136 husky
Started by keppoch, May 19, 2010, 10:34:28 PM
keppoch
the chain keeps slipping of the sprocket,any ideas
What can you tell us about what you have already checked out for cause or reasons?
Cut4fun
Does the chain gage match the sprocket gage?  3/8lp on 325 or vice versus.
Is the sprocket or spur wore.
Does the bar with sprocket tip match the chain and rim or spur?  As above also.
keppoch
everything matches,chain,sprocket, bar,it seems I`ll be cutting a little while then I notice the chain is not all on the bar, at the back of the bar it will slip of ,am I putting it on wrong, should the bar be tilted up a bit when putting it on or down out straight.
01crewcab
Bar should always be tilted up when tightening the chain.
2100(2),480, 281, 181,372XPW, 460,435,350,61(4),51-Huskys
49SP, 630Super(3),670's(4), 830, 920, 930 Jonsered's
S-XL925 Homelite
SP125C, 790, 250, 1010 Macs
27Ton Troybilt Splitter
NRA Life Endowment Member
Viet Nam Vet
John Mc
Sorry to mention something so simple, but are you tightening the chain adjustment after putting on a new chain? Also, with a new chain, it will stretch, so you've got to retighten often.
Rocky_J
No sag, no drag. I cannot explain it any better or simpler than that. If it is sagging then it's too loose. If you cannot easily spin the chain by hand then it's too tight. Most new saw users will go to one extreme or the other. They either run it until the chain falls off or they crank it down so tight that the chain can't spin. Running a dull chain makes the problem worse because a dull chain gets hot and stretches so fast that the chain can be out of adjustment after a couple cuts.
HolmenTree
Quote from: keppoch on May 19, 2010, 10:34:28 PM
Your chain may be a link or 2 too long for your bar, you may be at the end of its adjustment. What I'm saying is get the gap between the tail of the bar and sprocket as close as you possibly can. Then your chain should stop derailing with proper filing and tensioning.
Willard.
SawTroll
I agree with the others - the chain is either too long, or not tensioned properly!
Information collector.
