12:00 AM
I keep peeking in to see how things are going.  Hoping things are going as good for you as they are for this kitchen.  :)
Post by: Jim_Rogers on February 25, 2018, 10:21:32 AM
Pretty soon you're going to have to change the name of this story to Completed the build.
Jim Rogers
Post by: thecfarm on February 25, 2018, 01:43:55 PM
fishfighter,your computer is not happy?  :(  I have a Dinosaur and this thing is never happy. Refreshed kept The Dinosaur from eating me in all one bite. The refesh button helped me out.
Post by: sawmilllawyer on February 25, 2018, 08:32:38 PM
Looks like you have come a long way. Starting to get ship shape. Keep plowing.
Post by: fishfighter on February 26, 2018, 06:53:09 AM
Still have a long way to go. Just not in a hurry. Will be dry enough today to spray the bottom cabinets. Once I get that done, I have to rip up more oak boards and plane them down to make the doors for the bottom cabinets. Hope to start on that today. I rough saw them on my mill, so that gives me a chance to fire it up.
My stock pile of oak is starting to get low. Got a couple oak logs that need to be sawed up, but the boss will not let me.
Post by: fishfighter on February 26, 2018, 04:11:54 PM
Did get this done today.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1769.JPG?easyrotate_cache=1519679241)
Sprayed it, install the draw rails which took to around 1pm. Had to call it a day. So much for want I wanted to do today.
Post by: Magicman on February 26, 2018, 06:57:26 PM
Hey, I am glad to see you at least making some progress.  Small steps add up.  smiley_thumbsup
Post by: fishfighter on February 28, 2018, 06:07:38 AM
I was able to resaw some rough oak boards up for the lower cabinet door frames yesterday. Sawed them up on the band saw. From there, I edged one side on the joiner and then planed them all out. Then I had cut them to the sizes of the door frames. Bad thing, my SIL needed to use my biscuit joiner for a job, so I couldn't put them together. He should finish with it today. Besides I was ready to call it a day. Was hurting to much.
This morning I'm going in for that shot in my neck. Just hope it helps relive the pain I been having. Wish me luck.
Post by: Darrel on February 28, 2018, 10:37:24 AM
I've seen it repeatedly that things get worse for a day or two after those shots so if that is what happens for you, don't get discouraged, it will get better. Hang in there, the forestry forum family is pulling for you.
Post by: fishfighter on March 02, 2018, 06:18:32 AM
Still taking it easy. Not much relief. Had to get up out of bed at midnight.
Post by: Darrel on March 02, 2018, 08:58:30 AM
Saturday should be a better day. You are in my thoughts and prayers.
Post by: fishfighter on March 03, 2018, 07:43:40 AM
Well, I got out yesterday, sawed up the center inserts for the doors, pass them thru the planner and finished them out.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1771.JPG?easyrotate_cache=1520079966)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1773.JPG?easyrotate_cache=1520080021)
After that, I had to have a few of these.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1770.JPG?easyrotate_cache=1520080069)
Going to try and glue them all up today.
Post by: Magicman on March 04, 2018, 09:44:56 PM
Looking good Paul.  Steady as she goes.   :)
Post by: fishfighter on March 05, 2018, 06:32:19 AM
I did get the doors all glued up.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1776.JPG?easyrotate_cache=1520249080)
With the outstanding weather we been having that spring came early, yard work time. So, we been attacking that the better part of the weekend. Still have a bunch to do.
Post by: fishfighter on March 06, 2018, 03:39:30 PM
A cool front passed thru last night and all rain was gone by 6am. Got out and painted the cabinet doors. 4 coats on each side. Nice using a spray gun.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1777.JPG?easyrotate_cache=1520368185)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1778.JPG?easyrotate_cache=1520368205)
Post by: Magicman on March 06, 2018, 05:32:04 PM
Yup, we will have a few nice working days this week and those cabinet doors are looking good.  I'll be sawing about 75 miles East of you.   ;D
Post by: fishfighter on March 07, 2018, 05:03:15 AM
What town and what days? If you are sawing Thursday, I would like to drive out your way. Dang doctor day today in Baton Rouge for my neck and another Friday in New Orleans for my heart. The second one, they called and told me things have been happing that shouldn't. Tried to tell them I been in a lot of pain with my neck. They still what to check me out.
Lynn, you should have some nice cool weather to saw in.
Post by: fishfighter on March 08, 2018, 03:46:27 PM
Now it is time to decide if a change will be made to the upper cabinets. To stay the way they are or take out the center cabinets that are over the stove area and replace that area with a custom built exhaust hood that will be built out of oak as the cabinets.
All doors are done and this is what the top cabinets look like now.
  (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1781.JPG?easyrotate_cache=1520541870)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1782.JPG?easyrotate_cache=1520541890)
Post by: Darrel on March 08, 2018, 11:38:40 PM
Exhaust hoods are fine as long as they are high enough so that one doesn't knock his head whilst looking in the pot on the stove. Otherwise, we hates'um!
Post by: fishfighter on March 09, 2018, 06:55:53 AM
I think I will just for go that hood for now. I can always come back in do it. Was also thinking of building it out of copper. The wife loves the way things are, BUT, now she wants a faucet installed on the back wall to the side of the stove area. Would not be hard to do. I already have a water line were the frig area is. I can Tee off that line from under the house and run the line back up.
Got to head to New Orleans today. Another doctor day. It is a battery check up and find out as to why I was taking some hits. My battery life is getting short to were I will have to have a replacement soon. Hate that trip.
This weekend, rain in the forecast. That will give me a good chance to do a complete clean up of the bottom cabinets. I have dust everywhere. Once I get that done, I will spray them. Then hang the draws hardware and the doors. That will finish them. What I had already sprayed, I used up a full gallon. That stuff is costing $50 a gallon, but it sprays out super nice.
Post by: Magicman on March 09, 2018, 02:33:53 PM
Paul, I was West of Hammond for two days (Wed. & Thurs.) and yes, the weather was breezy but very nice.  I was sawing Cypress timbers which are shown in the Whatcha Sawin' topic.
Those cabinets are looking terrific.  Pat & I need to make another day trip so that we can stop by and take get a peek.
I realize that those health issues are distractions, but keep on keeping on.   :)
Post by: GRANITEstateMP on March 09, 2018, 02:35:06 PM
fishfighter,
I enjoy watching your progress.  Your creativity amazes me.  Hope you start feeling better.
Post by: fishfighter on March 09, 2018, 05:01:48 PM
Dang Lynn, that was less then an hour from me.
Always, all is good. I have to go back down towards the end of the month. The wife drove back. This trip was a SOB on the neck. Just knew I should of took something along for the ride, but I hate those things. Once I got back home, I popped a few tops. A bit better now. ;D
Post by: Briankinley2004 on March 10, 2018, 09:52:11 PM
West of Hammond..Must have been Satsuma or Pumpkin Center. I was in Madisonville until Thursday about 30 minutes east of Hammond. Have a boat there.
Post by: fishfighter on March 11, 2018, 05:39:26 AM
Yesterday I was able to spray out the bottom base cabinet.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1785.JPG?easyrotate_cache=1520760820)
Still have the island to do. Had very little rain, but today it is going to storm. :(
Post by: Rjwassink67 on March 12, 2018, 08:05:33 PM
Wow, found this thread a little while ago and just now finished reading it and catching up.  You are doing an amazing job!  With everything going on in your life you have all of my respect.  Keep plugging away.  I'm a few years away before I start my homestead.
Post by: fishfighter on March 13, 2018, 06:07:44 AM
Why thank you Sir. With all my troubles in my life, I feel that the Good Lord has blessed me with a good life.
Been laying around the house the last few days. Between my neck and spring pollen kicking my butt for the first time in my life, I just couldn't get out. :( I'm going to try and get out some today and install the draws and doors. ;D Still have to give the island a lite sand and spray it out. Using dust mask, that should help my sinus troubles from getting worse. ;D
Post by: fishfighter on March 13, 2018, 07:03:29 PM
Did get out and got a lot done today. 8)
Base cabinets are done other then hardware.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1790.JPG?easyrotate_cache=1520981445)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1792.JPG?easyrotate_cache=1520981487)
After that, I put a full attack on the island, sanding, cleaning and then spraying. Very happy how it came out. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1793.JPG?easyrotate_cache=1520981533)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1794.JPG?easyrotate_cache=1520981552)
Bad side of things, I'm short one set of hinges. >:( Just knew I had enough, but didn't. Only bang my head once. Not bad. ;D But both knees are killing me along with my neck. >:( Good thing I don't have to drive the 35 miles to get hinges. My daughter has to go that way tomorrow. ;D
Beer thirty now.
Oh, I am hoping I can get 3-4 strong young men to come help me lift the granite slab that goes on the island. It's an easy 400lbs. :o
Post by: Darrel on March 13, 2018, 08:13:31 PM
Ain't nothin' easy 'bout 400 pounds!
:D
Post by: Crusarius on March 14, 2018, 08:15:03 AM
Fish, I love the way this project is turning out, the stained glass was a great idea. I would love to help you with that top but the drive is a little further than a weekend trip for me. :)
After seeing this project I really want to learn how to do stained glass like that.
Keep up the great work.
Post by: fishfighter on March 14, 2018, 08:28:03 AM
My daughter did the stain glass. One of her hobbies. It really is not hard to do, but the glass sheets run over $8 for a 12"x12" piece. And yes, the glass really made the cabinets pop. ;D
Still trying to figure a way I can move a 400+ pound slab by myself and lifting it to install it on the island. :D DanG thing is on the front porch. Only have to move it about 30'. :D
Today is yard work day. :( But I also need to do a complete clean up inside the house. Got a bunch of scrap wood that I kept to burn in the woodstove. Now the spring is here, I don't need it. :o It's a cool 40F now, but by 10 am, it will be above 70F with a high of 75+ today. ;D
Post by: Crusarius on March 14, 2018, 08:34:27 AM
you probably have enough material left over to make a cart and use a jack to lift it into place?
Post by: fishfighter on March 14, 2018, 08:51:24 AM
I do have some roller moving pads that I built to use to move timbers. Problem there is just to lift the slab to get it on the roller pads and keep it balance at the same time. :D Then getting it thru the door way from the porch which is about 5" difference in height.
Post by: Ljohnsaw on March 14, 2018, 09:43:42 AM
I have a really steep driveway and a front door that is recessed into the front of the house.  There is 1 step up to the porch and 1 more into the house.  They backed their PickUp to the door but couldn't get the slab to clear the ceiling on the porch.  So they had to pull forward.  They put it on a material cart but then it wouldn't fit through the door (too tall).  Four guys to handle the 5' x 8' slab for our island.  Then they struggled to get it up on the island.  Don't try to do it yourself!  Too easy to break if it is not supported properly when you are setting it down.
Post by: fishfighter on March 16, 2018, 05:19:59 AM
Yesterday I was able to move the slab inside with the help of my wife. ;D Got two sets of moving dolly's. Built a frame to were I could stand the slab on it's side ad lock it in place. With the help of a pry board, I lifted one side up as my wife put blocks under. Then the other side. Slipped the dollies under and locked it in place. Then I built a ramp with different strips of scrap boards and plywood for the thresh hole of the door way. After that, that sucker just rolled in. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1799.JPG?easyrotate_cache=1521190986)
From there, got a bunch of blocks, block the wheels on the dollies and lower it down on the blocks. Then I was able to lift one side and my wife add more blocks. Got it better then half way up to the point that two men can lift one end and slide it over the edge of the island. SIL suppose to come by after work today and we will get it installed. ;D
Post by: LeeB on March 16, 2018, 05:24:05 AM
Where there is a will, there is a way. Sadly that concept is sorely lacking in today's workforce.
Post by: fishfighter on March 16, 2018, 05:58:56 AM
Yep, so true. :( Heck, I just might jack it up higher and slide it on myself. :D But then again with nothing but rain today and thru the weekend, I have a bunch of sanding to do on the wainscoting so I can spray that. :D
Post by: Crusarius on March 16, 2018, 08:29:08 AM
its amazing what you can do with a little rigging. I always find myself in that situation where it is impossible to get any help no matter how many times you help other ppl. I have managed to move my vertical steel mill by myself several times. that includes putting it on a trailer and taking it off. Without equipment. It is crazy what you can do when you have to.
Keep up the great work. Don't forget to take breaks when needed.
Post by: Magicman on March 16, 2018, 09:39:45 AM
I admire your perseverance and ingenuity my Friend.  Stay safe.  ;)
Post by: Ljohnsaw on March 16, 2018, 09:41:00 AM
Quote from: fishfighter on March 16, 2018, 05:19:59 AMSIL suppose to come by after work today and we will get it installed. ;D
How are you going to attach the top?  On my massive island (5x8 ), they first checked it for level and placed some different colored/thickness plastic wafers in the low spots.  When they were satisfied (leaving them in place), they emptied 2 or 3 tubes of silicon caulking in huge gobs all over the plywood.  Then, they lifted and carefully set the slab in place.
Post by: fishfighter on March 16, 2018, 12:24:51 PM
I used a 6' level when I built it. Once I moved it into place, I checked the top of the cabinet again. It's true plumb. So, I will for go the plastic tabs. I will place it on top, check to see how it is sitting. From there I plan on lifting it up and put some wood blocks here and there. then pump in silicone. ;D That is how I did the other cabinets that came out all level. ;D
Well, I got one wall of the wainscot done. Only had to do a lite sand. Cleaning and taping around it took more time then anything. :( Sprayed three coats  and I like it. ;D (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1801.JPG?easyrotate_cache=1521216746)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1802.JPG?easyrotate_cache=1521216789)
Post by: Magicman on March 16, 2018, 03:33:19 PM
So do I.  8)
Post by: Rjwassink67 on March 17, 2018, 07:32:21 PM
Looking great.  Your use of wood looks amazing.  Just the right touches.  I do like the stained glass.
Post by: fishfighter on March 17, 2018, 07:59:01 PM
Got that granite slab on top of the island. ;D Bad thing, I didn't have my phone with me to take a picture. :( I will get one of it tomorrow. ;D
Post by: Crusarius on March 18, 2018, 10:58:44 AM
Did you end up rigging and doing it by yourself?
Post by: fishfighter on March 18, 2018, 11:52:53 AM
I was about to. Was going to use my sheetrock hanger, but SIL and my daughter showed up. ;D
Pictures of said island. We all love pictures. :D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1803.JPG?easyrotate_cache=1521387978)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1804.JPG?easyrotate_cache=1521388002)
Was going to hit another wall, but it is storming here, coming down in buckets. :( And yes, again tonight, tomorrow. :(
Post by: Darrel on March 18, 2018, 11:59:27 AM
O  8) 8) 8) 8) 8)
Post by: Magicman on March 18, 2018, 04:08:21 PM
Magnificent.   8)
Post by: samandothers on March 18, 2018, 07:20:41 PM
Good job on the island counter top!
Post by: fishfighter on March 19, 2018, 03:26:36 PM
Got another wall done today. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1806.JPG?easyrotate_cache=1521486643)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1807.JPG?easyrotate_cache=1521486663)
Anyway, I been thinking a lot about the island weight. Between the island itself and the slab, the weight is over 500 lbs and a good chance over 600lbs. Problem I am thinking about is that over time with the small foot print of the island, it would sag the floor. :o
So, I came up with a plan to put another footing, a concrete pier and a 8'x 8"x8" beam directly under the island just for insurance. ;D I have everything on hand, so why not? Better to feel safe then sorry later. 8)
Another thing. I need to go see member Cypress man. He lives about 20 miles from me. last time I visit him, he has all the super cool tools a man would want. He happens to have a very sweet molder. I am going to see what he will charge me to mold up some crown molding out of oak for the other rooms. ;D Going to try in get up there tomorrow. ;D
Post by: LeeB on March 20, 2018, 09:32:04 AM
I really like the cabinets and paneling. The simplistic style along with the reveals really set it off and looks great. I guess you would call it shaker style?
Post by: fishfighter on March 20, 2018, 07:49:23 PM
Some what a Shaker. ;D
Got another wall done. Oh, the knees, but all is good. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1808.JPG?easyrotate_cache=1521588894)
That has all the living room wainscoting done. 8)
Started hanging the chair rail on that same wall. Same wood, just not sprayed yet.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1810.JPG?easyrotate_cache=1521588918)
The rail is made that the base plate up against the wall 3/4"x 2 1/4". The top plate is the same. The wainscoting sticks out about 3/8" from the sheetrock. So that cuts down on how much the top plate over hangs. I like it and so does the wife. ;D
Post by: fishfighter on March 22, 2018, 08:18:07 PM
Been kind of moving slow. DanG neck. >:( I did a road trip to Cypress man. He was just a sawing away. ;D Of course he was just sitting back in the control room, flipping the stick controller with two unloaders working their butts off. :D What a operation. First class. 8) Anyway, he is just to busy and as he said, he only deals with cypress. ;D I don't blame him. ;D He gave me a guys name that lives close to me that just might be able to help me out. ;D Going to try and go see this person next week. 8)
Now a report on what little work I got done. :( Got all chair rail hung. ;D Even got the windows in the living room boxed in along with the kitchen window. ;D
Dang phone will just not take a good picture when there is a lot of light. >:( This was the best I could do.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1814.JPG?easyrotate_cache=1521763913)
Yard work in the morning and then if I'm up to it, I am going back up on the roof and spray another coat of roof sealer. I have 4 more 5 gallon buckets, why not use them. ;D The wife will help me and be my ground person, I hope. :D :D
Post by: fishfighter on March 26, 2018, 06:14:54 AM
Got everything in the living room varnish. ;D Just have to get the area outside the bed rooms/ bath to varnish. I have to go buy a third gallon. :o  SIL will be coming to sand out the front bed room ceiling. With my neck, I just can't look up. >:(
So, today I will be hitting up Home Depot for varnish and it time to buy a bunch of plugs and light switches. Also, I will be picking up some ceiling pan lights.
Of course some things just don't make the cut. I have to move a ceiling light run in the kitchen area that suppose to be direct over the island. Oh well. When one doesn't have a set of house plans, one is going to make these little mistakes. :D This is the second line I had to move. ;D There will be a pot rack/lighting that will be installed over the island that I am in the stages of building it. Of course it will be wood/steal built. ;D
Post by: fishfighter on March 28, 2018, 07:54:23 AM
Just about finish all electrical work in the living/kitchen area. Got a power buy on some LED flush mount ceiling lights. I had installed 4 of them in the corners of the living room. These are 75W, dimmable lights. Full contact with insulation. ;D Was very easy to install them. Just cut a hole, drop your wire down. Hook that up and then slip the light up. There are two spring loaded clips that hold it in place. It's a all in one fixture. They cost $19.99 each and then I get a 10% discount on top of that. ;D A lot cheaper then buying a pan, light bulb and trim. ;D
Got a ceiling fan/light fixture to install in the living room and two more of those LED lights to install in the kitchen and then I am done. Will just have some small trimming to do. ;D
Post by: Magicman on March 28, 2018, 09:22:21 AM
It's good to see you keeping on keeping on.  We need to be thinking about another trip down your way.  :)
Post by: fishfighter on March 28, 2018, 10:03:26 PM
Lynn, stop in any time.
The wife and I did a full clean out this morning. She broke out the shop Vac. ;D From there, we hit a clean sweep around the outside. I did do a round up spray yesterday. We have a bunch of rain coming. :(
Back on those LED lights. I liked them so much, we made a road trip and picked up a few more. Heck, I will be replacing a few ceiling lights in my house. ;D
Tomorrow with the rain coming, I really have to do our taxes along doing our son's. Just something I been putting off that every time I think about it, it just kicks my butt.
On a side note. I did call my doctor about my neck. He sent in a order to another doctor for another injection. First one helped a little and hoping the second helps a lot.
Hey Lynn. If you plan a trip after Easter, I will try to get some Crawfish and boil them bugs. Right now they are just crazy sky high. After Easter, the prices drop big time. ;D
Post by: Magicman on March 29, 2018, 03:12:51 PM
Paul,  I have a couple of fairly large sawing jobs that have crept in on me, but I'm sure that we can make something work.
Post by: fishfighter on March 29, 2018, 06:14:45 PM
Sounds good.
Got out and redid the Kitchen lights. What a pain in the back side removing those electric jumper boxes that set even with sheetrock. :o Hag to do that to install some LED lights. That clean up things. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1829.JPG?easyrotate_cache=1522361176)
Still have to work on the island light.
Post by: fishfighter on March 31, 2018, 08:07:39 AM
Been doing some more electric work. Bad thing, my son had ran a bunch of lines in the box without marking them. :( So, what I did to trace them was hook up a 12V battery and charged up the system. Just about have all lines marked. Hope to finish that today.
Post by: Darrel on March 31, 2018, 11:42:02 PM
That sounds like a good idea. 12v don't bite to hard.
Post by: fishfighter on April 01, 2018, 08:55:31 AM
Happy Easter to all.
Finished tracing all lines. Looking forward to getting more done this week coming. ;D
Post by: LeeB on April 02, 2018, 09:19:48 AM
Great idea with the battery. I have a bunch of lines I need to trace.
Post by: fishfighter on April 02, 2018, 04:49:01 PM
12V will trip a 20 amp, 120V breaker. It just takes a few minutes. Really didn't know that, but I had one line that kept tripping the breaker. >:( Was a line that feeds the kitchen lights. Come to find out, I had a new light switch that was grounding out when I turn it on. >:(
Didn't do anything with the house today. Got on the sawmill. That turn out real bad that all mistakes were mine. :D Oh well. :D And yes, it's going to hurt the pocket  book. :o
Post by: fishfighter on April 05, 2018, 08:55:35 PM
Recouping a bit, I did start building that pot rack and a light fixture. Going to be a one of a kind. :D Biggest hard thing about this is the bracing above. Things are getting heavy. :o
Post by: fishfighter on April 07, 2018, 08:23:46 AM
Well, here it is. The rack has more work to be done on it. The light fixture light blubs are LED and they are hooked up on a dimmer switch.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1833.JPG?easyrotate_cache=1523102186)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1834.JPG?easyrotate_cache=1523102206)
Total cost, under $50 which includes the light bulbs. ;D
Post by: Magicman on April 07, 2018, 09:23:29 AM
That rocks Paul.  You said "one of a kind" and you hit the mark.  smiley_thumbsup smiley_thumbsup
Post by: fishfighter on April 07, 2018, 11:21:41 AM
Thanks Lynn. ;D Hope all is well your way. Just came from the back and patched that hole in the ceiling and other spots that need to be done. Still kind of dragging. :( The wife made me call it a day. :o
Post by: fishfighter on April 11, 2018, 06:34:11 PM
Been chilling the last week. :( Friday's blood work wasn't all that great. :o Anyway, got that second heck shot done yesterday. Was kind of hung over this morning, but got out for a good walk. Even the pop was happy. ;D
I did go slap on some mud on a couple spots in the kitchen area were I had moved a few things. The wife said she will put a lite sanding on these areas tomorrow. :D Just ain't going to happen. ;) Anyway, I will get to it in a couple days. 8)
Post by: Magicman on April 14, 2018, 03:44:22 PM
You have 'bout flooded out today.   :o
Post by: fishfighter on April 14, 2018, 09:33:12 PM
Sure did, but the water drain fast. ;D Bad thing, was without power a good 12 hours. :( All good now. 8)
Post by: BigZ La on April 14, 2018, 10:07:30 PM
Sorry to hear about that power outage Mr Paul, hope the weather wasn't that bad for ya'll. We made it through without any problems. Glad to see your still going strong on the project.
Post by: fishfighter on April 15, 2018, 04:26:31 AM
Happy y'all made it good. A lot of folks got bang up. :o
I did do some lite sanding in repair spots and a third coat of mud. I will reshoot those areas next week. I also did a sanding on the wainscoting in the bedroom/bath area. After Mass, I plan on taping up that area and maybe shoot some varnish.
Next Wednesday is a doctors day in New Orleans. :( Been kind of moving real slow the last couple weeks. Been fighting DanG fluid again which is not good. Don't know what they will be able to do to help this time. DanG extra 10 lbs I been carrying around is not helping. I'm sure I will be fussed at for not going down sooner. ;D
Post by: SwampDonkey on April 15, 2018, 06:30:11 AM
This is one fine build thread. Can't hold a good man down even when he's banged up roasted and flooded out. ;D
I like the stained glass doors and I to am putting in LED's in my new house and pot light LED's on the porches. The countertop is nice to but I'm not into heavy. I'm in the light weight class. ;) We are still under the glaciers here and very unusually cold, so no breaking ground yet for the basement. Then of course road closures until May 17th, so no full cement trucks allowed before then. The suspense, if there is any.  ;) ;D
Post by: fishfighter on April 16, 2018, 04:41:14 AM
Why thanks SwampDonkey. It's cool here too for this time of the year. :o
Yesterday, I did finish painting the rest of the wainscoting. Today, I got to put a check in the mail for uncle Sam. >:( Then I might try to get something done.
Post by: fishfighter on April 16, 2018, 02:48:54 PM
Now you see it.
Now you don't. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1840.JPG?easyrotate_cache=1523903848)
Just have to throw some primer on it. Got to wait till it dries.
Post by: fishfighter on April 23, 2018, 05:45:08 AM
Been taking it very easy. Doctors appointment kind of went the way that ended with higher doses of meds. DanG Entresto has my blood pressure all over the place. :( Just have to give it some time for me to adjust to it.
I have been doing a little work. Mostly wood trim. Finished out the area outside the bedrooms and bath. Got the door casing all done. Everything is varnished.
Sorry, didn't get any pictures.
Post by: Magicman on April 23, 2018, 08:37:12 AM
Even finishing the small jobs is another step toward completion.  smiley_thumbsup
Post by: tule peak timber on April 23, 2018, 09:02:26 AM
Just caught this thread,,,terrific work !
Post by: fishfighter on April 23, 2018, 02:40:31 PM
Well, I got out and floated the bathroom. Took 5+ hours and a box of mud plus 2/3 of a bucket. :o I'm beat and my plan for the rest of the day, drink a couple beers and chill. ;D
Post by: fishfighter on April 30, 2018, 06:23:38 AM
This weekend I was able to finish out the front bedroom somewhat. Well, all sheetrock work done along with shooting it and painting it. All I have to do is the window wood casing and hang the door.
Going to try and spray a second coat on the roof today. Good warm dry weather for the next few days is a good time to get this done.
Couldn't get up on the roof. DanG PB was way to low and the wife saw it. So, I went into the bedroom and installed all switches and called it a day. Been napping the better part. :(
Post by: Magicman on April 30, 2018, 08:13:08 PM
I am assuming that you meant BP as in blood pressure?  Anyway, take care of yourself my Friend.
Post by: fishfighter on May 01, 2018, 04:38:45 AM
Yep, DanG blood pressure. It's been running around 90/50 and taking a toll on me. Even upping my meds hasn't helped. Got to call New Orleans today to see what can be done. >:( Just don't know if the old ticker is calling it quits now. It's just leaving so DanG tired all the time. >:(
Going to try and get something done today. Maybe a little sanding in the bathroom. No ladders, just don't want to take a spill. ;D
Post by: Magicman on May 01, 2018, 07:07:50 PM
My Prayers are for you and your heart my Friend.
Post by: fishfighter on May 05, 2018, 07:41:33 AM
Thanks Lynn. They made a adjustment on a med that help a little. So, I been taking it easy. Been dealing with a big sweetgum twin tree the fell from a storm. Been burning it in place. Real big sucker. Heck, I don't own a saw big enough to cut it up. :o Got it down in size now. ;D
I even got a little sawing done on some SYP. 4/4x6" and some 2x6. Will be using that as decking on the porches. Still have more to saw up, maybe next week.
I also started hanging some J channel. I will be using vinyl for the eves and porches. Was going to use Hardie Board, but changed my mind do to the weight.
Post by: Magicman on May 05, 2018, 09:51:12 AM
I have been checking and waiting for your update.  :P
Post by: Briankinley2004 on May 05, 2018, 04:01:19 PM
I took the vinyl down on my porch and put up cypress bead board. Stained and sealed each one before putting it up and it was easier than doing vinyl in my opinion. Looks way better than vinyl too. Just a thought. I lived with vinyl for 20 years then pulled it all off and installed cement board everywhere there was vinyl except the porch ceilings.
Post by: fishfighter on May 06, 2018, 02:55:56 PM
I would love to go that way, but all cypress trees are off limits on my place. It has been that way when my granddad didn't saw them way back in the 1920's. Got some real big ones on my place. ;D
Anyway, started doing a little trimming outside.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1850.JPG?easyrotate_cache=1525632425)
Yes, Hardie board. Looking at painting it only once.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1849.JPG?easyrotate_cache=1525632402)
Will have to pressure wash the complete house before painting. Got hot fast today and called it quits around noon. I have all the back done and will start working on the sides maybe tomorrow.
Post by: thecfarm on May 06, 2018, 09:21:49 PM
That BP is low. :o  I can see why you are tried.
Post by: sawmilllawyer on May 06, 2018, 10:30:55 PM
I admire your keep on plugging away attitude! You will get it done even if it is small steps. Take care of your BP AND YOUR HEART first. Really have enjoyed this thread and your skill set.
Post by: fishfighter on May 07, 2018, 08:45:27 PM
Thanks guys. I do try to take care of myself. At 60, there is very little that don't hurt every day. :(
Anyway, have anybody ever deal with Dottie, you know 811? >:( What a pain in the backside. >:( I called the last Tuesday and gave all info. Thursday, had some lines marked, but one I needed was across a pipeline. When you call that number, they have 48 hours to respond. Got a auto call back, saying no need for them to mark the line. >:( Knowing better, I call them Friday. Got a call back this morning from them and told them what is what. 35 minutes later, two guys showed up. ;D They mark the line. The two lines are about 6' down. Bad thing, I had to grind off the teeth on my bucket on the backhoe. Can't dig across the pipeline with teeth. WTH? I planning only to dig down about 18". This is for a 2" sewerage line to a settlement pond.  And to throw more in the works, no digging can be done unless a crew is on the job. :( I worked as a union worker just about all my life, but this takes the cake. :D Only good thing, they asked when I wanted to dig. Told them first thing in the morning. :D They should be here at 7:30 am. Well I hope.
