4-53 oil filter
Started by Woodboogah, May 09, 2014, 10:32:42 AM
Woodboogah
I cannot find the oil filter.  I had all the panels off.  I have never changed the filter.  I have had it for a year.  I put oil in it almost everyday and figure its time to change out the filter ( i know bad logic).  I looked for a cartridge or spin on and cannot find it.  Where the heck is it.   The only filter  I can locate are fuel (which I have changed a few times) and hydraulic.  I even went down to the store so I could see which each one (cartridge or spin on) so I knew what I would be looking for.  I feel like a dummy not being able to find it!
Keenan Logging & Tree Care, LLC
Ed_K
It's sideways under the blower in line with the oil pan bolts.If it's got the cartraige get the adapter for a spin on (much less hassle).
Ed K
Woodboogah
I'll take another look.  I was probably looking right at it.  Thanks!
Timbercruiser
Did you find it ??  Better change oil more often than once a year . :D
Woodboogah
I know I should of already changed it.  Yes I found it.  It was in the front of the machine in plain site I just assumed it was the hydro filter it looked like it was on the back of the hydro tank but I followed lines and it was the oil filter.  Did not match any filter numbers that I found.  Done now.  Thanks
Tom L
Quote from: Ed_K on May 09, 2014, 12:55:09 PM
x2 on the spin on adaptor, then locate it remotely with some hydraulic lines so it is easy to get to.
those canisters that are on there originally are a real pain to change. I have mine relocated on the outside of the machine where you can just spin it off and replace it.
RKH Logging
[/quote]
i was thinking of doing the same thing can you show some pics of how you did it?
Tom L
here is a picture of the remote oil filter mounted outside of my machine,
parts were available from the detroit dealer when I converted it
