best wood to rebuild a circular mill
Started by mikes47jeep, February 24, 2012, 10:52:51 AM
mikes47jeep
Hi all
I picked up an Ireland left hand mill with a 48" blade
The iron parts are in excellent condition, but the wood is getting soft.
I was wondering, what is the best wood to use to rebuild a mill?
I was told ash was a good idea because of its strength and ability to absorb shock
However the supplier I'm going to I can get oak or maple for the same price
Are there any advantages from one to another?
Best regards
Mike
Ireland No.2 Left Hand Sawmill 48" blade
eastberkshirecustoms
duck_nutt
mikes47jeep
I'm talking about the husk, carriage and track bed
As far as the foundation I will be pouring concrete pilings.
Steel is out of the question, too expensive for a hobby mill, and I'm better with a saw and hammer, than a welder
Mike
What part of the country are you in?  That would help in species recommendations.
mikes47jeep
bandmiller2
Mike,I  had the same question when I rebuilt my old Chase-De Lane mill.Origionally the mill manuf. used southern hard pine.The biggie is stability,in fact its more important than stregnth.Our northern hardwoods are too twisty.When i was setting up my mill the power co. was replacing high line poles and cross arms in the neighborhood.I remilled the douglas fir cross arms ,clear and stable beautifull wood.My husk is a Lane #1 cast iron,but I used the 4"x8" dougie fir under the track.I would not be afrade to use white pine under the track if cut large enough,and had a roof over it.Old used timbers remilled is best if you can find them.If you use oak or ash mill them oversized,let them cure and recut to size. Frank C.
mikes47jeep
well thats settled im going to go with ash, seems to be a good idea
now duck_nut has me thinking, can i just set up ties like railroad track to place my mill on?
or would it move around too much?
Mike
Yeah it's too bad you weren't more local. I have a bunch of antique 10"x10" hand hewed beams I'm trying to sell.  I believe they are hemlock though. I'll probably end up cutting them up and feeding them to the furnace :(.
mikes47jeep
well your not too too far berkshire NY is only 70 miles one way for me
how long are they?
Woodchuck53
Around here at 25 cents a foot old telephone poles squared on 2 sides is a good reuse of them and the old ones are still treated better than new stuff. The power co. will let you pick and choose what you want and most times load you out if your not in a big hurry. And like I said a good reuse of some pretty good material. Chuck
Case 1030 w/ Ford FEL, NH 3930 w/Ford FEL, Ford 801 backhoe/loader, TMC 4000# forklift, Stihl 090G-60" bar, 039AV, and 038, Corley 52" circle saw, 15" AMT planer Corley edger, F-350 1 ton, Ford 8000, 20' deck for loader and hauling, F-800 40' bucket truck, C60 Chevy 6 yd. dump truck.
Quote from: mikes47jeep on February 24, 2012, 10:22:08 PM
how long are they?
I have (4) 16' and (4) 20'.  I actually have a guy stopping by over the weekend to look at them. I've had several calls on them already, but think I'm asking too much at $50 per timber. I think for your use, they would have to be trued up. The ol' timers definitely had skill (and way more patience than me) to make them, but I don't think they are that precise. I often wondered why they hand hewed them when there was originally a water powered mill on the property that made 12"-24" wide planks. Why not just saw them? I was going to resaw them when my mill is complete, but don't really want to mess with all those hand made nails- most times they just break instead of pulling out. Anyway, I'll let you know if I still have them after the weekend...
Ron Wenrich
My 2 cents.  Ash splits really well.  You don't see it used in many types of construction.  There's a reason for that.
Those old husks and tracks were put on softwoods when they were made.  Considering that a lot of those old mills were made in the NE, and they had access to the hardwoods; its curious that they never used them.
We had one that was rebuilt on Doug fir.  That was pretty stable.  If you can get heart pine, I think you would have a pretty stable foundation.  Hemlock could be OK if there is no shake.  If I remember correctly, the track was on a 4x4, the carriage was the same, and the husk was a 4x8.  If you get these sawed, make sure that its center cut.  You don't want to have these split from a 4x8, for example.
