A day cutting wood
Started by Peter Drouin, May 01, 2012, 08:49:55 AM
Peter Drouin
Nice day today, and got a late start,
Use my laser level and cut off the tops of the posts. I had some 4"x12"x24' and 2"x12"24' lumber laying around and used that.
I put some grease on the bigger lag bolts,
I didn't have a 32' timber around so I cut a R Oak from out in my woods.
The cat has a tilt on the body and forks.
Makes it easy to move the timbers sideways,
Can put the timber where ever I want it.
Bad pix, But started down the back side.
Should have been done today, But, at 63 I'm not as fast as I used to be. :D :D ;D
The Cat does it all. Now that's a machine.
Peter Drouin
Quote from: thecfarm on December 03, 2017, 06:21:23 PM
With a machine like that most of the sawmill work is a little easier.
nativewolf
Quote from: Peter Drouin on December 03, 2017, 07:02:49 PM
You make it look easy, at 63 you are still getting it done!
Liking Walnut
Bruno of NH
Peter Drouin
More to do before spring, Can't have FF members over and be uncomfortable Bruno.
:D :D :D :D :D :D :D
Peter Drouin
Thanks ,nativewolf, I try.
Chuck White
POSTON WIDEHEAD
4x4American
Welp today we started cutting a load of ties with da 70.  About 7hrs of cutting with two catchers and one pitcher we sawed 39 7x9 ties, 1200+- bf of cants and 1500+- bf of 5/4 flitches to turn into pallet stringers.  For the logs we were cutting it wasnt too bad, had to be houdini on alot of them to squeeze a tie out of.  I'm thinking that if I had a good run of 12-14" diameter logs that were fairly straight we cud prolly cut 65+ ties in a day with the mill.  Still getting the feel for everything but I'm tickled with the 70.  It is in fact a skookum choocher.  Also cut a guy out 200bf adk siding for his shed and he came and picked it up about 10 min after we cut it, just in the nick of time lol
Boy, back in my day..
nativewolf
Quote from: 4x4American on December 04, 2017, 07:24:56 PM
what sort of tie pricing are you getting up there?
Liking Walnut
Peter Drouin
Wait till you get good with the 70,  :D :D :D
Get all set up like you want and you will do a 100 7x9 a day. 8) 8) 8) 8) 8) 8)
4x4American
For sure Peter..and maybe if they made your .065" blades so I could cut faster :D .
Native wolf theyre at fiddy five cents rn fob sawmill
terrifictimbersllc
Try putting on two blades one inside the other.
Peter Drouin
I would like to try a .065 1¼x 7 blades 4x4..
Had a customer from a lumber yard. :D :D :D :D
Peter Drouin
Cat man, I have air getting in the fuel line, Think it's coming from the new fuel pump that was put in.
Andries
Oh man, it bugs me when the repairs need repairing.
Hope it's a quick and easy fix!
LT40G25
Ford 545D loader
Stihl chainsaws
Peter Drouin
New fuel pump was bad, He put in #2 new pump, All on warranty,
Good now, Maybe. :D :D :D :D :D :D
The biggest thing is the 30,000 bf of W Pine I ordered from 3 loggers.
I NEED LOGS. arg-smiley  :D :D :D :D
:christmas:
YellowHammer
DanG Peter, do you ever sleep?
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
OffGrid973
You guys have the best toys.  What age would you say you need your first cat?  Tilt arm optional after you get your feet wet I assume :)
Your Fellow Woodworker,
- Off Grid
POSTON WIDEHEAD
Quote from: Peter Drouin on December 08, 2017, 06:15:33 PM
I think they may have dropped them off in my yard.  smiley_sweat_drop
Peter Drouin
Quote from: YellowHammer on December 08, 2017, 10:02:02 PM
I'm up and  running-doggy just like you and Mr Goat.  ;D
:christmas:
Peter Drouin
Winter has come to A&P Saw Mill.
Darrel
Winter came here 1 week ago with about that much snow and most of that snow is still on the ground.
1992 LT40HD
