Another pine flooring thread...
Started by shinnlinger, January 01, 2016, 10:24:23 AM
shinnlinger
As I now look at my floor, and you can see it in the pics, I in fact did center nail the wider boards and they have not split.   A buddy of mine did a similar floor and countersunk screwed his floor down and plugged it.  I haven't been at his place in a bit but I will inquire if he has had any splitting.   A lot more work though IMO.
Shinnlinger
fishfighter
Quote from: Bruno of NH on January 03, 2016, 10:01:22 PM
I use 30lb roofing felt under the wood flooring helps with the creaks  .
Bruno
This is what I'm doing in my camp build in between sub flooring. I will be doing that also for the real floor.
shinnlinger
Today I got to sand a room.
I started with 100 grit but ended up going with 80  Next room I will start with 60 but 80 did leave some texture, which I like.
In the corners I used this little beast.
Shinnlinger
shinnlinger
Every once in a while you have to sink the nails a bit further.  The screws are for this areas where I needed a little more hold.
After running the sander in both directions I was pleased with the results.
So I vacuumed the dust and mixed up some tung oil.  I thinned with it roughly 25% solvent to help it penetrate.
Rolled on the first coat and made it pop!
Shinnlinger
customsawyer
www.thecustomsawyer.com
isawlogs
 I'm a big fan of rustic, really ike your floor!!!
   Marcel
samandothers
Great Job!!
That first coat made a world of difference.
Ox
Quote from: isawlogs on January 10, 2016, 09:28:05 PM
Me too!  I can't see how anybody would want fake, modern flooring.  Also it boggles me how people will carpet over nice hardwood floors.  Ugh.  Thanks again for taking the time to put up the pictures.  I'll be able to show the wife what good old fashioned flooring will look like in our addition.
shinnlinger
I hit the floor with some more tung oil according to this site.  http://www.realmilkpaint.com/products/oils/tung-oil-wood-finishes/#howtouse
I'll let you know how it turns out next weekend when I head back up there...
Shinnlinger
sawmilllawyer
Floors look awesome!!! Great work. That tung oil really makes the floor character stand out.
Stihl MS-361, MS-460 mag, Poulan 2150, 2375 Wildthing.
fishfighter
BUGGUTZ
WOW! Thats gorgeous, I really like it. You do good work. I am also very impressed with the downstairs floor. I like the 45 to break up the distance it looks great!
Everyone has to be somewhere.
cntryby
Grey haired riders didn't get that way from pure luck.
Bruno of NH
Looks great Mr Shinn
I like pine floors they are under rated.
Any rustic wood floor look great .
Lots of old houses in NewEngland with just square edge boards . Old school .
Bruno
nh-dan
Great looking floor, we want to do something like that on our floors. We plan on putting up a post and beam in Canaan in a couple years. Not to hijack the thread, but how was the town when you went for your permit, and how were the inspections?
Thanks Dan
woodmizer lt20D, NewHolland TC23D
nh
Are you thinking the town inspector would have a problem with what flooring is laid down?
Or referring to the post and beam construction?
shinnlinger
Timberframes are ok in Canaan.   Pm sent.
Shinnlinger
shinnlinger
For this room, I started with 60 grit and worked it both ways and then followed up with 80.  It went faster but you can still see saw marks combined with almost too smooth, so I don't know if I like it as much.
But overall I am pleased...
My daughter snuck in and painted some trees on her walls between coats...
Shinnlinger
Nice on the wall paintings. Helps take the eyes off the floor. She is a good artist.
Boards must have had some cup in them to not sand out the centers.
brendonv
Your making me want to start a new project!  I really dont need pine floors in my shed tho :D
Looking great, i like the wall art too.
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
Shinnlinger,
Not sure that you have noticed, but you have trees growing in your house.   :D :D :D :D
If I put down pine flooring will she come paint some trees on my wall?  ;D
Those tree look mighty alive. A super job!!!!!  Need a raccoon,squirrel or a deer looking out from behind one of those trees.
shinnlinger
If you look close, she snuck some chickadees and a wooly bear in there.  There is also a Cardinal but it didn't make this pic.  Not sure if she is done painting yet or not.  She wants me to put a loft in....
Shinnlinger
