Removing sawdust.
Started by Joe Hillmann, August 01, 2014, 01:53:59 PM
Joe Hillmann
I build "Rustic" items out the lumber I mill.  For now I use a wire brush to remove the sawdust that stick to the lumber.  It doesn't do the best job, it leaves quite a bit behind and is slow.
I was thinking of building something like a planer but with a round wire brush where the blades would go.  I am just wondering if such a thing already exists or if anyone here has a better method of removing the sawdust.
Have you tried using a ~12" sheetrock taping knife?
Philbert
Have you tried compressed air?
I blow off boards after sanding, and it clears the dust out of the pores before finishing.  Should work on rough sawn too.
Philbert
dboyt
Wire brush could leave an interesting surface on the wood for a rustic effect.  How about a vacuum cleaner with a rug sweeper attachment?  It would catch the dust.
Wisconsintimber
I've heard of board dedusters before but never seen one in use.
Joe Hillmann
I just did a search for boar deduster (never would have stumbled across that term on my own).  It looks like they are actually a common tool in resaw mills and pallet mills.   It looks as though most of them use nylon brushes rather than wire.
red oaks lumber
if you have the right set and the right pitch blade there should be very little saw dust left behind. also your feed speed might be to slow making finer dust.
Knute
In warm weather, I just use a broom while stacking. When frozen, use a scraper with a wood handle (old baseball bat in my case).
drobertson
de-dusters  are the way to go, nylon brushes, but I have to ask, are you feeding through the log fast enough?
this will leave an abundance of dust when it's not necessary'  just asking.
Chuck White
I have my off-bearer just give the boards a gentle tunk at the end of the mill when he pulls them off, then on jobs where we sticker the lumber, we use a leaf blower!
backwoods sawyer
chuck has about the easiest method and the one we used in the production mill, by the time the lumber made it to the stacker it had been banged around at every step of the way. Garden hose with a good spray nozzels works good as well.
seems like Baker made a nylon sweeper, but an unscrambler will do the same thing.
Guess the question is, How much wood do you plan to clean? and How much time do you want to spend cleaning wood?
Backwoods Custom Milling Inc.
woodyone.john
I seem to be more lazy than most then. I don't do anything just sticker it then let the wind clean it up over the next weeks and months.When I retrieve from stickered stacks its pretty dust free.
Saw millers are just carpenters with bigger bits of wood
Brucer
Quote from: Joe Hillmann on August 01, 2014, 01:53:59 PM
It's called a "wheel brush sander" and Makita makes them. The timber framer I used to saw for used them to clean up the surface of timbers that were to be used "rough sawn". They used the steel wire brush option because it would remove any surface stain, sawdust, and dirt that had got on the surface. The brush would still leave some dust sitting on the surface but it was easy to blow or brush off.
The things were pretty expensive as I recall.
Bruce    LT40HDG28 bandsaw
