Broke the reverser in my 225 today
Started by Maine logger88, April 24, 2014, 09:46:08 PM
Maine logger88
When I was decking some 8ft hemlock pulp today the reverser popped out of gear and wouldn't go back in forward or reverse gears. It has been bothering some about popping out lately and going into reverse hard sometimes so I figured that I'd have to dig into it sooner or later anyway. So I pulled the top cover off and found the roll pin holding the shift fork to the rod sheared off so I dug a little deeper and found the bottom tine of the fork had broken off. Anyone ever had this happen before I don't know what would have caused this but luckily it isn't an expensive fix
tantoy
Is it a Warner t-98 with reverser ahead of it?
1968 Garrett 20 Skidder
1991 Ford 1920 Tractor/Loader
2000 Takeuchi tb135 Excavator
Stihl 020, 041 Super, 084
Husqvarna 61, 181SE, 357XP
Maine logger88
 Its a NP trans not sure of the model with a reverser ahead of it. Got it all back together this morning it was a pretty straight forward fix.
chester_tree _farmah
254xp
C4B Can-Car Tree Farmer
Ford 1720 4wd loader hoe
Ugh. I meant.
Good to hear it didn't set u back too much.
254xp
Shotgun
Quote from: chester_tree_farmah on April 25, 2014, 06:28:25 PM
Ugh. I meant.
Chester, you can always edit your own posts.  No need to start a new post.
Joined The Forestry Forum 5 days before 9/11.
254xp
Maine logger88
