15 degree cutters
Started by simplicityguy92, March 22, 2011, 12:57:54 AM
simplicityguy92
where are chains filed to 15 degrees used i have only used 30 degree chain because i only cut soft wood
HolmenTree
Frozen wood, especially frozen birch, elm, oak etc. Chainsaw millers can go 15 degrees but usually run 0 -10 degrees. Soft metal cutting such as aluminum cutting with a fullhouse chain [cutters sequence with no gap].
Willard.
gizmodust
Simplicityguy92 are you milling or crosscutting?  When I milled with a chainsaw, I sharpened my chains 7-10.  Crosscutting I sharpen 20-25.  I find this good for my needs as I bounce between pine/poplar and oak/beech.  Just my 0.02 ;D ;)
Always liked wood with alot of character
simplicityguy92
i started fileing my ripping chain to 5degree i was wonder what 15 degree is used for as i dont see much of it
01crewcab
Your square ground chisel chain comes ground at 20 degrees. I believe some guys cut with chisel chain at 15 degrees.
2100(2),480, 281, 181,372XPW, 460,435,350,61(4),51-Huskys
49SP, 630Super(3),670's(4), 830, 920, 930 Jonsered's
S-XL925 Homelite
SP125C, 790, 250, 1010 Macs
27Ton Troybilt Splitter
NRA Life Endowment Member
Viet Nam Vet
tyb525
Personally, I find 15 deg to last longer for crosscutting, although it's a bit slower (I only cut hardwoods).
If you were doing a mix of crosscutting and ripping with the same chain, I suppose 15 would be a good middle ground.
simplicityguy92
for the soft woods i cut i file to about 28degree and i cut fast
gearman
I purchased two loops of Oregon thin ripping chain, from baileys, for a mill and 15dgree was the recommended angle for that chain
NH 55da, 270FEL, Farmi 351P, Husky 51, 359, Jonsered 2065, 2171
Well done is better than well said