Post by: fishfighter on May 10, 2018, 07:08:29 AM
Well, the pipeline crew was at my house for 7:30. ;D All went fine and the line is done across the pipeline. ;D
Settlement pond
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1855.JPG?easyrotate_cache=1525949945)
Just another 300'+ to go.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1856.JPG?easyrotate_cache=1525949997)
With the heat that we been in the last week, my work days are getting shorter. DanG 92F is not easy on me. :(
I did get some more trimming up with just one more side to do. Can't get the peaks. My SIL is using my 40' ladder. When he finishes up with it, he will bring it back and also finish out the peaks. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1861.JPG?easyrotate_cache=1525950024)
Post by: Magicman on May 10, 2018, 08:22:01 AM
Keep plugging along.  8)
Post by: fishfighter on May 10, 2018, 04:27:29 PM
Got back on it today and just about finished trimming eves out.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1863.JPG?easyrotate_cache=1525983257)
Well, as far as I am going to climb a ladder. ;D By 9:30, I called it a day. :(
I did add some drip edge that I was going to use all around. Not happy with it.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1864.JPG?easyrotate_cache=1525983279)
That is a 4" wide trim. It's coming off the first thing in the morning. I went and picked up some new trim that I should be happy with, I hope. :D
Post by: ksmitchell on May 17, 2018, 01:28:23 PM
Wow, I just spent the last few days reading this post from start to now. Fishfighter, this build is amazing and I am very impressed with everything you have done. I am hoping to start my cabin build here in a few months or next spring depending on the clean up I have to do at my property. Your post has given me lots of inspiration as well as ideas on how to do things. I look forward to seeing the end of this build, I hope your health turns for the better.
Post by: fishfighter on May 17, 2018, 02:36:32 PM
Why thank you Sir.
Very little work done on the house. We been in a heat wave the last two weeks. :o Topping out in the 90's with heat indexing in the 100's. :o So I been taking it very easy.
Post by: fishfighter on May 19, 2018, 06:16:36 AM
As dry as it is, I been on the backhoe doing dirt work. DanG bucket is skipping across the dirt it's so dry. :o Due to neglect of my pond the last couple years, I had a bunch of willow trees growing around it. Heck, they were easy 20' tall. My pond is now about 3' low due to no rain the last month+. :o I do want it to drop another 2'. I will be digging it bigger for the dirt to move it around the guest house yard.
Post by: fishfighter on May 22, 2018, 03:48:36 PM
Got out this morning and hung a door in the front bedroom. DanG oak was super hard. Had to sharpen my chisels a couple times. Also had to remove a piece of the door casing. That made things easy to install this heavy door.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1873.JPG?easyrotate_cache=1527017900)
I did resaw and planed some oak 1 1/2"x 5/16" thick stock that will be used for door casing trimming door stop. It just got to hot to do anymore. :(
Oh, still have to sand and paint the door.
Post by: Darrel on May 22, 2018, 07:24:25 PM
That is one good looking door!
Post by: Magicman on May 22, 2018, 08:50:27 PM
You probably have the only solid Oak doors in the entire state of Louisiana.  :)
Post by: fishfighter on May 22, 2018, 09:02:48 PM
Maybe so Lynn. :D I did have to use 4 1/2" hinges due to the weight. :o I do have an idea that is outside the box I might use. Still thinking on it. ;D Will let the cat out the bag in a day or two. :D Always thinking and love to try a different way. ;D
There is a good chance of some heavy rains here starting Friday and last 2-3 days. We really could used a bunch. Just maybe a TS to form in the Gulf. :o
Post by: Magicman on May 22, 2018, 09:17:48 PM
Yes, we will have a Tropical Event to contend with.  My hope that it will only be the much needed rain.
I'll be anxious to see your "outside of the box" idea.  smiley_idea
Post by: Darrel on May 22, 2018, 11:30:49 PM
Outside the box, a very good place to think and live.
Post by: Briankinley2004 on May 22, 2018, 11:46:50 PM
A continuous hinge works well on a heavy door. We do alot of lead lined doors for hospital CT rooms and most have either a continuous hinge or floor mounted hinge. Some of them we have to put wheels on as well. I doubt your oak doors are as heavy as lead if they are dry. 4-1/2" ball bearing hinges should work fine if so. Just make sure the jambs are thicker and fastened well
Post by: fishfighter on May 23, 2018, 12:17:24 PM
The jam is well secured I used 2" long screws thru the hinges, shims and into 2x4's. Not going anywhere. Yep, bearing hinges is what I used. Problem there, there is no pin. So only way to remove the door is unscrew it. :(
Did finished out the door and jam trim this morning. Came out nice. ;D Heck, even the wife liked it. :D Forgot my phone at the house. :(
Post by: fishfighter on May 25, 2018, 06:45:37 PM
Last couple days I been working on the back porch. So dang hot, so just looking for shade. ;D
First off was to install some 2x6's in between the joist. Once I got that done, I slapped on some tar/diesel mixture to protect it from bugs and rot. I hope it works. Were I had installed SYP and painted it with this mixture, no wood bees had touched it. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1877.JPG?easyrotate_cache=1527286784)
After that, I went and got some SYP 4/4x6" boards. To clear the edges and make sure that all of them are the same size, I edged them on the tablesaw.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1875.JPG?easyrotate_cache=1527286747)
Sawed out 30 and resticked them close by.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1874.JPG?easyrotate_cache=1527286708)
Now, I was going to past them thru my planner and then T&G them. The more I got to thinking about that, I saw that by doing that, there would be a good chance of trapping water. That will lead to rot.
So, this is my plan. Paint the under side with the tar mixture and on the top and sides, paint that with hot linseed oil. Now that tar mixture does dry out all the way to the touch. One can rub it and none comes off. But, just something about having a black deck will not work for me. :D
In that first picture, I did paint a couple boards on the under side.
Now if only I would get some rain here. Been having to run a pump 24/7 just to put some O2 in the water in my pond. It's close to 2' low now. Had a couple fish die on me. :(
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1878.JPG?easyrotate_cache=1527286809)
Got to love blue water. :D
Post by: Magicman on May 25, 2018, 07:05:28 PM
Plan on painting the Diesel/tar on the bark side of the boards and the pith side will go up.  That way if there is any cupping the edges will tend to go downward and not present a trip hazard.
Looks like the major moisture from Alberto will miss both of us.
Post by: fishfighter on May 26, 2018, 05:22:48 AM
Lynn, the way I had sawed up these deck boards, was most quarter sawed. And yes, painting the cup side only.
Back to using linseed oil. Before applying that, I'm going to stain out the boards to get them a bit gray.
Yep, that storm will not help with rain. :( Every afternoon, T storms have been popping off. Being were I am located at close to the Mississippi River and a big bend in it, that kills off the storms just about every time. I can watch the radar and sure enough, it happens. :(
Post by: fishfighter on May 27, 2018, 06:48:30 PM
Got the decking done today. And yes, I paid for it big time. >:( Of course a few boards had a bow in them. Using a 1/4" spacer to keep things right, I had one board that was easy 6+" that I had to pull in. A 2x4 and a couple 4x6's, I was prying that one in place. Well, something slip as I was pulling. Well, you can guess what happen. :D Got some real nice cuts and missing skin on my arms. Had on a white tee shirt that was red. >:(
Anyway, finished,  other then cutting the ends and I have to custom cut a end board that needs to be 6 1/2" wide. All others are 5 1/2" wide. Oh well. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1880.JPG?easyrotate_cache=1527461124)
Post by: Magicman on May 27, 2018, 06:57:32 PM
Ah, you will grow some more bark back onto those arms.   whiteflag_smiley
Looks like Alberto will miss both of us.
Post by: fishfighter on May 28, 2018, 11:30:57 AM
Heck Lynn, three days in a row I got a chunk of skin ripped off. >:( Started knocking my head into a diesel pump when filling up my truck. Had to stop filling due to the amount of blood poring out the gash. :o
Finished up that deck this morning.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1885.JPG?easyrotate_cache=1527521100)
This is the stain color I will be using. A mixture of steel wool and vinegar.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1886.JPG?easyrotate_cache=1527521118)
Kind of gave it some green, brown, reds and gray. The wife likes it. ;D
Oh, a picture of that oak door trimmed out.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1887.JPG?easyrotate_cache=1527521156)
Title: Re: Started the build.
Post by: Magicman on May 28, 2018, 12:34:26 PM
If your Wife likes it, you will be happy.   smiley_love
Post by: Darrel on May 28, 2018, 10:19:39 PM
The wife likes it, good deal!  :)
I like it too, but that really doesn't matter does it.  :D
Post by: fishfighter on May 30, 2018, 04:38:44 PM
I do like it some much, I started making a couple gallons of the stain. Takes about three weeks.
Last couple days, been taking it very easy and licking all my wounds. Did get out at day break to do a outside clean up. Had a lot of cut offs that I had to get out to my burn pile.
Other then that, it's so DanG HOT! Heat index has been hitting triples. :o No cooling within sight. :(
Got to do a road trip to pick up some planner knifes. Got a lot of oak I need plane out. When I make that trip, I will be checking on a fellow that makes molding. looking at get some 3 1/2" crown done. We will see. ;D
Post by: WolverineLiving on May 30, 2018, 11:24:37 PM
You Sir are an inspiration and your work is top shelf! I'm 54 and whine about my aches and pains all of the time, but after reading this I'm embarrassed and will shut up  :-[ The place is looking great and you should be very proud of what you've accomplished. Best of luck to you, can't wait to see her done!
Post by: fishfighter on May 31, 2018, 03:11:46 PM
Why thank you sir.
Got out and did some dirt work. Broke down my burn pile. It started when I was clearing the land and there was a lot of dirt in it along with everything else. Took a few hours with the backhoe and tractor.
The wife is a happy camper again. 8) Heck, she was talking of planting all kinds of flowers. Not going to happen. Still have to dig and install the rest of the sewage line right thru the middle.  :D
Of course I had to start a new pile. Did that when I dug up willow trees. ;D
Noon time, heat index at 103F and called it a day.
Post by: fishfighter on June 12, 2018, 10:39:06 AM
Just a little update. Really haven't did anything the last couple weeks. Due to heat and back under the weather. Got up out of the lounge chair and blacked out. Well, that screwed up my lower back again. >:( Still no relief from the pain, so I guess I will have to go in for a shot. >:(
Now if only we would get some rain. Very dry here. :o
Post by: Briankinley2004 on June 12, 2018, 10:00:55 PM
Looks like the rain is coming this weekend. I just canceled an offshore trip. 90% chance in Port Fourchon for Saturday
Post by: samandothers on June 13, 2018, 09:53:37 AM
Sorry to hear you are under the weather. Heal!
Post by: fishfighter on June 13, 2018, 07:03:44 PM
Why thanks guys. A lot of resting going on here.
Going to be a grandpaw again in about 50 days. Was drinking my morning coffee on the patio this morning and saw this.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1906.JPG?easyrotate_cache=1528930793)
   She was just finishing up laying her eggs. :D
Post by: fishfighter on June 15, 2018, 09:03:33 AM
It looks like a coon found the nest and ate all the eggs. >:(
Spent the day yesterday at doctors. >:( My little fall is not good. After a week, the pain got worse. :o X-rays showed no problems, but was told the area they looking at doesn't show good with X-rays. Got a cat scan set for Monday. Have to wait due to the insurance game. >:( If there is a fracture, I will have to have surgery. :o Mean time, was told to stay off my feet and use crutches to get around. >:( They did give me some good pain pills that has helped some. ;D
Post by: Magicman on June 17, 2018, 08:07:31 AM
I hope that all goes well with the back my Friend.  Congrats on the Granddad news.  :)
Post by: fishfighter on June 17, 2018, 10:44:29 AM
Lynn, DanG coon got her nest. >:(
Still just chilling. DanG pain is not lifting off which is not good at all. :o I will know what is what tomorrow afternoon and will go from there.
Also, my transplant team told me I have to get my battery changed out soon. Less then 6 months left. That will be 5 weeks of doing nothing after surgery for that. >:( Looks like no hunting unless I use a hand gun. Haven't did that in 15 years. :D
Post by: fishfighter on June 18, 2018, 06:57:29 PM
A bit of good news and some not so good news. I do have a very small hair line crack in my hip. :( Good new, I don't have to have surgery. ;D  Bad part of that, got to keep using crutches, take it easy and go in as need for a shot into the hip. That hurt, but has helped some with the pain.
So, I will try to get out and try to fix the track on my saw mill maybe in a day or two. I have to unbolt a section and then take the rail to a friends shop. He told me he should be able to bend it back. ;D This has been putting me off sawing some more syp lumber to cover the front porch.
Also, I have to start plane out a bunch of oak boards for trim and base boards. The wife will help me there. ;D
After almost two weeks of just laying around, I got to get myself back in the game of life. Sucks being the living dead. :D
Post by: Magicman on June 18, 2018, 08:07:47 PM
Steady as she goes my friend.  :)
Post by: fishfighter on June 18, 2018, 08:49:34 PM
Will do Lynn. ;D Good doctor did give me this option. He did tell me it will be a problem a long time without the surgery, then again that too was going to take a long time to heal up. So, I picked the less of two evils. ;D
Post by: fishfighter on June 20, 2018, 07:15:58 PM
Got out this morning and when and pulled a track off the mill bed. Had to get the wife to carry it up to the house. Then I was able to put it in the truck. I didn't get a picture, but with the rail laying flat, one end was a good 3" bend in it. :o
Took it over to my buddies shop. Said he will get it fixed in a day or two. He has a 150 ton press and said it will be no problem to fix it. ;D
Now the my mill is under cover, I think it is about time I clean it and do some touch up paint. Starting to get some rust spots. :(
On a side note. We been getting some rain. 8) Not much, but will take all I can get. ;D
Post by: fishfighter on June 23, 2018, 02:05:33 PM
Like a nut and with the wife eating my lunch, Got out yesterday and today. ;D Wasn't easy, But I just told myself there always a easy way. 8) I been waiting on my SIL to come finish out the bathroom sheetrock. As a contractor, he is way over tied up. I knew this, so no biggie.
So, just knowing sanding is very much labor that is way to hard on me. :( Well, the last couple weeks with time on my hands, I got to thinking about that. ;D
So, a $20 fixture and I was set for easy times of sanding. ;D I didn't want to use my good one. This is what I rigged up and I can't believe nobody came up with this idea. :o There are big ones on the market, but working in tight quarters, this was a win.  So, if anybody makes these in the future, send me a check. :D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1917.JPG?easyrotate_cache=1529775287)
Yep, some old pool hose that is 1 1/4". Took the bag off the fitting that hooks up to the sander and used duct tape to connect. Hooking it to a shopvac that has a very good filter system, it sucked up a easy 85-90% of the  dust. ;D Using 80 grit pads, things when very easy and fast. 8)
After passing that, just a very very lite hand sand was in order in the corners. ;D I really have to say, this has saved a lot of work. The only draw back, I had to dump and clean the vacuum filter often which only took a couple minutes.
As of 11 this morning, I have the bathroom primed out.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1918.JPG?easyrotate_cache=1529775331)
Next, got to pick up a couple bags of thinset. I have a bunch of Hardie board siding that is 4'x8' sheets. Going to put thinset down and install the Hardie Board on top. That will give a outstanding base for the flooring. ;D
Post by: submarinesailor on June 23, 2018, 02:18:17 PM
Been doing the same thing for years.  I have a Porter Cable RO sander that I hook to my shop vac for most of the sanding I do.  Went out an found a free 20'x1-1/4" hose making so I can put the vac outside while doing sheet rock - I get dust leakage even with good filters.  I recommend that every now and again you take the sander a part and clean it.  The dry wall dust builds up something terrible on the inside of the sander.
Bruce
Post by: fishfighter on June 23, 2018, 07:51:35 PM
I figured that the dust would build up. That is why I went and bought a cheap one. ;D For that $20 I spent, I'm a happy camper. :D
Post by: fishfighter on June 25, 2018, 03:37:00 PM
Spent a few hours this morning resawing and planning out some boards for the bathroom window and door casing. Got it done, but didn't have my phone with me. It's so DanG hot, I had to call it a day before 10. Heat index is 106F right now. Dead still. :o
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1919.JPG?easyrotate_cache=1529968170)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1920.JPG?easyrotate_cache=1529968212)
Over that door way is the track for the door. Got an idea that I going to give it a try. ;D
Post by: fishfighter on June 26, 2018, 08:01:13 PM
Really not all that happy with all that metal above the bathroom door. So, a outside the box and custom job as everything else, why not? :)
This was my idea. First I had to weld up a couple brackets for the off set and mounting things. I did have to make sure the rollers were clear. Once done, I had hung the door back up. Did I said this door is heavy? :D
Anyway, all is close, but still no cigar. :(
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1921.JPG?easyrotate_cache=1530056383)
Problem, I will have to pull the door trim off and plan it down another 1/16". :( Like I said, close, but no cigar. >:(
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1922.JPG?easyrotate_cache=1530056433)
It will be no problem, due to the fact I just tacked the door trim. ;D I still haven't varnish the door nor any of the trim. So, everything will come back down and work from there. :D I still have a bunch of custom works that will be installed in the bathroom. It's just going to take time. :D
Post by: Magicman on June 26, 2018, 08:12:34 PM
Very interesting.  You may have to make a video.   ;D
Post by: fishfighter on June 27, 2018, 04:13:28 PM
I did get the trim pulled and planned it down this morning. Had to call it a day.
Yesterday evening, I took another spill. >:( Yep, bang up my hip again. >:( at myself for not getting up slow out my chair.
Post by: fishfighter on June 29, 2018, 06:48:49 PM
No work getting done. Been on the hospital from yesterday. >:( Dang old ticker bottom out and they still don't know what is wrong. >:( Hope they figure what is what soon.
Post by: Magicman on June 29, 2018, 07:43:52 PM
DanG Paul and I know that you are doing your best to keep on keeping on.  My prayer is for your strength and health.
Post by: Darrel on June 30, 2018, 08:10:20 PM
And I'm saying a prayer for you too.
Post by: fishfighter on July 02, 2018, 10:40:38 AM
Hey, thanks guys. All is good now. Got out yesterday and at home. Very tired. Got to take it easy. :( I do have to go back next week. Also, again on the 18 I think. As to why they can't get things done all at once. >:(
Oh well, it's good to be home. ;D I just need to put some weight back on. My weight has dropped down to 159 lbs. :o That ain't good.
Post by: fishfighter on July 03, 2018, 10:14:17 AM
Got that bathroom door varnished this morning. Didn't have my phone with me, so no picture. Sure looks nice. ;D Got rain coming, I hope.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1924.JPG?easyrotate_cache=1530830398)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1925.JPG?easyrotate_cache=1530830425)
Post by: fishfighter on July 06, 2018, 08:33:46 PM
Resawed and plane out a bunch of lumber for trim work for the front bedroom early this morning before it got to hot.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1930.JPG?easyrotate_cache=1530923339)
Dang shame so much waste :(
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1929.JPG?easyrotate_cache=1530923385)
If only I knew what I could do with the waste. :( Firewood rack is full. :(
Post by: fishfighter on July 07, 2018, 12:40:02 PM
Trimmed out one window in the front bedroom. Did that after working on the sawmill and sawing up a little oak log.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1934.JPG?easyrotate_cache=1530981369)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1933.JPG?easyrotate_cache=1530981333)
Post by: samandothers on July 07, 2018, 12:43:08 PM
Glad you are back to it!  Don't over do it.  Looking great!
Post by: fishfighter on July 07, 2018, 12:56:01 PM
Hey, thanks. Small steps as I go. 8) Going to try and paint some ceiling tomorrow.
Post by: fishfighter on July 09, 2018, 01:35:32 PM
Got the bathroom ceiling painted yesterday and the walls done today. One of the few things I dislike is painting. :D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1936.JPG?easyrotate_cache=1531157361)
   Wanted something a bit lighter, but the daughter picked this color.
True color in sun light.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1937.JPG?easyrotate_cache=1531157377)
Tomorrow, I will go back and hang all the trim and door.
Post by: Magicman on July 09, 2018, 02:35:16 PM
Hey, if you don't like it you will have to deal with the family Veterinarian.  ;)
Post by: fishfighter on July 10, 2018, 01:18:48 PM
Really no problem Lynn. After hanging and varnishing out the trim, the color now has a tint of green. :D I'm sure once I install all the LED lighting, the color will lite up some.
Before varnish and paint.
After
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1939.JPG?easyrotate_cache=1531242775)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1938.JPG?easyrotate_cache=1531242761)
Doctor day tomorrow in New Orleans along with more tests. :( I will start finishing out all the wiring if I remember what was what. That one switch by the door is for 4 switches. 3 of them will feed a over head Vent/heater/light and the 4th feeds two over head lights. The later is something I have to go back and fill in the ceiling holes. Both have to be moved. >:(
Post by: fishfighter on July 12, 2018, 09:06:47 AM
Yesterdays trip was a all day trip. >:( Guess all is good.
So, with time on my hands, I got to kicking a crazy idea around. Being just about everything is custom built in this build, why not think outside the box even more. :D
The idea, I had my daughter make a moon stain glass that will be installed in the bathroom door. :D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1940.JPG?easyrotate_cache=1531400655)
She did finish it and dropped it off this morning. Just didn't take a picture of it yet. It's only 12" tall, so it's not over powering. ;D
A picture of it.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1942.JPG?easyrotate_cache=1531401893)
Post by: Magicman on July 12, 2018, 01:20:27 PM
I absolutely love it!!    smiley_thumbsup smiley_thumbsup
Post by: fishfighter on July 12, 2018, 02:00:22 PM
Well, to late now. Got a hole in the door.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1944.JPG?easyrotate_cache=1531418342)
Post by: PC-Urban-Sawyer on July 12, 2018, 02:55:41 PM
Love it!
Put a backlight in it and a switch to indicate occupied or off for vacant...
Herb
Post by: Darrel on July 12, 2018, 07:51:51 PM
Pretty nice! 👍
Post by: fishfighter on July 13, 2018, 05:40:30 AM
I did get the glass installed yesterday using silicone. Had to wait till today to flip the door over and put some silicone on that side. I had used some window tabs to center the glass in the door. Problem there, they stick out to much. So I will remove them then silicone. ;D Oh, did I say oak is hard? Like to never get those tabs to stick in. :o
The wife and daughter love the door. Does meet their approval. 8) Will update with a picture later this morning.
Still thinking on how I will make a locking device/handles for the door. I do have a couple ideas, but still kicking ideas around.
Post by: thecfarm on July 13, 2018, 06:22:56 AM
She did good and so did you.
Post by: fishfighter on July 13, 2018, 09:45:34 AM
Got the door hung back up.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1948.JPG?easyrotate_cache=1531489316)
Couldn't take a good picture due to to much light coming thru. The bathroom window is line right up with the door.
Post by: Magicman on July 13, 2018, 01:34:18 PM
Pat & I both smiled.  :)   :)
Post by: GRANITEstateMP on July 13, 2018, 04:13:07 PM
Man, your whole dang family is creative!  Door looks great!
Post by: fishfighter on July 14, 2018, 12:40:59 PM
Go out at first day light and loaded up the tractor with some 4/4x6" oak. Of to the sawmill to rip them down for door casing and some 2 1/4" lumber I need for cabinets in the bathroom. Once I did that, by up to the house and broke out the planner. Planed out a few boards for doors outside the bathroom and front bedroom. All others, I restacked and stickered.
Once planned out, off the install them. Got that done and had to call it quits for the day. To DanG HOT> :(
Didn't take any pictures. :( But, trim is trim. :D I will pick up were I left off tomorrow morning for a little more planeing out more lumber.
Post by: fishfighter on July 18, 2018, 05:26:16 PM
Been taking it easy with more time on my hands due to the heat. :( This heat spell has been real hell.
So, getting up early and hitting the ground at first day light, I been getting very little done. :( Resawing and planning out lumber. Anyway, started building cabinets for the bathroom.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1951.JPG?easyrotate_cache=1531948029)
I have more then that, but the only picture I took.
Took a bit of time, but I came up with what I wanted for door knobs thru the house. Yes, 3x the expense and 5x the trouble, but it all fits and I am so DanG happy along with the wife. ;D Like I told my grandson, we have diamonds.  :D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1950.JPG?easyrotate_cache=1531948086)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1949.JPG?easyrotate_cache=1531948118)
Got to love old school. Always walking thru my grandfolks  homes, I always look at those diamonds hanging on the doors . :D
Post by: Magicman on July 18, 2018, 05:52:35 PM
Gotta Love it.
(https://forestryforum.com/gallery/albums/userpics/20011/DSCN0125.JPG?easyrotate_cache=1434670235)
(https://forestryforum.com/gallery/albums/userpics/20011/DSCN0135.JPG?easyrotate_cache=1434850314)
That is the same diamond that I repurposed for the new Cabin bathroom.  It was reused from the bathroom door from late 40's in the house that I grew up in.   :)
Post by: fishfighter on July 18, 2018, 06:19:51 PM
Lynn, I tried finding those type of hinges. Couldn't. Even checked ebay.
Going to try to wrap up the bathroom tomorrow. Been wanting to take a trip up north, but can't. Was told I have 6 months on my battery or one week. >:( Asked to have it changed, but was told insurance will not do it till I get a alarm in my chest. >:(
I just don't know anymore. >:(
Post by: Briankinley2004 on July 18, 2018, 08:20:27 PM
Cant help ya with the battery replacement but I do have some jumper cables 8)  On the door hinges try this place.
Butt Hinge | Butt Hinges | Antique Brass Hinges | House of Antique Hardware (https://www.houseofantiquehardware.com/butt-hinge?GCID=S14464x015&KEYWORD=classic%20door%20hinges&partner=gpc&gclid=CjwKCAjwyrvaBRACEiwAcyuzRIw6dWyLF_iauIvnp0DNIl0AXn5sCXzCxWjULscW5NVGq-7PW3QlhhoCvrIQAvD_BwE)
Post by: Magicman on July 18, 2018, 08:33:29 PM
As you found out Paul, those non-mortice door hinges are well over 100 years old.   :-\
Post by: fishfighter on July 19, 2018, 06:57:19 AM
I did find some, but the problem is weight limits. That door is very heavy.
Post by: fishfighter on July 19, 2018, 03:13:02 PM
Got this put together today.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1955.JPG?easyrotate_cache=1532027366)
Almost finish the base.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1956.JPG?easyrotate_cache=1532027405)
Post by: tule peak timber on July 19, 2018, 04:57:52 PM
Nice! Keep up the good work and drink plenty of water !
Post by: fishfighter on July 19, 2018, 06:01:34 PM
Doing that and I worked in ac today. ;D All was good till I got tired. :(
Post by: fishfighter on July 25, 2018, 05:41:42 PM
Been taking it easy. DanG heat. :o
Just about finish the vanity.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1960.JPG?easyrotate_cache=1532554465)
Draws
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1961.JPG?easyrotate_cache=1532554484)
I did install the fronts to the draws, but didn't get a pictures. Everything is sanded down and I should get three coats of varnish on it tomorrow. Then I will get the doors done.
Still have another big cabinet to build for the bathroom.
Post by: Magicman on July 25, 2018, 06:41:25 PM
Paul, your middle name must be Timex.  Takes a lickin' and keeps on tickin'.   8)
Post by: thecfarm on July 26, 2018, 05:00:47 AM
All looks good.
Mine wood working skills stop when the tree hits the ground.  ;D
Post by: Jim_Rogers on July 26, 2018, 07:09:12 AM
Quote from: thecfarm on July 26, 2018, 05:00:47 AM
All looks good.
No it doesn't you have a sawmill.
Post by: fishfighter on July 26, 2018, 07:18:58 AM
Yep, have sawmill, one can build. ;D For the 3K I paid for mine, I think it has paid for itself many times over. ;D
Counting the cost of the mill and house build, I'm under 8K together. And that includes 1.5 K for a treatment plant that is in the ground. >:( One has to have it here. :D
Post by: thecfarm on July 26, 2018, 07:42:48 AM
Yes Jim you are right.  :)  But I would have a hard time building furniture out of wood.
Post by: Crusarius on July 26, 2018, 07:54:52 AM
Steel is much more forgiving. You cut it to short, oops, weld it back together and cut it in the right spot :)
As I get older and more patient I am getting better with wood. Pretty sure my steel fab skills are still better.
Post by: fishfighter on July 26, 2018, 01:11:59 PM
Three sprayed coats on varnish and it's done besides the doors.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1963.JPG?easyrotate_cache=1532624863)
Going to try to get the doors done tomorrow.
Post by: fishfighter on July 27, 2018, 12:35:21 PM
Got the doors done this morning. Just waiting on the glue to dry. Then I will sand out and varnish today.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1965.JPG?easyrotate_cache=1532709027)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1966.JPG?easyrotate_cache=1532709064)
Tomorrow, I will start on the other cabinets. Yes, two.
Post by: Magicman on July 27, 2018, 02:35:42 PM
smiley_thumbsup   8)
Post by: samandothers on July 27, 2018, 06:14:17 PM
Looking good!  Not letting any grass grow under your feet!
Did you do anything to the wood to Treat for bugs?  Looks like wood may have holes in it.
I like the look of your cabinets with the varnish finish.
Post by: fishfighter on July 28, 2018, 06:22:32 AM
Those holes are from Ambrose beetles. They all leave out once the wood dries. I did spray with Borate. Most of the wood I am using has been dried for two years. Also, with the amount of varnish I am applying, all wood is incased. I been keeping a very close eye on thinks to make sure nothing is living in the wood. Haven't seen anything yet.
Post by: samandothers on July 28, 2018, 09:21:52 AM
Looks great!  Thanks for the info.
Post by: fishfighter on July 28, 2018, 10:16:40 AM
Didn't get a chance to spray the doors, so I went out there and did them this morning. Also had moved the vanity in the bathroom. Once the doors are dried, I will hang them and get a picture.
Here is the vanity in it's place.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1969.JPG?easyrotate_cache=1532795850)
Post by: sawmilllawyer on July 28, 2018, 11:41:26 PM
 8)As always looking good!
Post by: fishfighter on July 30, 2018, 03:34:50 PM
Got out early this morning and knocked this base cabinet out.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1973.JPG?easyrotate_cache=1532978179)
It's 23 1/2" wide. That gives me about 1/8" on each side to slide it in place. But, after checking things for a third time, I ran into a little problem. :( To get that into this spot.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1974.JPG?easyrotate_cache=1532978212)
I will have to remove the door trim on that side. :D This cabinet is just across from were a set of stackable wash/dryer will be placed. The base cabinet will be there to store cleaning products and the likes. This area can be used to fold things coming out the dryer.
Now I wanted to used granite for the vanity and this base cabinet top.
Now this is were I could used a idea or three. On that base cabinet, I would like to have a extension about 14" extending out from the base cabinet. Looking for more counter top space. Was thinking some hinges that can fold up and out the way. Problem there, granite and weight.
Another idea, build a custom board that can be removed. Would have to install some slats on the walls, maybe 1"x1". Would be lite enough to remove when one needs to.
Let me hear y'all's ideas here. ;D
Post by: Crusarius on July 30, 2018, 03:57:04 PM
pullout flush to bottom of the countertop on ball bearing slides. takes up very little space adds bunch more space.
