Timber frame Shop Question
Started by Hans1, June 03, 2007, 08:54:16 PM
Hans1
I am planning to build a timber frame shop I would like to know what width I could go and still have a vaulted ceiling until the collar tie.I plan to use 6x8" red pine beams on 10' centers. this will be located in southern Iowa so snow load and code are not a problem.Thanks Steve
Don P
We must need a picture  :).
Collar ties should be ceiling joists at the plate level if possible. As you raise the tie the stresses rise fast. If you can design a ridgebeam to support the rafters, basically the rafters hanging from the ridge, then you can raise or eliminate the rafter ties.
