Echo 310 muffler mod
Started by Wchafee, May 11, 2014, 06:18:22 PM
Wchafee
6in oak  5/8/2014
Original muffler                             8.5 sec
Removed cat, drilled 2 5/8 holes     6.7 sec
trapper
please explain more. 9 min seems a long time to make 1 cut thru a 6in oak. First post welcome.   Would you fill in where you are located.
Rob5073
Surely that is supposed to be seconds!
ladylake
As usual huge gains with just a muff modd and tuning on a Echo saw.    Steve
JohnG28
Welcome,  you surely meant seconds, right?  ???
Wchafee
when you get old your mind will go bad too.
the time for stock should be 8.5 sec
Gaffney SC
trapper
Quote from: Wchafee on May 13, 2014, 08:33:00 PM
be careful there that is my and majicmans age also. ;D
petefrom bearswamp
Would a similar mod work on my cs600P?
where are the holes drilled?
Pete
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
LeeB
Quote from: trapper on May 11, 2014, 07:17:51 PM
Not if you were using it like a handsaw.  :D :D
