Steel wheels vs belted wheels for winter sawing
Started by climber2, February 12, 2018, 11:07:27 AM
climber2
As I continue researching mills for an upgrade thighs keep crossing my mind. This topic is one for sure to consider as I do most of my sawing in the winter months. This may seem strange but it's when I have the time to do it.
If you have some insight, please share it. Maybe there is no difference...
Timber Harvester 36htd25, 06 Ram 2500 5.9, 95 Chev 3500hd, 445ct Bobcat w/ Wallenstein winch, Bandit 200+, Morbark M12r, Countless chainsaws...
Dave Shepard
I have had zero problems sawing with belted bandwheels other than one instance of clumps of larch pitch under ther belt.
Doug Wis
   I do the bulk of my sawing in the winter and have had both. 1st mill was a Kennerbilt  with steel wheels and then upgraded to a TK 1600 with tight belted wheel. After tiring of the hassel of changing the tight belts, I switched to using the loose belts[B57 vs B56}. I don't saw a whole lot and am a long way from a pro at it, but I haven't noticed any difference between the 3 types of wheels. Actually never even thought of it till I read your post.
A man who says he can do everything at 65 that he did at 25 sure wasn't doing much at 25.
moodnacreek
Log sawing is not supposed to be done in spring or summer. You will always get better lumber sawn in the winter.
Larry
No difference that I can tell.  Belts can get destroyed on the first log or last for 300 hours.  Steel runs for a few thousand hours before needing attention.
JB Griffin
Steel at work, belted at home. Much much much perfer the steel.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
Dave Shepard
What do you see as the advantage to the steel wheels? I've only run the 40 series WM.
JB Griffin
Everything, their actually balanced and turned true with very little run out, no belt for junk to get under or replace, the crown lasts for 600mbf+, impossible with a belted wheel period. Not to say that belted wheels won't work, they obviously do, just not as well.
kelLOGg
You're right about the trueness of steel wheels. I had mine recrowned a few years ago and measured the runout when I installed them. less than 0.001 inches.
SineWave
Quote from: kelLOGg on February 13, 2018, 12:52:42 PM
Holy cow, a quarter of the thickness of a human hair...that's TRUE!
Alyeska Pete
Steel wheels also have the advantage of being able to run diesel instead of water and antifreeze.  And a lot less of it.
Dave Shepard
You can run diesel on rubber belts. That's all I ran on the '94 LT40. Never had a problem with the belts, or with pitch. I hardly run any lube on my Super. A little soapy water fyi clean now and then.
gmmills
   I have used both belted wheels and steel wheels on the same mill in the past.  Over all, properly machined, crowned, steel wheels are far superior to loose or tight fitting belted wheels. I can honestly say that I will never go back to a belted wheel.   No belts to be damaged buy broken blades. I am sure you all will agree, it is extremely frustrating to have installed new wheel belts and have a blade prematurely break cutting the new belts contact surface.  Steel wheels will also increase overall blade life up to double that of belted wheels. If you can afford to upgrade to steel wheels, by all means do not hesitate to do so.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Larry
Quote from: gmmills on February 18, 2018, 10:33:19 AM
When I had a mill with steel wheels, my bands usually died from sharpening.  With my belted wheels, bands die from breaking.  I'm not sure if my results can be contributed to the wheels or something else.
It would be interesting to hear from others that have ran both style of wheels.
JB Griffin
Blades at work last longer than they do on my wm, but thats not a fair comparison.  19" belted vs 36" steel :D
climber2
[quote
[/quote]
I agree.  Maybe a manufacturer could add to the conversation as well. There has to be reasons why some use what they do, 💰 aside
slider
I think your question has already been answered . The high production sawyers lean towards steel wheels.
al glenn
4x4American
My Baker resaw has steel wheels and my lt70 has belts.  The belts beat up the blade and the blade doesnt turn as nice.  The blade on the resaw runs nice and flat and when the blades break they don't ruin the new belts I just put on.  I'll be putting steel wheels on the 70 at some point
Boy, back in my day..
highleadtimber16
Quote from: moodnacreek on February 12, 2018, 12:44:25 PM
I've personally found my best sawing is in the spring/early summer. I do not like frozen logs. Especially frozen fir.
2011 Wood-Mizer LT 40 hyd w/ 12' Extension,
EG 200 Wood-Mizer
Cutting Old Growth Cedar from Queen Charlotte Islands.
starmac
Interesting, do they even make steel wheels for a woodmizer?
4x4American
Yea cooks sells em, but theres other ppl doing it also
Dave Shepard
Does the WM4000 run belts? You'll have one of those by fall. :D
