Regarding Tearout
Started by Glenn1, September 25, 2016, 09:30:34 AM
YellowHammer
Quote from: YellowHammer on October 07, 2016, 10:46:44 PM
Quote from: WDH on October 05, 2016, 08:20:53 PM
I also have the rotocator.
Me too, but mine's a homely homemade rig, with a block of wood and a dial indicator.  No doubt, when setting a planer, thousandths matter
It's also useful when setting the clearances very precisely.  Infeed roller, outfeed roller, in and out feed bed position and parrelelism, cutterhead depth, side to side height, chip breaker side to side and chip breaker depth, etc.  It's a good idea to set go over everything, and reset to factory.  For example, the chip breaker on my planer needed readjustment as the paint wore off, it's only a few thousandths, but it's the difference between purty good and flat as a mirror.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
I am a "flat as a mirror" guy.
