Need Physics/pivot point help for Chicken Scalder idea
Started by shinnlinger, August 27, 2013, 08:43:17 PM
shinnlinger
 Thinking of building a chicken dunker for scalding chickens. I would like at least 12 inches of travel at the end for a basket. Wondering what my X,Y,And Z measurements need to be to get that. Any pointers?
Thanks,
Dave
Shinnlinger
POSTON WIDEHEAD
I'll have to study on this one at the Sycamore Project this weekend.
I'll get back with you.  :)
You may have given a way for WDH to wake up me and Fishpharmer.  :D
shinnlinger
I think a rotary scalder would be easier to make, but I only have junk on hand to make a dunker.  I could cut the top half off an oil tank but then I would have to heat a bunch more water than I need too.
Dave
Shinnlinger
POSTON WIDEHEAD
Some of the best things have been made from junk on hand.  smiley_thumbsup
Why a motor? Could you get the balance point just about right and do it that way? Might even use some sort of weight for a counter balance? Be it rocks,old metal?
POSTON WIDEHEAD
Quote from: thecfarm on August 27, 2013, 09:12:19 PM
ROCKS.....OLD METAL? How BIGGA CHICKIN YOU TALK'N BOUT.  :o
You grow big tomatoes. I grow big chickens.  :D  Red Green may use a 8 cyl motor for a boat motor,well I use it for a counter balance.  :D
POSTON WIDEHEAD
Quote from: thecfarm on August 27, 2013, 09:17:21 PM
Your last name ain't SANDERS is it......as in KERNAL SANDERS?  :D
( you need to come to Georgia this weekend)
Will Crane do ya???? Put Ray in front of that and that is all you need to find me in Chesterville,Maine.
Grits and anything green will make me push away from the table mighty quick.
drobertson
Not a bad idea, kinda screwy, but, if you want to do it, as drawn, you will need a 31-32" shaft, pivoted around 9" from the right side of your drawing, (best I can tell,) the cam will be the tricky factor, might just make it manual and try some out, seems a little short to me, less you are doing Cornish hens?  david
DDDfarmer
I just get the water the right temp hold one foot dunk, swirl, agitate and 15-20 seconds later throw on the plucker.  As fast as I get them plucked next bird is ready to go, we set up a little assembly line up and go to it.
Local abettoir has a tank with a cork-screw style paddle. birds go in one end come out the other and right into the plucker drum. 6 people do a hundred or so an hour.
A dunking basket would keep your hands out of the water but would it really be any faster?  Not really a chore I like to take my time with.
Treefarmer C5C with cancar 20 (gearmatic 119) winch, Husky 562xp 576xp chainsaws
Brucer
The length of link Z doesn't matter (as long as it isn't too short).
The radius of the crank arm attached to the motor does matter. Call the radius R.
In diagram A, (2 x R)/Y = 12"/(X + Y)
In diagram B, (2 x R)/Y = 12"/X
In both cases, Z has to be more than 2 x R. These formulae only apply if the motor shaft is directly below the point at which Z attaches to the arm.
Bruce    LT40HDG28 bandsaw
shinnlinger
I have created over the years a pretty good setup complete with kill cones out of old roofing, a scalder made out of an old hot water heater, a drum plucker out of of an old snowblower, air compressir, and barrel.   A slick "water bath" eviceration table, a bunch of freezers I just fill with water the night before and plug in for ice cold water, PVC drying racks, bagging and weighing stations etc, etc.
Now it's time to make something else.  The idea if I can have 4 birds scald themselves, I can do something else to speed efficiency.
We do 200 birds a pop from wrangled, to bled out, to freezer bagged and weighed in 5 hours.   Love to see how 6 folks can do 100 birds an hour!
Really like the formulas.   I assume moving the motor for or aft reduces stroke length?
Great pointers.   Thanks!
Dave
Shinnlinger
