TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: ETOH Start Problems HomeLite 26b Blower (SOLVED)  (Read 978 times)
Offline zandoval
« on: July 05, 2015, 04:58:42 PM »
My neighbor gave me his old HomeLite 26b leaf blower because it was having such a hard time starting and then keeping running during use. I took it in with thanks and have kept it running (barely) over the past few years but this year no luck. So I took it apart and cleaned the carb and then checked the magneto and replaced the plug. Also did the flush and dry out trick as a final step. Still it would not start. After judiciously reading the posts on this forum about ETOH and carb settings I was brave enough to go for those H & L screws. Of course had to cut a grove in them with a hack saw blade and hen turned them clock wise till closed then back out about two turns then WOW... A POP...
After a few more adjustments all is OK now and looking closely I can see I now have the L screw turned only about 1/2 turn richer than before...
I remember as a kid working with my little .049 model airplane engines this old guy (probably my age) showing us that with old small engines adjustments could be just a hair of a turn before ya get it right then... POP...
THANKS
No matter where you're at... There you are...
Think its time to start the blower.
Started by woodhaven on Sawmills and Milling
Last post August 17, 2003, 06:38:45 PM
by Jeff
My problems are solved
Started by oldsaw-addict on Chainsaws
Last post February 01, 2004, 07:55:30 PM
by oldsaw-addict
homelite 990g recoil problems
Started by dwrenched on Chainsaws
Last post August 25, 2014, 03:21:13 PM
by Grandedog
Mill Won't Start- Solved!
Started by davemartin88 on Sawmills and Milling
Last post August 08, 2010, 10:03:41 PM
by pnyberg
