Author Topic: Walnut Stand-Alone Bar Top  (Read 2969 times)
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« on: June 07, 2014, 09:55:41 PM »
I built a stand alone island bar top for a Lady that wanted to replace a particle board and formica top.  Nothing fancy at all, just 9/4 walnut.  62" long x 39" wide.  Sometimes, the wood just speaks for itself and simple is good.  I matched the wood so that the sapwood flowed and looked natural.  She did not ask for it like this, but I did it this way because to me it gives nice color and character to a bar top.  People will explore and examine the wood when they are sitting at the bar.
If she does not like it, I will keep it, no problem  :).
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Walnut Stand-Alone Bar Top
« Reply #1 on: June 07, 2014, 10:02:41 PM »
If she does not like it, it will make a nice Birthday present for somebody.  ::)        :D
Offline WmFritz
« Reply #2 on: June 07, 2014, 10:15:49 PM »
Shameless  :D :D
Danny, I love it and agree that the sapwood adds to the beauty.
I've got one to build too just about the same size.
I hope mine turns out half as nice.  ;)
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
Offline beenthere
« Reply #3 on: June 07, 2014, 10:25:42 PM »
Nice job matching the colors in the top. Beautiful top, for sure.
Finish will be?  or is?
Offline Bill Gaiche
  • Home built bandsaw, Kioti ck30. Sthil 211 & 361.
« Reply #4 on: June 07, 2014, 11:00:57 PM »
She will love it I am sure. bg
Offline WDH
« Reply #5 on: June 08, 2014, 07:19:51 AM »
David,
If I knew anyone who might have had a birthday yesterday, I would gladly give it to them  :D.
BT, the top is unfinished.  The customer will do the finish sanding and apply the finish.  I recommended 100% tung oil and mineral spirits in a 1:1 mix.  3 or 4 coats.  It is the most water resistant of the oil finishes and can easily be renewed.
Another choice is mineral oil (like the medicinal stuff you get from the drugstore) mixed with paraffin wax like is used on butcher-block tops.  Shave the paraffin into a small pot using a cheese grater.  Fill with mineral oil.  Put on stove and heat the pot until the wax melts into the mineral oil.
A satin poly would provide the most protection from cups, glasses, etc that are prone to leaving water rings on wood surfaces, and might be the best choice, depending on how the top will be used, prepare i.e., preparing food.
BTW, BT, how are your walnut trees doing?
Offline thecfarm
« Reply #6 on: June 08, 2014, 07:23:29 AM »
WDH,write this down. My birthday is Sept 4th.  :D  hint,hint.  ;D
That looks good. As always.
« Reply #7 on: June 08, 2014, 09:29:15 AM »
Good info here Danny, saved to file.  smiley_thumbsup
Offline tule peak timber
  • roborob
    • tule peak timber
« Reply #8 on: June 08, 2014, 09:32:52 AM »
very nice !
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #9 on: June 08, 2014, 09:36:49 AM »
Very nice, $300 + easy  :D :D
A&P saw Mill LLC.
License NH softwood grader.
Offline beenthere
« Reply #10 on: June 08, 2014, 12:56:19 PM »
Quote
They are doing well, thanks... the plantation trees are fine but I'll not live long enough to see any of them harvested.  Another 40 years or so for them.
The many other black walnut trees on the place are getting to cutting size. No immediate plans to cut them however.
Offline drobertson
« Reply #11 on: June 08, 2014, 03:57:57 PM »
Pretty top there Danny! hard to see where anyone would not love this addition.
Offline mesquite buckeye
  • Trees are good- even ones with stickers
« Reply #12 on: June 08, 2014, 06:07:26 PM »
I like it!
 ;D 8) 8) 8) 8) 8)
Offline julio
  • I also have Traveled.
« Reply #13 on: June 08, 2014, 06:45:19 PM »
I got one that looks as good as that one and it wasn't my B-DAY   thankS WDH 8) 8)
If you put your finger in your ear and scratch, it sounds like PacMan.
Offline WDH
« Reply #14 on: June 08, 2014, 09:21:18 PM »
This one was made from some younger walnut trees that a logger friend of mine brought me.  The logs were all 8' long and averaged about 10 - 11" in diameter.  This made the sap and heart an interesting transition which created some nice patterns to work with.
Offline Larry
« Reply #15 on: June 08, 2014, 10:02:06 PM »
You used the sapwood as a design element and it worked well.  I like it :).
Offline yukon cornelius
« Reply #16 on: June 08, 2014, 10:08:30 PM »
should the sapwood be avoided or is it ok to work with? what moisture content do you look for. I thought maybe around 10% would make it pretty safe.
that is very nice top!!
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Offline WDH
« Reply #17 on: June 08, 2014, 10:13:33 PM »
Sapwood in walnut has the same qualities as the dark heartwood except for the color.  This was dried in my kiln to 8%.
Some of my customers only want boards with heartwood (I call them sapwood snobs).  Some of my more artistic customers love boards with the sapwood to heartwood contrast and all the colors that occur in the transition.  If you look at this bar top carefully, you can see these colors.  I call it rainbow walnut.  I have about 800 BF of this rainbow walnut on stickers ready for the kiln.  I plan to market it as "Rainbow Walnut".
« Reply #18 on: June 08, 2014, 10:22:02 PM »
Then you will find gold at the end of your Rainbow.  ;D
« Reply #19 on: June 08, 2014, 10:43:19 PM »
thanks wdh! I have a few walnut logs to be cut soon and I will have some projects inspired by this. I really like the rainbow/marbled look. plain dark walnut is everywhere!
Cherry, Ash, & Walnut TV Stand
Started by 21incher on General Woodworking
Last post January 22, 2014, 10:35:48 AM
by lowpolyjoe
Quick Question about Walnut? First walnut sawn. criticism wanted.
Started by strunk57 on Forestry and Logging
Last post June 15, 2014, 05:16:04 PM
by Oliver05262
was sawing some walnut and oak today - is walnut made of concrete???
Started by Andy B. on Sawmills and Milling
Last post September 15, 2013, 09:58:31 PM
by Gasawyer
question
Walnut or walnut sawdust to combat bamboo?
Started by Delawhere Jack on Ask The Forester
Last post April 24, 2013, 08:29:14 AM
by just_sawing
