New Mill!
Started by ncsawyer, February 22, 2015, 10:08:04 PM
ncsawyer
I have been contemplating updating my 94 LT 40 Manual to a new LT 40 Hydraulic for some time.  Will probably place my order in the next week or so. I am almost certain I will go with the 35.9 Yanmar.  It seems like 9 out of 10 jobs I do will have at least one 32+ inch log of some description. What is your experience with this little diesel? Will it handle the .055 blades?  Is it turbo charged?  Is it worth the extra coin over the gas?  I also see on the WM website that the LT40 manual has the 47 HP Yanmar as an option. Why not offer the bigger engine on the hydraulic mill?  It's offered on the super hydraulic as well.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
ncsawyer
I usually keep a check out CL.  Hadn't seen this one yet.  I'll have to give that guy a call. Thanks!
Chuck White
You'll saw a lot more lumber in a days time when you get the hydraulic mill, but mostly you'll feel a lot less aches and pains at the end of the day!  ;)
Finn1903
If your going with a new mill, why not go with a super hydraulic with the 47 hp?  That will pull any band you will likely be using.  You are welcome to take a run up I-40 and check out my mill.
WM LT40HDD47, bunch of saws, tractor, backhoe, and a loving wife.
You will never regret getting the larger Diesel, but you will if you get less.  Neither would you ever regret getting the SuperHydraulic.
terrifictimbersllc
Not seeing that the LT40 Manual has the 47HP diesel option, just 35HP diesel.   Added 47HP option to the super may be marketing or it also may be something else like having a heavier up/down gearbox/chain , heavier alternator etc.  DOn't know the answer, suggest you ask WM.
IMO if you're in business with the machine get the Super and the 47HP, debarker and Lube-Mizer.  These options pay you, not cost you.
ncsawyer
Quote from: Finn1903 on February 23, 2015, 04:18:27 PM
I would love to upgrade to the super hydraulic.  The LT 40 Hydraulic with the diesel and debarker is $33,000 including tax.  The super hydraulic is about $45k.  I just run mine on the weekends and work my day job during the week.  It would take a long time for the increased efficiency of the super hydraulic over the hydraulic to make up the price difference in my situation.
SPD748
All this talk of Super 40's has me skipping over to Woodmizer's site and playing with the 'build it' tool. I wouldn't sell my circle mill for anything but I'd love to have a portable bandsaw to add to the stable. Good luck with your choice and purchase!
-lee
Frick 0 Handset - A continuing project dedicated to my Dad.
410 Deere, 240 Massey... I really need a rough terrain forklift :)
Sawing Since 1-19-2013 @ 3:30 pm
Serving Since 2002
"Some police officers give tickets, some gave all."
ncsawyer
Quote from: terrifictimbersllc on February 23, 2015, 04:32:30 PM
http://woodmizer.com/configurator/model.aspx?item=LT40G26&engine=G26&id=LT40
The build and price app show the larger diesel option on the manual mill.
Finn1903
Quote from: SPD748 on February 23, 2015, 06:44:32 PM
-lee
Lee,
And I would love to have a circular mill for the custom projects where people want to see the circular marks.  To bad we were not neighbors, we would save each other another investment.
prittgers
I'm betting you will LOVE that little Yanmar.  Very smooth operation.  Not too noisy.  Very reliable.
And maybe try some of the new bi-metal blades as an alternative to the .055s.  The Yanmar can certainly handle the thicker blades, though.
Having a sharpener/setter makes running the .055's more economical since a person can run them for 1-1/2 to 2 hours and lightly grind them which removes the gullet cracks.
Parker Rittgers
Professional Sawyer, Retired, well, not really !
WoodMizer Alaska | 907.360.2497 cell 336.5143 office BevelSider.com ? Everything BevelSider
907.336.5143
prittgers@aksamill.com
terrifictimbersllc
Quote from: ncsawyer on February 23, 2015, 06:47:40 PM
Looks like you're right, guess you'd have to ask about the std. hydraulic/47 combination.  But myself I couldn't stand it with one hydraulic pump, done it a few times when a pump was down and slow slow slow.  But  I see where you're coming from with the cost of a new mill & your current situation.
Ga Mtn Man
If you can afford it get the diesel.  I frequently find myself wishing for more power.
FYI, it isn't all that difficult or expensive to add a second pump to a standard LT40HD.  If you add a second pump you will also need to change the alternator to a CS140, change a number of the hydraulic lines, and go to a larger battery (or add a second battery).  Of course adding a second pump doesn't make your mill a real "Super" as you won't have the larger up/down and fwd/rev motors (and any other differences that I may not be aware of ???).
ncsawyer
Most of the time I saw for customers at their place and they provide the help.  When this is the case, the speed of my mill is hardly ever the limiting factor.  It's usually the help. ;D
Buck
NC, keep an eye on the sawmill exchange.  There are some good mills out there on the used market.
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
samandothers
Go see Joe and the folks at Woodmizer in Albemarle! They'll fix ya up!
ncsawyer
Quote from: samandothers on February 25, 2015, 09:21:14 PM
I ordered my new mill this morning!  8) Now time to play the waiting game, should be at Wood-Mizer in Albemarle on March 18th.  I ended up going with the LT-40 Hydraulic with the 35 Yanmar.  Got a sawing job waiting for me as soon as it gets here.  Once I get caught up then I'll get to put it to work on my logs so I can finish my two building projects.
Billikenfan
Awesome.   Did they have to build it or was it in stock.  What options did you get besides the diesel engine.
Scott
2015 Woodmizer LT40  Hydraulic 35hp
Mountain Home Firewood Kiln. Beaver Wood Eater Firewood Processer.  John Deere 260 Skid Steer.
ncsawyer
Quote from: Billikenfan on February 26, 2015, 06:22:27 PM
Scott
They had one scheduled to be shipped in about 3 weeks.  I just got all the standard options plus the debarker.
samandothers
Congratulations that was quick!
ncsawyer
I have a few questions about the options that will be coming standard on my new mill.
My new mill will come with "simple set" and the auto clutch standard.  Of course my old mill had neither of these.  From looking on Wood-Mizer's website it seems that "simple set" only drops the head by a set board thickness and I have to determine where to begin my first cut to insure my last board is the correct thickness.  Is this correct?
Also when cutting with my old mill (without auto clutch) I disengaged the blade at the end of each cut.  It seems that this method of cutting would cause the auto clutch system to wear out prematurely.  I have noticed that in a lot of videos sawyers will leave the blade engaged for multiple cuts and only disengage the blade when turning the log or performing other tasks.  To me this seems like it could present a safety issue and also would increase fuel consumption.  How does Wood-Mizer recommend utilizing the auto clutch system?
Ga Mtn Man
To answer your first question, yes you are correct.
The auto clutch is a fairly simple and robust mechanism and I don't recall ever hearing of anyone wearing one out.  Keeping it engaged or not is a matter of personal preference and you'll hear good arguments for both sides.
You will quickly learn your starting points when sawing various lumber thicknesses.  Developing a cheat sheet is a simple matter.
I disengage the auto clutch at the end of each cut.  Other sawyers may not.
ncsawyer
Thanks for the replies.  My old mill has a sliding quarter scale that makes it real easy to determine where to start your first cut.  I would assume the new mills have the same.
4x4American
Yes it should have a quarter scale on it, which might give you a good idea where to start
Boy, back in my day..
