Finish for walnut
Started by Dan_Shade, September 15, 2018, 08:47:06 AM
Dan_Shade
I'm about finished building a crib for the wee one out of walnut (I'll attempt to post some pictures this evening).
Do any of you have a recommendation for finishing walnut?  I'm leaning towards using garnet shellac.
lots of dull bands and chains
Dan_Shade
Ok, I'm piddling instead of working:
rjwoelk
Very nice. I like that slightly lower front.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
bwstout
That is assume build. I use Pre-Cat Lacquer very hard finish. I use satin on the table tops makes the blues come through on walnut. I  use the gloss on most of my bowls it hold up nice under heavy use. But like any finish that is on something that is use a lot over time will need to be refinished again.
home built mill
WV Sawmiller
    Real pretty work. I am envious.
    The only thing I ever use on my walnut is tung oil. Whatever you use I would suggest you check to make sure it is safe around children. When the wee one starts teething he/she may chew on whatever is handy.
Dan_Shade
I thought about the teething, my beautiful walnut will be all chewed up!
Shellac should be safe if he eats any of it.   One reason that I'm leaning towards it.
Southside
In this instance could you call that "cribbing"?   :D
White Oak Meadows
bwstout
Once Pre-Cat Lacquer is dry it is food safe
home built mill
Brad_bb
It's furniture, so most any finish will dry and shouldn't be a problem.  So then it comes down to what you want the finish to look like.  Oil, poly, Lacquer, water based Urethane.  Water based urethane will have a true clear finish giving the walnut a true chocolate color without any orange tones. I like General Finishes products.  Consider the amount of gloss you want as well.  A water based flat finish looks good.  Don't let the "flat" fool you, it does have some gloss.  You do have to keep the product stirred as you use it or the flattening agent can settle out and you'll get a glossier finish.  Just stir well each time before you use it.  Finishing is a whole art in itself besides woodworking.  It takes patience. Expect the finishing to take as long as the build did.
tule peak timber
gunscrew
I use Teak oil on most of my walnut gun stocks ,but don't know about a baby chewing on it.
low_48
Shellac doesn't give the greatest moisture resistance. And by moisture, it can come in a lot of forms in a crib. There could even be the case when a liquid disinfectant will be needed when feces, urine, and vomit hit the walnut. Shellac will not hold up to that! A couple of thin coats of satin poly would be my choice. Unless you can get conversion varnish at a pro store. That would be my first professional choice.
Dan_Shade
I decided to use lacquer.
I'm happy so far.  The back has the final coat.
FLPINERAT
Very nice, I like it!
Friend built one once for a couple, don't recall wood species....but the couple required it unfinished and they used the "salad bowl/cutting board" finish oil on it!
That looks nice.
And the crib is for what wee one? Yours?
bwstout
looks great, I like lacquer finish it is easy to repair and will take abuse.
home built mill
tule peak timber
Dan_Shade
Thanks, my technique is improving. I realized that I was not using a wet enough coat and was having a rough finish, so I sprayed a thicker coat.
I used some ngr stain thinned with acetone to even out the color.
Dan_Shade
I entered the crib in the woodmizer personal best contest.
123maxbars
nice work, I use waterlox on my walnut, turns out great,
Sawyer/Woodworker/Timber Harvester
Woodmizer LT70 Super Wide, Nyle L53 and 200 kiln, too many other machines to list.
outofthewoods
Youtube page
Out of the
Dan_Shade
I didn't realize that I didn't post the finished crib.  Things are busy at my place. :)
doc henderson
I assume this is done already, just ran accross it.  i like Watkins danish oil.  for a child item, might then go with a minwax satin urethane.  spar for uv protection and water proof.
just oil
oil plus finishing wax.
satin spar polyurethane.  just saw the first 2 posts and no other reply, now i see page two.  just getting off work.  tired I guess,  very nice work Dan
samandothers
Great job and the finish is really nice!
