Author Topic: Spiral bark pattern  (Read 8792 times)
Offline Troy
  • Good help is hard to find!
Spiral bark pattern
« on: March 23, 2006, 09:53:09 AM »
I recently bucked a large chestnut oak that I will be cutting fence boards out of for the neighbors down the road.   Approximately 26" dbh, long and straight, but the bark spirals up the tree like a candy cane.  On a sixteen foot log the bark makes about a full quarter twist from one end to the other.  Is this going to be a problem log with lots of tension and corkscrew boards?  What's your experience with this type of tree?
Peterson ATS 8" 27hp
Offline Captain
Re: Spiral bark pattern
« Reply #1 on: March 23, 2006, 11:40:25 AM »
Yup!!
Offline Troy
« Reply #2 on: March 23, 2006, 12:00:19 PM »
That's what I was affraid of Captain!  I already told my neighbors that they should plan on nailing them up as soon as they come off the mill.  Anyone know what causes a tree to grow like that?
Offline Captain
« Reply #3 on: March 23, 2006, 01:30:26 PM »
You also may want to consider shorter lengths than 16 feet.
Captain
Offline Troy
« Reply #4 on: March 23, 2006, 01:44:33 PM »
I have a ten foot section, butt log, that I will be cutting boars for myself from, but they want sixteen specifically for fence boards.  Should start cutting them tomorrow afternoon.  Will let you know what happens!
Offline Norm
« Reply #5 on: March 23, 2006, 01:55:11 PM »
I'm interested to hear how it works out Troy. I had a 16' cherry brought in with a load that has a spiral twist like you describe. I'm going to buck it to 8' lengths and cut it all 6/4 when I slice it up. Hope it helps to minimize the twist effects.
Offline Rockn H
  • long way to go
« Reply #6 on: March 23, 2006, 02:11:49 PM »
Does the bark twist to the left or the right? ???  For us, a log with a left hand twist tends to be the one with alot of tension in it.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #7 on: March 23, 2006, 02:24:27 PM »
 In general , when a log has a twist .. it will give you pain through out the operation ... from sawing to drying to machining , now if I cut logs for myself , those twistys get put in the fire wood pile . Or I leave them standing .
 I know of one place where they put a spiral grain log in for a main beam in the center of the house, once it started to dry it lifted the floor .
   Marcel
Offline SwampDonkey
  • Large Tooth
« Reply #8 on: March 23, 2006, 02:27:42 PM »
Firewood. When I see it in rock (sugar) maple up this way, get ready for a living culvert, usually hollow on the but log.
Move'n on.
Offline SwampDonkey
  • Large Tooth
« Reply #9 on: March 23, 2006, 02:30:08 PM »
It'll probably be even worst of a pain in cherry. Any kind of excessive tension in cherry and it goes to pieces.
Move'n on.
Offline ely
« Reply #10 on: March 23, 2006, 02:31:55 PM »
not good for boards but you could market them as  wood propellars. :D
Offline Ron Wenrich
« Reply #11 on: March 23, 2006, 05:04:29 PM »
My understanding of a cause is that it is genetic.  So, letting them stand isn't really a good idea...you get an undesirable seed source.  Cutting and letting them lay may be a better option.
Lodgepole pine is pretty well known to have spiral grain.  They use them for telephone poles.  I had a prof that worked for a railroad back when the telephone lines followed the tracks and had crossarms.  For some reason, they were snapping lines in some real remote sections of Wyoming.
The culprit turned out to be spiral grain and humidity.  When the humidity would rise, the arms on the poles would turn.  When you got one turning one way and another turning the other...then the lines snapped.   :D
Offline SwampDonkey
  • Large Tooth
« Reply #12 on: March 23, 2006, 05:25:46 PM »
Sounds good to me Ron  ;D  ;)
Move'n on.
Offline woodmills1
  • the truth shall set you free
« Reply #13 on: March 23, 2006, 06:45:23 PM »
God made it that way.
Offline beenthere
« Reply #14 on: March 23, 2006, 06:59:04 PM »
God made em that way so the poles would screw themselves into the ground. It's just that we plant them first, and then they can't  do it themselves   ;D
Offline Troy
« Reply #15 on: March 23, 2006, 07:12:11 PM »
Interesting story Ron.  I did a search in the archives and found previous posts about the same subject.  Will see what it looks like tomorrow when I open one up.  They are right hand spiral, good and solid on both ends, so maybe it will be OK for fence boards.
Offline logwalker
  • Got Logs??
« Reply #16 on: March 23, 2006, 07:40:50 PM »
Cutting at 16', IMHO, you will have more leverage to nail them flat and keep them that way. This should prove interesting. LW
Offline wiam
« Reply #17 on: March 23, 2006, 09:26:22 PM »
I have cut spiral cheery to 5' and still had considerable twist from one end of aboard to the other.
Worked ok for small projects.
Will
Offline dail_h
  • G-Diddy and the Baby Hurlenator
« Reply #18 on: March 24, 2006, 12:19:52 AM »
   Righthand threads don't seem to be as bad as lefthand ones. Anybody else 'sperience this?
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
Offline Shamus
  • Another day in paradise...
« Reply #19 on: March 24, 2006, 10:03:16 AM »
I milled up a spiral western hemlock. It must have had ring shake as well, because all I ended up with were a whack of boards that broke into shards before I could even stack them. Useless...
D&L Doublecut Synchro sawmill, Procut chainsaw mill, John Deere crawler loader,  F350 4x4 flatdeck, 20 ton logsplitter, running Stihls
Sweet Gum, spiral grain, will the bark indicate this?
Started by Delawhere Jack on Sawmills and Milling
Last post July 09, 2012, 07:54:24 AM
by Magicman
Wood for smoking, bark on or bark off?
Started by Delawhere Jack on FOOD! FOOD! FOOD!
Last post February 15, 2013, 09:03:08 PM
by martyinmi
choosing a saw pattern
Started by Qweaver on Sawmills and Milling
Last post July 07, 2010, 05:07:01 AM
by Bibbyman
Lug Pattern on LT40
Started by 4x4American on Sawmills and Milling
Last post March 25, 2015, 09:47:18 PM
by 4x4American