The other option would be lifting hinge. not sure thats its real name but would allow the flat top to be under the countertop and be pulled out and lifted up to flush with countertop. this option takes up more space.
Post by: fishfighter on July 31, 2018, 07:23:26 AM
I did think of a pull out shelf. I will go try to find what I would need to see if I can make that work.
Got some much need rain coming today, I hope.
Post by: fishfighter on July 31, 2018, 07:05:09 PM
Every thing is together. The door.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1976.JPG?easyrotate_cache=1533077921)
Once things dried, it was time to put things together.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1978.JPG?easyrotate_cache=1533077977)
All sanded out and ready for varnish which I will get done the first thing tomorrow morning.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1979.JPG?easyrotate_cache=1533078006)
Post by: fishfighter on August 01, 2018, 05:55:03 PM
All varnished and in it's place.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1995.JPG?easyrotate_cache=1533160159)
And I finished the top cabinet. Still have to finish cleaning it up and build the door.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1994.JPG?easyrotate_cache=1533160195)
So much for rain. :( We are in need of it bad. It just keeps going around me. :(
Post by: Magicman on August 01, 2018, 09:43:07 PM
Rain is going around me too Paul.
The cabinet work is superb.   smiley_thumbsup
Post by: fishfighter on August 02, 2018, 07:33:40 PM
Lynn, we just had a three minute shower. :( Need a couple days soaking here.
First thing this morning, I hung that top cabinet. I did drop it a little compared to kitchen cabinet spacing.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1997.JPG?easyrotate_cache=1533251962)
To close up the little space in between the cabinets and walls, I have some oak strips that are 3/16" thick and 1/2" wide.
As you can see, I sure did have to pull that door trim away. :( Yep, tight spaces. ;D
Once I got that done, I built the door. This is it not glued together, but it is now. ;D Will sand it out in the morning and varnish it.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1998.JPG?easyrotate_cache=1533252007)
For some reason, I hit the jackpot to quarter sawed lumber. Should of put that stock were I have a bunch of other quarter sawed oak. :o Oh well. :)
Post by: fishfighter on August 03, 2018, 12:04:07 PM
Done with bathroom cabinets other then some small trim out. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_1999.JPG?easyrotate_cache=1533311729)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2001.JPG?easyrotate_cache=1533311764)
Taking it easy for the rest of the day. Kind of dragging. :(
Post by: fishfighter on August 05, 2018, 05:23:33 PM
So, it was back to the drawing board, and that is what I did. :D Worked on that extension and got it done.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2007.JPG?easyrotate_cache=1533503655)
With it extended.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2008.JPG?easyrotate_cache=1533503729)
Used 3" screws and glue to mount the side runners.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2006.JPG?easyrotate_cache=1533503746)
Once I got all that together, I had pulled the extension out. removed and sand then varnished. Just have to put things back together. Very happy how that worked out. ;D
Post by: Crusarius on August 06, 2018, 07:45:21 AM
Looks great. any reason you didn't use full extension ball bearing slides?
Post by: fishfighter on August 06, 2018, 08:13:30 AM
All the ones around here are 1 1/2" wide. Was looking for low profile and drawer sliders was small enough which is 3/4" wide.
Post by: fishfighter on August 06, 2018, 02:34:04 PM
Another day in the bathroom. Still trying to rap this up. First thing, had to remove the base cabinet and the vanity. Then it was time to clean up the floor of wall mud. Scrapping, vacuuming and the stealing the wife's mop. Glad she is not home. :D
Then it was time to cut out some pieces of Hardie Board. I just so happen to have a bunch of 4'x8' sheets. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2010.JPG?easyrotate_cache=1533579641)
As you can tell, the sub floor is still wet from mopping. :D
All cut out now.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2011.JPG?easyrotate_cache=1533579661)
I will remove it tomorrow and then put down some thinset and then put the boards back down. This will give a real good floating base for the flooring to come. ;D
On a side note. Found more then enough granite to cover the bathroom base and vanity cabinets. I will be going look at it this afternoon. If the color is good, I will get it. Bonus buy at $50 for it. Now if the color is good. :o
Post by: fishfighter on August 08, 2018, 01:43:56 PM
Yesterday, I had applied thinset and finish that. I did get that granite. Not the best color, but it will work. Spent the rest of the day cutting that up.
With the granite, there is a lip that was hanging to low for the pull out drawer. :( Raising it was out the question. :o So, mod two for that drawer. ;)
Had to remove what I added. Had to grind a little off the drawer slide and then cut into the base cabinet top front. Installed some runners and then installed the drawer slides. Hey, it works. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2014.JPG?easyrotate_cache=1533749393)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2015.JPG?easyrotate_cache=1533749430)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2016.JPG?easyrotate_cache=1533749447)
All in a day, I guess. 8)
Post by: Crusarius on August 08, 2018, 01:55:30 PM
how did you cut the granite?
Post by: fishfighter on August 08, 2018, 02:50:16 PM
Diamond blade on my circle saw. Used the same blade for Hardie board.
Post by: Magicman on August 08, 2018, 06:19:08 PM
Looks like you have been busy while I was traveling Paul.  Looking good!!!  8)
Post by: fishfighter on August 08, 2018, 06:59:35 PM
Small steps Lynn. Hope you had a great trip. We are dealing with my MIL. Things went to the crapper. Dang woman looks like she is 65 and was more active then that age. She is 80. She had came down with encephalitis. 100 tests and they still don't know as to why. :( This has been going on almost 4 weeks. >:( It is sad to see someone going down so quick. :( They will be transferring her to a local hospital under skill care maybe tomorrow.
Post by: fishfighter on August 09, 2018, 02:12:01 PM
More granite cutting.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2022.JPG?easyrotate_cache=1533838168)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2021.JPG?easyrotate_cache=1533838132)
Post by: fishfighter on August 12, 2018, 11:46:51 AM
Bathroom floor down. It's a vinyl floating floor 100% waterproof. All just snaps together.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2026.JPG?easyrotate_cache=1534088520)
Post by: Magicman on August 12, 2018, 03:38:21 PM
Looking Good my Friend.  smiley_thumbsup
Post by: submarinesailor on August 12, 2018, 04:20:42 PM
Quote from: fishfighter on August 12, 2018, 11:46:51 AM
Remember to caulk/seal around the outer edges.  Know someone who thought it was water proof and found out about the edge sealing requirement - grandkids, plus water equals the hard way.
Post by: fishfighter on August 12, 2018, 09:56:09 PM
It's 100% plastic. Under floor is sealed too! Going to try to get the base boards down tomorrow.
Been a hard week for the wife and I. It's been a year today our son passed away. That and with MIL in the hospital that will need 24/7 care, it has been really hard on the wife.
Post by: Magicman on August 12, 2018, 10:25:01 PM
Paul, my Heart is with you and your Wife.
Post by: fishfighter on August 13, 2018, 04:07:55 PM
Thanks Lynn. DanG doctors still don't know what is happening to MIL. 99% of all the test are back with no answer. What ever it is, it is attacking her brain on the right side and very fast. :(
Anyway, I did resaw enough lumber and planed it out for the bathroom. Going with 5 1/2" base boards. Got all cut for their places. Just have to varnish it all before installing. I like it. Makes the floor pop out. 8)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2029.JPG?easyrotate_cache=1534190317)
On a side note. Our daughter made this for us. The picture doesn't do it justice.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2030.JPG?easyrotate_cache=1534190355)
The morning sun will hit it just right. ;D
Post by: samandothers on August 13, 2018, 07:11:17 PM
I know this must be a rough time.  The work you are doing looks great!
Your daughter is talented.   Really liked the piece she did for your bathroom!
Post by: thecfarm on August 15, 2018, 01:57:23 PM
Enjoy watching your progress.
Just wish things was better for you.  :(
Post by: fishfighter on August 15, 2018, 04:51:25 PM
Thanks. Just been fishing up what was left in the bathroom. I do need to do a little touch up painting, install lights and plugs in that will rap that area up. ;D
Post by: Magicman on August 15, 2018, 08:21:18 PM
Post by: Armymann50 on August 16, 2018, 05:24:17 AM
You do good work!!!
Post by: fishfighter on August 16, 2018, 06:04:03 AM
Welcome a board Army. There is some great info on this web site.
Post by: fishfighter on August 25, 2018, 07:27:30 AM
Morning everyone. Been almost two weeks from my last update. :(
Haven't really been doing much on the build other then some painting. :( We still dealing with my MIL. Things have been going down hill fast for her. Also, ben riding the tractor doing a lot of clipping. As to why, I don't know. There are very little to no pecans here this year again. >:( This will make a fourth year of a bad crop.
Anyway, I'm going to try to fire up the sawmill today. Been putting that off way to long and not having season dry oak lumber will slow this build down. I'm >:( at myself for not doing what I should of done three months ago. I do have a few oak logs that were from standing dead trees. They are dried, so that is a plus to help me out. ;D
Post by: Magicman on August 25, 2018, 09:27:55 AM
I was beginning to get concerned about you so don't stay gone for so long. smiley_whip
We haven't had any Pecans either.  This Spring I punched holes in the ground around the tree's drip line and filled them with triple 13, and will try to do it each year from now on to maybe give the trees whatever they are needing.  I know that rain at the wrong time while they are pollinating will reduce the crop but we have been too many years without Pecans.  Of course my problem too is that my Pecan trees are at the Cabin 45 miles away.  The squirrels and Crows get first choice.  :'(
Farmer sawing customers here are busy getting hay in so not much sawing going on.  I thought that one would saw this week but now he is helping his neighbor with hay.  Really no matter because it will be cooler.
Edit:  The Farmer/customer called this morning and we are on for Monday.
Anyway I am anxious to see you finishing that Guest House.
Post by: fishfighter on August 25, 2018, 07:33:13 PM
Lynn, I am trying to finish, but it is getting harder by the day. More bad news for MIL. They calling it. :( They will be transferring her back to the local hospital Monday. Just to treat her to make her comfortable. Guess that is all we can ask at this time. It is very hard to see someone go down this fast in 6 weeks.
Anyway, jump right to it early and threw some more paint on the build. After that, jump on the tractor, loaded a log and off to the mill. Good dry water oak. Wasn't a big one, but knew for what I will need to build three doors, it will due. ;D Was nice to mill something for a change anyway. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2036.JPG?easyrotate_cache=1535238761)
Making my cant, guess the blade had it. :o
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2037.JPG?easyrotate_cache=1535238783)
Guess it happens after sharping them 5 times. 8)
Got that stack of lumber all done. Still need to edge a few boards, but no hurry there.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2038.JPG?easyrotate_cache=1535238804)
These are for the infill of doors. I sawed them 1" thick. I will plane them down to what I need. I have a very nice stanch of 2x6 and 2x8 that are nice and dry. Moisture on the center cuts is reading around 22%. Should finish drying down to 11% fast.
Post by: thecfarm on August 26, 2018, 05:23:07 AM
Yes,it's nice to run  a sawmill. :)
Post by: fishfighter on August 27, 2018, 09:03:35 PM
Today, they moved MIL back to a local hospital. She is now under Hospice care. There is no improvements and they still don't know what had attack her brain. :( This woman has been the back bone of her family. Had always had cooked a Sunday dinner for the family. Even after FIL pasted away almost 17 years ago.
Got a little work done today. Something I been sitting on that I was going to use in my house, but being my house is built on concrete, I just didn't want to go thru the trouble of installing it. :( One of my brothers gave me this. Come the first of next month, it will be two years he passed away. :'(
This is some very hard Rosewood. Very heavy.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2041.JPG?easyrotate_cache=1535417161)
   I have about 300 sf of it, but will only need about 180 sf for the front bedroom.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2042.JPG?easyrotate_cache=1535417185)
So, just about all painting is done in that room. Still have to do a little more varnishing on some trim.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2043.JPG?easyrotate_cache=1535417206)
   Maybe tomorrow.
Post by: Magicman on August 27, 2018, 09:14:12 PM
You will make good use of that flooring and it will be a nice memorial.  I have an item built into my Cabin that my (only) late Brother made.  It gives me a warm feeling keeping his memory alive.
Post by: fishfighter on August 28, 2018, 07:51:05 AM
Yes Lynn, it will. I have a few things of my son's that will be installed into the house too!
Post by: Armymann50 on August 28, 2018, 11:09:35 PM
I have an Oak log you can have. 25' long and about 34" across. It have been on the ground since Christmas.
Post by: fishfighter on August 29, 2018, 06:43:24 AM
Army, a log that big would kick my butt. I thank you for the offer. ;D Besides, right now I have a bunch already on the ground that I need to saw up along with many more standing dead trees. :(
Yesterday, I had to take a day of rest. Just couldn't get moving. One of those "bad days". >:( Bit better this morning. Had loaded a log on the mill a couple days ago that I might try to saw up today before any rain comes.
Got this
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2044.JPG?easyrotate_cache=1535563141)
All sawed up to 4/4x6" for base boards.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2045.JPG?easyrotate_cache=1535563162)
Should be enough. ;D
Post by: fishfighter on September 03, 2018, 08:07:56 AM
Haven't been doing much on the build. We still dealing with MIL. Hospice doesn't know how she is still alive. :'(
I did put some of the flooring out. Still letting it acclimate to the room. Now with a good chance of a TS coming our way, that will put off installing the floor.
Just having them out. Not installed.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2048.JPG?easyrotate_cache=1535974864)
Post by: Magicman on September 03, 2018, 10:34:17 AM
That flooring is gonna look good.  :)
Batten down your hatches because it looks like both of us will get whomped by Tropical Storm Gordon.  The map shows you taking a direct "eye" hit and I will be on the "wet side".  Look out for tomorrow PM and Wednesday.  :o
Post by: fishfighter on September 03, 2018, 01:58:36 PM
Will do Lynn. Keep a eye out on falling trees.
Just got home from the hospital. With her family at bed side, My MIL passed away just after 11am. She went very peaceful. :'( She will be missed by all.
Post by: Jim_Rogers on September 03, 2018, 02:08:10 PM
So sorry for your loss.
Jim Rogers
Post by: Magicman on September 03, 2018, 03:04:37 PM
Paul, I offer my sincere Condolences to your entire family.
Post by: Darrel on September 03, 2018, 05:09:55 PM
I will be saying a prayer for you and your family. I know that times like this are tough and my prayer is that you have the strength you need to see you through.
Darrel
Post by: fishfighter on September 04, 2018, 08:27:51 AM
Thanks everyone.
Post by: PC-Urban-Sawyer on September 04, 2018, 12:18:56 PM
Paul, my deepest condolences to you and your family. Praying the Lord will give all of you strength and peace in this time of your great loss.
Herb
Post by: LeeB on September 05, 2018, 01:27:57 AM
So sorry to hear of your loss. Although we have never met I can see from this thread that you have a huge inner strength. Draw from that well to help you get through your troubled times and give to your family support.
Post by: sawmilllawyer on September 05, 2018, 08:35:44 PM
Sorry to hear about your loss. You and your family are in our prayers. Keep the faith and stay strong.
Post by: fishfighter on September 08, 2018, 05:41:16 PM
Thanks again all.
Got out yesterday and finished up some dirt work.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2055.JPG?easyrotate_cache=1536442058)
Treatment plant. The lift station, instead of paying almost $300 for a fiberglass tank, I used a free 55 gallon plastic drum that has a screw top. ;D So if and when the lift pump goes out which they do, not much work digging to replace it.
So, to know were the center of the top, a picture with a tape.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2056.JPG?easyrotate_cache=1536442108)
Everything is now all covered back up.
Post by: Magicman on September 08, 2018, 09:27:07 PM
That picture printed out and filed with all of your other paperwork is a smart idea.   smiley_idea
Post by: fishfighter on September 09, 2018, 07:44:29 AM
Lynn, I did the same thing for my house. Save a lot of time. More so when I had to have the system pumped out.
How you made out with that storm? Not a drop of rain here. That water in that first picture came from the over flow of the tank which if full. Ground is super dry here. Had to use a pick to dig the section at the house.
Post by: Magicman on September 09, 2018, 02:49:52 PM
Gordon went 60 miles East of us so we had a complete miss.  No water or wind whatsoever.
Post by: fishfighter on September 25, 2018, 11:08:41 AM
Just a update. I haven't been able to get anything done the few pass weeks. DanG neck is doing it's best keeping me down. Now have a pinched nerve that has taking out use of my right arm and hand. >:( DanG pain level is out the roof. >:( Bad thing, called the doctors office more then three weeks ago and they can't get me in till the 4th of next month. >:(
So all I been doing is try to go for a short walk and laying around the house.
Post by: Magicman on September 25, 2018, 03:42:14 PM
Thanks for the update Paul and hopefully you can manage to get back to your project soon.  At least your lumber is drying.  ;D
Post by: Darrel on September 25, 2018, 11:39:55 PM
I good to hear from you, just wish it was better news. Hang it there and get better soon.
Post by: fishfighter on October 13, 2018, 08:04:46 AM
Lets try this again. Lost my post. Anyway, good morning everyone. Had a very good night of sleep last night. Got that shot yesterday in my neck. Helped a lot, but by no means, a 100%.
Last couple weeks, I been taking it very easy. My daughter been wanting a country kitchen table. I sawed out all the lumber well over a year ago and told SIL to come pick it up to build the table. Well, him starting a new biz in the last year leaves him with little to no spare time. :D
So, I started it. All out of SYP. Will finish out the legs today before LSU plays. Just have to add the top 45's and some pegs.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2085.JPG?easyrotate_cache=1539430397)
On a side note. There are some real good people here. Posting in a wood working thread, member "beenthere" replied. He took the time and sent me a set of Craftmans molder/shaper set for free. ;D When I got the package, I was like a kid on Christmas morning opening it. I will put them to use this week trying to make some molding for the guest house build. I found a couple places to make some, but they wanted a arm and a leg even supplying the stock. :o
Thank you again beenthere.
Update.
Legs are finish
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2088.JPG?easyrotate_cache=1539452059)
Post by: Magicman on October 13, 2018, 01:54:24 PM
That table will be exactly what the Doctor Daughter ordered.  ;)
It's so good to see your smiling :) face back on here. smiley_thumbsup
Post by: Darrel on October 13, 2018, 10:36:34 PM
Those are some pretty awesome looking table legs!  And as MM says, it's good to see you back!
Post by: fishfighter on October 14, 2018, 08:46:14 AM
Why thanks guys. The wife fussed me yesterday, but hey, all is good. Going to try getting the table top started today. All pieces have been done, just need to join them to start with.
Post by: fishfighter on October 15, 2018, 08:39:20 PM
Got the table top just about done.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2094.JPG?easyrotate_cache=1539649874)
Joining the live edge, I had to come up with a way to clamp and not damage it.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2091.JPG?easyrotate_cache=1539649931)
Worked like a charm. 8) Had to have SIL and his helper come by to bring the top inside. Way to heavy for me and the wife to carry. >:( Got rain for a couple days in the forecast, so I will lay low, need to.
Post by: fishfighter on October 18, 2018, 03:50:23 PM
Finished up the table today. Came out nice. 8)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2099.JPG?easyrotate_cache=1539891956)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2100.JPG?easyrotate_cache=1539891975)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2101.JPG?easyrotate_cache=1539891994)
Post by: bwstout on October 18, 2018, 03:55:54 PM
Fabulous  building one is on my next to do list.
Post by: Darrel on October 18, 2018, 04:44:10 PM
Yes it did, it came out very nice!
Post by: fishfighter on October 20, 2018, 08:56:40 AM
Yesterday I knocked out two benches to go with the table.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2103.JPG?easyrotate_cache=1540039912)
SIL came by after work and he took it home. Daughter loves it. She was surprised. She didn't know I was building it. ;D
Post by: fishfighter on October 26, 2018, 05:48:50 PM
My daughter sent this picture to me today. Her and SIL finished the table. Still has the benches to do. They did a real nice job. 6 coats of Spar Varnish.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2105.JPG?easyrotate_cache=1540590317)
Post by: thecfarm on October 27, 2018, 06:11:12 AM
WOW!!! That critter sure does shine.
You both are a match.
Post by: samandothers on October 27, 2018, 08:44:13 AM
You did a great job on the table!  Their finish sure makes the grain pop.
Post by: fishfighter on October 27, 2018, 10:30:37 AM
Gave them a bunch of wood scraps to test what stain they liked best.
Post by: Magicman on October 29, 2018, 07:55:02 AM
Outstanding Paul, that table is a masterpiece!!  :)
Post by: fishfighter on October 29, 2018, 09:28:11 AM
Why thanks all. It was a fun project to do. Was no rush. Biggest thing was hiding it away from my daughter till it was finished. She didn't know I was building it. ;D
I need to get back to work on the house build, but I been picking up some real nice SYP logs for free. They will be used for lap siding for a rent house that my daughter and SIL bought. They had added on to it and need to match the lap siding. To bad I can't get cypress.
Fog is very thick this morning which is keeping me off the road for a trip. :(
Post by: Magicman on October 29, 2018, 06:12:24 PM
Today's Cypress probably would not be much improvement over the SYP.  Most that I saw run in the 20" category with very little heartwood.
Post by: fishfighter on October 29, 2018, 06:57:46 PM
You are right Lynn. :( I did get out and planned out around 200BF of oak that I sawed up a good time ago. First had to resaw it. It was 7" wide, had to saw it down to 6". All this is for base boards. Guess that is a step in the right direction. ;D
Post by: Weekend_Sawyer on October 30, 2018, 01:42:57 PM
Paul, I have been following this thread since the beginning.
First let me say I am sorry for all the trouble you have been through.
some of the posts in this thread broke my heart.
Second is that you are one hell of a craftsman.
beautiful work throughout this thread.
Thank You for sharing
Jon
Post by: fishfighter on November 01, 2018, 07:26:13 PM
Why thanks Jon. Still waiting on Kaso to send my blades. Been over a week. :(
Anyway, had a very good time with my grandson for Halloween. He was a scary clown, me a bearded lady. :D Yes, I did have a dress on. :D Bad thing, just as we were finishing up trick or treating, didn't I stepped were I shouldn't. :o Yep, busted my butt and left hip. Yep, a bad one. Using a dam walker to get around. >:(
Post by: Magicman on November 01, 2018, 10:02:21 PM
Whoa Paul, hopefully it is not broken.  Stay in touch and give us an update.
Post by: fishfighter on November 02, 2018, 10:43:26 AM
Hey Lynn, I a bit better this morning. Able to put a little weight on my left leg. Still having a bunch of pain, but that eased up some. Should be good in a couple days. ;D
Today is our 39Th anniversary. Going to try taking the wife out to dinner.
Post by: thecfarm on November 02, 2018, 02:34:36 PM
I think dinner would be a good idea. You need the rest. And a few points with the wife helps too. ;D
Post by: Magicman on November 02, 2018, 07:28:35 PM
Dinner is a good idea and Happy Anniversary.  smiley_love
Now for a "none of my business" question.  It's fairly well know that I loves me some cajun cooking so tell we what a coonass orders when he goes out to eat??  ;D
Post by: fishfighter on November 03, 2018, 09:25:20 AM
There is a outstanding Mexican place here in town. Outstanding food. Got to have much season in the food to please a coonass. :D
Post by: Magicman on November 03, 2018, 09:09:23 PM
You are a good man Paul.  :)
Post by: LeeB on November 04, 2018, 12:24:10 PM
Quote from: fishfighter on November 03, 2018, 09:25:20 AM
Wait up, ain't Ventress north of I-10?
Post by: fishfighter on November 04, 2018, 01:05:58 PM
Yes it is. We have a bunch of Mexicans that live in the area due to sugarcane grown here. Very hard to find field help these days if you know what I mean. >:(
Post by: LeeB on November 04, 2018, 01:11:06 PM
How much cane work is there now that isn't mechanized?
Post by: fishfighter on November 04, 2018, 04:00:37 PM
It's still hand planted. That has to be done every 3 years. Then you need labor to drive field equipment and over the road drivers. The trailers they pull on the road are loaded up well over 100K. It's the only crop in the state that can have over 80K loads. >:(
Post by: LeeB on November 04, 2018, 09:05:21 PM
I well remember the muddy roads and a few hairy moments during cutting time.
Post by: fishfighter on November 08, 2018, 05:26:08 PM
Just a update. Still using a walker to get around. Doing the insurance game waiting for them to OK a CT. >:( Unreal. >:( Taking a bad fall and bruised to hell, one would think one could walk a week later. :o
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2108.JPG?easyrotate_cache=1541715889)
My neck is better after that last shot, so that is a go. ;D
I did get my saw blades in today ;D They dropped them off under my carport. Bad thing, it's been raining a lot here with more rain to come the next few days. Will get my daughter to put them away out the weather. Just can't do it myself. >:(
Will talk to SIL to see if he has the time to come over and start sawing the siding. I know he wants to get that done, so I can always sit, watch and tell him what needs to be done and me drinking beers. :D
Post by: Magicman on November 08, 2018, 08:00:08 PM
Well at least you can still laugh.  :D
Post by: fishfighter on November 09, 2018, 04:53:17 AM
I have to Lynn. DanG walls are closing in on me. Going to do a road trip today just to get out. I'm in need of a new air nailer. ;D My 16 ga nailer started giving me a little trouble. Then again it's about 15 years old.
Post by: fishfighter on November 15, 2018, 07:48:25 AM
A little update. :( Yep, I do have a break in my hip. Doctor wanted to do surgery and put a pin in it. :o Good news, there is another direction that we going to try first. They going to put a few shots in it today. I will have to have x-rays once a week to see if the fraction doesn't open up. :o Still using a walker to get around, and will have to use one for a long time till things heal.
I did get that new nailer. Bad thing, it's still in my truck. Haven't even took it out the box. Will do this morning. ;D
Post by: samandothers on November 15, 2018, 11:42:01 AM
Sorry to hear!  Take time to heal this, no 'pushing through it'.
Post by: Magicman on November 15, 2018, 11:49:42 AM
I am sorry to hear this Paul.  "Dr. Me" says to stay off of it as much as possible and let it knit.
Post by: fishfighter on November 15, 2018, 09:58:26 PM
Been doing that the last two weeks. I broke this morning and went to the back. Fired off the heater and woodstove. Let things warm up some and then start installing some flooring in the front bedroom. ;D Yep, paid for it. Didn't get a picture. Was hard working on the knees and when the wife found out what I was doing, she just about ran me all the way home. :D
Oh, the wife loved the flooring. ;D Will try to get a picture tomorrow.
Got that shot in this afternoon. Was told if I don't get any relief in the next 3-4 days, then for sure I will have to get a pin in. >:(
Post by: fishfighter on November 16, 2018, 07:13:57 PM
Good news. Was able to baby step today. 8) It was like learning to walk again. Still using the walker most of the time. :o Warmer weather, I got out. Was a very nice day. ;D Drove to the back and installed some more flooring. Picture I have is what I had installed before today.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2110.JPG?easyrotate_cache=1542413257)
Got about double of that now down. DanG glue is very thick due to the cold weather and very hard to spread. Then nailing is another story. This is some very hard stuff.
Will try to get more down this weekend unless I am sawing some logs. ;D
Post by: Crusarius on November 16, 2018, 08:52:27 PM
is that all oak? I love the looks of the different color gradients
Post by: fishfighter on November 17, 2018, 07:52:50 AM
Rosewood from Brazil.
Post by: fishfighter on November 19, 2018, 08:37:57 AM
Morning all. I am doing better. Still having to kind of hopping around. At least I don't have to use that DanG walker. ;D
Did get a little more of that flooring down. Had to stop due to the wife making me. ;D  Will try to finish up this week.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2112.JPG?easyrotate_cache=1542634627)
Post by: Magicman on November 19, 2018, 08:45:54 AM
Hopping is good and the flooring is too.  ;D
Post by: fishfighter on November 19, 2018, 08:55:10 AM
Yep, been good to just getting out the house. 8) Now if I could just motivate myself to go hunt. Haven't even been in the woods yet this fall. :(
Post by: fishfighter on November 21, 2018, 08:41:05 PM
A lot of work on the flooring, but I rap it up today. Very happy with it. Still have it give it a lite sand and then varnish it to make it pop.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2113.JPG?easyrotate_cache=1542850478)
A teaser with a piece of the base board I have that will be installed.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2115.JPG?easyrotate_cache=1542850509)
Happy Thanksgiving to all.
Post by: Darrel on November 21, 2018, 08:45:01 PM
That's a purdy floor! And happy thanksgiving to you too!
Post by: Magicman on November 21, 2018, 10:10:53 PM
Looks terrific and that is a good stopping point.  I wish you and your family the very best Thanksgiving Paul.
Post by: btulloh on November 22, 2018, 10:31:48 AM
Very nice floor, Paul.
Happy Thanksgiving to you and your family.
Post by: Crusarius on November 23, 2018, 09:20:52 AM
Thanks for taking us along on this journey. I love your work it is inspiring. Looks great to.
Post by: fishfighter on November 24, 2018, 07:03:14 AM
Thanks all, we had a nice family dinner at MIL's house. Was the last dinner there. :'( The family will be putting the house up for sale soon.
On a bright note. Yesterday I did a little shopping at Homedepot . They had some glass tiles on sale. Same ones that I was looking at a couple months ago for the kitchen backsplash. Just didn't want to pay $9+ per sf. Bought more then enough for $2.48 a sf and also got a 10% discount on top of that. ;D
Power buy for once. 8)
On another side note. My daughter and SIL are coming over to start sawing up some lap siding. Been waiting on them to come over and do this. :o That new box of blades have been shaking to be opened up and put to use. :D
Post by: fishfighter on November 24, 2018, 02:25:18 PM
Was good to get out and saw some. Bunch of lap siding that is 5 3/4" x12'6". We sawed up only one log and pulled 50 of them and some 4/4 lumber.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2120.JPG?easyrotate_cache=1543087303)
Post by: fishfighter on November 26, 2018, 03:57:59 PM
What is one to do when it's cold and windy? Fire up the wood stove and hang some backsplash . ;D Still have to grout it.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2123.JPG?easyrotate_cache=1543265447)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2122.JPG?easyrotate_cache=1543265471)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2121.JPG?easyrotate_cache=1543265492)
Title: Re: Started the build.
Post by: Darrel on November 26, 2018, 06:31:24 PM
I that backsplash is lookin real good.
Post by: fishfighter on November 27, 2018, 10:25:04 AM
Was a power buy. $2.48 sf. 8) Was looking at it a few months ago which was over $9 sf. ;D So far, I have about $375 into the total cost of the kitchen. Still debating to use a copper sink or something else. :o
Still hopping around, but the hip is doing better. ;D
Post by: fishfighter on November 28, 2018, 08:15:46 PM
Got the backsplash grouted in today. Used a bone color grout. Came out nice matching the counter top.