Stability is the key.  You can always engineer strength in your supports.
bandmiller2
Mike, my first circular mill I put on steel roof trusses,I took the crown out of them and they worked well, strong and light. Sometimes used they can be bought right.
Dakota
My Dad replaced the husks and track timbers with ponderosa pine.  He found a place that would let him dump his timbers in their treatment tanks for a mimimal cost.  That was 20 years ago and they are still sound.
Dave Rinker
mikes47jeep
i was thinking ash just because of its good strength to weight raito
and it absorbs shock well.
it also seasons very well, dosent seem to bow or twist with minimal srinkage.
as i said earlier i can get oak for the same price but it seems not to season out as true as ash
this is just my personal experiance, if im wrong feel free to speak up
Dakota ponderosa pine in my area is next to impossible to get in the large dimentions i need to rebuild a mill
Mooseherder
I built my tracks out of pressure treated pine bought at the local hardware store because that was what was available.  Time will tell if I made the right choice.  I'm thinking I may have made a mistake putting them directly on concrete and may opte to put some cross ties underneath to get the track off the ground and allow clearance for the carriage drum pulley shaft under the track rather than drill thru the track like the previous owner had it.
Al_Smith
FWIW most of the old circle mills around here were set up on oak .You don't find many that are still operational especially if they didn't have a shed roof over them .
Now also fwiw I've seen them set up on flat bed semi trailers and transported to antique tractor shows and the like and they worked out pretty well .They'd  handle a pretty good size log but it took a big fork lift to load it .
I'm full of ideas as usual .What about a long framed truck chassis or school  bus frame ? Fact I'm using a 27 footer for my bandsaw that once belonged to Wilson sporting goods of Ada Ohio and transported NFL footballs  over the USA at one time .
8 inch thick frame straight as an arrow .You'd have to put it on some good foundation though and get creative with the blade mount but it would be a darn sight easier and cheaper than buying a bunch of steel and starting from scratch I'd thing .You know they get them in wrecking yards ,strip the parts off and sell what they can but almost nobody has a use for the frames .Cash deal a person could probabley get one for less than scrap steel prices .An option,one of many . ;)
Rooster
I looked at a Altman-Taylor Circle mill (1898), that had Douglas Fir as the rail support. I havn't been able to determine if it was the original wood, or if it was replaced back in the 50's.  It was in a fire a number of years ago and it is quite charred.  The Franklin Grove Historical Society might try and get the mill operational so that it can help support it's own restoration efforts,and be a source of income for this non-profit out of NW Ilinois.
I might have some contacts in NY who might have some re-claimed DF that you could have re-milled.  Also by posting a note in the "wanted" section of the Forum might yeild some usable material.
Good Luck!
Rooster
"We talk about creating millions of "shovel ready" jobs, for a society that doesn't really encourage anybody to pick up a shovel."
Mike Rowe
"Old barns are a reminder of when I was young,
       and new barns are a reminder that I am not so young."
                          Rooster
Al_Smith
A number of years ago when I was involved in antique tractors we had the occasion to pick up an early 1900's Frick .The whole thing including the Buick straight 8 engine that powered it .We were going to set it with a jack shaft and belt up to the old tractors .
Politics in the local county fair being in a "good old boys " area pretty much killed the project of setting it up though .I got disgusted  with the whole thing and went about my merry way .I kinda figured if those hog farmers wanted to run the show they could set up the mill as they pleased which never happened .Not in the least bit surprising . :D
Personally, I think ash would be a poor choice for the reason that Ron mentioned. It's tendency to split. The timbers on a mill take a beating. If I was to use any hardwood, it would be white oak.
Ron Wenrich
Quote from: Al_Smith on February 25, 2012, 09:17:41 AM
You mean something like this?
Al_Smith
Yes pretty much the same of course with no power unit .The power being old tractors steamers etc .
