industrial leveling feet to level stationary mill
Started by fivedogs, May 17, 2013, 07:39:15 PM
fivedogs
has anyone used  industrial  leveling feet to level  a band mill that uses  angle iron for  track
my set up  now is a hudson 228  mill with 16 feet of track  on a cement pad  with  hemlock  polanks  mounted to  the cement  using  cedar shingles to level the track
would like a more permanent solution  any ideas   cheapest way possible  thanks for any help
                                                          fivedogs
drobertson
fivedogs, glad all I have is two, good ones though, and to answer your question in my view, permanent and less expensive are kinda of a cliché.  I believe an all thread and some welded brackets would work with the proper nuts, thrust washers and anchoring, but how to achive the least expensive way might require some leg work and bargin hunting,  keep searching and it will come,   david
