rebuilding 361 big bore vs stock
Started by sshier, October 17, 2013, 09:06:49 PM
sshier
Im rebuilding 361 what is best route for saw. It will be an every day limbing saw guess big question is realiability and power gain.
mastermind7864
Stick with the OEM jug if possible.....
tlandrum
randy is right stay with oem.  on some of the aftermarket junk you have to port it to just get it to run with stock oem.
www.wickedworksaw.com
wickedworksaw@gmail.com
Husqvarna and jonsered dealer
chainsaw porting for high production work saws
4233465399
sshier
Ok so if i port it and port muffler will i feel a huge diff or not. Although i've heard the 361's are screamers for there weight stock.
mastermind7864
Quote from: sshier on October 18, 2013, 06:22:14 AM
That depends on the timing numbers used, compression gain, or not....
Would you be doing any machine work to the cylinder or just a little port widening?
sshier
Just going to widen ports and open up muffler some clean up casting more or less.thinkin about just going big bore from baileys alot less expensive than stihl parts
mastermind7864
Stick with a standard bore cylinder.........big bores normally have wack port timing numbers. It's like whoever designs them is real stupid......
nmurph
Quote from: mastermind7864 on October 18, 2013, 12:20:22 PM
OP, you need to listen to this guy.
mastermind7864
Of course I don't know much about saw engines........I've only ported about 200 this year.  :new_year:
mastermind7864
Quote from: nmurph on October 18, 2013, 12:21:56 PM
Hi Neal........I got a parcel from you. I like those little buggers.
sshier
Ok well thats why im here because I need advice. Sounds like I need oem thanks
mastermind7864
Quote from: sshier on October 18, 2013, 03:58:57 PM
Some aftermarket kits are very good........I've just not been at all impressed with many BB kits. I've used a couple for the 372 that were nice, and also a couple for the 7900 that were good. But I've never seen one for a Stihl that was worth a crap.
