solubor- southern california?
Started by freckles, August 06, 2013, 04:38:23 PM
freckles
Hi!  I am new to the site, I stumbled here while researching about timbor---> solubor.
same stuff for 1/2 the cost.  I'm sold but can't seem to find it locally (los angeles) :(
I have looked up farm suppliers, ag chemical, fertilizer chemical and can't find anything. I called up the borax company and their distributors (2) on the western states have never carried but may be able to special order.
Any ideas?  I may just have to order timbor- 2x the cost but free shipping.
I want to treat crawlspace with solubor and glycol mix.
Thanks in advance :)
freckles
decided to purchase the borax and boric acid instead of trying to find a solubor source.  i put an order today.
i want to make the "bora-care" mix-  what kind of antifreeze?  the one readily available is propylene glycol?  are all antifreeze/coolants the same?  some are really cheap.
PineNut
I use a Bora-care equivalent as described in the attached link. When using the glycol the timber stays damp longer and it appears that the chemicals infuse into the wood better. The Tim-bor equivalent does not have the glycol and the timber will dry out quickly and there are crystals on the surface which don't do you any good. I flow the dilute solution over the lumber and dilute at about 1:4. Also with glycol, I do not have any problem with crystals forming in the solutions.
http://alsnetbiz.com/homeimprovement/homemade.html
