secondary brake on john deere b , c, series
Started by donny hochstetler, April 19, 2014, 08:45:29 PM
donny hochstetler
I have seen a lot of 540b 640,s logskidders, they have a good parking brake,   but I have seen them jump out on there own {lost one in a pond once}my question is,   they come with a secondary parking brake{an overcenter handle cable going down to brake mechanism on back of transmision} every one i have seen has been disconected, or is missing, :o   my mechanic says no good,    fire hazard  :o   Imight b getting a 640 c it has this brake, in non working order, I work by myself alot,and would feel better having a secondary brake in certain situations , in the back of my mind i"m always watching, especialy on a steep bank, I know somtimes I back against a tree, or put down blade.   is anybody out there using them, good experiance or bad should I even consider hooking it up, and how well do they hold I:m mainly concerned when i"m off the skidder setting chokers when i"m skidn I wouldn"t use it thanks
logger79
My 540b has one that works. I have had to replace the disc and pads at times. If you ever forget to release it you can have a fire quick. It gets hot fast and any debris down there will catch.
MJD
The 440 I had the parking brake was disconnected when i bought it, the guy I got it from said that was the reason JDs burnt up(i did get all parts). I always  bumped it to a tree when in hills setting chokers. The guy I sold it to put the brake back in service and added a light on the dash that would light up when the brake was set, solved the problem of driving with the brake on. Its still a good idea to keep that area clear of leaves and sticks.
donny hochstetler
thanks 4 ur input I might try n hook it up n just use it in certain situations I"m pretty good at keeping stuff clean and also keep fire extinguisher on machine I also like the light was wondering if you could wire up when you put it in gear a buzzer would come on ?
Offthebeatenpath
My 440d has a light when the brake is on and a buzzer if you put it in gear, so yes, it's very possible.
1985 JD 440D, ASV tracked skid steer w/ winch, Fecon grapple, & various attachments, Hitachi CG-30 tracked dump truck, CanyCom S25 crawler carrier, Volvo EC35C mini-ex, Kubota 018-4 mini-ex, Cormidi 100 self loading tracked dumper, various other little trail building machines and tools...
