Whatcha Sawin' ???
Started by Magicman, December 23, 2014, 12:00:38 PM
alanh
300 bdft of walnut, the guy says he is building a table and wants to make sure he has enough...must be a big table...
bags
Heres some aspen from the high rockies--- its a nice change every now and then from mill'in blue stain.
Resonator
"Quakies" is another name for Quaking Aspen. (I had to look it up,  learned something new.)
YellowHammer
Quote from: Magicman on March 12, 2018, 06:57:56 AM
Do you have a resaw attachment?  If not and if there is any warp or twist whatsoever you will have problems with thick and thin sides, corners, etc.  :-\
smiley_thumbsup
Bandmills with no down pressure attachment rollers or wheels like a true resaw to forcibly flatten wood to the bed don't work very well.  The mill will cut a straight line, but since the board isn't evenly pressed to the bed, it will have lots of thick and thins.
Been there, not pretty.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Darrel
I resawed some cottonwood once and had some success by putting weights on top the boards. Only did a half dozen pieces, would hate to do a whole whack using this method.
1992 LT40HD
Crusarius
Well I screwed up and posted in the wrong thread so I will try again.
My first cuts on my homemade mill.
Still needs some tweaking but very happy for my first cuts. This log came out of my firewood rack.
Ljohnsaw
That is pretty stuff.  The bark makes me think that is ash but the grain looks a little like oak - what is it?
John Sawicky
Lawg Dawg
Hopefully will get this one soon
Here are some easy to slap together sawhorses, can be built quick out of scrap 2x4 using a framing nail gun, just square cuts. Very handy around the sawmill. The ones behind my mill are at least 5 years old...just had to add some screws to them the other day
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Darrel
I've made saw horses like that. Next time I make them, I think I'll use a 2x6 for the top of the "I beam".
1992 LT40HD
Darrel
Crusarius, congratulations on your first cuts!
1992 LT40HD
Crusarius
Quote from: ljohnsaw on March 12, 2018, 10:31:41 AM
Definitely red oak. the bark was nasty. this stuff has been in my firewood rack for 3 years now. it is all starting to get pretty nasty on the outside. but the inside is still very nice. I may need to debark it before putting it in the woodstove.
WV Sawmiller
   Yeah, I have several sawhorses like that around my mill and they are very handy. I save any 3' long scrap 2X4 out of my slab pile to make them or stacking pallets. My horses don't have the angled side braces - just a board (can be 1X4 or 1X6 or 2X4, doesn't matter) on the sides but it does the same thing. I may try your design with the angled braces next time.
Crusarius
Those sawhorses are really nice.
Crusarius
Thanks Darrel. Will be exciting to see what comes out next :)
Lawg Dawg
Quote from: WV Sawmiller on March 12, 2018, 11:49:20 AM
That 45degree angle brace keeps them from "racking", keeps the nails tight longer.  Thats the only angle cuts to make...everything else is just "eyeballed" assembly! :D
Pro Sawyer Network
Resonator
alan gage
I made saw horses of the same design. I added a 2x6 to the top as well as a 1x4 running horizontally between the legs about 1/3 of the way up. Both those additions make them much more comfortable for sitting.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
Darrel
Quote from: alan gage on March 12, 2018, 02:07:44 PM
I made saw horses of the same design. I added a 2x6 to the top as well as a 1x4 running horizontally between the legs about 1/3 of the way up. Both those additions make them much more comfortable for sitting RIDING, :D
Alan
1992 LT40HD
Crossroads
Wow, I like that yellow birch!!
Sounds like I need to pass on the sycamore resaw, thanks for saving me from a headache.
I got to play around and cut some black walnut today.
Resonator
Thanks Crossroads, that tree was freshly cut down (green), and the color was best immediately after sawing it open. It also helped I had good sunlight that day, and that I had poured a gallon of water on it. (Trick I saw in an "Out of the Woods" video.)
I made my road trip today which was actually 82 miles instead of 72, but what's 10 minutes?   ???  Anyway 4 Cherrybark (Red) Oak logs 8' - 12' long but all were over 20".
Very nice and fairly clean logs.
The sawmill was barely off of the street, but it was a dead end so no traffic.
It's hard to tell in the picture how steep the setup was.  The outriggers have many boards under them and I had to use a step stool to climb into my seat.  I could not let the back outrigger down without digging a hole, it stayed up.
I sawed an assortment of 4/4, 5/4, and two 9/4 bookmatched pieces for a table.  They were a knockout.  The lumber tally was 1215 bf.
And then the customer drug out the customary ERC "logs" :o  to be squared up.   :D
I am off tomorrow and will start the Walnut/ERC job Wednesday.  ;D
OffGrid973
Love that yellow birch.  What does that stuff look like a year later once it had time to get near 12%?  I may have to go on a hunt in north east, do we get that one up here?
Your Fellow Woodworker,
- Off Grid
Crossroads
Nice work MM, I saw the step stool right off, but didn't see all the door shims until I read about them.
I have tomorrow off and no jury duty, so I think I'll try to put the new wide debarker on. Seems like a lots of new parts to come without any directions or a drawing. I'm gonna have to finish nd 4x4's video and slow it down 4x so I can see what's is supposed to look like.
Lawg Dawg
MM, what did the erc scale at?  :D
Pro Sawyer Network
Lotsa purdy stuff being sawn.  :)  Thanks @bags for showing the inside of a Quakie.  smiley_thumbsup
