Miter Gauge Support
Started by 21incher, June 13, 2018, 03:25:47 PM
21incher
Got a new longer bar miter gauge and it needed some extra support out front to be useful so I added a plastic table for it.
Here is the video about adding it
Miter Gauge Support For My Grizzly G1023WRLX Saw Using A Kreg Miter Gauge - YouTube
Also found a usefull gauge for setting up angles on the gauge for cutting segments.
Here is a video about it
Miter Set Segments Review And Kreg Precision Miter Gauge Update - YouTube
teakwood
Nice work!
I never had any luck with that miter gauge on my table saw. the 90 degree cut was never precise enough for me. I'm hoping to purchase a real sliding table saw one day
Dan_Shade
Slightly off topic, but this is a great way to square up a miter gauge or sled.
5 Cuts to a "Perfect" Cross-Cut Sled - YouTube
lots of dull bands and chains
21incher
Quote from: teakwood on June 14, 2018, 08:48:52 AM
Nice work!
Thanks. My last saw had a sliding table and I miss it at times but it took up a lot of extra space in my tiny shop. This gauge is pretty good when set using that miter setup fixture but was useless without that little support to keep it from twisting. Those euro style sliding table saws are really nice if you have the room. :)
teakwood
Quote from: 21incher on June 14, 2018, 08:01:30 PMThose euro style sliding table saws are really nice if you have the room.
Yeah i know! If you buy a sliding table saw than a real one! Nothing under 5-6k. The problem is i would have to build more shop room and that would cost another 5k, so my hands are tied.
I make my 90degr cuts with a hand circular saw and a straight clamped up on the boards. it's very accurate but painfully slow
Bruno of NH
Nice work
I have a sliding table on my shop saw.
I have 3 table saws  :)
Larry
Thought you might like to see my miter saw. It's a Hammond Glider printers saw with a sliding table that I modified a bit. It has about 20" of crosscut ability in a very small footprint. No rip capacity.
Instead of a miter gauge I designed and made a quadrant with a vernier scale copied from the Incra miter gauge. I designed it for one tenth of a degree accuracy but in practice it does far better. 19 segments, no problem.
I've done hundred's of segmented rings for turning projects. I make a practice ring first to be safe but 90% of the time its dead on.
The Miter Set is a great idea...wish I thought of it and I enjoyed your review.
A few segmented rings.
teakwood
Wowww!! you sure have passion, patience and lots of talent. Nice work
21incher
That is a great saw Larry. I recently saw one on craigslist and wish that I had room for one. I don't know why table saw manufacturers don't buy into miter set and incorporate the tapered holes in the tables. Just love your segmented turnings. :)
