n4400 hammer resaw blade
Started by Woodslabs, February 21, 2018, 10:42:32 PM
Woodslabs
Hi All,
I'm looking for a resaw blade form my hammer N4400 bandsaw.  I would like a inch thick.  As for the length and teeth count i'm not sure.  Can someone point me to where i can buy one and what specs are good for a resaw blade?
Thanks in advance!
check out www.woodslabs.ca
Tom King
Lenox Woodmaster CT  1"  1.3tpi       I run one on a 24", but know some can run one on a MM16, so think you should be able to.    I buy from bandsawbladesdirect.com, and the welds have always been perfect.   It will cut as smoothly as a Resaw King on a smaller saw, but about ten times faster.   The carbide teeth last a long time if you only cut wood.