With a little warm spell, but some rain, I am going to try in rent a floor sander and sand out the front bedroom and slap down some varnish in the next few days.
Post by: fishfighter on November 30, 2018, 08:35:41 PM
Got the front bedroom sanded out. 2+ hours for a little room. I did a full crack filling which was very little. That flooring is super hard. :o Still have a little more sanding I will get done tomorrow. Hope to get a coat on varnish on it tomorrow too!
Sorry, no pictures. :(
Post by: fishfighter on December 02, 2018, 10:40:56 AM
Yesterday, I spent a lot of time on my hands and knees sanding. :o Once finished, a bunch of vacuuming and then more.
First thing this morning, more vacuuming. Then I hand wipe the complete floor with some tact cloth.
All clean and ready for varnish. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2133.JPG?easyrotate_cache=1543764699)
First coat starting to go down.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2134.JPG?easyrotate_cache=1543764718)
A lite coat for the first coat.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2135.JPG?easyrotate_cache=1543764736)
Oil base varnish. Say's that it takes around 8 hours to dry. Going to hit 77F here today. Hope it will dry so I can get a second coat on today.
Post by: Darrel on December 03, 2018, 09:50:44 AM
Oh that looks nice!
Post by: fishfighter on December 03, 2018, 08:15:30 PM
Had to wait till over night, but got a second coat down. Didn't take a picture, but it really is now popping. I will be putting down 4 coats. ;D
Got that done and I then sealed the backsplash area. After that, had to cut some grass. :(. Then started a clean up and getting ready to start laying flooring in the kitchen/living  room area. ;D
Problem there, I have so many things in that area and really no place to move it. :o Guess it is time I will have to close in my old sawmill building. :o Yep, this old building that severed. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_01235B15D.JPG?easyrotate_cache=1426183690)
That has been a few years ago I had put it up just after I got my mill. :D
Post by: Magicman on December 03, 2018, 08:29:18 PM
I was hoping that you had not breathed too many fumes and conked out.  smiley_dizzy
Post by: fishfighter on December 03, 2018, 09:11:13 PM
Lynn, I been venting the place. ;D Hip is just about 100%. Now if I can talk myself into making a hunt.
Post by: Armymann50 on December 04, 2018, 06:19:07 AM
love the floor.
Post by: fishfighter on December 06, 2018, 03:16:40 PM
Started laying some flooring in the living/kitchen area.
100+ year old SYP quarter sawed T&G. ;D
This picture shows before and after passing a board thru my planner.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2137.JPG?easyrotate_cache=1544126803)
As you can see, there is a easy 1/8" varnish. :o Problem, the varnish is trying to burn the knifes on the planner. :(
some flooring down, front to back.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2139.JPG?easyrotate_cache=1544126840)
Most likely install the rest unfinished. Just so much more I will have to sand. :(
After a bit of sleep to think about that varnish problem, I am going to try to remove it with a heat gun once day light comes. To me, this flooring looks like it has never been sanded. The boards I pasted thru the planner, I did not remove any wood. Will report back later. ;D
Post by: Magicman on December 07, 2018, 07:46:11 AM
Don't even think about sanding it off.  Won't work.  Replacing dull planer knives may prove to be the cheapest route.  I would start on one side of the planer and when that portion got dull, move down a board width and use that section until dull.
How about the possibility of flipping it?
That "old time" Pine flooring is priceless!  smiley_thumbsup
Post by: fishfighter on December 07, 2018, 08:15:02 AM
So much for using a heat gun. Didn't work. :( Guess I will sand or buy a few sets on knifes. For sure replacing knifes would be easy on me, but not the pocket book. :D
A lot of rain coming today and tomorrow. Guess a road trip will be made to get some knifes. 8)
Post by: Darrel on December 07, 2018, 09:31:13 AM
I've had good luck slicing it off with the sawmill. Gotta go slow so the blade doesn't ride up.
Post by: fishfighter on December 07, 2018, 10:55:52 AM
There would be no room for era doing that. These boards are only 3 1/4" wide and 3/4" thick. Some of the boards I have are over 20' long. :o
Lynn, can't flip them. They are under scored.
One thing I haven't tried, try using my electric hand planner. It cuts 3" wide and knifes for it are cheap. Most I can do there is burn it up. Running them thru my other planner, that was putting a hurting on it. :o
Post by: Magicman on December 07, 2018, 08:26:38 PM
I figured that the underside was scored but I had to ask.  The hand planer idea could be a winner.
Post by: LeeB on December 07, 2018, 10:34:19 PM
What about some good fences and your table saw? Saw blades are cheaper than cutters for the planer. You might have to shorten some of those 20 footers to make them a little more user friendly.
Post by: fishfighter on December 08, 2018, 07:30:10 AM
That might work, but would leave saw blade marks. Then that would be having me sanding even more. :(
Another thing I was thinking that would cost about the same as knifes for my planner, why not try a varnish stripper? :D Been looking at some. So, when I go to pick up some knifes, I will pick up a few different strippers. ;D Problem with the strippers I have read, it has to be used above 60F. I can make that happen, but don't want to leave space heaters running without being there. :( And yes, would have to for no less the 24 hours at a time.
It's a catch 22 right there at this time of the year.
Post by: Magicman on December 08, 2018, 09:27:14 AM
The only thing that is easy with using a stripper is talking about it.  :-X
Post by: Treehack on December 08, 2018, 10:03:32 AM
I would try a combination of the table saw and planer.  Run a pass on table saw that takes off all but a little film left on board.  Then one pass through planer to remove the film.  This way cheaper saw blades would take brunt of the abuse while still keeping your thickness and less wear on planer.
Post by: Treehack on December 08, 2018, 10:07:43 AM
 By the way, your flooring is outstanding.  Love the rosewood and your before and after pics of the SYP reminds me of cutting into a janky lookin' log and finding a treasure inside.
Post by: fishfighter on December 08, 2018, 02:56:48 PM
Well, tried a stripper. Now keep a clean mind. :D Made my choice and found some aftermarket knives for my planer. $36 a set, Dewalt, was $54.99 a set. Ordered 3 sets and should get them in mid week.
Did cook a pot of Gumbo. Weather is just so nasty here today. Gumbo weather for sure. ;D
Post by: Magicman on December 08, 2018, 03:03:00 PM
Gumbo, now you are speaking da language.   thumbs-up
This mess should be gone next week so we can get busy again.  8)
Post by: Briankinley2004 on December 08, 2018, 11:06:41 PM
Might be easier to install the floor then use stripper followed by a floor sander. If its just varnish build up you may be able to get it off with just the sander. Thats the way most wood floors are "redid" anyhow.
Post by: fishfighter on December 09, 2018, 07:39:16 AM
I was going to do that, but after trying to sand some with my belt sander, that changed my mind. The belt gummed up real fast using a 50 grit. There has to be a lot of wax on top of the varnish. Besides that, the build up id real thick. Stripping the wax off and the trying to sand would take a very long time and a lot of extra work.
By just passing it thru the planer, it is taking about 95-97% of the stain and varnish leaving the boards to look very old which I think would match out real good with the build. I really like the look. ;D Of course I could take it down to new wood, but don't want to. Using the planer, all boards are matched and once I finished installing them all, I might get away with little to no sanding. ;D
Post by: Darrel on December 09, 2018, 09:06:13 AM
Where did you find knives for $36?  I'd like to give them a try.
Post by: fishfighter on December 09, 2018, 10:04:32 AM
On Amazon. Powertec 128010 12 1/2" knives.
Don't know if they will last or what.
Post by: Magicman on December 09, 2018, 02:40:25 PM
Paul, review my Reply #804 above.  I would take a magic marker, etc. and mark the board widths across the infeed.
Post by: fishfighter on December 09, 2018, 04:31:54 PM
Got you Lynn. Was going to put some tape. ;D
Went in and papered out the front bedroom. Got to move things over. Got to paper what I put down in the living/kitchen room area. Need to paint the ceilings. Being I will be waiting, it will be a good time to do it. Should of done that to start with, but hate painting. ;D
Post by: fishfighter on December 11, 2018, 06:03:19 AM
Got everything moved and the ceiling painted in the living room done yesterday. Even hung a new ceiling fan in there. The one I had, just didn't match the room. Still thinking of what color to use for the walls. I have to go pick up some more varnish for more trim, so I will look at colors today.
Post by: fishfighter on December 15, 2018, 02:56:26 PM
Got the planer knives in. Started planning out flooring. Good news, the after market blades fit. Bad news, they are lasting about what DeWalt's blades last. not long. Getting about 130 to 145 SF of flooring per set of knives. :( I did try just taking a hair off at a time. That was worse. :o Things wanted to gum up fast. Anyway, got some more flooring down. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2149.JPG?easyrotate_cache=1544903070)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2148.JPG?easyrotate_cache=1544903088)
Will get more down tomorrow. Got to move the kitchen island or just go around it. Sucker weights a couple tons. :o
Post by: Magicman on December 15, 2018, 07:40:54 PM
I would suggest moving it.  Sometime in the future someone might decide against the island and then..... :-\
That flooring is going to be smiley_thumbsup
Post by: Darrel on December 16, 2018, 09:47:09 AM
That's some mighty fine looking flooring!
Sometimes the hassle is worse than the expense. Glad that the cheaper knives worked.
Post by: LeeB on December 16, 2018, 09:53:00 AM
Those disposable knives can be honed once or twice. Use a fine grit diamond sharpening stone.
Post by: fishfighter on December 16, 2018, 03:37:57 PM
I wonder if there is a place that could resharpen  the knives. Got around 10 sets just sitting around. :-\
Got more flooring down. At about the half way mark. I did move the island. Wasn't easy, but got it out the way. Will try to get more down tomorrow.
Post by: LeeB on December 16, 2018, 09:01:11 PM
You can't do much more than give them a honing., there just isn't enough too them. Take off much and they won't have enough left to reach the wood. I always just made a couple strokes down the back and a few light strokes on the edge just to refresh the edge without taking too much off. Once or twice is about all I ever got out off that.
Post by: fishfighter on December 17, 2018, 06:29:09 AM
Guess I will give that a try on a rainy day. Sharpening knifes to me is one of those things I just don't care to do. That goes for kitchen knifes too! ;D
Post by: LeeB on December 17, 2018, 08:45:43 AM
I cut a slot in a board on the table saw just slightly less than the width of the blade. Can't remember the angle. Used a thin kerf blade. Used that to hold the planer blade while sharpening it. If I remember correctly I used about a 600 grit diamond sharpening stone and just a couple passes down the edge and flattened the back a little. I've still got several of them but gave the planer to my SIL. The blades make good scrapers once you can't hone them again.
Post by: fishfighter on December 17, 2018, 03:43:58 PM
Thanks for the tip. Just might do that.
More flooring done. One can see the kitchen island. Was a job just getting it up. :o
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2151.JPG?easyrotate_cache=1545078631)
Have less then 25% left to do. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2150.JPG?easyrotate_cache=1545078608)
Now for bad news. Finished up in the back, came up to the house. Grab me a beer and sat down outside on the patio. Popped my top, and all hell broke loose. :o Dam CRT-D(pacemaker) started vibrating. :o Scared the heck out of me. :o Well, I knew this was coming. Just two weeks ago I had a reading on it. Was told I had two months left. Not. >:( Called in and now I will have to have a replacement done in less then two weeks. :o Bad thing, this will shut me down for about 3 months or more. >:(
Post by: Magicman on December 17, 2018, 04:41:31 PM
Paul, If I am reading you correctly, it means that you will be (not out but) back in commission in about 3 months.  My prayers are with you my Friend.
Post by: fishfighter on December 17, 2018, 06:54:54 PM
Lynn, was told it will take 3+ months to heal. Big reason, I'm so dang skinny. Really. :D The one I have now sticks out a good inch, just under the skin. When it was put in, I was close to 200lbs. This morning, 161 lbs. :( Not good at 6' tall. :o
Post by: Magicman on December 17, 2018, 07:08:30 PM
I understood Paul, but I am being "half full" with your situation.  Sounds like you need more Gumbo.  :)
Post by: LeeB on December 18, 2018, 10:52:04 AM
I must agree with Lynn on this one. Only a minor slowdown. You're much to tenacious for it to be anything else.
Post by: fishfighter on December 22, 2018, 11:11:38 PM
Wind and rain the last few days, I just lay around the house. Today, with a lite frost to start with, I had it on my mind to finish the flooring. And I did, putting a full days work in. Felt good, but paying for it. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2154.JPG?easyrotate_cache=1545537785)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2155.JPG?easyrotate_cache=1545537809)
Post by: Magicman on December 23, 2018, 07:51:38 AM
Careful Paul, but I know that it is tough just sitting when you know what must be done.  Of course the "doing" is also good mental therapy.  That entire Guest House is going to be a thing of pride as well as beauty.
Post by: fishfighter on December 23, 2018, 09:08:46 AM
Lynn, building this house has been very good therapy for me. Heck, in fact it has helped my heart getting a little better. My EF was down below 15%. Last check, I am up to 20%. Not often a heart repairs itself. Big reason the doctors keep telling me what ever I am doing, keep doing it. 8)
Post by: Darrel on December 23, 2018, 10:24:29 AM
Paul, even though we have never met and quite likely never will, it somehow feels like you are a friend. This thread has been very inspiring to me. Watching the build has been great, but way beyond the building of the guest house has been the story of the man. Watching you persevere through all adversities has truly brought courage to my heart.
Post by: SwampDonkey on December 23, 2018, 06:31:52 PM
Magicman is always a good spokesman, but some of them thread views is mine to. I am a quite man in real life. I like to listen more than talk regardless of the post count. :D
Post by: fishfighter on December 24, 2018, 06:30:27 AM
Why thank you Darrel. Maybe one day, I just might pick up and start traveling. Never been up in your part of the world. Would love to make a trip to the Northwest.
On a side note. Installing that floor. I used right at 1972 nails. How I know? Had two boxes with 1k in each box. ;D
Installing the floors, you can see in some of the pictures that there are some blue lines. Those are flooring ratchet straps. Big help pulling everything together. My brother that gave me the flooring also gave me those straps. Yesterday, he would of been 65. Today, my oldest brother that passed away also would of been 66. God rest their souls. :'(
Post by: Magicman on December 24, 2018, 08:12:31 AM
Which makes that "memorial" flooring even more special.
Post by: fishfighter on December 24, 2018, 10:44:39 AM
Now if only I can get this doctors appointment done early today, then me a JB will have a date cooking a gumbo. ;D
Merry Christmas all. May the Good Lord smile on y'all and your families.
Oh, lets not forget that our loving Saints are rapping up things for the Superbowl. 8)
Post by: Magicman on December 24, 2018, 01:47:26 PM
I have already chopped the onions and celery and Pat has sauteed them for our Christmas Gumbo.  The Roux is next.  Lotsa prep going on for our get together tomorrow evening.
Post by: Magicman on December 24, 2018, 04:07:25 PM
(https://forestryforum.com/gallery/albums/userpics/20011/IMG_5475.JPG?easyrotate_cache=1545685328)
How is your pot of Gumbo coming along Paul?  I think that it is best after it "rests" overnight but if I had some rice I would try this tonight.  food6
Post by: fishfighter on December 24, 2018, 06:10:26 PM
Quote from: Magicman on December 24, 2018, 04:07:25 PM
Lynn, had to for go making a gumbo. Spent way to much time at the doctors. :( Going to have the replacement Friday morning.
Back to gumbo. I always have my vegs ready. Make my roux and when it's finished, hot, I drop my vegs in. I always use a cast iron big pot that was pasted down to me from one of my grandmaws. Very heavy, thick pot that I NEVER let the wife to cook with. ;D Once the vegs are cooked, I add some water. Bring to boil and cut back to a very low fire. Let it sit. The oils will come to the top. I skim it off and then I go from there. So, fried frog legs is on with some other goodies. We will be heading over to a BIL's house tonight for a little get together and go to a nieces house tomorrow for another get together, dinner.
Post by: Magicman on December 24, 2018, 08:17:48 PM
Paul, my Prayers for a successful procedure will be with you Friday as you get your replacement.  Then for Healing Grace as you go through your recovery period.
Please keep us updated as often as you can.  God Speed.
Post by: Darrel on December 24, 2018, 08:38:01 PM
One of these days I'll have to head to the South to get away from the snow and more importantly, see what gumbo tastes like.
My thoughts and prayers are with you Paul and will be even more come Friday.
Post by: LeeB on December 25, 2018, 03:13:28 AM
Best wishes to you Paul on a successful surgery and recovery.
Post by: SwampDonkey on December 25, 2018, 04:50:46 AM
I was thinking about you guys with your gumbo while I was eating my lobster last night. :)
Good luck Paul and recover quickly.
Post by: Greyman on December 27, 2018, 02:27:26 AM
Back to the reclaimed flooring...  I was watching a log building show, forget which one, but they used a wire brush machine to clean up boards like that.  It looked just like a sander from the outside, they didn't show the insides.  I guess it's just a wire brush cylinder in place of the sander drum.  They ran it thru a planer after that.
Post by: fishfighter on December 27, 2018, 07:53:44 AM
I did rig up a brass wire wheel on my RAS to clean out the T&G. After doing that, I got tired and stopped. From there, I just used a chisel to clean out the T&G as I installed the boards. Was much easy.
Post by: Magicman on December 28, 2018, 08:51:32 AM
Paul, I know that you are off to get your new Heart Appliance today.  Just know that my Prayers are with you during the procedure and your recovery.
Post by: Darrel on December 28, 2018, 10:29:52 AM
Paul, just stopping by to let you know that you are in my thoughts and prayers today.
Post by: fishfighter on December 29, 2018, 08:56:15 AM
Hey thanks guys. Surgery went good. Doctor stuffed this one real deep.  I am hurting, but all good.
Post by: Magicman on December 29, 2018, 01:18:56 PM
Thank You my Friend for that encouraging report.  Now follow the Doctor (and your Wife's) orders and get yourself properly recovered before you tackle what you ain't 'posed to tackle.  thumbs-up
Post by: fishfighter on December 30, 2018, 09:19:05 AM
DanG Lynn, you sound like my wife. :D With all this time just to sit around, more new projects keep popping in my mind. Not good. :D
Post by: thecfarm on December 30, 2018, 10:41:51 AM
Quote from: SwampDonkey on December 25, 2018, 04:50:46 AM
:D    :D
Good luck to ya.
I don't see why some foods from away has to start with g.
Post by: terrifictimbersllc on December 30, 2018, 02:39:35 PM
Not far away @thecfarm (http://forestryforum.com/board/index.php?action=profile;u=436).  I just called your Hannafords store over in Farmington.
She said they are in the cereal aisle over near the oatmeal.
musteat_1 musteat_1 sketti_1 sketti_1 food6 food6  :) :)
(https://forestryforum.com/gallery/albums/userpics/21495/DSC_0092.jpg?easyrotate_cache=1281294583)
Post by: fishfighter on December 30, 2018, 02:54:44 PM
You know that us southern folks love our grits. 8)
Post by: terrifictimbersllc on December 30, 2018, 04:43:11 PM
And I am glad you are willing to share them with us!   8) 8)
Here we have (from 12 o'clock), biscuit, bacon, a little egg, grits, CHEESY grits, sausage, and biscuit again.
Southern hospitality from Birmingham Alabama cooks at a volunteer project I worked on.
(https://forestryforum.com/gallery/albums/userpics/21495/proper_breakfast.jpg?easyrotate_cache=1370641450)
Post by: Darrel on December 30, 2018, 06:28:07 PM
Yum!
Post by: WDH on December 30, 2018, 06:48:16 PM
Take the biscuit and open it up.  Then add some maple syrup, slather it on both sides of the biscuit (the maple syrup needs to come from GAB or Maple Flats or Chuck White or another FF member), add the sausage to make a sausage maple syrup biscuit, you can even add some bacon.  Mix the grits and eggs thoroughly, and have at it.
Post by: thecfarm on December 30, 2018, 06:50:28 PM
An alert has been put out on the Kittery Border. Any and all clerks and personal and management are instructed to say that any and all the stores has grits. This way no grits will tried to be sneaked through the bridge at Kittery. But just in case all personal and guards and all checkpoints has been notified of a threat against my Maine border. Over head drones are been deployed and all canine grit dogs are being used and in place as I type this alarming post. If needed helicopters and planes and troops are on standby. The Coast Guard is on patrol just in case a threat in made on the Maine Coast. Looks like some of our Boys and Women will be enjoying New Years Eve on grit Patrol. Prison cells have been prepared to house any law breakers during this trying time. jl
Post by: WDH on December 30, 2018, 06:53:12 PM
I know that you must hate all these foreign invaders like grits and EAB.
Post by: thecfarm on December 30, 2018, 07:07:00 PM
If only EAB was as easy to annihilate as grits. :(
Post by: WDH on December 30, 2018, 07:10:02 PM
Ray,
You are in real trouble.  Grits are insidious.  Inexorable.
Post by: thecfarm on December 30, 2018, 07:24:54 PM
yes,grits are all of those big words and then some. But my crusade and campaign is never ending.
Post by: Magicman on December 30, 2018, 10:14:27 PM
(https://forestryforum.com/gallery/albums/userpics/20011/RC6.JPG?easyrotate_cache=1397438723)
Do you need a reminder??  :D
Post by: Darrel on December 31, 2018, 12:40:33 AM
Y'all can just go ahead and send some all of those grits y'all don't want to Sprague River.
Post by: thecfarm on December 31, 2018, 06:17:31 AM
That is a lifetime supply for the state of Maine.  :D
Post by: fishfighter on December 31, 2018, 09:24:30 AM
If only we could keep our crawfish like our grits, we would be good. But no, crawfish are selling at $4 a pound live right now. >:(
Post by: Briankinley2004 on January 01, 2019, 12:12:47 AM
at $4 a pound I guess I will stick to shrimp and grits or grits and grillades until I can afford crawfish & grits. I think these 80 count shrimp are $2 a lb now
Post by: schakey on January 01, 2019, 06:42:04 AM
If Maine doesn't want the grits just send all to me in Ohio.
Take care fishfighter get well real soon.
Post by: Darrel on January 01, 2019, 10:27:20 AM
Quote from: schakey on January 01, 2019, 06:42:04 AM
Wait just a little minute here!
I've already got dibs on all unwanted grits!
See post 870
;D 8) :)
Post by: thecfarm on January 01, 2019, 10:46:26 AM
That box of grits is used in any and all of my training courses to be used as a visual aid. It gets passed around for all to see and feel. Than locked away in a bioharzard red lockable steel closet.
Post by: Darrel on January 01, 2019, 10:47:39 AM
I'm joining you Paul in the land of resting up and recovery.  My feet skidded out of control on ice whilst playing with my dog. Down I went and broke 3 ribs (one of them in 3 places). 2019 will get better!
Post by: Iwawoodwork on January 01, 2019, 11:45:30 PM
Darrel, would be nice to level out that hillside you live on,  imagine it gets pretty slick when packed and frozen.
Post by: Darrel on January 02, 2019, 10:05:25 AM
Level might help but what would help even more would be for me to figure out that I should not participate in rough and tumble play when it is so obvious that I'm the underdog.  :D :P ;D
Post by: fishfighter on January 02, 2019, 07:41:14 PM
Dam Darrel, better stay out for under your dog. ;D  Hope you heal up fast.
Myself, doing good. 8) Did get out for a good walk yesterday. Been raining here the better part of the day. Flash flood watch till Friday morning. :(
Post by: fishfighter on January 04, 2019, 07:20:56 PM
One week later, I'm a kicking. ;D Still hurt a little, but nothing I can't handle. Still have a bunch of swelling, but as of today it looks 100% better.
Warning, kind of nasty. Don't look or let me know and I will take the picture out.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2160.JPG?easyrotate_cache=1546647264)
They shaved my chest and now I could take a steel brush to it. ;D
Post by: Magicman on January 04, 2019, 08:23:06 PM
Actually since you are up and kicking, I think that is looks very good.  :)
Post by: LeeB on January 05, 2019, 08:44:29 AM
Doesn't look near as grizzly as pics of Lynn's feet.
Post by: Darrel on January 05, 2019, 10:24:53 AM
That surgical wound looks to be healing nicely.
Post by: samandothers on January 05, 2019, 08:50:02 PM
Dang Darrel hope you heal quick.  You can't run with the big dogs like you use to! :)
Fish, glad you are healing!
Post by: fishfighter on January 06, 2019, 08:48:19 AM
I did do a short walkabout hunt yesterday in the back 40. First time this hunting season to step in the woods. :( Armed with only a .45 pistol. Not able to shoot a long gun. Saw one big pig and one doe. Both to far to shoot. Might try again later today. ;D
Post by: fishfighter on January 07, 2019, 07:34:56 AM
Sunday was just so nice outside, I had to just do something. ;D So, the base boards that are in the front bedroom, I took them outside and varnished them up. Got a lite sun burn on the top of my head, but felt good. :D Going to install them in place today. Got to love air guns. 8)
Post by: fishfighter on January 08, 2019, 05:48:16 PM
Another warm sunny day that hit 75F. Knew it was to come. There was no way I was just going to sit inside the house on a day like today.
So, I played a little and found what I was looking for towards some shoe molding. ;D
First, a pair of saw horses, a board, screwed down to the horses. Using a 1/4" round router bit, I had just made a pass.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2162.JPG?easyrotate_cache=1546986645)
Once passed with the router, I put the board to the table saw.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2163.JPG?easyrotate_cache=1546986683)
Had to watch on how much weight I was dealing with with my left arm. All good. The boards I used were 7/8" thick oak. Same as the base boards.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2164.JPG?easyrotate_cache=1546986704)
Once I finished, I had passed a sander on them very lite.
Profile 7/8" high by 5/8" thick. Has a very small off set at the top. Should be no problem making and matching this shoe molding in the future. ;D Not to good of a picture. Will get some once I install.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2165.JPG?easyrotate_cache=1546986757)
Post by: Magicman on January 08, 2019, 08:08:30 PM
Looking good Paul.  thumbs-up
When I was doing the work on my Cabin, I found that it really didn't matter (to me anyway) about the molding profiles as long as everything in the room was the same.  Next room may be different but you can't see both of them at the same time anyway.  ;D
Post by: fishfighter on January 10, 2019, 08:11:18 PM
Cool day, little wind and a lot of sun shine. Had to do something. ;D Need a door for the front bedroom closet. Big sucker, 38 1/2"x 82 1/2". Is a sliding door and just about got it done.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2166.JPG?easyrotate_cache=1547168659)
One problem. It's way to heavy for me to lift it by myself. ;D Will get some help tomorrow. Still have two more of these to build.
Post by: Magicman on January 10, 2019, 09:02:54 PM
You are becoming a real "door whisperer".  Guess that rain will get to you tomorrow evening/night.  Ours will be Saturday.
Post by: sawmilllawyer on January 10, 2019, 09:15:04 PM
Always impressed with your work ethic and especially your drive to keep on keeping on. Oh! the closet door and shoe moulding both look great. Good to see you are still going like the energizer bunny rabbit. 8)
Post by: Magicman on January 10, 2019, 10:19:32 PM
I think that he plugs up and recharges at night so that he can run all day.
Post by: Weekend_Sawyer on January 11, 2019, 06:06:01 AM
Glad you are up and about.
You can't keep a good man down!
Post by: fishfighter on January 11, 2019, 08:21:13 AM
Thanks guys. I really think and feel that the new package I got has gave me my spunk. ;D Even the wife thinks so. :D
Post by: Magicman on January 11, 2019, 08:46:50 AM
Hey now, we were talking about your git-up-and-go.  Your spunk is between you and your wife.  :D
Post by: samandothers on January 11, 2019, 02:44:20 PM
Glad to hear it is going well!  Door looks great!  How did you join the rail and stiles?
Post by: fishfighter on January 12, 2019, 09:51:17 AM
Look real close at the ends.
Finished and varnish out.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2170.JPG?easyrotate_cache=1547304436)
Post by: fishfighter on January 15, 2019, 05:39:55 PM
Good Lord it has been cold and windy. :( DanG shame it is hard on me when it is hot and cold. >:(
Anyway, yesterday I did a little iron work building the tracking system for that closet door. Today with the help of my wife, I got that door hung. Very happy how it came out. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2172.JPG?easyrotate_cache=1547591399)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2174.JPG?easyrotate_cache=1547591350)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2173.JPG?easyrotate_cache=1547591362)
Have a little touch up painting to do. Also, I will be doing a live edge board to cover the cross tracking like I did the bathroom.
I also got the base boards down, but ran out of time to install the shoe molding. Got tired. :(
Post by: WDH on January 15, 2019, 07:26:50 PM
Good job.
Eat the elephant one bite at a time (old saying).
Post by: Magicman on January 15, 2019, 07:56:27 PM
Beautiful work my Friend, keep on keeping on.  8)
Post by: fishfighter on January 17, 2019, 08:23:26 PM
Got a little done.
Base board and she molding.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2175.JPG?easyrotate_cache=1547772060)
Top plate covering the sliding door tracks.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2177.JPG?easyrotate_cache=1547772127)
Of course I had to take the door down to varnish the door trim. Will get it back up in the morning.
Post by: Magicman on January 17, 2019, 09:13:00 PM
That old Oak is showing out.   :)
Post by: fishfighter on January 17, 2019, 09:46:51 PM
Lynn, I do have a problem. Checking my oak stash, I am short of some 2x6's. :( Guess I will try to fell a standing dead oak tomorrow and throw it on the mill. Got 5 or 6 of them to saw. I will pick out a small one just for 2x6's. ;D
Post by: Darrel on January 17, 2019, 11:05:08 PM
Like Lynn says that oak fantastic!
Have fun and stay safe tomorrow!
Post by: fishfighter on January 25, 2019, 05:36:10 PM
Just a update.
Had did some painting in the living/kitchen area. Finished all of that.
Way back when I started this build, some things new to timber framing I didn't know. :( The big problem I had was when I made the braces. The more I got to thinking about them, the more I hated the ones I installed. So, being a timber frame/stick build, is I took out the braces, I should have no problems due to the way all beams are supported by 2x4 walls.
So, I took a sawsall to them and out they came. Them I made new ones. To install them, I used biscuit jointer into the braces and post/beams with some good glue.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2183.JPG?easyrotate_cache=1548454185)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2185.JPG?easyrotate_cache=1548454231)
I have them all up. Problem, I have to stain them to match the posts and beams. Still working on a stain for that.
Had a little time to make thresh hole in between the bathroom/ other area out of oak. The difference in height is about a 1/4" in the flooring.
