Names for metal pegs
Started by trouts2, August 04, 2018, 08:31:16 PM
trouts2
   What are the various names for metal pegs used in testing joints or temporarily holding joints together?  I have seen T types but there was one that seemed even better.  It had a sort of flag at the side of the top end of the thick end of the peg.  I assumed the bottom part of the flag was for banging on to get the peg out.  I saw this type a week ago and the name was given.  I since decided I wanted to get some but forgot the name(s) and could not find the name(s) after googling around for an hour last night.
Dave Shepard
I've heard them called drift pins and podgers. The style you are talking about are blacksmith made.
Brad_bb
Podgers.
I made a set of 25.  I had them copper then Nickel plated.  They look nice.  I plated them because if you don't, they will rust and I don't want to deal with that.  I need to take a pic.  I didn't build the carrying boxes/totes for them yet.
Jim_Rogers
I call them "test pins" and the ones with holes through them are easier to store. You take a second one and put it through the hole of the first one in the timber peg hole and it make a "T" handle and you can pull or tap it out.
The ones I have are tapered so that they can be used for 3/4" holes or 1" holes.
Jack Sobon suggested that the large diameter of the big end should be 15/16 of an inch. That what I have.
Jim Rogers
trouts2
Davd Shepard,  That's it, podgers.  .  Thanks.  After seeing them and thinking about their usefulness I tried to find them again.   I could not remember  if they were at a sales site or not.  I could not find them again and you are probably right, that they are blacksmith made.
Brad_BB, nice clutch of pins.  I doubt I'll ever use a pin larger than ¾".   I think I would like to test pin things together on the ground.  Having a 20 inch pin is pretty long.  I'd have get the beams off the ground for that.  I'm work alone.  I thing a shorter pin I think would be more suitable for me.  There's a small machine shop close by that will do small requests.   I'll see what he can do for a pin.
Jim_Rogers, I looked at your web site and did not see any.  Did you give up on the idea of stocking them? If those were McMaster then they are pretty long also.  I think 15" for the ¾ pin.
Brad_bb
If you see the taper goes down to 1/4 inch...I think I shortened them and a can't remember the final length.  I didn't need them to go that small.  I'm not where they are right now.  When I first finished them and had a timberframe crew onsite, they used them and wanted to buy some from me.  I just gave them some. Enough to do about one bent. I think I have 25 left.  Theirs weren't nickel plated though, just raw steel.
Jim_Rogers
In the for sale section of this forum is our tools for sale list. In the miscellaneous section you'll see "test pins" listed. I have some here on hand.
Jim Rogers
Ljohnsaw
Brad/Jim,
Plating is nice but would Stainless Steel work or would it be too soft?  Aluminum would be much easier to fabricate but I think that would be way too soft/weak and likely stain the wood like it does my hands.  But AL would be so much lighter to carry around!
Dave Shepard
SS would be great, other than its tougher to forge and machine. Al wouldn't hold up well.
