POISON IVY
Started by Tom Posch, December 12, 2018, 04:13:29 PM
Tom Posch
I brought some logs into the yard today from a job.  Some have a green vine on them that I suspect is poison ivy.  I get that stuff bad!!  I can't leave the viney stuff behind because the tree guy did me a favor saving the stalks for me.  Is there a way to get rid of the PI?  I know it will get me handling it either on the mill or if I were to process it as firewood.
slider
I would rather deal with it green before you saw. It can stay dormant for 4 years. If it is dead and you saw it will get you. Been there.
al glenn
Mad Professor
I get that stuff real easy/bad
I'd try to I.D. the vine for sure.  Got pictures?
The Ivy vines I've seen have not been green unless they were very small/end of vines.  The large vines climbing trees, look woody and can appear "hairy" with tiny rootlets that work into the trees bark.
Firewood might be the worse thing to use the wood for because if there is any of the plant that gets burnt the smoke is highly toxic to those allergic.
Trees on my property that have climbing PI gets the vines cut and the re-sprouts sprayed with glyphosphate.  I stay away from those trees for years until any residual of the Ivy has rotted away.
Brad_bb
If you're in NJ, it's dormant now and less hazardous than in the spring and summer.  I just put on my gloves and pull it off the logs and put in in the dumpster.  If you don't have that you may need to have a garbage can with a contractors bag to put it in.  I put it in the construction dumpster because I don't want to burn it with the rest of the bark and sawdust, and I don't want to leave it on site.
Don't let it touch anything but your gloves, and then treat your gloves as if they are contaminate and do not touch the outside of them with bare hands and do not touch yourself or your clothes when wearing them.  I thought I was immune, but broke out on my forearms two summers ago.  When I was doing firewood and picking up rounds from Ivy that was on the ground.  Pulling dormant or dead ivy off of logs has not caused any break out with me.  Sometimes the mature vines will break off and stay attached to bark.  Use your spud and remove the bark and dispose of it that way when needed.
Prednisone is what the dermatologist prescribed for my outbreak.  It will help suppress your response to it.  I kept the left over in case I got it again, but haven't.
barbender
I'm thankful we don't get the vining ivy up here, it's bad enough right on the ground👎
Mad Professor
This might help to I.D. the vine
https://www.poison-ivy.org/identify-poison-ivy-poison-oak
You could also check out the site the wood came from and look for any signs of plants there.
As mentioned if you handle it don't touch yourself.  As soon as possible wash with cold water (does not open skin pores) and detergent to remove the oils.  Wash any clothing separate w/plenty of detergent.
AND MOST IMPORTANT, do not go to the bathroom without washing your hands thoroughly first.
btulloh
Quote from: Mad Professor on December 12, 2018, 06:07:23 PMAND MOST IMPORTANT, do not go to the bathroom without washing your hands thoroughly first.
And then some.
If it's got green leaves this time of year it's probably NOT poison ivy.  They would have turned red and yellow and been off a couple months ago.  It's quite spectacular in the fall.  If you've got green leaves now, it may be regular ol' english ivy.  The leaves are substantially different that poison ivy.
HM126
terrifictimbersllc
Yes pull it off first best you can.  sawing it is an invitation to 5 levels of misery.  :'( :'( :'( :'(
I sawed ash covered with PI with a cardiologist once.  He was out of work for a week.  His wife tried to tell me about everywhere he had it :o :o :o but it was TMI for me.
Old Greenhorn
much better to pull or cut (with a hand ax) the vines off the sticks before cutting with either the mill or a chainsaw. I get it pretty good too and I whacked a vine with my chainsaw last spring (saw it too late) and it weaponized the sap so that it hit me between the cuff of my glove and the end of my shirt sleeve  on both arms. Use gloves, clean all tools and get rid of that stuff in a safe manner. Mill the sticks with the same caution and shower immediately afterward, just in case. It's miserable.
Mad Professor
Quote from: Brad_bb on December 12, 2018, 05:52:27 PM
Brad, it is still potent in winter but less so than summer.  Beware!
The first time I contracted it, was as a 7 year old with my cousin.  We found a wonderful little stream full of native brook trout.  Water was low and they were spooky.  In t-shirts and shorts, we crawled up to dip some worms, right through a patch of PI.  We got some nice little trout, but also learned about PI.......
Here is a monster vine in winter:
DelawhereJoe
In the words of Jeff "Don't touch nothing hairy", I het the stuff bad too, I kill it whenever I find it growing witha mix of 3 things roundup, 2,4-D and brush-b-gone.