  Starting with some 2x4 oak stock, passing it thru the planner, I then put it to the table saw.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2186.JPG?easyrotate_cache=1548454281)
Sanding
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2187.JPG?easyrotate_cache=1548454321)
Finished product. Just sitting in place till I finish out the pine flooring. Then it will be glued down.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2188.JPG?easyrotate_cache=1548454335)
Tomorrow I will try to fire up the saw mill. In need of some oak lumber. That, and I will start making some molding to trim out the post and beams.
Post by: Magicman on January 25, 2019, 07:26:33 PM
That threshold is about what I had to do between the mudroom and back porch at the Cabin.  Took a full 2X6 White Oak board and started whittling.  Same situation between the new and old portion of the living room except I used a 1X6 Cypress.  Strangely, I do not have a picture of either.  :-\
Post by: fishfighter on January 26, 2019, 10:17:40 AM
The difference between the floors is because I had installed 5/16" hardie board below the vinyl flooring in the bathroom. One of those, I didn't plan for. Oh well. ;D
Post by: fishfighter on January 28, 2019, 09:27:22 PM
Sawed up one small oak and had to call it a day last Saturday.
Some 4/4 and some 1".
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2189.JPG?easyrotate_cache=1548686375)
Today I broke down and started resawing, and planning out a bunch of lumber for all trim work that was needed done. Had a late start due to the coffee pot broke. >:(
Got all door trim hung in the living/kitchen area. Really looking nice. Sorry, didn't have my phone with me, no pictures. :(
I will be attacking the back bed room soon. There is a ton of junk I have to remove out of it and then I have to remove sheetrock off the walls. Reason, have some wiring to run along wanting to change a few things. I will have to frame a closet out too. Really nothing hard. I am also thinking of adding a door in that room that leads out to the back porch. Would be easy to do. This is a guest house and if two couples stay, ones in the back bed room would have a step out the back without going thru the rest of the house.
On a side note. Hopping to get a dusting of snow here by morning. ;D Had two last winter, but it could be 8-10 years before the next snow fall here. 8)
Post by: Armymann50 on January 31, 2019, 03:21:32 AM
Nice work
Post by: fishfighter on January 31, 2019, 05:43:54 PM
Thanks Army.
Today, I did a clean out off on the porches. Had so much trash like scrap lumber. A lot to the point I couldn't use the areas. >:(
Then did a little corking inside.
After that, it was time to try out staining the braces to match out. Had fixed up a batch of vinegar 1 qt and two small pads of steel wool pulled apart. Been mixing it up every day for about 8 days and testing it.
Braces before stain.
After
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2193.JPG?easyrotate_cache=1548973823)
Dang close match. ;D Once I clean and wipe down the posts and beams, it will match.
Tomorrow, some varnishing of trim work.
Post by: Darrel on January 31, 2019, 07:38:46 PM
Looking mighty fine!
Post by: Weekend_Sawyer on February 04, 2019, 08:05:02 AM
How are those angle braces attached?
In the last pic the brace on the left shows the pith.
I really like the the way that looks.
Jon
Post by: fishfighter on February 04, 2019, 11:02:45 AM
1" dowel pins and glued.
I did saw up enough 4/4x6" pine boards for the front porch last Saturday. And then yesterday I fought a big SYP log. Had to trim it down a bunch just to be able to saw it up.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2194.JPG?easyrotate_cache=1549295858)
After the fight that I think I won. :D Was in need of 2x4's.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2195.JPG?easyrotate_cache=1549295895)
Post by: Bruno of NH on February 07, 2019, 03:29:27 PM
Looking good fish you do nice work.
Post by: fishfighter on February 07, 2019, 06:48:26 PM
Thanks. The last couple days I had to clean out the back bedroom. Two trailer loads to the burn pile. :o Record breaking temps here. :o Talking hitting 82F, but having a cold front to come in tonight. :(
Today, I ripped down some sheetrock. :( Had to due to needing to do some rewiring. :( Got that done and also finished the rough in wiring.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2196.JPG?easyrotate_cache=1549582442)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2197.JPG?easyrotate_cache=1549582477)
Still have more stuff I have to go thru. A lot of loading ammo stuff and boat parts.
Sawed up some 2x4's, but they are still to wet to use. :( I need around 20 to build a closet. :( Guess if I have to wait, it would put me back a long time. >:( So, maybe I will just go :'( buy some tomorrow. :'( That hurt. :D
Post by: fishfighter on February 09, 2019, 11:14:43 AM
Got the closet framed in yesterday. Cost me $60 for 2x4's and a box of framing nails. >:( DanG box store framing lumber is junk. >:( I hand picked and out of the ones I did, I would of rejected a 1/3 if I sawed them up. ;D
Fixing to head back and hand insulation. Maybe start hanging sheetrock tomorrow. This room will go very fast, I hope. 8)
Post by: Tin Horse on February 09, 2019, 01:33:53 PM
Quote from: fishfighter on February 09, 2019, 11:14:43 AM
I sure agree with that about the lumber thing. When I framed my shop with box store 2x6 I couldn't believe the bad quality. I had some dry milled lumber and things went better with it. I wouldn't ever try to sell that quality.
Post by: fishfighter on February 09, 2019, 07:25:28 PM
For sure about box store lumber. :( How in the world will a house stand 50+ years building with the junk they are selling?
Anyway, that room has new insulation. Took me longer that I expected, but done. Looking at the weather, I am hoping that I can order some sheet rock for Monday. It's going to be iffy with rain next week. :(
Forgot, it was 38F here this morning. Cold for me. Fired up the wood stove and with in a hours time, I was peeling everything off down to a Tee shirt. Bad thing, my 30+ year old staple gun broke. :o Had to run and buy a new one.
Post by: fishfighter on February 12, 2019, 11:46:45 AM
Have a couple more sheets of sheet rock to hang and then I will start to float it out. Weather is for the ducks here today. Rain and more rain.
Post by: Magicman on February 12, 2019, 01:27:12 PM
Nice to see you making progress Paul.  Yup, Duck Weather here too.  :-\
Post by: fishfighter on February 13, 2019, 06:36:08 PM
Yesterday, I had to take a full days rest. Fluid over load. :( Extra meds were on order.
This morning I felt like a young buck. 8) Was up to finishing out hanging sheet rock. ;D First up, had to get my home made rock hanger out. ;D Had installed the lower rock and then it was time to hang 12' goods up.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2204.JPG?easyrotate_cache=1550100214)
I did have to cut about a 1/8" at the center seam. :( So I screwed across the top and let it over lap, then I had cut it. Then screwed into place.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2206.JPG?easyrotate_cache=1550100238)
Same for the other side.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2205.JPG?easyrotate_cache=1550100262)
All done. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2207.JPG?easyrotate_cache=1550100282)
Maybe I will try to start floating it out tomorrow. 8)
Post by: Magicman on February 13, 2019, 09:49:42 PM
No envy from me.  I have done my share but only because it is one of those jobs that has to be done, and glad when it is over.  :-\
Post by: fishfighter on February 14, 2019, 08:27:11 AM
For sure Lynn. I put floating out sheet rock high on the list of things I hate to do. 10x higher then painting. ;D
Post by: fishfighter on February 15, 2019, 07:15:20 AM
Got the first coat of mud up yesterday.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2211.JPG?easyrotate_cache=1550232645)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2210.JPG?easyrotate_cache=1550232670)
Will try to get a second coat on today. Don't care to sand at all. :(
Post by: fishfighter on February 25, 2019, 08:03:07 AM
Just a update. I have one more lite sand to do and then spray the texture.
Been doing some work on my backhoe and some helping my daughter and SIL hanging siding on a house they added to and rebuilding it.
SIL sawing up siding a few months ago.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2118~0.JPG?easyrotate_cache=1551099016)
They had let it dry and then primed both sides.
One side done and tied in.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2214.JPG?easyrotate_cache=1551099060)
More work today on my backhoe. Got to drop the transaxle. Pinion gear went out. >:( This is a big job. Yesterday I sawed up some oak 51/2"x12" beams that I will saw them 24" long for cribbing to block up the backhoe. Dang thing weighs in at 13K and will have to get under it. So I don't want it going anywhere. ;D
Post by: fishfighter on March 04, 2019, 10:56:02 AM
Been working on the backhoe. Axle dropped which wasn't all that bad to do.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2217.JPG?easyrotate_cache=1551714454)
Open the transaxle up and yep pinion gear gone.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2219.JPG?easyrotate_cache=1551714471)
Good news, just about have the transaxle back together. Need two new cotter pins. It's cold here and wind blowing hard out the north. Just don't want to go to town to pick them up. ;D
Post by: Magicman on March 04, 2019, 08:26:22 PM
It's good to see you making progress on the backhoe Paul.
Yup, this cold can go back to the Glacier where it came from.  :-X
Post by: fishfighter on March 04, 2019, 08:55:38 PM
I did finish putting the axle together and moved it to the backhoe. Then the rain started. >:( It's now sleeting here hard. >:(
Dang shame all the oaks started blooming out last week, but I know winter is not over till the pecan trees bloom. ;D They are the last trees to do so in these parts. Suppose to get down to 29F tonight. High tomorrow maybe 50F. Didn't even reach 40F today. :( Wet, windy and cold. Three things I hate the most. :D Gumbo was good tonight. 8)
Post by: Magicman on March 04, 2019, 09:23:08 PM
Quote from: fishfighter on March 04, 2019, 08:55:38 PMGumbo was good tonight.
Wow, I'll bet it was and I would love to sample a bowl of your Gumbo.  food6
I did get a bowl of Gumbo last week while on the road sawing but is wasn't Coonass Gumbo.  ;D
Post by: fishfighter on March 05, 2019, 08:53:35 AM
Lynn, if you get back down my way, let me know a day before hand and I will cook you and Miss Pat a good gumbo. ;D
Post by: Magicman on March 05, 2019, 09:28:44 AM
No "if", it will happen my Friend.
Post by: fishfighter on March 07, 2019, 08:02:52 AM
Backhoe is fixed. 8)
Doctors appointment today. :(
Post by: Darrel on March 07, 2019, 10:26:21 AM
Quote from: fishfighter on March 07, 2019, 08:02:52 AM
Have you ever wished that you were as easy to fix as a backhoe?
Good luck at the appointment.
Post by: fishfighter on March 08, 2019, 08:49:19 AM
Dang backhoe is like me. Slow starting, smokes a little, leaks from everywhere and always needs work on it. :D
Doctors appointment went good. CRT-D needed a complete tune up. Took about an hour, but all good now. 8)
Post by: Darrel on March 08, 2019, 10:24:28 AM
Good deal!
Post by: fishfighter on March 08, 2019, 05:40:41 PM
Put in just about a full day work. Started with cutting grass and water. >:( It had to be done one way or another. :( Then climb on the backhoe and moved a couple hundred yards of dirt around the guess house. Still have a bunch more, but first I have to dig it up. ;D
Did a quick walk thru the house. Trying to get motivated to get back sanding. :( Will try to finish up that back bedroom this weekend.
Post by: fishfighter on March 11, 2019, 09:35:34 AM
Finish floating and shot texture yesterday. 8)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0005.jpg?easyrotate_cache=1552311075)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0001.jpg?easyrotate_cache=1552311098)
I will prime it today. ;D
Post by: Magicman on March 11, 2019, 09:40:17 AM
Looking good Paul.  It's also good to see you sorta back to your own self.  8)
Post by: fishfighter on March 11, 2019, 02:56:08 PM
Thanks Lynn. Got the room all primed out. Will paint the ceiling tomorrow. That will be white, but still haven't picked a color for the walls.
Post by: Magicman on March 11, 2019, 04:14:46 PM
She will..... :D
Post by: fishfighter on March 14, 2019, 02:47:17 PM
Been painting and got it all done. 8) And yes Lynn, I did pick the color. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0006.jpg?easyrotate_cache=1552588419)
Today, I started boxing in the windows. Problem there, I had to shut it down due to rain. :(
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0008.jpg?easyrotate_cache=1552588465)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0009.jpg?easyrotate_cache=1552588509)
Just have to add the outside trim.
I got to order some more knives for my planner. It's going to take just under 200 sf of flooring. Will be the same flooring as the kitchen/living room area.
Have another problem. Most of the oak I have sawed up is reading around 13-14% moisture. :(  Thinking of moving all inside the house and just run some fans on it 24/7 till I can get the moisture down below 11%.
Post by: Magicman on March 14, 2019, 05:26:21 PM
I am just glad to see you stirring and getting-r-done.  8)
Post by: fishfighter on March 16, 2019, 09:05:33 PM
So much for finishing the back bedroom. The more I got to thinking, the more there will be a change. I did finish up all painting, wood trim around the windows and installed plugs and switches.
Back to the change. This is outside the bedroom.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0015.jpg?easyrotate_cache=1552783778)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0012.jpg?easyrotate_cache=1552783718)
Inside in the room.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0014.jpg?easyrotate_cache=1552783765)
Boy, did I screw up or what? Even more so for a change I want to do. >:( Yep, I didn't center the door way to start with. Not to bad of a change/fix. The biggest change I want to do is add some timbers to the area outside of the bedrooms. By doing that, it would carry off from the kitchen/living room areas. ;D
So, this afternoon, after figuring out what I will have to do, I sawed up a couple beams. I will saw up what else that is needed tomorrow.
Big reason I am going to try this, if it works, I am wanting to do this in my house on a grand scale. 8)
Post by: Magicman on March 17, 2019, 08:21:34 AM
As long as your mind has a plan, your butt is still in control.  Most of us fly by the seat of our pants anyway.  :D
Post by: fishfighter on March 17, 2019, 09:18:26 AM
You got that right Lynn. :D One of the logs I sawed up yesterday had to be the nastiest logs that was ever sawed. Sucker had mushrooms growing off it. A lot of punk wood. Was a short log, but more then long enough to get a 4x10 out of it. I have around 6 more standing dead oaks that need to be felled. Might do that today. Having a very slow start to my day already. :(
Post by: fishfighter on March 19, 2019, 08:08:17 AM
Door way moved and beams going up.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0018.jpg?easyrotate_cache=1552951078)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0019.jpg?easyrotate_cache=1552951131)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0020.jpg?easyrotate_cache=1552951163)
Going to try and finish this up today.
Post by: Magicman on March 19, 2019, 08:32:07 AM
Looking good.  smiley_thumbsup  I believe that "Oakey Dokey" will be OK here.    ;D
Post by: fishfighter on March 20, 2019, 07:30:14 AM
Wrap it up yesterday. Just need to stain them out with vinegar/steel wool mixture and add the braces.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0026.jpg?easyrotate_cache=1553080996)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0025.jpg?easyrotate_cache=1553081022)
I like it and it made the area to match the kitchen/living room area. 8)
Post by: fishfighter on March 23, 2019, 07:10:44 AM
Yesterday I had to take it easy. Was hurting from the day before working up in the attic. Had to install a heater/vent in the bathroom ceiling. Very tight area. :o
So, I had went back into the kitchen and address something that needed to be done.
Before
It is hard to see, but I didn't complete cover the walls above the window and back door with tile. So that was what I did.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0029.jpg?easyrotate_cache=1553338406)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0027.jpg?easyrotate_cache=1553338495)
Just need to grout it out now.
Post by: Magicman on March 23, 2019, 08:14:46 AM
Another step Paul.  I like your "cranker-upper" beam raiser.  8)
Post by: fishfighter on March 23, 2019, 08:24:42 AM
Lynn. I built that to life sheetrock. Still have more use for it down the line.
Post by: fishfighter on April 02, 2019, 05:27:33 AM
Just a little update.
Did finish grouting out the kitchen. Been doing a lot of dirt work outside. We been having some good dry cool weather. ;D Had many tree stumps that I need to dig up along with extending my pond. I need the dirt to put all around the guest house. Only problem there, with the Mississippi River high, once one digs a couple feet down, overnight it fills with water. :o
Rain coming towards the end of the week. So I been moving, stacking dirt. Moved about 300 yards yesterday and have a 100 or so let to do today. Raising the area around the guest house is a big job. It's bigger then a ac. Going to raise that by about a foot. A lot of dirt. :o Sure glad I don't have to buy that much dirt. ;D
Will get some pictures today.
Post by: fishfighter on April 11, 2019, 08:09:34 PM
Small up date.
Really haven't been doing much. The old ticker went into cardo shock and ending up in the hospital for a few days. :( All is well now and was flat out told to slow down and take it easy, which I did.
Yesterday, I had climb on the backhoe to dig a line from the house to the power pole for under ground service. Had to be 3' deep.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0036.jpg?easyrotate_cache=1554943803)
So I went closer to 4'. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0033.jpg?easyrotate_cache=1554943769)
With the water table so high, you can see how fast water was coming in. :o It is all filled back in. Something about throwing $300 into a hole and cover it back up with dirt. :D
Today, got out early and packed dirt. Then started grading to were I had added dirt in the front of the house. Wasn't a good idea. >:( Had hit a area that I dug out a stump and before I knew it, the tractor bottom was in dirt. :D Front to back. :D Had to use the backhoe to lift, pull it out. Called it a day after that mess and went cut the grass. :D
Picture of my poor little old tractor.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0037.jpg?easyrotate_cache=1555033126)
8)
Post by: Briankinley2004 on April 11, 2019, 10:30:02 PM
I have an old Ford 1600. That picture looks familiar :D :D
Post by: LeeB on April 12, 2019, 04:23:45 AM
I'm glad to see you are heeding the doctors advice and slowing down.  ::)
Post by: Magicman on April 12, 2019, 10:42:45 PM
I had wondered where you were and what you were doing??  Now I don't know whether to admire you or fuss at you??  I do want you to finish that project so I can come to see you and it, but I would prefer that you were still kicking.
I really do understand so keep at it, but do pace yourself.  :)
Post by: fishfighter on April 13, 2019, 07:50:09 AM
I am really taking it easy. First hint of feeling somewhat bad, I shut it down for the day and rest. Of course the wife is watching like a hawk.
Yesterday, the area that I added the post and beams, I had to paint the walls. Took about an hour and after that I did shut it down for the day.
Maybe today I will go stain out those post and beams.
Post by: fishfighter on April 16, 2019, 06:47:10 PM
Been taking it easy, so I been doing small little projects.
Got a dump station in. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0052.jpg?easyrotate_cache=1555453998)
Installed a ceiling fan in the back bedroom.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0054.jpg?easyrotate_cache=1555454036)
Got another just like that for the front bedroom.
Stained out the new post and beams.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0062.jpg?easyrotate_cache=1555454122)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0063.jpg?easyrotate_cache=1555454166)
Once I clean up the older beams and post, they should match.
Also, been doing a few honey do's around the house to keep the wife off my case. ;D
Post by: fishfighter on April 18, 2019, 06:04:37 PM
Little more done. Small steps.
Finished out hooking up the electric water heater.
Then install the attic stairs.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0064.jpg?easyrotate_cache=1555624676)
Yep Lynn, the lift in action again. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0066.jpg?easyrotate_cache=1555624717)
All done.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0065.jpg?easyrotate_cache=1555624749)
Post by: Magicman on April 18, 2019, 10:01:27 PM
Yup, I noticed the lift before I scrolled down and saw your remark.   ;D
I am loving your steady progress.  8)
Post by: fishfighter on April 25, 2019, 12:57:43 PM
Been taking it very easy. Feeling ok, but tired all the time. Got all door trim hung in the back bedroom. Had some touch up painting done too.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0069.jpg?easyrotate_cache=1556211057)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0068.jpg?easyrotate_cache=1556211028)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0067.jpg?easyrotate_cache=1556210996)
Now if only the weather clears up, I will then try to start planning out some flooring. DanG shame I bought new knives over a month ago and yet tried to get the flooring done. :(
Post by: fishfighter on April 29, 2019, 07:14:00 PM
Pieces, pieces and more pieces. That is what I been up to. Been trying to get some bids on ac/heating. Hoping some time this week. Anyway, just knocking off small stuff, some electrical, some touch up painting and then some more. Still taking it easy even after seeing my Doc. Back on a new/old drug that I took before. Got to watch this very close due to BP had dropped way to low in the pass.
One of those custom pieces that took little to no time to build, but being heavy, was a SOB to hang.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0076.jpg?easyrotate_cache=1556578836)
Kept the bark on the live edge. Was a bit to match corners, but did so. ;D Total cost, $32 for the mirror. Just have to put up two ceiling LED lights up in the bathroom and I will finish that up.
Post by: Magicman on April 29, 2019, 07:38:13 PM
That is a nice update Paul.  I had figured that you had foundered on Crawfish or Gumbo.  8)
Post by: fishfighter on April 29, 2019, 07:58:02 PM
Lynn, had my fill of crawfish. Not one of those things I go crazy after. Now some good fat boiled crabs, I could eat that every other day. ;D
The list is getting shorter, but yet way so much to do. I'm at the point of seeing it finish, but yet I been having shorter days working on it. :( The old ticker is really starting to slow me down these days. >:( It's got to the point to were it is getting hard just to walk to the back. But, I live by the words, " if there is a will, there is always a way." 8)
Post by: Magicman on April 29, 2019, 09:10:48 PM
Yup, you are reaching the point where you are wanting to actually complete stuff.  Check it off of the list and then move on to something else that you can finish.  It's a good feeling.  :)
Post by: sawmilllawyer on April 29, 2019, 11:35:06 PM
Really like that mirror! Looks like you are getting it done. My hat is off to you and your thrift and ingenuity. Just got to keep moving. Soon to check off another project.
Post by: fishfighter on April 30, 2019, 06:09:22 PM
Quote from: sawmilllawyer on April 29, 2019, 11:35:06 PM
Yep, knocked off some more small stuff today. ;D
Going to try in do some outside ground work tomorrow. Still have a lot of dirt to move in place around the house so I can install real good steps.
Got a AC guy coming Wednesday and another coming Thursday. Hoping to get the main power line hooked up by Friday if it is not to wet. Might have a small problem installing a ac/heating system, but I figured a way to make the room for a system in the attic. I am still up in the wind as to what kind of system I am going to go with. I did wire the house to go with PTeck systems, then even looked very hard at mini split systems or just a standard AC/heating system. Just don't know at this time.
On a side note, the bathroom is complete. Got the last two lights hung today. Back bedroom is finished up to the point were I just need to install the flooring and base boards.
Post by: Darrel on April 30, 2019, 07:17:25 PM
Good for you, sounds like you're getting close to the finish line.
Post by: fishfighter on May 01, 2019, 09:06:04 PM
Had past up dirt work for planning out some flooring. Was a job I care not to do again. Three hours and I have more then enough for the back bedroom.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0079.jpg?easyrotate_cache=1556758902)
Title: Re: Started the build.
Post by: Magicman on May 01, 2019, 09:31:37 PM
Paul remind/refresh me, the back bedroom that gets this flooring.  It's the old building that you "married" to the new building?
Post by: caveman on May 01, 2019, 10:24:18 PM
Paul, I got caught up to date on your project and you today.  You and the work you do inspire me and I am sure many others.  I have enjoyed following this build and lesser men would have folded their tents if presented with just a portion of the adversity that you have overcome.  I really like the look of the oak beams and doors.
Kyle
Post by: fishfighter on May 02, 2019, 08:10:10 AM
Quote from: Magicman on May 01, 2019, 09:31:37 PM
Yes, it is. That room is 12'x16'.
Thanks caveman. Been a long road from buying a small sawmill to building this house. A lot of water has passed under the bridge.
Post by: Magicman on May 02, 2019, 08:16:58 AM
Getting close(r) to the finish line makes one start to get anxious.  Please take the time to pace yourself Paul.  I am getting antsy to come down to see it.  :)
Post by: fishfighter on May 04, 2019, 11:05:32 AM
Any time Lynn. ;D Had a couple ac people come in. Had to ;D at their prices. Unreal. Best price was $8039 installed. :D Have a buddy that is a ac guy that will be coming next week. He will tell me were to install ducting and everything else. Then he will come back and install the units. He said he would do it for free, but I will throw some money his way. This will cost me around $3200 going this way.
I did move more dirt around the front of the house. Rain coming down today. :( So I can't do anything there. I need to pour some concrete for the front steps as a base pad and another pad for the ac condenser unit. Maybe get this done next week.
Post by: LeeB on May 04, 2019, 11:51:45 AM
They do sell precast AC pads fairly reasonable. Just a thought.
Post by: fishfighter on May 04, 2019, 07:12:49 PM
Quote from: LeeB on May 04, 2019, 11:51:45 AM
Yes, but over time they start to bow to the center, trapping water. Suckers game there.
Dirt work out front.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0081.jpg?easyrotate_cache=1557010741)
  Now if only it will dry.
Did started the first two strips of flooring in the back bedroom today. Had added a 2" wide in the door thrash hole.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0082.jpg?easyrotate_cache=1557010764)
Then I had to saw out a piece to line the wall. Then pop a line and nail it down. Reason, so I am able to line up the flooring run coming into the room.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0080.jpg?easyrotate_cache=1557010804)
Will get back on it Monday and knock out the room.
My one grandson will be making his first communion tomorrow which I look forward to go to. ;D
Post by: Magicman on May 04, 2019, 08:52:20 PM
Quote from: fishfighter on May 04, 2019, 11:05:32 AMAny time Lynn
My sawing wagon is loaded right now plus I haven't seen the Cabin and property since that twister came through.  Maybe I can get some time off after I knock a few of these sawing jobs out.  That road trip sawing has me behind.
Post by: fishfighter on May 06, 2019, 07:15:52 PM
Lynn, I hope all is good. If you need any help. let me know. I will load up the tools and head your way in a heart beat. 8)
Just about finished laying the floor down.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0092.jpg?easyrotate_cache=1557183585)
The different between the two floors are less then 1/16". :( Oh well. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0094.jpg?easyrotate_cache=1557183607)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0095.jpg?easyrotate_cache=1557183627)
Kind of would of finished the flooring, but even with knee pads and started before 8 am and quitting at 4 pm without a break. I called it a day. Besides that, I would be piecing more flooring then I would of like to do. :o I have well over 400 sf left of this flooring, so I will pull out 4 more long boards and just plane the out tomorrow. ;D
First thing in the morning, I got to get up in the attic. :o Got to do some bracing and then some cutting. Got to make some room for the air handler. >:(
Post by: Magicman on May 06, 2019, 09:45:34 PM
Oh wow Paul, you did a job on that flooring.  Compensating for a slight floor height is what thresholds are for.  thumbs-up
Post by: fishfighter on May 07, 2019, 07:52:48 PM
Finished laying the floor down.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0099.jpg?easyrotate_cache=1557272583)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0096.jpg?easyrotate_cache=1557272602)
Now just waiting on a ac to go in to sand and varnish out the complete house. ;D
I also had to do some work up in the attic, which was the first thing I did this morning before the heat wave. Had to add some new braces and cut out some old ones. Went easy then I expected. ;D
After that, I climbed on the tractor and did a little grading of the front yard. Still way to wet. :( Then it was time to climb on the ZT and cut some grass. That took a couple hours and then a few beers. ;D
Post by: TimGA on May 07, 2019, 08:40:50 PM
Been watching this for a while, great job and great inspiration considering health conditions. That is a lot of work for one person. Can't wait to see it finished.
            Tim
Post by: sawmilllawyer on May 07, 2019, 10:46:41 PM
Floor looks great, can't wait to see it after it is finished. Paul I also sent you a PM. Keep on moving even if it is small steps you will get there. Andy.
Post by: fishfighter on May 08, 2019, 06:28:40 AM
Thanks guys for the kind words. Been over 3 years now on this project. :o I will finish this some day and then I don't know what I will do. :D
I did call a couple people yesterday to see what it will cost to have them come in and shoot some close cell foam under the flooring. I did price a DIY kits. That is around $1200. If I search some more, I am sure I can find a better price then that. 8)
Post by: fishfighter on May 14, 2019, 02:40:52 PM
After last weeks rain, almost 15" in three days, things are starting to dry out. Today is the first day I was able to do a little work.
This is a pad for the front steps.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0110.jpg?easyrotate_cache=1557858891)
All finished but the drying.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0112.jpg?easyrotate_cache=1557858917)
Post by: fishfighter on May 16, 2019, 09:19:03 PM
Man, just jumping thru hoops. >:( Trying to get power into the house is unreel. 20+ years ago, one only had to get a treatment plant inspected. Now, >:( One has to get a resurvey to make sure one has built above flood stage, a inspection for safe power feed from the parish and then more. >:( Been waiting on this. >:( Got a inspector coming in the morning. ;D AC/heating system should be in next week. Just sitting around finishing the electrical work waiting on the other man. >:(
Post by: Magicman on May 16, 2019, 10:09:49 PM
I can understand the "hurry up and wait frustration" but it will all be worth it after completion.  8)
Post by: fishfighter on May 17, 2019, 05:58:38 PM
Well, the parish inspector busted my bubble. >:( >:(. Kind of somewhat of a problem. Having the main breaker panel in a closet. >:(. of course they passed a law as that is a no no. Did that less than a year ago. Asked the inspector if I could be grandfathered in, nope. >:(  Well, he did give me a somewhat easy fix. I had cut back 15" of the closet and add a wall. All done now and I will just build some cabinets into that area. ;D Will post a picture later.
Post by: Magicman on May 18, 2019, 09:43:58 AM
Well thankfully it was a fairly simple fix for a guy with a saw, hammer, and brain.  8)
Post by: fishfighter on May 18, 2019, 02:26:19 PM
You know a sawsall can do some damage quick. ;D Did talked to the parish inspector. He will be by early Monday morning. The power company boss man that I know, came got what he needed for the work order. All good there. He told me as soon as the parish signs off, he will have a crew right out. ;D
Post by: sawmilllawyer on May 19, 2019, 11:30:35 PM
Quick thinking on the closet. Still perking along. Stay at it you will get there!!!
Post by: fishfighter on May 20, 2019, 11:45:26 AM
Inspector came in and all good now. 8) Boy, did I do a no no again. ;D Was in the meter pan and I knocked one of the lugs off and it fell down into the under ground pipe. :o Had to get another rope, tie a rag on and tie it to the rope I have running thru the pipe to pull the power cable thru. Pulled that thru and out popped the lug. ;D All good again. :D
Should get power maybe today or tomorrow. ;D
Got the surveyor coming Wednesday. Have to have a final floor elevation done. No cost for this due to having already paid to have a flood elevation already done.
Post by: Ljohnsaw on May 20, 2019, 12:08:30 PM
Quote from: fishfighter on May 20, 2019, 11:45:26 AMWas in the meter pan and I knocked one of the lugs off and it fell down into the under ground pipe.
