WM DH4000 kiln
Started by customsawyer, June 24, 2016, 03:40:18 AM
customsawyer
I have a opportunity to get a DH4000 kiln that is still new and in the crate. The problem is that the crate hasn't been taken very good care of. Even the control box looks like it has seen some weather at times and one of the fan motors is missing. I don't see any vents in the crate either. What are the chances this unit will still work.
www.thecustomsawyer.com
Raider Bill
Offer them $300 and take your chances. materhead
The First 70 years of childhood is always the hardest.
scsmith42
Jake, The main kiln unit is self contained and designed for a humid environment, so it should be ok. The controller though, is a different story.
My 4000's controller has two delicate plc's that cost over 500 bucks each to replace. I would offer $500 - 750 so that you have room for the missing pieces and potential replacement components needed.
Tom's 3638D Baker band mill
OneWithWood
What brand of controller is it?
One With Wood
GeneWengert-WoodDoc
The compressor should be run every six months to help keep the seals lubricated.  A major replacement might be needed, so the price of $500 seems reasonable to minimize your risk.
