Milling Pecan with 7-Turbos
Started by E-Tex, December 06, 2018, 09:58:37 PM
E-Tex
Is anyone milling PECAN with 7° Turbos?  How do they do?
I milled a large Pecan log yesterday with a 4°.  It was Hard and SLOW going.
The last few months I've used 7° Turbos almost exclusively (was using only 4's prior to that), so I don't know if I am just use to sawing faster with the 7's or was is just the Pecan being HARD that made it slow?  I just wasn't impressed with myself!
Saw'd 34" slabs with my WIDE.....wish I had the diesel for that one.
LT-50 Wide, Nyle 200Pro Kiln, Mahindra 6065, Kubota 97-2 / Forestry Mulcher
L2 Sawmill LLC
Southside
I have milled Pecan, Hickory, and White Oak on my 35 with T7's and they did just fine.  It was actually frustration with 4's that drove me to the Turbos.  You have more ponies on your 50 than my 35 does so it should be even better.  Have mostly only sawn pine on my 70 but have a big whack of mixed hard wood to do in a week or so with it, the only band I have for that girl is a Turbo.
White Oak Meadows
I have had 4°blades to wave with both Post Oak and Pecan.  Both times I switched to 7° Turbos and sawed flat.  The last White Oak that I sawed on two different jobs, I never bothered with a 4° blade.  I put the 7° Turbos on and sawed.
SawyerTed
+1 on switching to Turbo 7s.  They just cut better in all woods.
Resharp is replacing 4s with 7s and new blades are T7s.
I replaced all of my 10° blades with 7° Turbos and I will probably do the same with the 4° blades or just discard them.
E-Tex
I've been building my T7° inventory as well.  but thought I needed the 4s on the Pecan.  I wish I had tried the 7.
L2 Sawmill LLC
Here is the Pecan log that the 4° blade would/did not saw without waves.
I quickly changed to a 7° Turbo blade and sawed it.
E-Tex
I have some 4°'s for sale!!!!!!!!  ;D
L2 Sawmill LLC
jb616
Nice information to know. I have been using 4's as I have been cutting only hardwood. I will definitely try the turbo 7's. Can they reprofile the 4's into the turbo 7's when they resharpen if I decide to switch?
Southside
Can it be done? In theory, but nobody is going to do it. At least Turbos are on sale now.
White Oak Meadows
DR_Buck
Quote from: Southside logger on December 08, 2018, 12:22:16 PM
....... At least Turbos are on sale now.
I've switched exclusively to Turbo 7s on my new Super-Wide.     And this morning I took advantage of the current sale on Turbo 7s with free shipping.  ordered 2 more boxes.
charles mann
iv been wondering which blade, or blades i need to get for my build. i will mostly be cutting hardwoods, pecan, red/white/live oak, maple and walnut, with the occasional SYP. my blades will have to be around 308"-312" x 2" wide with around 100 hp on a diesel.
Any recommendations?
Temple, Tx
jb616
I was going to order a box and it says for high horsepower, wide cut mills.....mine is an old LT30 with 24hp....will I be ok?
Southside
My 35 has a 25 HP Kohler and it is fine
White Oak Meadows
Skipper11A
Quote from: jb616 on December 08, 2018, 04:00:20 PM
I called WM to ask about their Turbo 7 blades and the WM Tech told me that they are made for high horsepower mills.  He told me that with my 24HP engine I should stick with 4° blades.  I was impressed by his knowledge and appreciated his integrity.
richhiway
My mill came with 10* blades and I have been cutting white pine, seems fine. The manual says 13* for pine. Would they be better? I purchased the winter cutting assortment as I understand a lower degree blade (7*) is better in frozen wood,pine included. Sound right? Thanks
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Ford 340 Backhoe
D6c
Saw the sale on T7s...seem to be available in carbon steel or bi-metal.  Is bi-metal worth it?  I switched to bi-metal on my metal cutting saw and they're great.
As far as HP...my 20 hp Onan originally came with 10 deg blades.  Recently it was recommended I use 4 deg but it seems my cutting speed is slower.  If 10 deg worked I would think 7s would.  (Sawing mostly hardwood)
Southside
Quote from: D6c on December 09, 2018, 09:55:47 AMIf 10 deg worked I would think 7s would.
