gasket ?
Started by trapper, October 16, 2018, 09:25:43 AM
trapper
What do I need for gasket material for the door of my central boiler classic?  The temperature is starting to raise too much after the damper closes.  Also what glue?
Ivan49
Does it use rope gasket material. If it does on my Woodmaster I used silicone it 1 inch long strips all around the door and stuck the gasket in that. Do not use a solid bead around the door because when you have to replace it again. a 15 min job becomes a couple of hours and a lot of words of why you did that the first time
buckgrunt
I recommend going to this website for all your OWB parts:   https://www.woodfurnaceworld.com/collections/e-classics-parts
Dave Shepard
It does use rope, about 1" diameter. I have a new rope and sealant from CB somewhere. I'll post particulars when I find them.
trapper
buckgrunt thanks for the link.  Any other tips.  First time changing gasket.  Furnace 15 years old running year around.  Been lucky only 1 small leak so far 2 years ago.
Dave Shepard
I found my gasket, so a picture as promised. That's a quarter on there. This is from CB. I didn't measure the length. Found a spare draft door in the box, too. Bonus!
