Drive sprocket on LT-40 misaligned
Started by Jjoness4, January 14, 2017, 08:18:21 PM
Jjoness4
Got my new LT-40 home and sawed with it for about an hour today.  When returning the head  heard an unusual noise coming from the head feed drive sprocket and it looks like it is misaligned with the chain.  The sprocket allen  screws seem tight.  The chain tension appears within spec. but it seems tight to me.
Any thoughts?
2017 LT40HDD35 , Kubota 4701, Ford 3000, Stihl Farmboss
Tree Dan
some of us lt 40 owners including myself had that sproket come loose.
I would have another good look at it, the sproket could have moved to the side a bit.
They do recomend a bit of Loc-tite on that set screw after the sproket is in the correct position.
I think there should be a setting that you can meassure from the main beam to the center of the sproket , maybe a lt40 member will post this.
Have fun sawing when you get back at it ;D
Dan
Wood Mizer LT40HD, Kubota KX71, New Holland LS150, Case TR270
6400 John Deere/with loader,General 20" planer, Stihl 880, Stihl 361, Dolmar 460, Husqvarna 50  and a few shovels,
60" and 30" Log Rite cant hooks, 2 home built Tree Spades, Homemade log splitter
Ga Mtn Man
My LT40 did the same thing when I first got it.  The cam roller that tensions the chain around the sprocket was not in the correct position, causing the chain to ride off the roller when gigging back.  Moving one or two of the spacer washers on the cam roller to shift the roller's position slightly fixed the problem.
Jjoness4
Quote from: Tree Dan on January 14, 2017, 09:18:41 PM
Dan
It would seem that this being a fairly common problem that this clearance spec would be well defined.  I will take a close look at that sprocket position.  Wonder if WM puts loc-tite on that set screw at the factory?  Thanks for you response.
Quote from: Ga Mtn Man on January 14, 2017, 09:20:02 PM
I wondered about all those spacer washers.  Manual did not give any help as to possibly moving some on the other side of the cam roller.  Thanks for your help.
YellowHammer
It's important to keep the drive sprocket aligned reasonably well with the center of the chain, or you'll hear a clacking noise as the sprocket teeth rub on the inside links to the chain.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Kbeitz
I would be putting a split collier on both sides of the sprockets.
Love machine shop work
and Wood work shop work
And now a saw mill work
MartyParsons
Hello,
No roam for a split collier.
   WM has been using this assembly for many years. Maintenance is required to keep the belt tight and the pulley tight on the shaft. The 3/8 bolts that hold it to the C frame are slotted and the assembly can be moved if needed. There are also shims on the cam idle bearing that could be changed, I have never needed to do this.
I would start by setting up the mill, with the engine off and the key off push the saw head forward. You may remove the battery cover and the middle track oilier. Watch how the chain travels on the idler pulley. If it rides in the center of the cam bearing one way then tracks differently when you push the saw had back you may need to loosen the 3/8 bolts and turn the assembly to help with the tracking of the chain.
I the manual it states that the chain should be 7 " to 8" from the top rail to the chain. This should give you an idea what the tension of the power feed chain is. Adjustment is made at the rear of the frame.
I hope this helps. Ask more questions if needed.
Marty
Kbeitz
No room for split collars then I would go with split sprockets.
They don't come loose.
paul case
I had this same problem , sorta, on my '94 lt40. The sprocket is welded on the shaft and the other end has  a belt pulley that was loosening  letting the whole shaft slide in the bearings. The key came out and it quit. The chain had rubbed marks all the way down the mill when I figured it out.
PC
pc
Tree Dan
Quote from: paul case on January 15, 2017, 03:55:43 PM
Paul I think that would be the sproket that made the marks on the main mill beam.
I had the same marks, right to the bare metal of a mill with under 100 hrs on it.
Funny thing im starting notice the drive slowing down right in the middle of the bed.
I do have loc-tite on that set screw...its got me thinking now, I better take a look at it in the morning.
PC
Jjoness4
Problem fixed.  It was the set screws on the sprocket.  One was partially tight and the other was loose as could be.  This was with 2 hours on the mill.  Just not tight from the factory. The sprocket was moving toward the rail about 3/16".  Didn't have any loc-tite but will get some tomorrow and fix more permanently.  Thanks for all your responses.  Check your set screws!!!!  As Marty says this is a maintenance checkpoint.
paul case
I don't think it could possibly be the sprocket since the roller chain wraps around the sprocket the chain is closest to the mill box beam. Besides that  the marks where the paint is rubbed off are at each pin on the chain and they mark up and down 2'' or more.
PC
pc
Tree Dan
Quote from: Jjoness4 on January 15, 2017, 07:58:19 PM
2 hrs on a new machine should not imo need stuff like that checked
Anyway, remember I put loc-tite on my set screw, and i got it as tight as i could without striping it.
One other thing there are different strengths of loctite
I remember there is one that you need to heat with a torch if you ever need to take it apart.
Glad you got it fixed up, just keep your eye on it
Kbeitz
Does the sprockets have key-ways ? Or only set-screws ?
A trick you can use is to double up on the set-screws.
One on top of the other.
goose63
Dont use the Red Loc tite but use the Blue Loc Tite the Rsd is a forever thing. Dont ask me how I know
goose
thank you to all the vets
Jjoness4
Quote from: Kbeitz on January 16, 2017, 06:01:23 AM
Dose the sprockets have key-ways ? Or only set-screws ?
Kbeitz
I worked in the defense industry (military high explosives) for 44 years.  We in fact used your suggestion for equipment that could not lose nuts, bolts, screws into the highly sensitive product.  When we could not wire lace we double nutted and put set screws on top of set screws with Red loc-tite (or the military version).
Quote from: goose63 on January 16, 2017, 12:31:58 PM
I know the same way you do!!!
KirkD
Is there room for an allen head and safety wire?
Wood-mizer LT40HD-G24 Year 1989
You should absolutely be checking for lose bolts or parts or any number of conditions on not only new equipment, but any equipment you run. Just part of being a good operator. Having been in the seat of more than one new commercial circle mill, I can tell you they are far more prone to little maintenance issues than one broke in.
YellowHammer
Red Loctite can be removed with elevated temperatures.
Just a little heat will break it down, about 325°F, easily done with light hit with a propane torch.  It'll melt, crystalize, and come apart no problem.
YellowHammerisms:
paul case
Quote from: YellowHammer on January 16, 2017, 08:59:53 PM
x2
PC
pc
Jjoness4
Quote from: KirkD on January 16, 2017, 07:52:42 PM
No.  Wire lacing is used for nuts primarily.
drobertson
Theres been a few occasions where a slight peen at a few points around the top of threads have reduced the backing out of sets
Just as a note, this is not an area for continued or problematic concern.
