Echo CS-440 muffler removal
Started by Ga Mtn Man, May 17, 2015, 01:07:34 PM
Ga Mtn Man
Can anyone tell me how to remove the muffler on an Echo CS-440?  The bolts/nuts are buried 3" down a shaft in the muffler and I can't tell what they are.
ladylake
 Just sent you a PM,  4 mm, make sure to use a good quality allen, nothing worse than stripped screws.   Steve
Ga Mtn Man
Thanks Steve.  All I have is some low-quality allen wrenches.  I guess a trip to HD is in order :-\.
Mt. Man, what helps is to dip the end of the allen wrench in valve grinding compound and be sure its bottomed out in the bolt head. The grits give it a good grip on the bolt head. Frank C.
4x4American
Sounds like a good trick, Frank C.
Heat usually helps things move...so if you're having a hard time try getting it hot.
Boy, back in my day..
SlimJim
Hey Mtn Man -
Try these will last a lifetime-
http://wihatools.com/
spray some penetrating oil into the tubes let sit for 20 minutes, then remove.
