wanting to purchase a tj 225a skidder
Started by axesmasher, January 05, 2014, 10:24:46 PM
axesmasher
ok so this is my first ever post!  8) on any forum actually hah i grew up cutting firewood on our property and have been driving a skidsteer and john deere 6410 and a john deere 955 since i can remember i learned a whole lot of respect for machinery chainsaws and axes   ( the axes took a wile  when i was a kid i broke a few axe handles splitting wood) i have been a mechanic for about 5 years and did my first engine re & re at 16 years old, yes i may be young and i have made some mistakes  but hey  live an learn   im looking at buying a skidder and i found one for my budget i think just off the top of my head would any of you consider putting a 453t in a 225a tj?  because i can get one from the wreckers down the road from me for almost scrap value
the good: found a 74 tj225a on kijiji for 3000$ he is willing to sell me a set of ring chains, he has changed all the fluids in it minus the engine oil (below will explain why) the guy is willing to deliver it to my farm in Huntsville
the bad: the Detroit 353 has a big hole in the side of it
the ugly: the front tires are worn and there is not a speck of paint left on the *DanG thing
oh one other thing  :new_year: y'all
Better to understand a little than to misunderstand a lot.
axesmasher,welcome to the forum. I broke a few maul handles off,much to my Father dismay.
clww
Many Stihl Saws-16"-60"
18-Wheeler Driver
Neilo
If it is a 1974 year, it is not a A series. At that age it should be a D series. A photo will help us with the age of the machine.
I don't think a 453 will fit in the frame of a 225, the frame is probably too short. If it does, it will require sergery to the hydraulic pump linkage and probably move the transmission back.
Maine logger88
Welcome to the forum! If its a 74 its not an A series the A's didn't come out till the 80's as far as a 453t you would have to do some fab work to make it fit and it would be a lot of power for a 225 almost double the power of the stock motor
Maine logger88
Oops I guess neilo already said about the same thing
mad murdock
Welcome to the Forestry Forum axesmasher!  I would look for another 353, or another similar sized industrial diesel, and then if you have the $$ the tools/skills and the time, go for it!  You will have a machine that you will know a lot about, so you will be able to operate it for years to come and maintain it yourself for the most part. The old machines are still well worth the effort, they don't build them Like they use to!
Glenn
Axesmasher - you need to come to the east side of Algonquin.  There are a few timberjacks for sale here in decent running shape.  I know of one old 225 that has been completely overhauled for sale and several average condition machines.
Maine372
your motor issue has been addressed. so ill skip that.
tires, as long as they hold air run them. the chains will give you all the grip you need. if the tire is slipping inside the chain, run a short peice of chain from each side of the chain to a bolt through the wheel.
and paint is a luxury, youll just feel bad when you put a scratch on it anyways.
axesmasher
WOW WOW WOW  ;D I was not expecting this much attention   thanks to all that posted  i got talking to a guy from work today and he said hes seen a quick fix he said if i put a new piston and connecting rod in it and re sleeve the cylinder i could drill holes around the hole and tap them, then bend up a piece of like 1/4 inch plate and seal it up  it would at least hold coolant again and work for a wile   to me this seems a little sketchy  but hey ive seen some pretty darn cool ingenuity from some guys who have been in the trade for 30 odd years what do y'all think?  of course i would be looking for a new engine though it would just be a temp fix    on that thought   could i fit a deutz fit in it?  because where i am a lot of the marsh farmers have deutz powered equipment that i could probably score for a reasonable price thanks again for the welcoming
axesmasher
as for the "A" "D" model designation letter  ...sorry about that should have been paying a little more attention  ::)  the guy who is selling it told me it has rockwell axles i hope he is true i guess the only other axles they came with were the eaton ones? ill try to get pictures of it  i feel like i should list some of my equipment in my sig but since my uncle has retired his stihl fleet  my sig would be a page long   i now have about 10 saws of all different shapes and sizes!  working on getting them all running lol i may  not even need to sharpen a single chain all season HAHAH
Maine logger88
I have heard of people fixing blocks like that with good results i have no personal experience with it tho.Yeh most likely if its a 74 its Rockwell why don't you like the Eaton rears there a lot bigger than the rockwells
bushhog920
buddy made a cover plate for his dozer that had a big hole in the block, drilled and tapped the block with some rtv worked good.
axesmasher
marine logger 88   to be honest i am just more comfortable working on them a buddy of mine on the marsh has an M931a1 AM general (deuce and a ½) military truck and i helped him rebuild all 3 of the axles on it  ive never worked on an eaton   im not bashing eaton by any means its just that if ever something was to happen in the bush on a -35 degree day id like to be in and out as fast as possible
good to hear there is some tested and true evidence of the patch-a-block method  haha i might give it a shot just to get her running then at least i can work with it till i find a new engine
Bobus2003
Fixed a hole in the block of my dads old case skid steer with liquid steel and some chicken wire. Held up fine for a while
Maine logger88
Yeh I was just curious there's nothing wrong with either one. Come to think of it dads 230 with a 353
had a piece of diamond plate welded on the block no idea how they did it but it was on there when he bought it and still there when he sold it so it definitely can be done depending on how bad a hole and where it is in the block
axesmasher
Hahahah what the heck is dis yooper LOL  typo. I sent that on my mac i still dont know how to use it.  I ment    this season.
axesmasher
Disregard my last post. My phone and computer are acting up. Or maybe i need glasses. I defiantly thought i made a typo but on further inspection i did not.      Very weird.
Shotgun
Quote from: axesmasher on January 07, 2014, 07:59:49 PM
You're just not paying attention to your keyboard.      :D
Joined The Forestry Forum 5 days before 9/11.
M_S_S
I have seen blocks welded, think they used NyeRod (not sure if that is the correct spelling) I do now it is used for welding cast. Also have seen them patched. I think a lot would epend on were the piston came out, if it screwed up the water jackets or not. If it didn't you should be able to resleave and patch the hole. ED
2- 562xp 24"bar
         576xp 28"bar
         385xp 28" and 32" bars
         25 ton Speeco
         6600 Ford
         02 Dodge diesel
         73 Ford 250
BargeMonkey
 I know where there is a 353 in a machine, and I know it would go relatively cheap. Listen, ive been down this road, bite the bullet and put a 4bt in it. They have them for 2k-2500 all day long. I had to put a head on my 353, rebuild the blower and check the bottom, cost me almost 5k done by a good mechanic. Just my 2 cents but if I knew she would have gotten a heart transplant and I wouldnt need ear muffs and ear plugs while sitting on a screaming, dripping driptroit.
axesmasher
The patch would be temporary. I would be getting another 353 or similar engine though
axesmasher
Pretty much heartbroken right now my father is completely against geting the skidder.  I dont want to be a sore looser but im upset about it. Oh well. I guess  my dad enjoys colecting firewood and logging the half arsed way    I guess this thread is dead now :(
axesmasher
I was under the impression that this was something you were going to purchase.
Or was that skidder something you were trying to talk "Dad" into buying ??
axesmasher
....... >:(  im not a mooching kid who gets dad to pay the way for everything, no i had 5000% in the bank had arranged the float to pick it up, my dad owns the property and didn't want me "mucking about everywhere for a little wood"  i have bought a used Wallenstein forwarder and made a pto winch for the front of my WHITE 6065 out of a school bus rear end and a reduction box for pulling logs it works ok.