Reminds me of a time I was "saving money" by doing my well pump myself. :-\ It was highly recommended and I wanted to put a 4" pvc liner down my well before I put the pump in.  So I drilled/perforated several 20' lengths of pvc for the bottom section (320' well).  It was raining while I was doing this.  I tied a rope around the pipe to support it in the well casing while I glued the next section on.  So now I have 40' of pipe vertical and the water level is about 10' below grade.  As I'm sliding it down through my rope loop, it takes off down the well.  All I can say is DanG!  I'm pondering how this is gonna mess up getting the pump down there along with the rest of the lining when I look down the well.  I see the reflection of the water surface and I keep seeing a circle appear and disappear. What the...  Turns out my pvc pipe was *slightly* buoyant.  I was able to tie a hook on some rope, drop it down the middle of the pipe and snag the bottom end.  After that, I had two ropes on it and lowered it about 1' at a time.
Post by: Bruno of NH on May 20, 2019, 07:51:34 PM
Your are an inspiration to all :)
It looks great  8)
Would like to meet you some day
Bruno
Post by: fishfighter on May 21, 2019, 03:22:29 PM
Thanks Well, got as far as the power line hooked up, but no meter. They can't install that till I get the final floor elevation done. Those guys supposed to be here sometime this afternoon.                                              Got the elevation done. Now how long it takes to send that in. 8)
Post by: Florida boy on May 21, 2019, 05:43:58 PM
I once dropped a full size pair of channel locks down a main feeder conduit. Thought I'd never get it out but did eventually...
Haven't  stopped in on this thread in a while.  The progress looks GREAT! love the floors. Won't be long now.
Post by: Magicman on May 21, 2019, 08:23:57 PM
Somebody dropped this monkey wrench and bolt down a knothole in a Cedar tree.
(https://forestryforum.com/gallery/albums/userpics/20011/IMG_4095.JPG?easyrotate_cache=1522981003)
They couldn't get it out
(https://forestryforum.com/gallery/albums/userpics/20011/IMG_4097.JPG?easyrotate_cache=1522980985)
.....but I did.  :-X
Post by: realzed on May 21, 2019, 09:05:17 PM
OUCH!
Post by: doc henderson on May 21, 2019, 09:11:21 PM
MM you sure are Lucky... a little WD40 and you got a like new monkey wrench and bolt. :D
Post by: fishfighter on May 23, 2019, 05:05:15 PM
Yep, they don't make them like they use to. ;D > Anyway, I have power. ;D AC system coming tomorrow. Hope to have that up and running by next mid week.
Post by: Magicman on May 23, 2019, 08:26:41 PM
By midweek, you will need it.  smiley_sweat_drop smiley_sun
Post by: fishfighter on May 26, 2019, 07:41:33 PM
Been working up in the attic. Un godly hot. :o Heat index been hitting close to 100F. Slow progress, but things look good. 8)
Post by: fishfighter on May 30, 2019, 07:37:13 AM
So, after spending 6 days up in the attic, now I know as to why AC guys charge so much to install a ac system. :o There is just so many parts to a system one forgets that one just doesn't see. :o
One first has to build everything when it comes to the duct work.7 drops and I will be adding a 8th one. Of course one has to install collars on the vent boxes. The duct sealer glue takes 20 hours to dry. :(
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0121.jpg?easyrotate_cache=1559214735)
Then one has to cut the ceiling for the return duct. That includes sawing a ceiling joist. Then framing.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0130.jpg?easyrotate_cache=1559214058)
Off course, one has to build a decking for the air hander and then get that up in the attic, then build the intake duct.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0131.jpg?easyrotate_cache=1559214073)
Of course using trusses, one has to cut some braces out the way and then add new braces. :o
Once one gets the vent boxes mounted in the ceiling, one starts aging ducts to them.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0125.jpg?easyrotate_cache=1559214756)
For the back bedroom, that was just about a full days work. :o I had to take one of the roof panels off due to little to no room. :o  Bad thing is, I will be adding a second drop in that room. That room will need it. It's on the north, and west side of the house which will need extra cooling and heating.
I did ran the set lines, Tstat wires and two #8/3 wires for the heat strip and air hander fan motor.
Yesterday my ac buddy came by. Asked if I wanted a job doing ac work. Not know, but heck no. :D
Today I will try to rap up everything, but then again adding that second drop might take a day.
Post by: Magicman on May 30, 2019, 07:45:13 AM
It also sounds like one waited until HOT  smiley_sun weather before starting on one's AC/Heat installation.  smiley_sweat_drop
Take care and stay hydrated.
Post by: WDH on May 30, 2019, 07:49:57 AM
One must also be crazy to do that ones-self :).
Post by: Magicman on May 30, 2019, 08:19:41 AM
When stuff needs to be done and one is the only one there, one finds one's self doing what needs to be done.  Being a bit crazy helps.  smiley_dizzy
Post by: samandothers on May 30, 2019, 08:40:05 AM
Well I recon that makes fishfighter number ONE!  Make it so number one!
Great job on the HVAC.
Post by: fishfighter on May 31, 2019, 05:27:50 PM
Quote from: Magicman on May 30, 2019, 08:19:41 AM
This and I have more time then money. :D
Got just about all done. :( Got to hot and had to shut it down.
Got that 8th drop done. Wasn't that bad. ;D All duct work is finished. 8)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0141.jpg?easyrotate_cache=1559337167)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0142.jpg?easyrotate_cache=1559337189)
Just so happy there. ;D All I have left to do is do a little plumbing. Just run the drip pan drain lines and hang up two disconnects for the air handler. 8) Maybe two hours at most to do that. Bad thing, got to go help my SIL do a small job at one of my friends Mom's house tomorrow morning. Hope to knock that out fast and then come back and finish up. My ac guy said he could finish it out Sunday if I am ready. ;D
Post by: Magicman on May 31, 2019, 07:04:56 PM
You gonna blow your ceiling insulation in?  Fiberglass, cellulose, foam, or ??
Post by: fishfighter on May 31, 2019, 07:12:59 PM
Blown in Rock wool. Cost a little more, but one gets more R value with it. It's what I have in my house now and I am very happy with it the past 25 years. 6pm, heat index was at 97. :o Just know it was above 100 today. Only good thing about this hot weather and working in the attic is I cut back big time on the Lasix. ;D
Post by: sawmilllawyer on May 31, 2019, 07:27:43 PM
Well One has to do what one has to do to get it done. Looks like one did what one had to do. Agree crazy probably helps. Great Job!!! Yeah, I have done attic work like it better in the late fall or early spring. Rock Wool insulation is a better choice. I bet your are glad that job is almost behind you.
Post by: fishfighter on May 31, 2019, 07:44:30 PM
Sure will be. Then it will be time to finish out the floors maybe after a week or two running the ac unit. Mean time if it stays dry, I have 1200' of water line to run. :o Need water bad now to wash the outside of the house so I can paint it. Once I get that done, I decided to install vinyl  soffit. Was going to use Hardie board, but I loss a lot of arm strength. :( Another health problem with no fix. :(
Post by: Darrel on May 31, 2019, 11:39:49 PM
This is getting exciting. Almost done!!!
  8)
Post by: fishfighter on June 02, 2019, 12:36:20 PM
All finished on the work I needed to do. My buddy has a Dr appointment tomorrow. Maybe Tuesday I will have it up and running.
Post by: fishfighter on June 04, 2019, 02:06:35 PM
Talked to my buddy this morning. He told me he needs a couple more days rest. No problem there.
More ac pictures.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0146.jpg?easyrotate_cache=1559671017)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0147.jpg?easyrotate_cache=1559671066)
Also, as dry as it is, more dirt work done. Front and back and right side just about all done.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0150.jpg?easyrotate_cache=1559671121)
Added more dirt to the south side. I will be adding a carport there. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0152.jpg?easyrotate_cache=1559671101)
With that little storm down in the lower gulf, that should bring some much needed rain here starting tomorrow thru the weekend. Hope none goes to the mid west.
Post by: fishfighter on June 06, 2019, 12:33:12 PM
So, here we go again. Had close to 5" of rain this morning in less then 2 hours. :o Parts of the parish had as much as 10" of rain. We are still forecast for 2"-3" more over the next couple days. All good here. ;D
Baton Rouge and area around is flooded again. :o
Post by: samandothers on June 07, 2019, 12:54:35 PM
So much building in urban areas decreases the land to absorb and mitigate run off can cause increasing the flooding issues.
Post by: fishfighter on June 15, 2019, 03:41:46 PM
Quote from: samandothers on June 07, 2019, 12:54:35 PM
Not a problem here. This is country at it finest. ;D
Been some time from last post. Ac system up and running. 8) Been a little under the weather, but still going at it.
Had rented a floor sander for a day for a rough in sanding. After that, I pasted some floor filler.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0156.jpg?easyrotate_cache=1560627008)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0155.jpg?easyrotate_cache=1560627045)
I will started Monday and get to sanding out the floor, maybe.
Post by: doc henderson on June 15, 2019, 04:41:09 PM
progress!!!
Post by: fishfighter on June 19, 2019, 10:07:18 AM
Happy to report that I check the power meter and in 5 days running the ac, set at 84f, I used only 33 KW's. 8)
Post by: fishfighter on June 23, 2019, 10:46:45 AM
With the heat on and the start of summer, it's already way to hot. Heat index has been 105F+. :o Thank God for ac's. ;D
Got the floors all sanded out. 8) Used this beast. Just as bad as a killer tiller. :o Total time, about 19 hours running that sucker. :o
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0159.jpg?easyrotate_cache=1561300704)
Still have a ton of dust to clean, but very happy the way the floors turn out. ;)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0160.jpg?easyrotate_cache=1561300715)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0162.jpg?easyrotate_cache=1561300735)
Today is a day for rest. ;D
Post by: Darrel on June 23, 2019, 12:56:57 PM
Yep, I'd be happy too. That looks really good and I'm sure it looks even better in real life!
Post by: Magicman on June 23, 2019, 03:15:51 PM
 :o  Looking good, you earned a day of rest.  8)
Post by: fishfighter on June 23, 2019, 07:16:57 PM
Quote from: Magicman on June 23, 2019, 03:15:51 PM
That didn't happen. SIL and daughter showed up at noon wanting to saw up more lap siding. :o Got as far as loading a real big pine log on the mill and had to call it a day. Told SIL that one has to start sawing at 6am. Will saw it up next weekend. ;D
Going to have to chill a couple more days. Just hope I get some rain to help cool things down.
Post by: sawmilllawyer on June 23, 2019, 11:38:12 PM
Those floors look great! Sounds like the A/C was the ticket for your sanding marathon. Keep on plugging away you will get there.
Post by: Magicman on June 24, 2019, 07:31:13 AM
Quote from: fishfighter on June 23, 2019, 07:16:57 PMJust hope I get some rain to help cool things down
Looks like you are getting your wet wish.  I am too.  ;D
Post by: fishfighter on June 25, 2019, 03:12:53 PM
Got out this morning and made a couple hundred feet of shoe mold. Super hot and called it a day at 10am. :( Didn't take any pictures. :(
Post by: SwampDonkey on June 29, 2019, 05:24:31 PM
Looking good. :)
I never installed AC here, as we are north of the snow line. We have been lucky so far, only had to days in the 80's and one was a dry air and the last one yesterday was a muggy 87. This is feeling more like a northern summer, 70's and maybe 1-2 days of muggy heat once in awhile. The last two summers was 90's for 3 months. I may eventually get a unit next year, but we also have the furnace to bring dryer cool air up from the basement. Tonight it is 53% down there and 65% up stairs since windows are open and it has been a stretch of shower weather. :)
Post by: fishfighter on July 01, 2019, 08:53:52 AM
Down here, one has to have a ac like people up north need heating.
Still on the fence on what to use for the flooring. I did order a gallon of Waterlux. Was told it's a outstanding product for flooring.
Saturday, I had picked up our new family.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0180.jpg?easyrotate_cache=1561984786)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0184.jpg?easyrotate_cache=1561984814)
7 week old Boykin. My old dog is not a happy camper. ;D
Yesterday, got some time on the sawmill. 8) Had SIL doing most of the work due to we sawed up well over 400sf of lap siding for him. Besides, I did all the hard work breaking down a 30" butt syp log by myself. I did sawed that up to get the most quarter sawed out of it. 8)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0191.jpg?easyrotate_cache=1561984627)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0192.jpg?easyrotate_cache=1561984652)
Post by: fishfighter on July 08, 2019, 04:29:44 PM
Really haven't been doing much on the house. Been down in Panama City with the wife, daughter and her family. That has been the first trip I took in almost 12 years.
I did get some shoe mold up in the living room. Didn't have my phone with me, so no pictures. :(
The weather here is super hot. I will try tomorrow start applying so of that waterlox in the back bedroom. This is the product I will be using. https://www.waterlox.com/about/ (https://www.waterlox.com/about/)
Anybody ever used it in the pass?
On a side note. Our little pup is coming along fine. Even the old dog is acting young again. ;D
Post by: Magicman on July 08, 2019, 04:53:52 PM
Not used it, but it's good to see you back.  Been wondering where you were, but I do understand HOT.  I will not be sawing anything until the end of August or maybe even September.  smiley_sweat_drop smiley_sun
Post by: fishfighter on July 08, 2019, 07:33:24 PM
Hey Lynn, hope you been taking it easy with the hot weather. DanG heat index been above 105 to as high as 108F. No wind at all. :o
Did get a couple pictures of that molding I hung. It is 3/4"x 1 1/8" shoe molding with a small lip.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0224.jpg?easyrotate_cache=1562628233)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0225.jpg?easyrotate_cache=1562628256)
Reason of installing it, I had a gap from the post to the sheetrock. That will keep getting wider over time as the post shrink to dry out the next couple years.
Still trying to make or find someone to make some crown molding for the ceilings. Still no luck there. :(
Post by: btulloh on July 08, 2019, 08:25:23 PM
You can cut some nifty cove moulding on a tablesaw that makes for a nice crown moulding. It's kind of fussy but works well if you don't need 1000 ft. It's an interesting technique.
Post by: fishfighter on July 08, 2019, 09:22:20 PM
Going to need about 1k '. :D
Post by: btulloh on July 08, 2019, 09:45:00 PM
Ha. Of course. It's possible just a little time consuming.
Seems like somebody on here with a molder could run a batch for you.
Post by: fishfighter on July 09, 2019, 08:38:45 AM
Bad thing right now is that I don't have enough stock on hand. :( So that will put some things way behind. :( I still have a couple dead standing water oak trees that should be somewhat dried. ;D Might try to fell them this week, but if that low pressure storm over Fla moves out in the Gulf, all bets are off. Getting some forecast to as much as 20+" of rain here.  :o
Post by: Magicman on July 09, 2019, 10:17:16 AM
Remember too that you can make crown molding by stacking individual width pieces/strips that have different router designs.  Round over, bead, cove, etc. stacked will produce some nice molding.
Post by: samandothers on July 09, 2019, 12:02:12 PM
Waterlox is good since it can be touched up.   It does give an amber tint to the wood. Look forward to seeing how it  finishes up.
Post by: fishfighter on July 09, 2019, 12:09:34 PM
Well, I just finished putting down the first coat in the back bedroom. Yep, I'm a happy camper. I did some test were the kitchen island is going to be with two kinds of varnish. Wasn't happy at all.
Back bedroom.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0229.jpg?easyrotate_cache=1562688154)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0230.jpg?easyrotate_cache=1562688185)
Going to take no less then 4 coats. No sanding in between coats, 24 hour drying time per coat.
Post by: sawmilllawyer on July 09, 2019, 06:18:07 PM
That really makes the grain pop in that floor for  sure! I like it a lot.
Post by: fishfighter on July 10, 2019, 01:24:16 PM
Got the second coat down this morning.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0231.jpg?easyrotate_cache=1562779226)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0232.jpg?easyrotate_cache=1562779247)
Two more to go. 10x more easy then using any varnish. ;D
Post by: Crusarius on July 10, 2019, 01:59:34 PM
just using a roller or brush?
Post by: SwampDonkey on July 10, 2019, 02:12:25 PM
I know some of these finishes say no sanding required, even what I am using on the stairs and rail. But sanding will be done between coats. Of course a floor sanding is a heck of a lot bigger job. ;)
https://www.minwax.ca/wood-products/hardwood-floor-finishing/minwax-super-fastdrying-polyurethane-for-floors-350-voc (https://www.minwax.ca/wood-products/hardwood-floor-finishing/minwax-ultimate-floor-finish)
Post by: fishfighter on July 10, 2019, 02:24:56 PM
Quote from: Crusarius on July 10, 2019, 01:59:34 PM
Sheep skin. Cost $15 local. Have to use paint thinner to clean up.
Post by: fishfighter on July 10, 2019, 02:27:04 PM
Quote from: SwampDonkey on July 10, 2019, 02:12:25 PM
Used that in the front bedroom over rosewood. I will have to go back and hit it with a lite sand for a third coat.
Post by: Crusarius on July 10, 2019, 03:10:55 PM
woh some simple sheepskin rag? that has to go on real fast and easy.
Post by: samandothers on July 10, 2019, 06:19:43 PM
Looks really good!   Hope you had some good ventilation that stuff will leave ya light headed!
Post by: fishfighter on July 10, 2019, 08:39:17 PM
Quote from: Crusarius on July 10, 2019, 03:10:55 PM
Quote from: samandothers on July 10, 2019, 06:19:43 PM
There is a wood pad and a painters poll screws in.
Yep, windows open in just that room and running a big old box attic fan pointing out the back door. Bad thing, I had to shut down the fan and close windows due to the weather. :(
Post by: fishfighter on July 11, 2019, 10:10:06 AM
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0234.jpg?easyrotate_cache=1562853993)
Post by: fishfighter on July 11, 2019, 10:12:18 AM
Third coat applied.
Second coat dried.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0235.jpg?easyrotate_cache=1562854109)
Third coat. It's building up.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0240.jpg?easyrotate_cache=1562854065)
Post by: samandothers on July 11, 2019, 10:50:06 AM
Looks very nice!
Post by: Crusarius on July 11, 2019, 10:57:29 AM
Sweet. thanks for the info.
Post by: fishfighter on July 12, 2019, 06:44:12 AM
Going to try and get the 4th coat down this morning before the rains start. That TS will be coming up this way. Forecast to as much as 27" of rain thru Sunday. :o Shouldn't be a big problem here, I hope.
Post by: Magicman on July 12, 2019, 09:20:21 AM
Hunker down my Friend and hopefully it will not spawn any twisters as it moves North.  We are only forecast to get 8" to 12" of rain.  ::)
Post by: SwampDonkey on July 12, 2019, 09:25:01 AM
'Only' :D That's still nasty enough, it would put indoor pools in old basements up here. ;)
Post by: Magicman on July 12, 2019, 09:27:32 AM
There are no basements in our part of the country.  What comes down runs off.  Of course it may back up in low lying areas so flooding is always a threat.  :-\
Post by: SwampDonkey on July 12, 2019, 09:29:44 AM
Yes, and probably a better idea as long as your on a dome. ;)
Post by: fishfighter on July 12, 2019, 09:40:41 AM
About as ready as I can Lynn. Added extra weight to all covered wood piles. ;D
Had time to do the 4th coat.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0242.jpg?easyrotate_cache=1562938207)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0241.jpg?easyrotate_cache=1562938239)
Suppose to dry out as a semi gloss finish. I'm still up in the wind if I will drop it down to a satin finish. To do that, one just orders a gallon of that finish and it does it in one coat.
On a side note. They stated that one gallon will finish out 500sf. This room is 12'x16'. Just about used the full gallon. Might have maybe 6-8 oz left. ;D The first coat, I used a third of a gallon and didn't think I would have enough. ;D
Post by: fishfighter on July 14, 2019, 06:54:54 AM
Update on the weather here. Barry was a bust, thanks God. We are just getting rains. Dry air from the north had sheared the storm which saved a lot of flooding down here. ;D
Still getting rain from the storm and that will still be coming down tomorrow. Nothing heavy and much needed here. ;D
Post by: SwampDonkey on July 14, 2019, 07:04:48 AM
Well that is good news.
Post by: sawmilllawyer on July 14, 2019, 09:48:02 AM
That is very good news. Was wondering how y'all fared during the hurricane.
Post by: fishfighter on July 17, 2019, 08:01:01 AM
Spent the day picking up branches and cutting the yard. The state has a no burn order going on now. >:( I need to burn off a few piles of branches before any more rain.
I did install some more trim, no pictures. Had ordered more of the Waterlox that should be in tomorrow. Hoping to get all coats down by the weekend.
Post by: fishfighter on July 18, 2019, 10:30:53 AM
Got the Waterlox in yesterday afternoon. First thing this morning, I clean up the floor real good and passed a tack rag. Did started applying the waterlox.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0257.jpg?easyrotate_cache=1563459911)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0258.jpg?easyrotate_cache=1563459929)
I did split the room to make it easier. I like it and the wife loves it. ;D
Post by: LeeB on July 18, 2019, 10:43:53 AM
Are you going to finish the wainscot or leave it natural?
Post by: fishfighter on July 18, 2019, 11:06:00 AM
It is coated with a satin varnish.
Post by: LeeB on July 18, 2019, 11:21:20 AM
Oops.  :-[
Post by: fishfighter on July 21, 2019, 08:03:33 PM
Was under the weather yesterday, but was able to get a third coat on this morning.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0263.jpg?easyrotate_cache=1563753665)
Post by: Darrel on July 21, 2019, 08:23:49 PM
 Man, that looks GREAT!!!  8)
Post by: SwampDonkey on July 22, 2019, 03:19:17 AM
Coming right along. 8)
Post by: samandothers on July 22, 2019, 10:29:12 AM
it does look great !  Are you doing anything before each coat, or just wiping it on?
Post by: fishfighter on July 22, 2019, 06:50:43 PM
No sanding in between coats. ;D
Still a bit under the weather, but I still got a bunch done. I didn't want to put the forth coat down till I got three coats down in the kitchen area. Had another problem there. When sanding the fill coat, I wasn't able to get the area of the toe kick areas. First thing this morning, I attack those spots and all was good. Yes, even block sanding by hand was needed. :( Then I had to drop the island over it's area which I had marked and treated the area. DanG island I know weights more then 1 thousand pounds. :o
After passing a tack cloth and much vacuuming and then taping, I was ready to apply the first coat. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0266.jpg?easyrotate_cache=1563834720)
In this picture if one looks close at the bases of the beams, one can see were I split the room. I did a flaring sand before hand. ;D Was the reason to leave the forth coat.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0268.jpg?easyrotate_cache=1563834738)
Overall, I am very happy with the product. For those that would use this produce, I would say that time to fully cure is way out there to as much as 6 months. :o But, that all depends on the weather.
Another thing, this product will darken the wood over time till it cures which for me will be a plus. ;D
Post by: SwampDonkey on July 22, 2019, 07:49:33 PM
Today I put down Minwax Floor varnish I mentioned earlier on the stairway and hand rails. Was dried hard, no tack, in 2 hours. But was a very good drying day and had box fan blowing that dry air. :)
Post by: fishfighter on July 23, 2019, 11:26:42 AM
Second coat down.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0271.jpg?easyrotate_cache=1563895431)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0272.jpg?easyrotate_cache=1563895449)
Post by: fishfighter on July 24, 2019, 09:37:56 AM
Real nice weather here today. Good dry cool air. Got down to 68F. ;D
Got the third coat down.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0274.jpg?easyrotate_cache=1563975268)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0273.jpg?easyrotate_cache=1563975285)
Post by: fishfighter on August 03, 2019, 07:31:46 AM
Just a small update. Been under the weather so I been resting a lot. Really been very tired. :(  Saw my doctors which all they did was make more appointments with other doctors. >:(  Just about had enough of that. Feeling a bit better, so I am going to try and get that 4th coat down today.
Post by: fishfighter on August 03, 2019, 12:30:25 PM
4th coat down,
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0286.jpg?easyrotate_cache=1564849616)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0287.jpg?easyrotate_cache=1564849650)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0293.jpg?easyrotate_cache=1564849668)
Post by: LeeB on August 03, 2019, 12:33:53 PM
Looks real nice.
Post by: Crusarius on August 04, 2019, 12:06:05 AM
Do you have CO detectors in your living areas? I had a pretty bad scare with that one day and realized that was why I felt like I had no energy. I had a strong enough concentration of CO in my shop the map gas torch would not light.
I have since remedied that and all is well with me again.
Post by: fishfighter on August 04, 2019, 07:38:32 AM
I will install them in the future.
Post by: rjwoelk on August 05, 2019, 10:41:25 AM
What kind of wood is the flooring? Is this bought or did you make it yourself? It is very nice.
Post by: fishfighter on August 05, 2019, 11:16:38 AM
100+ year old quarter sawed pine, it came out of New Orleans.
Post by: rjwoelk on August 05, 2019, 11:40:55 PM
Did you do the T and G ?
Post by: fishfighter on August 09, 2019, 01:01:04 PM
No, it was TG already. Top board was before sending it thru a planner. Burnt up 5 sets of knives. :o  Bottom board after. Boards are 3 1/4" w 3/4" thick.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_2137.JPG?easyrotate_cache=1544126803)
Heat index here has been hitting above 105F. Has me shut down all together. :( That and I still been under the weather is not helping.
Post by: Magicman on August 17, 2019, 08:33:01 AM
I am just catching up with my reading  :P  since taking time off for vacation.  It's good to see your progress in spite of this brutal heat.  smiley_sun
Stay cool my Friend, and I don't mean that in "hippy" terms.   smiley_sweat_drop  This mess will kill you.
Post by: fishfighter on August 17, 2019, 08:39:38 AM
Hope you and Pat had a good trip.
Yep, the heat is way to much. I started building a door for the back bedroom. I can only get a couple hours work done brfore the heat runs me inside. :(
Post by: fishfighter on August 22, 2019, 11:30:20 AM
Got that door finished and varnish.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0391.jpg?easyrotate_cache=1566487629)
Still under the weather and having other health problems. >:(
Post by: Weekend_Sawyer on August 22, 2019, 12:44:02 PM
 I hope you are feeling better.
I love that door!!!
Jon
Post by: fishfighter on August 22, 2019, 02:08:36 PM
Thanks, got one more I need to build. Going to try in hang this one tomorrow.
Post by: samandothers on August 22, 2019, 04:59:36 PM
Heat and humidity in the dog days of summer are rough!  Take it easy and protect your health!
Post by: Darrel on August 22, 2019, 06:43:30 PM
Beautiful door!
Post by: Magicman on August 22, 2019, 09:16:06 PM
This weather is brutal my friend.  Please take it easy.  smiley_sweat_drop smiley_sun
Post by: sawmilllawyer on August 22, 2019, 10:52:45 PM
Amen on the being careful in the heat. Heat stroke comes easy in these temperatures. We got a break today with less than 100 degrees and a rain.
Post by: Weekend_Sawyer on August 23, 2019, 07:51:26 AM
If you haven't, it would make a great thread in the wood working section to document how you build that door. That way I can copy it!
Jon
Post by: fishfighter on August 24, 2019, 04:20:21 PM
Will try.
Finished up hanging the door.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0400.jpg?easyrotate_cache=1566677603)
The heat has been bad and yes, been staying out of it as much as I can. ;D Got some more test to do, but it's all about my pancreas not working which has been keeping me real tired. :(
Post by: WDH on August 24, 2019, 08:46:11 PM
Love the way the panels match the wainscot.   Hope you get to feeling better soon.
Post by: SwampDonkey on August 25, 2019, 05:18:57 AM
Looks good. :)
The door handle hardware reminds me of them in grandma's house.
Post by: fishfighter on August 25, 2019, 08:36:11 AM
Yep, always loved old door hardware. Bought them at Home Depot, around $25 a set.
Post by: sawmilllawyer on August 25, 2019, 10:54:17 PM
Really like that door and the old timey hardware. Thanks, for the tips. Keep on plugging away, it is turning out great.
Post by: fishfighter on August 26, 2019, 09:01:15 AM
Quote from: Weekend_Sawyer on August 23, 2019, 07:51:26 AM
Jon
Spend about an hour yesterday making a post and lost it just before finishing it. >:( There are some pictures I loaded up.
Post by: Magicman on August 26, 2019, 09:13:56 PM
It can very easily happen if you are using Microsoft Edge.  :-X
Post by: Weekend_Sawyer on August 28, 2019, 07:32:46 PM
I looked at the pictures in your gallery.
Very nice.
Do you use a router table?
Post by: fishfighter on August 29, 2019, 09:13:44 AM
Dado blade on a table saw.
Post by: samandothers on August 29, 2019, 09:35:10 AM
I too enjoyed the pictures, thank you.  What was the thickness of your rails, stiles and panels?  1 1/2"  and 3/4"?
I bet those were heavy doors.
Post by: fishfighter on August 29, 2019, 09:46:12 AM
1 1/2", inserts are 5/8" ship lap. Yes, the door is close to 125+ lbs. Had to use heavy duty hinges. ;D
Anyway, still under the weather and just been chilling. :( I did get out a little yesterday and played on the backhoe till it got to hot. ;D
Post by: TimW on August 29, 2019, 07:33:31 PM
I was in your photo gallery and came upon your Ben Franklin Parlor stove.  Before my divorce, we had one for ten years.  It stayed with the house when we sold it.
How do you like your's?
hugs,  Brandi
Post by: fishfighter on September 05, 2019, 01:06:31 PM
Sorry just getting back to you. I love it. Had used it 10-12 times to the point,  in very cold weather, working inside. It warms up the complete area. Puts out a lot of heat. Bought it off Craigslist for I think $150.
Still taking it easy and doing a little painting at the house for the dear wife. That is one thing I could hire out. ;D
Post by: Magicman on September 05, 2019, 08:29:42 PM
Gonna be too hot for the rest of this week and next week to do anything outside.  Stay close to the AC my friend.
Post by: fishfighter on September 06, 2019, 07:35:12 AM
Getting tired laying around besides in and out of doctors appointments and still no answers. >:(
Got some wood planning to do this morning for some trim. I'm about 100% sure the wife will give me a hard time. :D
Post by: Nebraska on September 06, 2019, 11:55:00 AM
Hang in there I've enjoyed watching your thread. Hopefully you'll get answers soon.
Post by: woodybutcher on September 11, 2019, 08:24:02 PM
fishfighter, WHAT AN INSPIRATION!!!!! I found this thread last weekend, and have read nothing on FF since I started.  :P :P :P. You do beautiful work, and are skillfull at many tasks. I love your cabin. Someday I may try to find you. Through trials and tribulations you have perservered. There is nothing wrong with your heart. Now while it sounds like the blood pump in your chest may have issues, you have more heart than alot of people that I know. keep on keeping on. God Bless.
Post by: fishfighter on September 13, 2019, 06:22:50 AM
Why thank you. ;D I started this thread and hope it helps others. When I do feel good, this build has help me. The last month or two, I haven't got much done. :( Really was looking to finish it up before winter, but IDK these days.
I been getting a little seat time on the backhoe expanding my pond. I am using the dirt to build up the yard around the house. The yard area is a good ac or so.
