drying pine
Started by Engineer, March 06, 2005, 07:46:01 PM
Engineer
Local mill has a Northland kiln.  He has offered to dry whatever I have in exchange for some work from me.  I have a few thousand BF of 5/4 white pine, some of which is air dry at about 14% and some of which is still in logs.
Questions:  can I mix them or should the already air-dried stuff be dried separately, and about how long should it take to get to 7%?    Also, will the kiln treatment slow down or stop the rate of decay from blue stain/sap stain/mildew?
QuoteAlso, will the kiln treatment slow down or stop the rate of decay from blue stain/sap stain/mildew?
Yes
The best way to prevent bluestain and mildew on pine is to get it dried down to ~20% as quick as possible. i.e. before the fungus has a chance to grow. Putting it straight into a kiln after sawing would be the best option.
I'd say seperate the air dried and green wood and kiln seperately. The air dried stuff will only need a short period to dry / have pitch set. The green stuff will need a bit longer.
Ernie
Do you know the purpose of the steaming offered by Taranaki Saw mills?
Does it somehow aid drying or is it just for pretreatment with CCA?
Ernie
