Author Topic: Another one saved from the scrap heap  (Read 852 times)
Offline mad murdock
« on: June 21, 2015, 10:33:38 AM »
a scrapper that comes around our work a few weeks back had a "later" model Homelite XL12 in his truck with a broken starter recoil. The saw looked little used. He said grab it if you want it, so yesterday i got around to checking it out. Minor cleaning and a recoil spring and rope are needed.  I swapped a side cover from another XL I had to see if it was worth it. Compression was 135 cold as received. Bar and chain appear almost new. It ias an Oregon chain 72LGX "like". The rakers have a bent over "top" type of safety feature, never seen that before. I put an o ring on the oiler pump. It cuts good after a minor tweak on the carb adjustments. Stsrts by 2-3 pull every time. I will get a few pics up later today.
JD AMT 626, Turbosawmill M6 Warrior Ultra liteweight, Granberg Alaskan III, lots of saws-gas powered and human powered :D
Offline mad murdock
Re: Another one saved from the scrap heap
« Reply #1 on: June 21, 2015, 11:05:41 PM »
As promised,
Offline mad murdock
« Reply #2 on: June 21, 2015, 11:07:53 PM »
This pic shows the anti-kickback feature on the depth gauges.  Never used a chain like this before.  I filed it and it appeared as though it was a brand new chain, never been filed.  The things people throw away. ;D
Offline kellysguy
« Reply #3 on: June 22, 2015, 02:02:18 AM »
Threw away cause he cut up hid old lady with it. :D
Offline fossil
« Reply #4 on: June 22, 2015, 11:53:28 AM »
That's an Oregon Vanguard chain. Very common on homeowner 3/8" pitch saws
Tim
Offline mad murdock
« Reply #5 on: June 22, 2015, 03:23:18 PM »
I figured it was some Joe weekend woodcutter anti-kickback device from yore.  I will use the chain as it came with the saw, but if I don't sell the saw, I will put regular 72LG or something on it.
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #6 on: June 22, 2015, 05:00:44 PM »
The XL-12 Homelite had to be one of the best saws ever made. I got my first one in 1964. I was cutting swamp Spruce with a C-9 Homelite, it weighted 10 lbs more then the XL-12.
Offline HolmenTree
« Reply #7 on: June 22, 2015, 07:37:42 PM »
There's  nothing wrong with that Vanguard chain. Best smooth bore cutting chain out there. Also the wide top depth gauge is very precise keeping the .025 setting throughout a log
without over biting in rotted wood when going into solid wood.
Fastest  smoothest  ANSI rated green chisel chain out there. ;)
Offline mad murdock
« Reply #8 on: June 22, 2015, 10:50:17 PM »
Thanks for the endorsement HT. i am going to use it. It does cut fine I like it better than the safety link chain. LJ48, I would put the old Homelite XL up there with the Mac 10-10. They were mainstays for literally decades!  Still good saws today, IMO.
Saving a tractor from the scrap heap
Started by Modat22 on General Board
Last post July 16, 2008, 10:16:59 PM
by lmbeachy
saved from scrap metal
Started by weisyboy on Sawmills and Milling
Last post February 09, 2011, 04:51:47 AM
by weisyboy
Another couple saved from the scrap pile
Started by bushmechanic on Forestry and Logging
Last post August 02, 2015, 06:10:58 PM
by jocco
How the FF saved...
Started by sandhills on FOOD! FOOD! FOOD!
Last post December 25, 2016, 05:34:59 PM
by sandhills