My SIL should be coming over this weekend to help me saw up a couple oak logs. I have a couple dead standing trees to fell. That should cut down drying time, I hope.
Got more test coming next Monday that should have answers.
Post by: woodybutcher on September 13, 2019, 06:08:58 PM
You will be in our prayers on Monday. Wish the best for you, and hope I have as much energy when I retire. I have grandkids to keep me busy. :)
Post by: Magicman on September 14, 2019, 07:49:10 AM
Please keep us updated.  :P
Post by: fishfighter on September 18, 2019, 05:38:54 PM
Here it is Wednesday with little to no answers. Had to go back in today. Nothing but bad news there telling me I have a lot of fat on my liver. I think I open a can of worms and a road I don't want to go down. :( So far they found many problems, but unable to pin point the worse. More test, but I am about to just shut that down all together. Kind of been fighting gut problems about 3 years and I think I will just keep going with what I have.
Overall, I'm good, but very tired. Hoping for some cool weather soon. I have a mission if anything and I will complete it. ;D
Post by: Weekend_Sawyer on September 18, 2019, 07:50:33 PM
Thank you for keeping us updated.
Now you keep fighting, we're all with you.
Jon
Post by: LeeB on September 18, 2019, 08:52:18 PM
I don't know what your diet is but a keto diet can help with a fatty liver.
Post by: TimW on September 18, 2019, 09:31:02 PM
Quote from: fishfighter on September 18, 2019, 05:38:54 PM
I had gut problems for 10 years.  No doctor or medicine fixed it.  When I couldn't see my regular Doctor, I went to another doctor in the same office.  He prescribed medication for when you fail a bowel sample exam.  The same exam that I always passed.  My ills disappeared after that and with cutting back on caffeine, just this last spring.
hugs,  Brandi
Post by: samandothers on September 19, 2019, 12:34:51 PM
Sorry you are having a rough go currently.  Hang in there and keep pushing!
Post by: fishfighter on September 19, 2019, 01:45:34 PM
Quote from: LeeB on September 18, 2019, 08:52:18 PM
Hey, us coonasses eat just about anything. :D
Post by: fishfighter on October 04, 2019, 06:31:09 AM
Still hanging in there. Still have one more test on the 16 of Oct. They do have me on some meds that are helping a little.
On the build, I really haven't did anything due to the heat. Just unreal heat here. Been in the upper 90's. Very dry. I been doing some more digging on the pond and moving dirt all around the house. Wish I had a dump trailer which would save a lot of time. Been getting in around two to three hours work till I shut it down for the day.
We should be getting our first cool front next week. If that happens, I will try to get my water line down in the ground. Got 1200' to trench. I really need the water so I can pressure wash the outside of the house so I can get it painted. I will be spraying that. So that is keeping me from putting up the eves which will be vinyl.
Post by: Magicman on October 04, 2019, 08:32:19 AM
Thanks for the update on yourself as well as the building.  Yup, also been close to 100° here so very little work especially mid-day.
Post by: fishfighter on October 10, 2019, 05:41:15 PM
Dirt work, dirt work and more dirt work. Some pictures of what I been up to being so dry here.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0439.jpg?easyrotate_cache=1570742378)
Did a big draw down on my pond due to a attack of mud cats by the millions that hatched. >:( Water is well over 10' low.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0441.jpg?easyrotate_cache=1570742398)
In the process of making a island.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0443.jpg?easyrotate_cache=1570742420)
That area is 15' deep and goings around to the left. Got many dirt piles spread all around the house.
With a little cooler weather, I had rented a trencher. The ground is so hard and dry, the trencher could not trench. :o First 12"-18" top soil is blue gum buck shot clay. Hard as concrete. The trencher couldn't even clean out what little dirt there was. :o
Anyway, a family member let me used this.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0438.jpg?easyrotate_cache=1570742515)
 ;D
Slow going with it due to having to shave down. Just can't dig. Been working on putting the water line down. ;D Just about at the half way mark to day. Took the time to back fill and grade things today due to high chances of rain. This picture was taken yesterday which is about the 350' mark. Got a good 600' done now and hope to rap this up by the weekend.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0436.jpg?easyrotate_cache=1570742500)
Oh, 1" pex tubing in 500' rolls.
Post by: Nebraska on October 10, 2019, 10:17:25 PM
How deep do you trench down there?  Sure beats our five feet.
Post by: Kainkelly on October 11, 2019, 12:47:30 AM
Quote from: fishfighter on October 04, 2019, 06:31:09 AM
It's hard to work after it gets so hot, the heat can be a vacuum for energy it feels like. Love your build by the way!
Post by: Magicman on October 11, 2019, 07:55:50 AM
It's good to see you making some progress Paul.  At least we are getting a slight break from the miserably hot weather, and also may now get some much needed moisture.
Post by: fishfighter on October 11, 2019, 09:09:10 PM
Quote from: Nebraska on October 10, 2019, 10:17:25 PM
I am going down around 18", but 1 foot is good here.
Lynn, we got a lite shower here. By passed me again. :( Suppose to get down to the mid 50's tomorrow with a high of 70. 8)
Post by: Magicman on October 11, 2019, 09:27:19 PM
The only reason that I try to bury water lines deeper than 6" is to keep them from possibly getting damaged.  If they are below the grass roots they won't freeze.  ;D
Post by: SwampDonkey on October 12, 2019, 05:17:52 AM
The guy doing the excavating at the new house said his line was down 8 feet. He plowed snow off the top all winter and the frost went down that deep and froze his water. I said, the old line here was down 6' and we plow all winter over the top, but it never froze in 50 years. Last spring there was only a thin crust of frost under the snow. I could dig and plant raspberry canes the end of April.
Post by: WDH on October 12, 2019, 07:21:14 AM
A glaciated frozen land.  If I came up there, I would expect to see Wooly Mammoths.
Post by: fishfighter on October 12, 2019, 07:38:49 AM
Snow loads and permafrost are things we only hear on tv. ;D Just ain't happening here. 8)
Had to chill yesterday, but I am like a young buck this morning with this cool weather. ;D A bit more day light and I will get with it.
Post by: sawmilllawyer on October 12, 2019, 01:08:25 PM
Yeah weather was cool here yesterday and this morning, felt great. Knocked down a large dead standing twin stem red oak tree yesterday afternoon. Chainsaws really earned their keep on this one. Didnt hit the house, pool, pool decking or my wife's Japanese maple or crepe myrtle trees, either.  Whole lot easier to do hard work when the temperature cooperates.
Post by: SwampDonkey on October 12, 2019, 02:43:39 PM
In the words of Lord Strathcona, "A man who has been frozen and roasted by turns every year must be the tougher for it, if he survives it at all". :D
Post by: Magicman on October 12, 2019, 05:26:23 PM
In Paul's situation he is either steaming hot, bone dry, or soupy swamp.  When he can fish he has gotta fish with no time to stop and cut bait.  help_me
Post by: fishfighter on October 13, 2019, 12:15:22 PM
Rap up the water line this morning. 8) Just have to hook it up now.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0448.jpg?easyrotate_cache=1570982685)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0450.jpg?easyrotate_cache=1570982699)
Going to need some rain to help pack down the dirt. Then I will grade out everything. That is going to take some time. Then I will order rocks for the drive way.
Came across a power buy on some 5/4 treated deck boards. More then enough to use to deck out the front porch. Will install them this week coming.
Post by: Magicman on October 13, 2019, 10:10:51 PM
Good job.  I think that we have some moisture coming this week.
Post by: fishfighter on October 14, 2019, 11:56:48 AM
Getting some lite rain now. ;D Had to get out early to fix the dirt coming on my driveway. Finished just as the rain started this morning. 100% today, 80% tomorrow. Wednesday early morning I have to go in for that internal ultra sound. :(
Post by: fishfighter on October 17, 2019, 02:45:46 PM
The ultra sound went good. Still having problems, but the meds that I am on is helping.
Monday, I started nailing down boards on the front porch and finished today.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0453.jpg?easyrotate_cache=1571337747)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0454.jpg?easyrotate_cache=1571337764)
Just have to trim the ends on this.
Hoping to get the water hook up coming next week so I can get things pressure washed for painting.
Post by: Magicman on October 17, 2019, 08:53:58 PM
You da man Paul.  8)
Post by: Nebraska on October 19, 2019, 07:51:28 AM
Looks good.
Post by: fishfighter on October 22, 2019, 08:59:11 AM
Haven't been able to do much due to rain. Still waiting on the parish to come hook up a water meter. :(
Post by: Magicman on October 22, 2019, 09:13:02 AM
We should be dry this week but more rain this weekend.  The cooler weather will be nice with a predicted 41° which will be our coolest since Spring.
Hummingbirds are gone.
Post by: fishfighter on October 22, 2019, 04:46:28 PM
49F here for tomorrow morning. ;D
Anyway. went and picked up some piping and fitting for the water line to hook up at the house. Total shell shock at the price. :o Unreal. :o Would of never guess even half the price. >:(
Guess your best price for these ? 4", 12", 20" pipes, two elbows, two valves and two PEX connectors.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0469.jpg?easyrotate_cache=1571776247)
When to put it in and had to stop. DanG Red Ant nest. Guess with the rain, they looking for high ground. >:( Now y'all folks up north that has never had to deal with these mean suckers, y'all missing out. :D Had one fellow from up north and he laugh at them till about 5 all at once went to biting. :D Next day we laugh our butts off at him. He gave them full respect after that. :D
So I put down some bait to kill those suckers off or run them away. Will try again tomorrow.
Post by: Old Greenhorn on October 22, 2019, 05:38:07 PM
My guess is 80 bucks for about 10 bucks worth of parts.
 I never underestimate those red devils. I got mailed years ago and when my Doc took a look at it 5 day later he nearly lost it. Thought I was gonna lose my foot.
Post by: btulloh on October 22, 2019, 05:44:27 PM
Shouldn't be more than thirty bucks , but I'm guessing more based on your post.
Fire ants are nasty. Worse than yellow jackets, but at least they can't fly.
Post by: SwampDonkey on October 22, 2019, 06:50:35 PM
Humming right along old timer. 8)
Post by: fishfighter on October 22, 2019, 08:45:48 PM
$81 and change. Didn't feel a thing walking out the door. :(
Post by: fishfighter on October 23, 2019, 02:16:17 PM
Ants gone, was able to get that line hooked up. The dirt under the house was so dry, I had to use a welding chipping hammer. ;D
The white tube is a PVC 4" pipe that goes over the cut off valve.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0471.jpg?easyrotate_cache=1571854172)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0472.jpg?easyrotate_cache=1571854207)
All is back filled now. Now only went they will come hook me up. :(
Post by: btulloh on October 25, 2019, 08:49:06 AM
Happened to be at HD yesterday and checked out the galv pipe.  Pricey.  Seems like it's gone up a lot. ??  I can see how that $35 bunch of stuff cost you $81.  What's going on with these prices?
Post by: fishfighter on October 25, 2019, 09:02:27 AM
Don't know. Was just in shock. :o Still no meter. >:( Raining cats and dogs here, so another rest day which I can use. ;D
Post by: Magicman on October 25, 2019, 09:08:31 AM
Some of those "cats & dogs" are making it up my way too.  A total washout for today and tomorrow AM.
Post by: doc henderson on October 25, 2019, 09:59:18 AM
I priced wire mats for concrete and they are higher.  I am told it is trade stuff/tarrifs.  have to deal with it.  at least we are taking on china and not kicking the "can" further down the road... I guess aluminum is higher too.   :D :D :D
Post by: fishfighter on October 29, 2019, 09:20:42 AM
This post will be labeled " The good, the bad and the ugly."
First, the good. ;D I now have water. Heck, I had even fired up the water heater and have HOT water. 8)
The bad, first world problems. :( People showed up to install the meter. Got to talking to them. Found out that I would be charged a base fee for water per month which I had no problem with which was $10. BUT, they also said I would be charged another $18 a month for garbage pick up fee per month. That was even I told them that the house is not finished. :( And on top of that, the house would fall under yearly taxes. >:(
So, I told them do not hook up the meter. In turn, I had hooked up to my main line to my house at this time. ;D
Now the ugly. >:( I had a leak. >:(
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0476.jpg?easyrotate_cache=1572306566)
Dead center. :o When I installed the water system, I had pressure tested it and all was good. That nail is from when I installed the bathroom vanity.
Now another good. ;D For some reason in the back of my mine I kept telling myself do not finish out the closet in the front bedroom. Well, this is twice of saving me not finishing it out. ;D
Anyway, was a easy fix.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0477.jpg?easyrotate_cache=1572306596)
Got rain coming for the next few days. Yep, the rainy season is here.
Post by: Magicman on October 29, 2019, 09:50:21 AM
I have everything on the same meters at the Cabin because of the same reasons that you had.  Same electric meter and same water meter.  It cost more to do it but cheaper in the long run.
Post by: fishfighter on November 04, 2019, 07:06:18 AM
Lynn, we are thinking of moving into the little house and then remodel or our house. After that we might rent the big house out. Just don't know yet due to the fact of were to put everything. Saturday marked 40 years of being married. :D
Yesterday the weather was nice. So I got out there and pressure washed the house. That sucker had come cob webs. ;D Going to hit it a second time just for the heck of it today.
Will wait a few days to dry out and go back for a second corking, then painting time. 8) Now that will depend on the weather here. Good thing about living in the south, one can see all 4 seasons in one week at this time of the year here. :D
Oh, still don't know what color I'm going to paint it.
Post by: Magicman on November 04, 2019, 10:16:44 AM
Yup, work between nasty's but at least we ain't glaciated.  :D
Back to the water meter, it was the additional garbage pickup and sewer charges that forced me to put everything on one meter.  :-X
Post by: texansfan on November 08, 2019, 09:46:13 AM
Whatever happened to this project?
Post by: fishfighter on November 08, 2019, 10:18:52 AM
Still working on it. Been recorking the complete outside and hoping to get that painted soon.
Overall, things are moving real slow. Still having some health problems that is kicking my butt. >:( Got my weekly blood work to do and the doctors appointment for the ticker. For some reason, fluid has been a big problem the last few weeks. Got to the point that I can't lay down no longer then about 4 hours. Not much can be done about that other then what I am doing now. :(
Yesterday, I took the time to hook up the crapper and gave it my blessing. ;D
Got some real cold weather coming next Tuesday and Wednesday. Going to find out how good PEX is first hand.
Post by: Ljohnsaw on November 08, 2019, 11:16:33 AM
Quote from: fishfighter on November 08, 2019, 10:18:52 AMGot some real cold weather coming next Tuesday and Wednesday.
What, 50°? ;)  Been gettin' down to 40° overnight here with 80° during the day.
Post by: fishfighter on November 08, 2019, 12:49:46 PM
Talking in the 20's for a couple days. Poor suckers up north will be in the teens and lower. :o Big artic front pushing all the way to the Gulf Of Mexico. :o There is a chance of sleet too!
Post by: fishfighter on November 15, 2019, 10:20:13 AM
Did have a 12+ hour freeze here. Have to say that the PEX held good even though none of the lines under the house are insulated at this time. ;D I did run the heater thru the night inside. Had it set at 50F.
Post by: fishfighter on November 19, 2019, 08:07:24 PM
Got to super nice days coming tomorrow. Got paint and looking to start spraying. Got to start early due to the million+ lady bugs that swarm once the temp get above 60F. Dam things are coming out the sugarcane fields by the billions. >:(
Title: Re: Started the build.
Post by: Sedgehammer on November 20, 2019, 08:22:59 AM
Quote from: fishfighter on April 11, 2016, 10:03:41 AM
Had one heck of a set back this weekend. >:( Was under the camp with my son doing a little plumbing work and before I knew it, I passed out. :o Not once, but twice. Scared my son big time along with me. He help me out and before getting to the house, I passed out again. The wife rush me to the ER.
Come to find out that I came down with a bad case of vertigo. Still kicking my butt this morning. >:( Never had this before and taking meds for it, but still having my house spinning out of control. >:(
Anybody ever deal with this?
On a side note. Thank God it didn't hit me a 1/2 hour before when I was up on the roof. ;D
Been reading the thread here since early this mornin and came across this.... First of all have to hand it to ya for persevering. If one has a dream, then it helps thru all the health crap one has to deal with. Now to your virtigo... I know exactly what you are dealing with. Almost 4 years ago I was climbing up into  cab over semi. As I was grabbing the steering wheel with my left hand to pull myself up and in I pulled a tendon in my left arm by my elbow. The sharp pain caused me to release the steering wheel, which caused me to fall backwards and out onto the blacktop below. Bounced my lower left back and my head off of the pavement. To this day i have severe back pain. Taking 3 different pain meds for it. My head is still messed up. Can't drive. Bright lights or shiny things make me unbalanced. It's even hard to watch tv at times. If it's a fast moving scene have to look away. If I turn my head too fast, even causes it. I used to make breakfast for the family on weekends, that's even a hard pull now. the bending and turning will cause the same thing. A couple of weeks ago me and a guy i hire to help me with stuff was installing the 2" pvc pipe from the well head to the pond and we had to bend the pipe slightly. So was heating it with a propane torch. It was getting towards evening and one could see the blue flame. With me moving it around to heat the pipe, that movement passed me out. Fun, fun, fun. Oh, to add to the fun I had a heart attack a year ago..... Anyways, didn't mean to derail the thread, but reading what you are dealing with thought I'd add my 2 cents. Keep up the good work!!
Post by: doc henderson on November 20, 2019, 08:42:00 AM
pure vertigo and especially with head movement, can be the inner ear, the semi circular canals.  they are in three planes, and have tiny nerve cells like tiny hairs lining a tube filled with fluid.  when you rotate, the inertia of the fluid, makes a force on the nerve cells.  your brain uses this to tell if you are rotating in space, like a gyro.  as we get older we can develop crystals in the fluid.  If they get stirred up (from lets say crawling under a house), it is like a boulder ramming into the fine hair cells that normally send a message to the brain, from just the fluid.  so the nerve (sensor) give a signal off the chart, and your brain perceives it as rotation.  there is a maneuver and ENT can do, to get the crystal out of the canal.  the other concern, is that it can be a tiny stroke. so follow up with your Dr.  This is where the phrase, "it is hell getting older" came from.  not sure who came up with the golden years.  must of been a youngen!   :) smiley_old_guy
Post by: Sedgehammer on November 20, 2019, 11:44:52 AM
Been through all that and it's not the issue. I've had more tests than I can count. 6 MRI's i think. No stroke. They have a term for it. Vestibular something (forgot the full term). They said my impact damaged something that can't be fixed.
Post by: fishfighter on November 20, 2019, 03:17:12 PM
Got some paint sprayed before the bugs came out. 8)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0501.jpg?easyrotate_cache=1574280445)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0505.jpg?easyrotate_cache=1574280423)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0504.jpg?easyrotate_cache=1574280477)
Still have two more sides that I will get done tomorrow morning. Then some trim work painting. But, I have to say, spraying is the only way to go. ;D Takes more time to cover what you don't want sprayed then to spray. ;D
Post by: fishfighter on November 21, 2019, 07:01:30 PM
Rapped up the painting today. Will try to get the trim done next week. Rain coming tomorrow. :(
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0506.jpg?easyrotate_cache=1574380136)
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0509.jpg?easyrotate_cache=1574380172)
Post by: Magicman on November 24, 2019, 08:18:09 PM
I am glad that you were able to get-r-done between "weathers".  Lookin' good my Friend.  8)
Post by: fishfighter on November 25, 2019, 08:59:29 AM
Thanks Lynn. Hope all is well with you and Miss Pat.
Post by: Magicman on December 02, 2019, 08:16:28 PM
As well as I can be recovering from this total knee replacement.  Pat is a good caregiver.   smiley_love
Post by: fishfighter on December 03, 2019, 09:10:24 AM
Good to hear that. Got a buddy that just went thru a second replacement.
Myself, I been under the DanG weather again. Been having trouble with fluid build up for no reason. >:( That 10 lbs I put on is a lot for me which is all fluid. Doubling Lasix hasn't helped much. :o
Post by: EOTE on December 08, 2019, 10:40:39 PM
Hey y'all,
I've been mainly posting in the "Whatcha sawing" thread but have been lately searching for a thread where I can share my coming experiences in building my future retirement home.
The back story is that I retired a couple of years ago (typical forced corporate retirement) so my wife and I bought a 30 acre piece of  wooded earth out in east Texas with the intent of building our retirement home and enjoy life there.  Only about a quarter of an acre was actually clear so we built a steel barn as our center of operations and mapped out where we wanted to build our future home.  We saw that we needed to clear a lot of trees including a fire break around the home site and barn.
Long story short, my wife and I cleared about 2 to 3 acres of land and ended up with a BIG pile of logs.  After checking what I could get for the logs, my wife and I came up with the bright idea to buy a sawmill and cut all of the lumber for our new home, starting with those logs!  We figured we could cut up that stack of logs and harvest some of the bigger trees from the rest of the land.
So as we plunged headlong into this adventure, we learned that there were lots of other things we needed to think about like drying, stacking, and storing the lumber we cut.  We needed a place for the sawmill and we needed a way to process all of the lumber once we cut it.
So here we are over a year later, having cut down about a hundred trees and turned them into over 50K board feet of lumber, plus a drying house, storage house, and sawmill house, all of which we built by hand ourselves.  I am now preparing to do the actual site prep for the house (it's not post and beam, it is stick frame construction, traditional gambrel roof farm house) and am hoping to find a thread like this one where people are showing the progress on their builds, their lessons learned, and challenges faced.
So, after this long winded post, is this thread a good home for this or would you recommend a different one?  I don't want to start a new thread if it would be redundant.  Your feedback would be appreciated.
Post by: btulloh on December 09, 2019, 07:34:45 AM
Sounds like you've got an interesting build and process going on there @EOTE (http://forestryforum.com/board/index.php?action=profile;u=44084) .  I think it deserves its own thread so we can follow along over the course of time.  It will be interesting to see how you proceed with the sawing and building.
This thread is specifically about @fishfighter (http://forestryforum.com/board/index.php?action=profile;u=28788) building his fishing camp which he's been working on for some time and getting close to the finish line.  He's provided a very interesting and detailed account of the whole journey and we've all enjoyed it.  I expect yours will be interesting too, and it deserves it's own thread.  Sounds like we need some pictures of what you've been doing already!  Good luck with your sawing and your build.  I'm looking forward to watching your progress.
Post by: doc henderson on December 09, 2019, 08:14:18 AM
@EOTE (http://forestryforum.com/board/index.php?action=profile;u=44084) we will look forward to seeing you plans and problems you encounter as you move along.  there are some great builders here too so you can get opinions on how to proceed if you encounter a fork in the road.  I agree, come up with you own title and "let er rip" so we can follow along.
Post by: Magicman on December 09, 2019, 09:48:16 AM
I absolutely would start a new topic detailing your building adventure.  My project did not qualify as "timber frame" either so I put it in the Woodworking Board.  Cabin Addition in General Woodworking (http://forestryforum.com/board/index.php?topic=47709.0)  Maybe it would have been better suited in the General Board, but anyway it went where it went and had many followers.  (I too am a product of "forced retirement" but I was too young (51) to actually get a retirement :-X )
It will be interesting to follow your progress.
Post by: EOTE on December 10, 2019, 08:43:53 PM
Hey y'all,
I took your advice and started a new thread
Building our Dream Home a.k.a. Delusions of Retirement (http://forestryforum.com/board/index.php?topic=108689.msg1697417#msg1697417)
I hope you will stop by for a while and enjoy the posts.
Post by: fishfighter on December 11, 2019, 06:58:57 AM
Still been under the weather. Haven't been able to get out. :( But I have been doing a few things around the house for the wife that I had been putting off. ;D
Post by: Magicman on December 11, 2019, 08:47:33 AM
Thanks for keeping us updated on your "kicker" Paul.  One thing about us older codgers, we might be lame and crazy, but we ain't lazy.  :D
Have a good day my Friend.  :)
Post by: fishfighter on January 20, 2020, 08:55:05 AM
Good morning all. Sorry for not posting. Hope all are well. Haven't done any work on this build. Been doing honey do's in our house.
Had took out the back door and installed a set of double doors. Big project due to having to move a window and then some. Done
Second project was to add a new pantry closet in the kitchen. Done
Third project is redoing the master bathroom. This is a very big project. We had a Jacuzzi tub. Got to the point that it was to hard for the wife to keep up along with getting in and out of. Myself, I couldn't use the pump. It almost drown me setting off my CRT-D. :o
Anyway, I been wanting a soaking tub a long time. Well I have one now. Sucker is 68" long and being 6' tall, it fits great. ;D
Had took out a short wall, moved some light switches, Moved recess ceiling lights and swapped over to LED's, did some floor work, built a new vanity cabinet, retexture the room. Been throwing paint by the gallons and I am still doing that. Hope to rap this up in the next few days and then on to the kitchen for a complete remodel there.
Post by: Darrel on January 20, 2020, 09:35:33 AM
Glad to hear that you're still up and at it. I was wondering how things were going.
Post by: samandothers on January 20, 2020, 11:55:06 AM
Busy guy!  Big Tub! Lots of weight!
Post by: Nebraska on January 20, 2020, 03:42:35 PM
You've been really busy. Good t hear from you.
Post by: BigZ La on January 20, 2020, 09:04:44 PM
I was starting to worry about you, good to hear you were just busy. Keep going.
Post by: fishfighter on January 21, 2020, 08:18:16 AM
Quote from: samandothers on January 20, 2020, 11:55:06 AM
Weight is a problem for me. I can't put any on. Only weigh in at 165.
This is the tub I had installed. Nice to fill that sucker up with hot water and have a cold drink soaking in it. ;D
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0604.jpg?easyrotate_cache=1579612321)
It's all trimmed out and window shad is in place. I couldn't find white tiles to match, so I installed brick pavers.
Post by: samandothers on January 21, 2020, 08:39:15 AM
Yep done that a time or two!
Post by: Magicman on January 21, 2020, 09:37:58 PM
It was good to finally see your post and read about your activity.
Pat and I were talking about you yesterday.  I reminded her that I could give you a call if you did not come up for air soon.  Almost a month is too long to be MIA.  no_no
Post by: fishfighter on January 22, 2020, 08:57:03 AM
I know Lynn. Will not go MIA in the future. How are coming along with the knee?
Post by: Magicman on January 22, 2020, 09:11:29 AM
The Dr. said I had no restriction nor limitations so I tried it out.
Still a bit of swelling, but I sawed two days with much walking, climbing, twisting, and whatever else goes with it.  No pain but I will keep some ice on it a couple of times today.
I have an appointment with the shoulder Dr. tomorrow.  I am wearing a shoulder brace which helps.
Post by: fishfighter on February 07, 2020, 04:00:18 PM
Got a chance to go tree shopping today. Felled two nice water oaks. I am in need big time of some 1x6's to finish up the trimming. Just been doing things around the house that I had put off way to long.
This is the first one. Have a twin too! 161/2" at butt, the other end is 14 1/2" and the log is 24' long.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0626.jpg?easyrotate_cache=1581108661)
Post by: Magicman on February 09, 2020, 08:13:38 PM
It's good to see you stirring about.
Looks like we will have rain all of this week, so no sawing for me.  Hopefully I can satisfy a couple of customers before Dr. Shoulder Sawbones on the 21st.
Post by: fishfighter on February 10, 2020, 09:59:12 AM
Got one of the two sawed up, stacked and stickered. That was the first time in almost 6 months from the last time I ran my mill. :( I did enjoy sawing again. ;D
Yep, raining here too! :(
Post by: EOTE on February 10, 2020, 02:14:05 PM
Quote from: Magicman on February 09, 2020, 08:13:38 PM
We have rain all week too.  However, in my case it means processing boards into shiplap as it is indoor "sawing".
Post by: fishfighter on March 16, 2020, 06:15:07 PM
Still doing projects at the big house. Just finished up the master bedroom. I going to take a break from building anything. Having a few health problems that has pop up. Nothing bad, but just pushed myself way to hard. ;D
Hope and pray all stay safe from the bug going around. :o
Post by: Magicman on March 16, 2020, 06:43:39 PM
You stay buttoned up tight Paul.  With your health situation, this is one thing that you do not need, but it is always good to hear from you.  ;)
Post by: fishfighter on March 16, 2020, 08:34:08 PM
Well, that goes for all older folks. :o
Came down with a bad case of arthritis in both of my hands. :'( Very painful.
Post by: fishfighter on March 27, 2020, 07:57:03 AM
Morning all. Hope all are healthy. Been doing ok here.
With the dry and warm weather, I started breaking down dirt piles that I had moved last summer/fall around the guest house. Was nice and fun playing in the sand box. :D
Please stay safe.
Post by: Magicman on March 27, 2020, 01:44:43 PM
Good to hear from you Paul, but nothing exciting happening here, nothing unexciting either, just nothing.  Maybe I will find out what my future is from my shoulder Dr. Monday when/if it happens.  Hopefully I can confirm some sawing appointments.
Post by: fishfighter on April 10, 2020, 08:11:44 AM
Good morning all. Just stop in to say we are fine here. No work on the build other then dirt work.
I hope all are taken care of their selves.
Post by: bwstout on April 10, 2020, 09:19:36 AM
I was thinking about you wondering  how you were doing knowing your health issues just glad you are doing good. I have really enjoy fowling   your build.
Post by: Magicman on April 10, 2020, 05:10:40 PM
Thank you Paul for checking in.  Nothing happening here except avoiding crowds, but still sawing.  Only one big ole Pecan log tomorrow, but several biguns (Oak) next week.
Post by: fishfighter on April 11, 2020, 09:10:32 AM
Good to hear you keeping busy . Going to try and do some resawing today if the rain holds out. Keep a eye out for that bad weather coming tomorrow.
Post by: Armymann50 on April 25, 2020, 07:37:19 PM
Need more pictures.
Post by: fishfighter on April 25, 2020, 08:21:30 PM
Been remolding things in the big house. Got one more room to paint and replace the flooring and one room to just replace that flooring which was redone about two years ago. The boss wants her floors all the same. :D
Post by: fishfighter on June 04, 2020, 10:40:44 AM
Just checking in. Haven't been able to do anything the pass month. Bad back problems. :-\
Hope all are doing good.
Post by: Weekend_Sawyer on June 04, 2020, 11:55:37 AM
Glad you checked in, I was wondering how it was going.
Sorry to hear about your back.
Ive been having a sore back for the last couple of weeks also.
I never have a sore back but then I'm working a lot too.
Jon
Post by: samandothers on June 04, 2020, 01:21:00 PM
Dang backs!  Hang in there and recover!
