Author Topic: Issues with Gearmatic 19 will not release or reel in.  (Read 1148 times)
Offline SHR
  • Member*
« on: April 22, 2018, 03:31:58 PM »
We have rebuilt the master controller of our Gearmatic 19 and it will not release and Free spool. We can hear parts moving in the winch when the control handle is moved and the cable moves when the lever is engaged.  any thoughts would be appreciated.
Offline lopet
  • Do not climb any higher your comportable falling !
Re: Issues with Gearmatic 19 will not release or reel in.
« Reply #1 on: April 22, 2018, 06:32:00 PM »
I am no expert here but when you can hear parts moving inside the winch it sounds like you have to pull things apart and then ask for the experts to chime in, good luck anyways. Some guys love them , some hate them.
Offline pdxh20
  • small woodlot owner
    • American painting
« Reply #2 on: April 23, 2018, 07:29:32 PM »
Here's what it looks like inside:  8)
Have a look at my IH S-8 skidder project thread for more...they can be a bear to pull apart, but if you put 'em back together right and don't let 'em sit forever to seize up, they pull like crazy and never need adjustments.
'56 American crawler crane, Komatsu mini-ex, multiple Stihl saws, '75 IH S-8 cable skidder, 2000 F450 30' bucket truck, '95 Chev 4 x 4 2500 p/u, '05 Sprinter SHC 2500 van
Offline Brian w
« Reply #3 on: April 25, 2018, 02:20:07 PM »
I am not a winch mechanic just a logger but it sounds like u just need to do some adjusting should be two bolts one adjust the brake the other adjust the winch in side sounds like your brake is to tight try to hook it to something and try to pull it off that way
Offline Gary Davis
« Reply #4 on: April 25, 2018, 09:30:03 PM »
if IT WORKED BEFORE IT MIGHT JUST HAVE AIR IN THE LINES
Offline jd540b
« Reply #5 on: April 26, 2018, 09:56:55 AM »
X2 on the lines.  I have to bleed the lines ALOT to work air out of system in ione of my machines before it will release.  Usually pumping winch lever for 15-20 min.  Even at that usually takes a few hrs to come to it.
moved
MOVED: Issues with Gearmatic 19 will not release or reel in.
Started by Roxie on For Sale
Last post April 22, 2018, 03:42:16 PM
by Roxie
gearmatic winch wont release?
Started by huskyxp on Forestry and Logging
Last post August 19, 2011, 02:22:22 AM
by John Woodworth
Gearmatic 19 issues
Started by Plankton on Forestry and Logging
Last post December 05, 2015, 06:03:33 PM
by chester_tree _farmah
Gearmatic 19 issues....
Started by Upnorth on Forestry and Logging
Last post January 14, 2014, 06:50:37 AM
by Upnorth
