Draw Boring
Started by nas, October 30, 2011, 09:51:44 PM
nas
I am building a TF sugar shanty using the Jack Sobon garden shed design, and I was wondering if draw boring is common practice or if most of you drill and peg after the joint is together.
Nick
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
Dave Shepard
Draw bore everything. If you don't, you will get gaps as the timbers shrink.
Brad_bb
Although I don't do it for a living and only have a handful of frames under my belt, I was taught to drawbore and it makes sense to me, especially for green wood.  Draw boring allows you to go back and whack the pegs again to tighten up if needed.  This makes sense for green wood, but is also good if needed for seasoned wood.  Seasoned wood you shouldn't need to, but it doesn't hurt giving you that option.
  I was taught to make pegs by riving a green oak log chunk with a froe, keeping the rivings wet in a rubbermaid rectangular storage container with water until you go to shave it.  Then shave it down on a shaving horse with draw knive takes about 60 seconds or so per peg(tapered peg).  Fast, cheap... I know timberframers who have their kids make pegs.
Carpenter
     For what it's worth, I draw bore everything.  The one time I didn't, I wish I would have.  That was on a small king post truss and the way it fit together, once I got everything to fit I really didn't want to take it apart again to drawbore it.  So, I just ratchet strapped it and drilled the peg holes and pegged it.  It turned out alright, but not as good as all the other joints that I did drawbore.
nas
Thanks guys.  Brad, do you keep the pegs wet after you shave them too?
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
Brad_bb
No, they can dry after they are finished.  You want to keep them wet so that they are easy to shave(much softer).  Also note that if your peg blanks dry out, you cannot put them in water and re-wet them. Due to the structure of oak, the water will only resoften the outside 1/32nd or so of the wood.  It will not let water back in throughout.  That's why it's important to rive a green log chunk, and put the blanks right in water to prevent it's water from going out.
Dave Shepard
Rough out your billet and store it in a bucket of water. This will keep everything wet until you need it.
jimdad07
Not to hijack the thread, but how much of an offset needs to be drilled for draw boring?  Are the pegs also tapered along the whole length of them?
Hudson HFE 30 Homesteader bandmill w/28' of track
Couple tractors, a bunch of chainsaws and not enough time to use them.
Brad_bb
1/8"
I don't have a picture handy, but tapered from the tip to about 3 inches from the outside end (where you are clamping in your shaving horse you cannot shave, but it works out perfectly).
jimdad07
Quote from: Brad_bb on December 03, 2011, 09:50:50 AM
1/8"
Thank you.
Brad_bb
Here's one video I found on youtube.  The chunk he is using is pretty dry as he said he took it from a firewood pile for the demo.  But you want to work a green chunk that you keep wet.  It shaves much easier and smoother that way.  Dry oak can come off in chunks when dry.  It's really easy to take too big a bite with the draw knife when it's dry.
http://youtu.be/i6l6SMihNNE
Jayson
1/8th " is a good rule of thumb.  If your working softwood with lots of relish kick it up a notch.  Especially if you have green wood(timbers).  I have always(when I haven't bought them) rived out of well seasoned locust or white oak and then dressed them with a draw knife or a spokeshave.  Buying them is pretty cost efficient and you have lots of options and species to choose from.   If you don't have a froe you can split pretty straight grain stuff with a hatchet and a mallet.  Make sure your pegs are very dry before putting them into service. They won't shrink and have optimum strength.
       Draw bore religiously.  A little draw boring hymn "To the end is a dead end".  If you are moving towards the end of a tenon you are going the long way. Things can get a little confusing in some joints (scarfs and splines) but if you make good habit, like most skills they become second nature.
Dave Shepard
I know Brad, and Heartwood!  8)
I've found it's better to have a little too much draw bore than not enough. I like to visually check the peg holes at assembly, and if it is a little too much draw, you can always clean it up with a gouge, not enough, and there isn't much you can do without plugging and redrilling.
frwinks
Quote from: Jayson on December 03, 2011, 09:10:09 PM
and to the shoulder, it will hold 'er :D
Jayson
Dang it, that's the one I was trying to remember!
canopy
Quote from: Dave Shepard on December 03, 2011, 09:20:09 PM
not enough (draw), and there isn't much you can do without plugging and redrilling.
That would make for a great video.
timberwrestler
Yup, that's me in black fly season trying to do an impromptu video with a crappy froe, and old wood.
Thanks for hooking HW up with some decent peg stock this year.  A little round goes a long way.  And by the way (Dave), I had heard through the rumor mill someone was working on some dutch barns, and I was a little worried until I figured out it was you.  Don't want a nice old Dutch barn getting all hacked up.  I know you'll do a good job.  I don't think I've seen you since Bing's raising, and man that was a tough one.  All hardwood, and lots of different people who worked on the frame over a really long period of time.  There were a few things that I missed too, but it all went together, and it looks great.
Dave Carlon always says to offset the peg hole in the direction you want the other piece to move.  It's easy enough with a straight mortise and tenon, but rafter peaks and weird things can be counter-intuitive.
www.uncarvedblockinc.com
www.facebook.com/uncarvedblockinc
Dave Shepard
Hi Brad, thanks for stopping in! That was one great oak log that those rounds came from. I busted up another for a raising in New York last month. I'll be working on the second barn all winter, you are welcome to stop in. Will was down to the shop last night with the Berkshire Wood Workers Guild for a tour.
LarryG
I was just wondering I'm building a post and frame sawmill shed this coming year out of white pine. I'm planning on draw boring the joints. I also have some maples on the property would the maple work for my pegs or should I be looking for something else. I don't have any oak that I want to cut.
Woodland Mills 126
Yanmar 424 Tractor
Jim_Rogers
Maple is fine, use what you've got.
Jim Rogers
Brad_bb
Also it wouldn't hurt to spray or dip your pegs with a borate to keep PPB away If they are exposed outside.
