Autoclutch gearbox
Started by HousewrightVA, April 22, 2018, 01:28:32 PM
HousewrightVA
So at 185 hrs the gears inside my autoclutch gearbox have broken.Seems an unusual situation.Any one else had this problem?
skidsteer logger
Case 1840  440  580B
2016 LT40 Super
POSTON WIDEHEAD
I'm not there nor have I seen your auto clutch.
So don't holler at me.. :D :D :D
Why do you thing its the gears that have gone bad?
If something has broken can you post a pic.
Several things could be going on that makes the auto clutch not work.
Thanks.
MartyParsons
Hello,
  have not seen this in some time. They failed about 4 years ago, they were making the belt tight at the factory. If you have your belt tight it may have caused the issue. The belt works fine loose and no more gear box issues.
It would be cover under warranty for 2 years.
M
HousewrightVA
skidsteer logger
Case 1840  440  580B
2016 LT40 Super
HousewrightVA
Problem fixed !
New gearbox installed today.
Thanks PA Woodmizer, you guys are the best.
skidsteer logger
Case 1840  440  580B
2016 LT40 Super
