Cutting Burn Wood
Started by rmack, March 16, 2013, 10:58:18 AM
rmack
I was told a long time ago that wood that came from a forest fire was very hard on equipment because of the abrasive nature of the carbon coating on it... is this true?
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
Tree Feller
I've read the same thing from fallers, that the burned bark dulls their chains very quickly...sawing in the black, they call it.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
clww
I've talked with loggers and have been told this, too. The worst was ash deposits left over from Mount Saint Helens doing the clean up on the surrounding forests. One tree felled then sharpen the chain, then repeat.
Many Stihl Saws-16"-60"
18-Wheeler Driver
Peter Drouin
I cut some burnt wood 20' fur
had to resaw from 10x14" to 8x12" , from a old rr bridge that some one set fire, saw just fine
A&P saw Mill LLC.
License NH softwood grader.
fuzzybear
Fire killed is the NASTIEST stuff to cut. You have black ash all over everything and no matter what you do it does not come out. It gets everywhere on you.
  I wore dust masks for the 2 days I cut that nasty stuff. Went through a mask every hour. You do not want to breath that stuff. Cutting without a mask is like putting your head inside your wood stove and trying to breath.
I never met a tree I didn't like!!
Bibbyman
We had a fire get out of control and burned a rack heap.  It scorched an ash about a foot at the base.   I later cut the tree and tried to saw the log.   I quickly decided it'd make better firewood and put it on the pile to go to the Blockbuster.  The Blockbuster struggled to lop off a chunk.  Then it receded to be split.  It ended up on the slab pile.
Sawing since '94
justallan1
I've cut maybe 20 burned trees and found there is a world of difference after the bark is removed and for whatever reason some of the smaller logs are just full of pitch and you just use them for bunks.
The trees that I am cutting were burned only enough to scorch the needles off and burn partly through the bark, so maybe how much they are burned makes a difference. I think my saw goes through these trees easier than WRC telephone poles.
Allan
rmack
thanks, sounds like it's something to stay away from unless it's a small, nice job like resizing some timbers. ;)
Welder Bob
1972 Patrick AR-5
Belsaw Boat Anchor
justallan1
Like Fuzzybear said, it's surely a mess to work with. The way I'm looking at it is it's all free and it's only a couple miles from my house for me so why shouldn't I cut it. There are literally millions of trees to be had right now, so why not. Even if I use extra blades I'm saving on all of the other costs.
Granted, I'm doing this on the side, so I may see things differently.
Allan
rmack
Quote from: justallan1 on March 17, 2013, 08:28:32 AM
Allan
Are those public or private lands?
Welder Bob
1972 Patrick AR-5
Belsaw Boat Anchor
Justallan
You have a good plan to give it a try. I'm thinking you will not find it overly tough on blades or chain, but maybe a bit messy.
It's messy, it's no harder on saw chains and blades. I never heard of it being so. Not that me hearing of it makes a difference, but all I ever heard about was the mess.
ohwc
In my experience running a chainsaw (not a mill) I did not notice a difference in chain wear. However it is definately nasty and dirty. Every refuel and sharpening we would have to knock out the air filters really good.
justallan1
The bit that I've sawn IS a big mess, that was part the reasoning of putting my mill on a trailer and taking it to the trees.
I didn't think it was so bad on my chainsaw, but I touch up my chain pretty often.
Rmack, everything I'll be sawing is from private land.
Allan
tyb525
I don't see why carbon would be harder on blades than the wood itself. Wood is carbon based after all (like all living things). Ash from a volcano might be abrasive though, that stuff is more like a mineral isn't it?
Jemclimber
Diamonds are carbon. Carbon in different forms can be of varying hardness.  Saw them and decide if it's worth it.
lt15
QuoteAsh from a volcano might be abrasive though, that stuff is more like a mineral isn't it?
tyb is right, as the gritty ash from the volcano eruptions is nothing like the carbon powder left after a burn.
Rub some off and roll between your fingers, and I find it is just dirty.
Brucer
I've only sawn a little burnt wood. The biggest problem is that the heat of a fire will harden the wood just beneath the burnt area. The heat can also precipitate minerals out of the sap. Both are hard on blades.
Bruce    LT40HDG28 bandsaw
Minerals in sap are in solution when they move up the tree, the heat of fire doesn't change them. For instance, northern white cedar is hard on blades because of silica, no fire involved. It is conceivable however that if dry wood of a species is hard to saw, it will be hard sawing when dried out by fire. But what really is the difference? Charcoal and black on your clothes?
fuzzybear
Quote from: SwampDonkey on March 19, 2013, 05:39:20 AM
And up your nose, and in your ears, under your cap, and how the heck did it get in my shorts?  and did I mention It does not come out of clothing? It is not only charcoal, but a type of oil also.
  I find it funny that loggers are exposed to doses of this "charcoal" that would have coal miners cringing at the thought, but there is no protection funding from the guberment to protect a loggers lungs like a miners. "go and cut, it will be OK, never mind what it's going to do to your health in the long term" this seems to be the official stance on fire killed logging.
FB
fuzzybear
Who is being forced to cut burned timber?
Curious too where the "official stance" is coming from.
This day in age, no one has to work where they feel unsafe or their health is at risk. For these two reasons you can refuse work.
justallan1
Nowadays working around cattle I find myself digging stuff out of my mouth, nose, eyes and ears that make a little charcoal sound pretty good. Turning wrenches, it's a good day when I get to climb under something in the shop or on a road, the other 90% of the time I'm in a puddle of water, oil or whatever.
I have a resume that says I should be making more money working indoors, but what's the fun in that! ;D
Allan
tyb525
I watched a show about a charcoal making operation, apparently the owner (old guy), exposed to the dust daily, was in the hospital for something and his lungs checked out clean as could be. Of course that's just what they said.
Best suit up before cleaning the flu, the stove pipes and the ashes. ;D
