Another what is it?....
Started by IMERC, October 04, 2018, 04:08:48 AM
IMERC
Does anybuddy know what this is?..
these two pictures is all I have..
Who ever invented work didn't know how to fish.... Here fishy fishy....
Hilltop366
maple flats
Maybe for making holes in heavy leather in order to stitch it.
terrifictimbersllc
Could it be for making holes in heavy leather? Harnesses?  Drill a hole with the gimlet and make it bigger with the pointed punch.
That is a shop woodworking tool.  The leather case is for storage and not for wearing.
I am guessing but it could have been used in the 1800's for drilling holes for hand whittled dowels that were driven through mortise & tendon joints.  I am curious as to what the knurled brass knob held?
Here is an old fireplace piece that I used at the Cabin.
During the "destruction" portion of the rebuild.
The 16" mortise & tendon joints were secured with dowels.
Finished.
moodnacreek
It looks you would screw it in a tree and then attach a ground wire !
lxskllr
Looks hard to use. That's a big weighted offset handle for such a small drill. Looks like it would be hard to keep straight.
Peter Drouin
I'm in the leather bunch. :D :D
A&P saw Mill LLC.
License NH softwood grader.
JV
Are there any makers marks on the tool?  The brass nut suggests that something else attached to it or it attached to another piece.  The leather case to me indicates that it was possibly also used outside of a shop.  I collect antique tools and haven't seen anything like it.  It definitely is a curiosity.  I'll have to dig through some books.
John
'05 Wood-mizer LT40HDG28-RA, Lucas 613 Swing Mill, Stihl 170, 260 Pro, 660, 084 w/56" Alaskan Mill, 041 w/Lewis Winch, Case 970 w/Farmi Winch, Case 850 Crawler Loader, Case 90XT Skidloader, Logrite tools
Resonator
Maybe an antique combination corkscrew and ice pick?
I am on my phone and can't do a link but Google "gimlet tool".
Hilltop366
For getting a sample of something in wooden barrel.
Drill a tapered hole with the gimlet, temporary plug with the pointy end after the sample has been taken then tap in a plug with the hammer end. ??
IMERC
WOW!
what a fine batch of responses.
thanks...
Quote from: Magicman on October 04, 2018, 09:14:19 AMam guessing but it could have been used in the 1800's for drilling holes for hand whittled dowels that were driven through mortise & tendon joints. I am curious as to what the knurled brass knob held?
this is what I thought...
the take a sample makes sense...
in a different direction ... Cannoneer's  Touch-hole cleaning tool?
what ever it is I can't find an answer...
IMERC
Quote from: JV on October 04, 2018, 09:05:10 PM1... Are there any makers marks on the tool?
2...The brass nut suggests that something else attached to it or it attached to another piece.
3...The leather case to me indicates that it was possibly also used outside of a shop.
1... no..
2... lock for the gimlet?..
3... Maybe the owner did the case independent of the tool...
thanks for looking guys..
low_48
I'm thinking early multi-tool. Pick, gimlet for drilling holes, maybe hammer head, and then possible way to mount other tools with the brass nut and slot?
Don P
I was thinking line holder. Gimlet a small hole, stick in the pick and then tie a line under the knurled nut, but make no sense compared to a nail. The end with the nut looks mushroomed from being used as a hammer. Not a clue.
btulloh
It's for starting holes in Unicorn horns.
I hope we find out what it's for.  It's an interesting tool.  I haven't been able to dig anything up that looks like it.
HM126
sharp edge
I'm thinking along the lines of a tool used to splice wire rope.
SE
The stroke of a pen is mighter than the stroke of a sword, but we like pictures.
91' escort powered A-14 belsaw, JD 350-c cat with jamer and dray, 12" powermatic planer
JV
I'm not having any luck so far.  I'm wondering if it isn't a one off user made tool.  The tip of the "handle" looks larger than the gimlet.  The tip could be a punch but could be used as a pivot point for something attached to the tool.  Or it could be an old punch used to make the tool.  Definite head scratcher.
John
IMERC
