Author Topic: Echo 590 Brake  (Read 1226 times)
Offline luvmexfood
Echo 590 Brake
« on: July 11, 2015, 11:07:14 AM »
My 590 to a hard lick this morning. Don't even want to go into what happened. Bent bar. Brand new handle broke. Anyway saw runs and either the brake is stuck on or clutch is locked up. Think it is the brake. Anything going to jump out if I take it apart to check into it. Springs etc.
Give me a new saw chain and I can find you a rock in a heartbeat.
Offline dougand3
Re: Echo 590 Brake
« Reply #1 on: July 11, 2015, 12:11:58 PM »
Pull brake handle back (if possible) before removing clutch cover. Most clutches have 2 springs - if damaged, you need new ones or a whole clutch. Clutch drum may be damaged, too. I doubt springs will fly out but stay behind clutch cover anyway.
Husky: 272xp, 365, 261, 61, 55 (x3)
Stihl: 036, 026, 011AVT
Poulan: 4218, 2000
Offline luvmexfood
Re: Echo 590 Brake
« Reply #2 on: July 11, 2015, 03:51:44 PM »
Took the brake off. Saw runs fine with no visible wobble in the clutch. Here's what is happening. When installing the brake band it is real tight around the clutch housing. I'm at a loss. Wonder if the steel piece that all the brake, bar bolts etc. mount on could have gotten warped?
So far looking at a new bar, brake handle, front handle, possibly a new coil spring that works the brake and don't know what else. Can see a slight bend in the housing that the coil spring mounts in but it just holds the spring so shouldn't be a problem. Oh an an air filter buts that is not because of accident.
Guess I will have to take it to a shop. That's what happens when your mind is not 100% on what your doing as it should be when falling.
Offline dougand3
Re: Echo 590 Brake
« Reply #3 on: July 11, 2015, 04:59:22 PM »
If the brake band is tight and not engaged....something is making it's effective diameter smaller. Some piece bent between brake band and handle - ie: brake connector or one of the springs. The shop will probably say you need a whole new clutch cover/brake assy. Maybe the handle is salvageable. Since it's non functioning now, might as well take brake assy apart and look. You can easily find an IPL: goggle Echo CS-590 IPL. See what part looks wrong.
Poulan: 4218, 2000
i just cant get a brake
Started by coxy on General Board
Last post May 08, 2014, 01:22:26 PM
by sandhills
664 brake question
Started by cutter88 on Forestry and Logging
Last post November 17, 2012, 07:59:13 PM
by tlandrum
timberjack brake
Started by EricR on Forestry and Logging
Last post December 19, 2018, 07:00:33 PM
by mike_belben
Brake Broke
Started by paul case on Sawmills and Milling
Last post May 26, 2017, 02:24:02 AM
by Kbeitz
