homemade bandsaw
Started by revid, February 01, 2015, 02:30:13 PM
revid
planing on making a homemade bandsaw and wondering what are mininum wheel diameters for different blade widths? I got two aluminum 13" wheels I was hoping to use but didn't know if I could use with ie:1 1/4 blades?
york
Hi there,for the 1 1/4 in. Band`s you need at least an 19in. Band wheel....
Always look at what the industry does.....
Albert
Revid, you could use 13" wheels but you would loose band life and it would limit your clearance between the cut and the top  band, think slab cut a branch nubs. As Bert said I wouldn't go under 19" probably half the band mills in use are 19". Bigger is better if you have the power and a ridged frame. The band wheels are the most important part of the mill, they are no place to skimp. Frank C.