The Turbos have a deep gullet, completely different animal, which is my guess as to why they are recommended for higher HP engines. In order for them to saw clean you need to keep your feed speed up or they will leave chatter on a board - yes you can saw too slowly with them for sure.  On my LT35 I run the feed speed right up to barely below the stall point, and she does fine.  20HP - can't say on that one, the Kohler on my 35 is labeled as being 25 HP but the exact same engine is on my edger and rated at 23.5 HP, so maybe it's like automobiles and the standards have changed in how HP is measured.  Do you know of anyone around that has some Turbos and you could buy one and try it?
Oh - and yes the bi-metals are harder for sure, and they hurt more when you wreck them.  I run the double hards myself and have no complaints.
White Oak Meadows
Crossroads
I'm pretty sure I'll have a box or 2 of the T7 before the sale ends on February
Busysawyer
I've seen this on this forum before and I just dont get it. I have ran nothing but the turbo 7 blades since I got my mill . I've said it before but i guess I'll say it again. I agree with woodmizer and think these blades are better suited for high horsepower mills. My 70 with a 46hp diesel barely has enough power to pull them through big hardwoods. Grade sawing your typical walnut and cherry saw logs yeah no problem but get some big oaks or hickory and my 46hp seriously struggles to cut well with the turbo 7s. What kind of logs are you guys sawing using the turbos on the lower hp mills?  By the way I'm not the only 70 owner that feels this way. I've talked to quite a few that have found the same thing.
Even a blind squirrel finds a nut every once in awhile
This is kinda like an "always" and "never" conversation because either answer could be right or wrong depending upon the log size and species.  I would give it a try because the worse outcome would be a compete failure and all that it cost was a blade.
Busysawyer
Mm, like I said I've never tried any other blade on my mill so as far as I know the turbo might be the best option. I've talked to several 70 owners that jumped on that turbo train and jumped right back off. When I need bands I'm going to try some kascos from cutting edge. Richard is going to send me three different profiles to try out. Who knows I might still like the turbos after that. I've had bad luck with the Turbo blades breaking at the welds and woodmizer wont stand behind them so I figure I'll give someone else a chance to take my hard earned money. I might go through a couple boxes with no breaks then I get a box that 4 break within the first 15 minutes on the mill. I call woodmizer they go through the checklist with me. Alignment right on, guide roller down pressure to spec, blade tension on the money, tracking perfectly.  No problems with the mill and they say no problems with the band so it must be my fault. Apparently my ability to properly change a band and run my mill varies from box to box of blades.
barbender
Thatbwould be very frustrating. Folks always talked like WM was very good about standing behind broken blade welds.
Southside
I have never had a refusal on a broken weld, honestly never even been asked about it.  Just told to send it in.
BS as to your question about size, about a month ago I had a pair of 20' long white oak come in for a customer, they were 32" on the small end so I had to Bibby them and it was before I had my 70 so I sawed them on the 35.  Now handling, turning those beasts was a nightmare, at first I would take them off of the mill, turn them, then put them back on, but sawing them was no issue at all.  Basically it was a full width cut for most of it - no problems with Turbos, lumber came out nice and smooth.
I wonder how my HP the hydraulic pumps on the Super 70's consume, combine that with a wide head with a full width cut and maybe the band speed is dropping.
One thing with Turbos is that they will cut until they don't, what I mean is one pass they are fine and the next they are dull, seems to come all at once.
White Oak Meadows
Busysawyer
Barbender, as Southside stated he's has been told send them in. This is what I've heard from other guys as well. I think a lot of my customers service issues with woodmizer is based purely on who I get on the other end of the line. I'm not the type of person who is going to complain, argue or go higher up on the food chain unless I have a serious issue.
Southside, I'm new to this and like I said all I've ran is the turbos. I'm beginning to think I might just be expecting too much from my mill as far as cutting speed goes.  I started off grade sawing walnut and cherry exclusively, the vast majority of that was walnut. I think maybe I just got so used to flying through the cut that now that I'm cutting and slabbing large logs of harder species im just wanting to go faster than what the mill will handle.  It's not that im getting poor cut quality it's that I have to travel what seems to me a painfully slow rate. Also in a way I'm glad to hear from yet another Sawyer they are having wm bands break in the welds prematurely. According to the guy at woodmizer I'm the only one with these issues and there has been no quality control issues with manufacturing of the bands.
