20in bar for husqvarna 240
Started by scotty84, July 20, 2014, 08:11:50 PM
scotty84
Hi can anyone help; I am after a 20 inch bar for a husqvarna 240. I understand that it is only a small saw with small clutch but I am cutting some posts and rails with a mill attachment I have made and lose 3 1/2 inches when it's on the mill. So I wouldn't be loading the chain up fully I just need a bit more length. Any help would be appreciated.
Cheers, Scotty.
ladylake
 You can sure run it  but it will be slow going when you close to the max.  If you have quite a bit to saw it's a lot cheaper the hire a band saw or buy a small band mill as it's real hard on a saw milling lumber.   Steve
scotty84
Yea it is very steady going but I'm in no rush haha. Do you know of a bar that will fit the 240e? That's what I'm after. The part number or where I can get one online? Cheers Scotty
scotty84,I'm no help. But I do want to welcome you to the forum.
SawTroll
What you are looking for is a 20" bar with the A041 mount pattern in 3/8" lo-pro. I am not really sure that exists, but it likely does?
Be aware that 3/8" lo-pro bars usually are an inch or two shorter than "called".
Anyway, my advice is to not do this - if you want to mill you need a considerably larger and better quality saw. The 240e is just a cheaply made Poulan product, not made for work like this at all......
Information collector.
Grandedog
     Howdy,
   GB makes those 20" bars in a replaceable sprocket nose at a good price. It's a PO20-50WR .
Regards
Gregg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
