My Eye went Screwy
Started by Magicman, June 19, 2014, 10:11:31 PM
Ed, what you described is an ocular migraine. I use to get them all the time while sawing, and still get them on occasion.
doctorb
Sounds like a partially detached retina, a "floater", which is a piece of small particulate debris in the vitrious of the eye that got into the wrong spot, or even a cataract.  A cataract, however, would not develop as a sudden loss of vision.  Best of luck tomorrow.  Where's the closest ophthalmologist to you?
tawilson
Might be too many sharp turns on the new zero turn.
2017 LT40HDG35 WIDE
Woodmaster 725
I dont make sharp turns.
doctorb
You could have lunch at the hotel!
I'd have lunch across the street at the white house first!
Best news possible. I had some fibers tear away from the optic nerve, but it did not result in a tear of the retina. Odds now of the retina tearing are quite low because it didn't tear initially. In time my vision should clear up and the flashing subside.  What I thought was much worse for this eye than the other because of the symptoms, turned out to be not near as bad.
LeeB
Good news indeed. Guess we'll be seeing each other next month after all. Yeah, I know. Poor humor.
Hilltop366
Sounds good, if not already bad enough. Take care.
Good news, that sounds like a Vitreous separation which is what I had.  Yes, I agree with LeeB, it will be good for us to be able to see each other.  ;)
ronwood
Jeff,
Good to hear that it was not to bad. What would cause the fibers to tear?
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
If it was a Vitreous separation, the cause is directly related to birthdays and heritage.  ::)
Ayup.  And that is what he said.
samandothers
Good to hear this outcome.
doctorb
I had breakfast at the White House.  Excellent.  Always nice when your doc says ,"do nothing, and it will get better."
Ed_K
Ed K
Busy Beaver Lumber
Hope you are doing better Lynn. I get those spots once in a while too
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
