Killing insects
Started by peter nap, January 31, 2008, 06:29:21 AM
peter nap
I'm getting a stack of logs that were taken down for a power easement. They've been stacked for about a month. I'll get the bark off of them as soon as I get them here. I plan on using them whole in the building and am concerned about insects.
Is there a homebrew concoction I can treat them with in case there is any sign of insects...hopefully one that won't change the color. These are all pine.
Texas Ranger
Bark insects will not be a problem, wood borers will, and there is little to do to the logs before you cut them that will be effective and practical.  Heat is the best treatment.
sleepy
Getting the bark off before spring is the key. The beetle larva can't survive with out the bark to protect them.
"I would rather try and fail than to never have tried at all"
M Williams
Hey Don !! Fancy meeting You here ;D
Wish You had bought land a bit closer so we could team up on some of these projects.
peter nap
QuoteHey Don !! Fancy meeting You here Grin
I'll be darned......Hello Mark! 8)
zopi
It's a small world...but I wouldn't want to paint it..
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
beetle
try this:
65% water.
20% Borax.
15% Boric acid.
Heat the above slightly to dissolve, this will give you the maximum solubility of borates in water.
Too many hobbies...not enough time.