You could power one from a John Deere A but you couldn't crowd it too much .An 820 JD would zip right through but they could bring those right down on the governor for all old John could put out if they wanted to .
Something like a 40HP Case or a big Russel steamer . powered them like childs play steam just a rolling out the stacks .You could see the steam plumes and black coal smoke for miles .
Anybody who's  never seen steam under power and likes old antiques it's worth a trip to see it .
ALWOL
   Well this being my first post, I may be a little out of line but I would like to share some of my experience with old circle mills.
   All of the mills that I have redone, (one Lane, a Fisher and Davis, a Kingsland and Douglas, a Deloach, and Frick) all used what I think was Southern Yellow Pine for both the carriage ways and the husk frame. I used White Oak for the replacement, because that is what I had on hand. If you have the choice between Oak and Ash, use the Oak. It is tried and proven, and I would have some concerns about splitting and warping. White Oak is also much more durable to the elements than is Ash.
  It is a lot of work, but it will all be worth it when you hear a properly tensioned blade singing through a nice Walnut log.  Good luck!
     Alan
There's a big difference between staying busy and making money.
Axe Handle Hound
They use ash for tool handles and baseball bats, two very high stress applications.  Yes, it does split, but it takes an incredible amount of pressure before giving in.  If you support it well enough there's no reason ash should break.  That being said, I will agree with Jeff that if I had white oak available that's what I'd use.
The way I'd look at it is that bats and handles aren't typically full of large bolt holes that shorten the grain and add stress points for failure. Handles always break, bats always break, they don't just wear out from age or decay.
jcbrotz
Why not locust? White Oak would be second.
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
mikes47jeep
well come monday
ill take a trip to the mill and get a quote on some oak
hopefully it wont cost me an arm and a leg but only time will tell
Mike
bandmiller2
Thats the kicker you need wood milled for your sawmill but you need the sawmill to cut the wood.Mayby find a local sawyer to mill some for you.Has anyone tried those glue-lam beams.??What ever you use slap on the baddest preserver you can find and put a roof over it. Frank C.
mikes47jeep
well a place about 10 miles away will cut odd dimention lumber for me
so he's my first choice
i have seen some lam beams used for the mill tracks
i wouldent mind two 48 footers for my mill track
MHineman
  I agree Ash splits easily as firewood, but I've not had problems as lumber.  White Oak will resist decay much better, but Ash will dry much quicker and therefore be stable sooner.
  It would be great to mill the beams and then remill them after drying, but I doubt you have that much time.
  If you can get beams from the cants they should be more stable than timbers from one side of a log.
1999 WM LT40, 40 hp 4WD tractor, homemade forks, grapple, Walenstein FX90 skidding winch, Stihl 460 039 saws,  homebuilt kiln, ......
Ron Wenrich
Quote from: Axe Handle Hound on February 25, 2012, 02:16:58 PM
They use ash for cheap handles.  Price out hickory handles and you'll see that they are more expensive than a shovel with an ash handle.  I believe Babe Ruth used a hickory bat.  Most ball players can't swing the heavier bats.
Meadows Miller
Gday
I think the reason alot of mill makers used Softwoods for the frames is dimensional stability Hardwoods have alot less of that and higher shrinkage rate which would have meant alot more unstable during the changes in season but I have also heard of Oak frames but it would all have to be cut heart free the same as with the SYP frames alot of the manufactures supplied their mills with  ;)
And you also have to consider weight when alot of these mills where popular they where generally shifted arond and setup by manual labor  :o :) so setup weight was even a concern back in those days a #1 meadows tipped the scales at about 4000lbs including the Mud Sills under the Husk  which is bloody light when you consider the amount of wood you can put over them a day  ;)
I think if your going to have a timber frame mill you need to have a shed over it  ;) ;D ;D 8) Thats just my thoughts on the subject  ;)
Regards Chris
4TH Generation Timbergetter
Ron Wenrich
A shed also keeps sunlight off the blade.  Sunlight on a blade can cause all sorts of problems.