Post by: fishfighter on June 04, 2020, 01:25:42 PM
Had problems with it in the pass. This time around, things got worst. It's to the point that it has caused Drop Foot. Having and bad time just to walk now. Lost all strength in both of my arms which started a good 6 months ago. Had a shot put in, but no help there with the pain. Will see a neurologist next Tuesday. Bigger problem is my family history. Have 4 first cousins, three that passed that had ALS. I will be tested for it.
Post by: Magicman on June 04, 2020, 09:59:36 PM
I am very sorry to read about your woes Paul.  Hopefully the test will reveal something that is treatable.  My Prayers are with you my friend.
Post by: thecfarm on June 05, 2020, 09:35:23 AM
I hope you will get better.
Post by: Bruno of NH on June 09, 2020, 06:56:16 AM
Hope everything gets better for you.
Post by: fishfighter on June 09, 2020, 08:31:15 AM
Will be seeing a neurologist this afternoon. Got a Mono CT for Friday. Some other test too! It's killing me just sitting around. To dang hard to even get out for a walk.
So, thanks guys. ;D
Post by: Magicman on June 09, 2020, 02:26:50 PM
Thanks for the update and please continue to keep us updated.
Post by: fishfighter on June 09, 2020, 07:25:52 PM
Hey Lynn. Not good news at all. And I though heart failure was bad. :'( All nerves are working fine, but muscles, well they are breaking down big time.D Doctor order some blood work and he just flat out and said I need to go to Houston Tx to get check for ALS. Talked to my cousin that has ALS, he and his wife will make a call out there to try to rush things to get me in. Was told it can take as much as 3 months to get in for a appointment.
At this point, Took a chill pill and drinking a couple cold ones. Day started bad with the ac starter relay going out which I fixed by the hardest and when down from there.
Tomorrow will bring on a new day, I hope and pray.
Post by: Magicman on June 09, 2020, 07:55:36 PM
I read your reply to PatD and our Prayers will be for and with you.
Post by: Walnut Beast on June 09, 2020, 09:49:15 PM
My prayers are with you also. Hang in there!
Post by: thecfarm on June 10, 2020, 05:50:10 AM
I am hoping for you too!!
Post by: bwstout on June 10, 2020, 07:20:01 AM
Our prayers are with you have so much enjoyed you build
Post by: fishfighter on June 10, 2020, 11:28:08 AM
Hey thanks all. As far as the build will go, I will try to pass it on to My daughter and SIL. That or even give the house away to someone that needs it and can finish it. I do have a couple in mine for that. It could be move to their place very easy.
Post by: doc henderson on June 10, 2020, 11:31:37 AM
I hope it does not come to that, and that you get reassuring news.
Post by: Nebraska on June 10, 2020, 09:48:44 PM
Praying for you, hoping for the best. I have enjoyed reading your journey and admired your grit and your courage.
Post by: fishfighter on June 12, 2020, 07:51:00 AM
Yesterday evening, I had my daughter and SIL over. Took the golf cart to the back. They said they will finish out the house. I will have to show SIL how to run the sawmill again. Had did that before a few times. Only need some more oak boards for trimming out base boards. I did cut some in the fall, but I am sure what I have is not enough. :( SIL is a very good carpenter which he does for a living.
Another thing I did was I turn on the AC. Haven't ran it since last fall. I will shut that down in a day or two.
Post by: samandothers on June 12, 2020, 08:13:35 AM
Prayers for strength physically and mentally as you move forward.
Post by: fishfighter on June 12, 2020, 09:09:30 AM
Hey thanks. Fixing to go do that nuke CT. They going to inject the dye in my spine. Can't do a MRI.
Post by: fishfighter on June 21, 2020, 11:18:10 AM
Happy Fathers Day.
Yesterday, I had my daughter and SIL over. So SIL help me or should I say did the work of planning out some boards for the last closet door .
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0834.jpg?easyrotate_cache=1592752221)
Was nice to try and get something done, but paying for it today.
Health wise, not so good. I have a appointment in Houston on July 6. Will be there for 3 days testing. At this point, my spine and my neurologist think I have ALS. The reason going to Houston. Was told it could of taken up to 3 months to get a appointment, but at this time, I lost a lot of muscle mass. All info was sent and guess as to why I got a fast appointment.
Other then that. I am trying to keep it together. ;D
Post by: Magicman on June 22, 2020, 08:20:18 AM
Keep on keeping on Paul and keep us informed as you can.  Also if you need/want to give me a call you know that you are welcome.
Post by: Weekend_Sawyer on June 22, 2020, 01:00:44 PM
I'm pulling for you buddy.
Jon
Post by: sawmilllawyer on June 22, 2020, 11:17:25 PM
Pulling for for you over here in Oklahoma. Keep moving and don't let them get you down!!! Your attittude is what mattes most at thid time. keep plugging snd do not stop.
Post by: fishfighter on June 28, 2020, 10:13:22 AM
Hey thanks all. Yesterday, SIL and I finished building that last door. Still needs a lite sand and then varnished. I am going to try and get that done today if I can get it up on some sawhorses.
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0837.jpg?easyrotate_cache=1593353535)
It's under my carport rapped in plastic right now.
Post by: samandothers on June 28, 2020, 10:24:48 AM
Good job by you and the SIL on the door!  Looks heavy.
Post by: fishfighter on July 01, 2020, 07:09:59 AM
The door is a easy 125lbs. :o The wife and I got it up on saw horses and I was able to sand and then sprat varnish it. All done now. This is a closet door that will be installed on a track system. Door is 34"x82".
(https://forestryforum.com/gallery/albums/userpics/38788/IMG_0839~0.jpg?easyrotate_cache=1593601766)
Post by: Magicman on July 01, 2020, 08:01:38 AM
The door is beautiful and thanks for the update Paul.  8)
Post by: sawmilllawyer on July 01, 2020, 08:42:22 PM
Nice work on that door. Looks Great.
Post by: samandothers on July 02, 2020, 12:27:42 AM
Gorgeous door.  You are doing good!
Post by: fishfighter on July 02, 2020, 09:48:13 AM
Well, my SIL is doing good. He is a master carpenter. Been doing it around 20 years. Said he loves to do finishing work. He will be over tomorrow to work on the house.
Post by: caveman on July 04, 2020, 06:38:26 PM
Paul, that door looks like new money.  I am glad you are still able to build.  You have a talent that very few of us have.
Post by: fishfighter on July 06, 2020, 10:14:31 PM
Good Lord, I hope not. SIL has a great eye. Takes someone that has the love of wood. ;D Heck, he can even build a pirogue. He stepped in helping me show over 20 people how to do it building two for him and my daughter.
Anyway, here in Houston. Got here Sunday. Today was a long day with many test along with many doctors and other people.
Nothing but bad news which I already knew what is what. Tomorrow, have a couple more test that insurance doesn't pay for. A test that will marker my DNA and if anyone else comes down with this crap, it might help them. I am the 5th person in my family that now has or had this crap. Had 3 first cousins that died and a 4th that is close to dying.
They have plans for two more days testing, but after tomorrow, I will tell them that is it. Ready to get back home.
Post by: Magicman on July 07, 2020, 01:13:57 PM
Certainly not the news that we were hoping for Paul, but you had already indicated that you knew what you had.  Please keep me/us updated and you know that I am fairly close and can be at your place in a couple of hours if you need me.
Post by: fishfighter on July 07, 2020, 10:50:32 PM
Thanks Lynn. We are now back home. Very tiring trip. Will take it easy for a couple days.
Post by: fishfighter on August 05, 2020, 09:26:50 AM
Good morning all. Just to let y'all know, I'm still kicking. This ALS is moving fast. I am at the point of using a walker 100% of the time.
On a side note, got a chance to go down to Orange Beach Al for a couple days with the wife, daughter, SIL and grandson. Had even got in the water which was nice. But, I had to climb the beach like a sea turtle till out the water and then have my daughter and SIL lift me. Over all, was a very nice trip. ;D
As far as any treatments, there is none.
Being a Vet, the VA is stepping in to help and pay for any mods I need done at the house.
Post by: Weekend_Sawyer on August 05, 2020, 12:35:09 PM
Thanks for being open and keeping us informed.
I am pulling for you.
Jon
Post by: samandothers on August 05, 2020, 02:11:48 PM
Glad you got a family beach trip in this summer!  We have ours in about 6 weeks if a hurricane does not blow in.  Also glad the VA is stepping up.
Post by: Magicman on August 05, 2020, 07:52:19 PM
Thank You for the update Paul.  I have been keeping up with you a bit by watching when you log onto the FF.
You know that I am fairly close if you need me.
Post by: fishfighter on August 26, 2020, 07:16:54 AM
Update on my health. Things are getting rough for me to get around. It's moving very fast now. Was suppose to go to Houston tomorrow for a appointment, but with the weather, had to cancel.
I am at the point now that even with a walker, I am having a very hard time getting around the house. I was told to eat any and everything that I was told not to eat the last 30 years. :D Problem there, I am still loosing weight. A lot of muscle mass. :o From the start of July, I was at 165. Yesterday, was at 149. Started having a hard to time breath.
Pain wise, still dealing with that in my back. It's very hard to stand up due to the pain. I still get outside, but that is a act of congress to do so.
Over all, I am still hanging in there. 8)
Post by: bwstout on August 26, 2020, 08:12:35 AM
praying for you, so much enjoyed your build.
Post by: WDH on August 26, 2020, 08:00:51 PM
You are amazing, Sir.
Post by: doc henderson on August 26, 2020, 10:25:10 PM
GOD bless!
Post by: Sedgehammer on August 27, 2020, 03:40:22 PM
Ahh [I have typed a profane word that is automatically changed by the forum censored words program I should know better]. I had been reading your thread at times and knew you were sick, but had no idea it was this crap. I must say that this made me tear up. i don't know ya, but I don't care, I'm saying a prayer for ya and for your family anyhows. Hope you're right with our maker. Sounds like your family has a stable SIL to lean on. Prayers from here to there.
Post by: caveman on August 27, 2020, 04:02:49 PM
Fishfighter, you have been and continue to be an inspiration to many of us FF members.
Post by: Magicman on August 27, 2020, 06:46:04 PM
Paul, Thank you for the update.  I have been carefully following your health condition and my prayers continue to be with you during your struggles with this dreadful disease.
Post by: samandothers on August 28, 2020, 12:30:56 AM
Sad to hear the affect of the illness.  You are in my prayers.
Post by: Walnut Beast on August 28, 2020, 01:05:01 AM
Your in my prayers. You have a great attitude due to the circumstances. Hang in there 👍
Post by: fishfighter on August 28, 2020, 12:01:44 PM
Thanks folks. I been bless cause the Good Lord has gave me a extra 10 years. The lord gave me the strength to start the build of the little house which had help my health. 8) It's just rough that I am unable to finsh out the house.
My days now are from bed to lounge chair. Not much else I can do.
Post by: Darrel on August 28, 2020, 01:50:22 PM
You and yours continue to be in my prayers.
Post by: sawmilllawyer on August 29, 2020, 01:09:06 PM
Your persistence and determination are amazing I truelly enjoyed the little house build. Great work. Prayers sent concerning your illiness. your courage and conviction is a testament to all of us. Take care, good Sir.
Post by: Weekend_Sawyer on September 02, 2020, 12:37:30 PM
Hang in there, I'm glad to see you on the forum.
Jon
Post by: fishfighter on September 06, 2020, 10:11:18 AM
Still hanging here. Got a appointment in Houston on the 17. It's time for a wheelchair now. Dang right leg is starting to give out along with my left arm now.
On a side note, been able to gain a couple lbs back. Now back up to 150 lbs which is good somewhat, but fat, not muscles. Guess that is better then loosing weight. ;D
Post by: Magicman on September 06, 2020, 10:32:24 AM
Thanks for the update Paul, and keep us posted my Friend.
Post by: Bruno of NH on September 10, 2020, 08:13:47 PM
Paul,
You are an amazing man a inspiration to all.
Thinking of you and your family.
Many have enjoyed following you work on the house build.
Bruno
Post by: fishfighter on September 21, 2020, 10:43:10 AM
Just a update. Trip to Houston was rough. No good news there. Now have a power wheelchair ordered and breathing thingys too. I have gain some more weight back which is good.
Sad thing I saw on this trip was what Laura did to southwest Louisiana. :'( Those people took a big beating. Ground zero was around Lake Charles. about 25 miles east and 15 miles west was just wiped out. Not many trees are still standing. That same path runs a good 100 miles to the north of the coast of Louisiana. Bad thing, the news is just not reporting on what has and is happening. These folks still need help.
Post by: jasonb on September 21, 2020, 04:24:40 PM
fishfighter
I saw your build first on Tigerdroppings and then again on this forum and was pretty bummed to learn of your medical problems.  God Bless you in your fight and may all your days be happy.
Quote from: fishfighter on September 21, 2020, 10:43:10 AM
I have gone twice to cook jambalaya, hamburgers and hotdogs for the people in south Lake Charles and Sulphur.  I didn't get to see much but what I did see was really torn up.  They have a long way to go before they have any type of normal life.  I got caught up in the 2016 flood and I would rather have that situation than what SWLA is going through.
Post by: fishfighter on September 21, 2020, 07:06:16 PM
Why thanks. Just wish I could go help these people. I had many family members that were displaced from Katrina which changed their lives all together.
Welcome to FF. There is a ton of info here. Many boards to look into. ;D
Post by: realzed on September 22, 2020, 07:11:11 PM
Certainly says tons about your character - that in spite of your own personal problems, you take the time to recognize others having issues and hardships and wish there was a way you could help them out..
Congratulations for just being one fine human being - and I say that in all sincerity!
Post by: fishfighter on September 26, 2020, 10:30:09 AM
Why thank you Sir.
Made another trip to the doctors office. Been dealing with a lot of pain in my back. It's nerve damage. Started a new pain med for that. It's helping. ;D Did get a temp power scooter. I will get out and ride up and down the road today. My street is a dead end with little traffic on it. Will pack a small ice chest with some beers and enjoy the day. :D Weather is nice and with some very cool weather coming next week. 8)
Post by: Magicman on September 26, 2020, 10:52:29 AM
It's good to hear that you are able to get out and about with your new "wheels".  I too plan to enjoy this cooler weather.
Post by: LeeB on September 26, 2020, 08:48:51 PM
Quote from: fishfighter on September 26, 2020, 10:30:09 AMI will get out and ride up and down the road today. My street is a dead end with little traffic on it. Will pack a small ice chest with some beers and enjoy the day.  Weather is nice and with some very cool weather coming next week.
Enjoy yourself. You deserve it. Your positive outlook is a huge inspiration. You are a hero.
Post by: samandothers on September 26, 2020, 10:35:14 PM
Hope you had a great outing and plans for others in the near future! Go 'hog' wild!
Post by: fishfighter on October 11, 2020, 08:09:21 AM
Morning all. Hope everyone is in good health and sawing away.
Myself, still hanging with the help of my dear wife. Can't walk at all now even with a walker. Been using a loaner power scooter to get around. Still waiting on the one I ordered. >:( Also still waiting for contracts to redo my house. >:( That has been more to do with all these storms we been getting.
Still having a lot of trouble breathing. Saw a doctor for that last Thursday. Had to be the best ever doctor I ever been to. He knew my complete health history without looking at a computer. Anyway, he has a group of people that will be here tomorrow with equipment to help me out. Would of been here Friday, but the storm stopped that.
Delta did some damage around the house, but not to bad. Just a big mess and a couple small trees down. We did loose power, but that is back on.
Post by: Magicman on October 11, 2020, 08:20:26 AM
It's good to hear an update from you Paul, and at least you did not blow nor wash away.
I wish you the best during your journey with this ALS.
Post by: Bruno of NH on October 11, 2020, 02:34:31 PM
Post by: samandothers on October 11, 2020, 09:04:37 PM
Thanks for update.  Glad storm did not deal you more trouble.  Hope the folks and their equipment can aid you tomorrow.
Post by: thecfarm on October 12, 2020, 07:25:15 AM
Drinking and driving!!! Make sure no one calls the cops on ya.  :D
Sorry to hear of your troubles.  :(   You are in my thoughts.
Post by: sawmilllawyer on October 14, 2020, 07:38:05 PM
Always good to see or hear from you on here! Sorry about the ALS news.
Post by: fishfighter on October 15, 2020, 12:41:08 PM
Had tried the ventilator. Nope, nope and more nope. It freaked me out all together. Doctor did send in some chill pills, but I am still scared to try even though I need it bad. :(
The other machine is a cough thingy. That helps a bunch, but it works like a ventilator and sucks up and collapse my lungs. :o
This morning I woke up crying due to the pain I was in. Took a couple hours with pain meds and now have it under control somewhat. As far as my back doctor, he said there is nothing that can be done to help. I will look for a new doctor now. That is BS. >:( There is no reason I should be in the amount of pain I been in. >:(
Other then that, still getting weaker by the day. Thanks for the prays.
Post by: doc henderson on October 15, 2020, 02:03:14 PM
I have held back a little as you are probably getting lots of advice.  The ventilator takes getting used to, like scuba equipment.  If your back dr. is a surgeon, and says there is nothing else, maybe try a pain doc.  If you have respiratory weakness, some are concerned that the pain meds will further diminish your respiratory drive.  not all Docs in the same specialty are created equal.  If your pain is not controlled and the vent is not working for you, (If you were here), I would consider a hospital admission to get a handle on your pain plan, and see if with assistance, you can get accustom to the vent.  Is it bi-pap with a mask?  I worked as an RT in undergrad.  we used to vent ourselves so we could see why people panic.  A person has to learn to work with the machine.  I worked with a lady with ALS for several years (40 years ago).  She remained in the hospital as her husband never felt he could take her home.  Dorothy "Dot"!   FF I wish you well, and hope my comments did not create further conflict.  let me know if i can help.  God Bless.
Post by: fishfighter on October 29, 2020, 05:58:13 AM
Hey Doc, thanks. They still adjusting the ventilator. Me sitting up verses laying down is a very big change. So it's hard to get things right. Then I get a solid crude big up in my throat that blocks my air way. >:( We did buy a new bed that lifts and adjust out like a hospital bed. Helps a little.
Another problem that is starting is that my left foot and ankle has been swelling a good three times the normal size. That is starting to travel up my leg. From my knee down, all that is numb, but yet I still have feeling in it like pressure.
I will be seeing a pain manager doctor today. He is the same doctor that has been doing to roid shots in my back. Don't know how that will go. I am still in a lot of pain. :'(
Have another appointment with a ALS doctor group in Baton Rouge tomorrow. That is like 5 or 6 doctors that will be seeing me.
I had applied to a few drug study groups to see if I can get in one of them. More then willing to be a guinea pig to help find a cure of this crap.
Storm wise, all good here thanks to the cold front that pushed it northeast. Hope all in it's path are good.
Post by: Magicman on October 29, 2020, 09:20:43 AM
It's good to hear from you Paul, and I wish you the best with your Dr.'s appointments.
Yup, we also dodged Zeta plus the temperature is dropping.  The Forecast is for the high 30's Monday morning. Yikes!!  :o
Post by: doc henderson on October 29, 2020, 09:44:09 AM
good job.  I hope your docs collaborate and work together.  times have changed and that seems harder to do.  remember the cough facilitation, and suction if you have it.  legs will swell with less activity.  get it elevated and get a photo to your primary doc.  may be infected and need an antibiotic.  your pain and ALS docs may not want to take that on, but you can show it to them.  best wishes.
Post by: samandothers on October 29, 2020, 09:49:59 PM
Good to hear you were not bothered by the storm.  Hope Doc appointments go well and they can help with the pain and swelling.
Post by: fishfighter on October 31, 2020, 12:14:28 PM
Two days with many doctors and test.
Pain doc, going to try a temp block next Wednesday and a second one the next Wednesday. Has to be done that way for insurance to cover a real block.
 Ventilator has been adjusted again, but didn't use it last night due to me being way to tired. Still tired this morning.
New power chair suppose to come Tuesday.
Left and right legs, had test done. Was checked for blood clots and blockage.
A new brace has been ordered for my left foot.
Overall, yesterdays ALS clinic visit was fair to good. As they told me, they will try to make me at ease.  They have a nurse that if I need something, she is on 24/7 call or someone else.
Post by: Magicman on October 31, 2020, 12:45:58 PM
Thanks for the update Paul and I know that you are hanging as tough as you can.  :snowball:
Post by: fishfighter on November 03, 2020, 08:25:11 AM
I am trying to give it hell Lynn. ;D Will try to get out and vote today with the help of my dear wife. Yesterday made 41 years married to her. 8)
Post by: samandothers on November 03, 2020, 09:19:55 AM
Good to hear you have the medical folks helping as they can.
Post by: WDH on November 03, 2020, 07:14:23 PM
Congrats on 41!
Post by: fishfighter on November 21, 2020, 10:51:43 AM
Hello all. Hope all are fine. Not much going on here. Just taking it day by day.
Post by: Magicman on November 21, 2020, 08:30:50 PM
Try to keep your chin up my Friend, and continue to keep us updated.
Post by: Bruno of NH on November 24, 2020, 06:45:56 PM
Yes please keep us updated
You are an inspiration to all.
Post by: fishfighter on November 26, 2020, 11:32:35 AM
Happy Thanksgiving all. It's just the wife and I today. Our daughter was exposed about 8 days ago, but no signs which is good. She wants to stay away just in case. Will get tested next Monday.
We did ordered a handicap van last week. Hope it comes in soon, maybe next Monday. It's being shipped in from up north. Had got to the point it is almost impossible for me to climb in the car or truck now. The VA is paying a bunch on the van.
Work on the house should start any day now. All monies are in place. That will be a big plus once done. The VA is paying out over $78K for the work.
Yesterday they burnt the nerves in my back. Still a lot of pain, but hope that lets off. Having a very hard time to breathe. Lung muscles/chest muscles are very weak now. I am having much more other problems going on now too. Thank God I have a caring wife.
Post by: btulloh on November 26, 2020, 11:45:42 AM
Happy Thanksgiving Paul to you and your family.
Post by: PC-Urban-Sawyer on November 26, 2020, 03:15:09 PM
May the Lord reach out to you and grant you relief from pain and discomfort in this time of trial and tribulation.
May the Lord give you and your wife the strength to bear the effects of this condition on you.
May the Lord bless you during this Thanksgiving day.
Herb
Post by: Armymann50 on December 27, 2020, 06:45:42 AM
 I found out last night that "Fishfighter" has passed away.  Prayers for family and loved ones. He will be missed
Post by: WDH on December 27, 2020, 07:00:18 AM
May he Rest In Peace.
Post by: Jim_Rogers on December 27, 2020, 07:10:09 AM
So sorry to hear this, but he is no longer in pain or suffering. Prayers to his family from all of us on the forestry forum.
Jim Rogers
Post by: LeeB on December 27, 2020, 07:23:52 AM
So sorry to hear this. The man was an inspiration to us all in determination and courage.
Post by: Magicman on December 27, 2020, 08:45:48 AM
(https://forestryforum.com/gallery/albums/userpics/20011/IMG_2376.JPG?easyrotate_cache=1495072957)
It was my pleasure to meet and visit Paul at his home a few years ago:
LINK (https://forestryforum.com/board/index.php?topic=80057.msg1484501#msg1484501) and LINK (https://forestryforum.com/board/index.php?topic=80057.msg1484558#msg1484558)
Rest in peace my Friend.
Paul Stephen Rockvoan
Ventress, LA
Post by: chet on December 27, 2020, 09:49:52 AM
So sorry to hear this. Condolences to his wife and family.
Post by: Ljohnsaw on December 27, 2020, 10:34:39 AM
So sorry to hear this.  His can will-do was such an inspiration to me.  I wish his family peace in knowing his pain is over.
Post by: realzed on December 27, 2020, 10:45:47 AM
My condolences to his family and friends, both near him and here on this forum.
He was very talented and admired for his wood related work and for his strength battling this insidious and unforgiving situation inflicted upon him - yet he handled it with grace and some humor, while still caring about others around him..
RIP
Post by: doc henderson on December 27, 2020, 10:50:10 AM
Blessings to his family, and may he rest in peace!
Post by: btulloh on December 27, 2020, 11:40:39 AM
He was a good man with a fighting spirit and he will be missed by all.  Condolences to his family and friends.
Post by: sawmilllawyer on December 27, 2020, 04:20:18 PM
I am sad to hear of Paul's passing, inspired by his complete can-do attitude, thankful he is no longer in pain and hopeful he is in the good place. Condolences to his family.
Post by: Armymann50 on December 27, 2020, 06:45:11 PM
from his  daughter dad -fishfighter
I had to come on here because I know how important this board was to him. It's with a heavy heart I have to let you guys know that My dad, Paul (fishfighter), is finally out of pain. He left this world on Christmas Day to be with my brother. As you guys know, he was diagnosed with ALS 6 months ago. He kicked heart failure's butt for 11 years. The last 2 weeks was very hard for him. He was totally dependent on my mom, lost all of his strength, couldn't lift his computer even, and he couldn't even think clearly since he was in so much pain. The last week his respiratory system started to fail. On Christmas morning, he called us to be by his side. He watched us open presents and told us he loved us and was going to miss us. He then slipped into a coma state and was gone within several hours.
He was an amazing father, husband, and man. He was only 62 years old. I could only imagine what he could have done if he made it into his 80s...he probably would have reinvented the wheel. He was determined to keep going all the time despite his diseases. With a heart function at about 10-20% he accomplished more than many people a fraction of his age. When he was told he had 6 months to live, he fired his doctors and lived another 8 years.
He loved the outdoors. He taught me as a young girl how to live off the land. I can remember being left on a deer stand alone by the time I was 10. I was always comforted when I saw him coming to get me down. He would be so proud that I made it, even though I didn't see anything. When I did kill my first deer at 12 he was so happy. It was seriously Bambi and since I never had shot a deer I clearly did not know how to age one. I remember I was crying. He comforted me and said, "Don't feel bad, that's the best tasting meat." As he finished skinning and gutting it and promptly folding it whole into a 55qt ice chest! He also taught me how to process my own game. When I entered veterinary school I did great in gross anatomy. I had dissected so many deer, organ and muscle identification were a blast. Still to this day I clean and process my own game.
He would spend hours with my brother and I as children in False River and Old River. When we were younger he was a big bass fisherman. He would pick us up a cage of crickets for us whiie he would work the piers. I think I caught the same brem over and over. At that time he was also commercial shrimping out a 16 foot boat and selling coon hides on the side in addition to working 12 hour shifts to support our family and send us to a Catholic School.
When we became teenagers we started saltwater fishing. We would fish the rodeos in Venice and Grand Isle. I just couldn't understand why I couldn't go to the docks to watch the weigh ins (lord know I know now!). He won 3rd place one year in Specks. He should have won a whole lot more but he was always having to tend to our rats nests, lines, hooks, and most of the time working on a broke boat. He loves to fish Tuna the most. One of my favorite saltwater stories was when me and my husband first started dating (we were 16). He invited Mitchell to come fishing with us. We were parked in the area near a bouy around 16 miles out. We were bottom fishing about 60 foot down for snapper. My dad told us don't leave the line in the water without putting it in the rod holder. Soon after my dad had casted out a drift line with a large dead shad on it. Zippppp, fish on. Dad screams to Mitchell get the gaft. Mitchell, sitting next to me, reels his line up in a panic....leaving about 1 foot of line in the water and goes to help him. Dad loses his fish at the boat. All at one time, whoosh there goes Mitchell's pole! I can literally see the pole going straight down into the ocean. The bubbles steaming off the reel as it looks like it's attached to a torpedo. Dad takes a deep breath and says it's ok. I have another pole if you want to fish. My new boyfriend says no way, I'm so sorry. Ten minutes later I feel a pull on my pole, fish on. I start to reel it up, feels like every snapper I caught that day, heavy. Reel down, pull up, reel down, pull up.....then I see something, not a fish. Something long and thin. It's the *DanG rod and reel. My hook was attached to the cross bar on the reel of the other pole (60 feet down). We all reach for Mitchell's previously lost pole and snatch it. His fish still on the other end! My dad said we won the lottery!! Mitchell didn't fish the rest of the day. Maybe that helped shape their relationship. We ended up getting married 13 years later and he was a blessing to my father ever since.
When he was diagnosed with heart failure he was forced into retirement. He was told he couldn't be around heavy machinery, generators, etc. Due to his pacemaker. He sold his boat at that time. My son (his only grandchild) was born. Since my mom kept him while I was at work he felt like it was a redo since he didn't get to see us grow up since he worked so much. It truly was a blessing to have Dylan around.
He decided since he couldn't fish, and kept passing out in the woods that he would get back into duck hunting. I was his side kick. We went to every WMA, lottery hunt, and wood duck hole we could come across. I was his retriever. I ended up buying a dog and training it. That's when all the ducks pretty much disappeared.
That's when he started building his cabin. If you haven't seen his craftsmanship it's awesome. He is completely self taught and could fix any problem. He was great at rigging stuff. He has a tread online of his build if anyone is interested in seeing it on the forestry forum.
I met a few of you guys at his pirogue builds. I still have a sticker on mine....fishfighter classic and I love tities and guns.
Guys, I know this is long, I just wanted to honor him! He was amazing person! He loved you guys. You were a place for him to air his frustrations and share in his victories. I know I don't have him anymore. I can't call him and ask him advice on random things (because trust me he knew pretty much everything). I'm lost, my mom is lost...he is no longer hurting. He is with my brother again. I can at least come on here an read his advice to you guys. I can read his voice through his comments.
I do not know final funeral arrangements yet. I will post them here when available.
Once again thank you guys for supporting my dad over the years.
Post by: Walnut Beast on December 27, 2020, 08:02:26 PM
Thank you for sharing this. The first part was very difficult to read. My deepest condolences. I enjoyed interacting with him on the Forestry Forum. I'm glad you where all there with him. He will be deeply missed but not forgotten. You and your family are in our prayers
Post by: Magicman on December 27, 2020, 08:04:38 PM
fishfighter's Obituary (https://www.legacy.com/obituaries/name/paul-rockvoan-obituary?pid=197372899)
Post by: doc henderson on December 27, 2020, 09:58:34 PM
WOW!
Post by: Nebraska on December 29, 2020, 03:11:07 PM
Sorry to see this, he fought an inspirational  courageous fight. Glad he is at peace my condolences to his family and friends.
Post by: Weekend_Sawyer on December 29, 2020, 03:14:05 PM
I am sad to hear we have lost a dear friend. I will miss hearing from you Paul.
Jon
Post by: samandothers on December 31, 2020, 11:47:26 AM
I have not been on in a while and just saw this.  I am sad to read of Paul's passing.  He has left great memories/examples of his 'get to it and get it done' attitude.  I am at a loss for words.  My condolences to the family and friends. Rest in Peace fishfighter.
