Pto on power unit
Started by 1wkinsley, September 14, 2015, 08:36:50 PM
1wkinsley
Can i put a pto adapter on the drive shaft of my power unit?
jmouton
you mean  you want to hook up a pto   on  an engine or electric motor ,,,sure you can    or am i not understanding the question,
        jim
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
crowhill
Will the power unit you want to use run at the same rpm as the PTO shaft on the Farmall B? Or is that a non-issue?
TimberKing B-20, Kubota M-4900 w/FEL with tooth bar, hyd thumb and forks, Farmi winch, 4 chain saws.
whitepine2
Quote from: crowhill on September 14, 2015, 09:32:24 PM
Yep.you can buy a unit that will turn more than one PTO shaft if you need
I think one can turn at 1000 and one for 540 if need be try googling for more information. Might be kinda $$$$$ but are available.