Southside
Pick up some Tecnu, it is a scrub that you use to remove the oil from your skin and it works wonders.  I keep a bottle in the truck because we actually have vines larger than the one in the picture there, and I have seen them flow sap like a garden hose after being cut.
Tecnu
White Oak Meadows
doc henderson
I agree with all so far.  It is the oil that causes the skin reaction sort of a contact dermatitis.  I have never seen the respiratory stuff from burning.  If you can provide a barrier from the skin, you can prevent it.  There is a topical lotion applied pre-exposure that I have never tried.  I have bought the cattle exam gloves at tractor supply, and put real gloves over the fingers to pull it.  If you know you have gotten into it, you have about 15 minutes to wash with soap and water and may not get the reaction.  It shows up first in a day or two in the highest oil exposed areas.  It can remain on boots and gloves, but should be gone if you wash your clothes the usual way.  It may appear to be spreading since more areas next to the original area show up days later.  It is not from scratching, but the lesser exposed areas.  Topical over the counter steroid creams can help, but often the area is much larger than originally expected.  Prednisone works well and that way stops the entire reaction or lessons it sooner.  I have a landscaping buddy, and he gets 100 pills every year or so.  If you put it in a firewood pile, it may be the gift that keeps on giving. bon_fire
maple flats
I second the Tecnu. I used to get PI real bad, but since starting to use Tecnu I either don't get it or very little. If I do get it I just scrub again using Tecnu and COLD water.
I used to buy it from Ben Meadows, likely Forestry Supply has it. If they offer more than one, I use the one that comes in a tube. When I use it I wash, rinse with cold water, and repeat 2 more times. That stuff is better than gold when you need it.
florida
You don't need to spend money on Tecnu. Any spirit will remove it, turps, mineral spirits, even gas,  just like any other sap. As long as you clean up within 4 or 5 hours of contact it won't bother you.
General contractor and carpenter for 50 years.
Retired now!
barbender
I disagree on your time frame, florida. I've brushed ivy when picking wild asparagus. I was fully aware that a leaf barely touched my wrist, and kept that area isolated until I got home so I wouldn't spread the oil. Within an hour of touching it I had a streak of blisters where that leaf touched me. I have to get it off immediately or I'm in trouble. I don't want to wade into TMI territory, I will just say I don't have a part that hasn't had poison ivy on it😳 IMO, the most miserable area to have it on is your face. Facial skin seems to respond to it differently. It swells more and gets really leathery. Miserable stuff👎
trapper
Woodpecker52
Its the vine with red rootlets sticking out  of the main vine  usually grabbing tree bark.  My dad would take a bit of leaf in the spring and put in in some bread and eat it, claimed a Choctaw indian  in the 1930's would do it and said it would prevent you from breaking out, fact is he never got the itch from pulling the stuff out etc.  I would never do it, he also would pick up any snake he saw except the viper type,  he was a Methodist preacher and one day he looked down from the pulpit and saw a garder snake on the floor, he just kept on preaching walked over and picked it up and dropped in out of the nearby open window, he turned around and saw about half of the congregation  headed out the back door.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Southside
A friend of mine took his then girlfriend - now wife, and very soon to be mother of his child - out on a date one time and they ended up in the woods.  He is one of those who is not allergic to poison ivy, she however is blonde, very fair skinned, and EXTREMELY allergic to the stuff.  Suffice to say she ended up in the hospital and he had some serious 'splanin to do to her daddy given the location of some of the rash.    :o
White Oak Meadows
barbender
florida
barbender- Sounds like you may be more sensitive than a lot of people. I don't have any issues with it as long as I remember to clean up. I usually use mineral spirits and it takes it right off. We also have an invasive exotic down here called "Brazilian pepper" which has a sap that causes many people to break out. Also, a common mango has sap that causes the unwary to break out around their mouths.
Retired now!
Tom Posch
doc henderson
Well southside logger, I'm hoping the progression from girlfriend, wife and soon to be mother of his children occurred over several years but the mention of a "daddy made me wonder if this all happened last week!!!  lol
doc henderson
Tom.  hard to see the leaves well but that does not look look the poison ivy we have around here.  You might google some close up pics of the leaves and or send a close up picture of your stuff.  I agree with an earlier post, if it is still green and just recently harvested, depending on where you live, prob. not PI.  should be 3 separate leaves attached at the same point.  There are some phone apps to help ID leaves of various trees and plants.  maybe more of an ivy that stays green all year.
doc henderson
final thought, make sure the leaves are all the same, might be both.  Although, PI leaves should have been brown by now
