I need some custom signs
Started by Raider Bill, September 01, 2011, 12:37:12 PM
Raider Bill
I wonder what the rules are on a black powder cannon?
Bro. Noble
I imagine the main rule with blackpowder cannons is to be careful ;D
I used to be into blackpowder shooting and the cleanup got to be a real aggrivation.  A friend of mine had a morter that he liked to shoot-----he just hosed it out when he got done shooting :D :D  He use orange juice cans,  punched a hole in the bottom and stuck some cannon fuse through it then poured a little concrete in the bottom making sure that the fuse wasn't covered.  He then put some black powder in the can and capped it off with more concrete.  It worked really well.  It would be interesting determining just how long a fuse you needed and how much powder to use.  I'd want to stand behind a tree until I got everything finetuned ;)
I'm sure that any of your local reinactors would be able to tell you if there are local regulations.  I don't think there are any here.  If I had one, I'd shoot it and not worry about it :)
Quote from: Raider Bill on September 06, 2011, 05:54:47 PM
An LP cannon would be easier to rig up and it just keeps on working.  The soybean farmers use them here to scare away the deer.  They are also used to scare away blackbirds.
Simply, it is just a pilot light burning in one end.  LP is injected through an orifice.  When the mixture reaches about 10% the LP ignites....BOOM, and then the process starts over again.  Here is one:    http://scarecannon.com/
You could put one of those at your place in Florida  :D.
Don_Papenburg
I know where you can have a cast iron barrel made  for the cannon.  make a steel tube the size of the can/casing. turn a wooden pattern . Then ship the whole bunch to John over at CanDo Metals in StAnne Illinois .  Or make up the tube and use one of the patterns that he has .   Email me if you want more info.
A guy down the road has a small cannon, has a 1 inch bore. He shoots if off at times. Sometimes when he had too many beers at 2 in the morning.  ;D  I wake up and tell the wife Bob is at it again and go back to sleep.
Raider Bill
Ok I am in contact with Busy Beaver's signs.
I'm thinking of this,
Warning Danger!
Private Shooting range ahead
Proceed with caution
Trespassers could/will be shot.
Maybe a skull and cross bones.
Any suggestions?
Magicman, I've seen/heard LP cannons when I lived up north. they used them for crows and geese in the corn fields.
Freedom6178
------Freedom6178------
Prepare for the unknown by studying how others in the past have coped with the unforeseeable and the unpredictable.
George S. Patton
'12 Mustang, '03 F-250 SD 4x4, Stihl Farm Boss 18"bar, '09 Arctic Cat 550 TRV EFI
Raider Bill
Remember to add, survivors will be shot again.
I was very happy with the signs I had made for my property. I designed my own at http://www.buildasign.com/
https://forestryforum.com/board/index.php/topic,24810.msg375441.html#msg375441
DouginUtah
Quote from: Raider Bill on September 07, 2011, 12:10:42 PM
Warning Danger!
Private Shooting Range ahead
Trespassers might be
accidentally shot
CYA
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
You want to keep your sign as serious and as official as possible.  Too much language about being shot and the sign will/may be perceived as a joke or ignored.
WH_Conley
I agree with MM. I would just put the first three lines and leave it at that.
Bill
Raider Bill
Quote from: Magicman on September 07, 2011, 02:05:05 PM
Quote from: WH_Conley on September 07, 2011, 02:42:50 PM
I believe you guys are right.
red
Busy Beaver Lumber
Bill
Sent you some artwork to take a look at and comment on.
Fred
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
You might take out "Proceed with Caution" as you do not want them to "proceed" at all.  "Proceed" back the way you came.
Dan_Shade
you could make a sign that the area houses a skunk ranch
lots of dull bands and chains
Raider Bill
Fred from Busy Beaver Lumber made these signs for me, 24X18 less than a week turn around!!!
